gprovost Posted March 14, 2019 Posted March 14, 2019 @Igor Could we imagine another mechanism than to use git as an "upload front-end" ? Using git as some kind of spool folder is really not ideal. For instance if I clone today the armbian upload git project the size of the objects is already reaching 1.2 GB for a project that is essentially just a structure of empty folders. I even see the following error during cloning Cloning into 'upload'... remote: Enumerating objects: 75, done. remote: Counting objects: 100% (75/75), done. remote: Compressing objects: 100% (61/61), done. kex protocol error: type 7 seq 49316022.52 MiB | 6.67 MiB/s remote: Total 844 (delta 33), reused 40 (delta 14), pack-reused 769 Receiving objects: 100% (844/844), 1.22 GiB | 6.03 MiB/s, done. Resolving deltas: 100% (251/251), done. The easier would be to provide a FTP service with the same structure and limited access to people you grant right to upload.
lanefu Posted March 14, 2019 Posted March 14, 2019 (edited) 12 hours ago, gprovost said: @Igor Could we imagine another mechanism than to use git as an "upload front-end" ? Using git as some kind of spool folder is really not ideal. For instance if I clone today the armbian upload git project the size of the objects is already reaching 1.2 GB for a project that is essentially just a structure of empty folders. I even see the following error during cloning Cloning into 'upload'... remote: Enumerating objects: 75, done. remote: Counting objects: 100% (75/75), done. remote: Compressing objects: 100% (61/61), done. kex protocol error: type 7 seq 49316022.52 MiB | 6.67 MiB/s remote: Total 844 (delta 33), reused 40 (delta 14), pack-reused 769 Receiving objects: 100% (844/844), 1.22 GiB | 6.03 MiB/s, done. Resolving deltas: 100% (251/251), done. The easier would be to provide a FTP service with the same structure and limited access to people you grant right to upload. Is it for long term storage, or just for exchanging data.... I could setup some object storage.. i think there's even an official SFTP gateway fro s3 now. Edited March 14, 2019 by Tido fixed quote
Igor Posted March 14, 2019 Posted March 14, 2019 8 hours ago, gprovost said: is really not ideal I agree with that. It was designed for quick fixes, upload via web ... and that works ... until file is not too big I realized that later that sources packages are out of range. Will do something on a long run.
Igor Posted March 14, 2019 Posted March 14, 2019 16 minutes ago, lanefu said: i think there's even an official SFTP gateway fro s3 now. I can open incoming directory for direct upload, but since it's not a total urgent matter it can wait a while. 1
Igor Posted April 8, 2019 Posted April 8, 2019 On 3/14/2019 at 9:38 AM, gprovost said: The easier would be to provide a FTP service with the same structure and limited access to people you grant right to upload. Prepared. Anyone needs a (s)ftp access to repository incoming directory should send me a public key. Structure is the same as from the build script.
gprovost Posted April 8, 2019 Author Posted April 8, 2019 3 hours ago, Igor said: Prepared. Anyone needs a (s)ftp access to repository incoming directory should send me a public key. Structure is the same as from the build script. Great ! Just sent you my pub key by PM ;-)
Igor Posted April 8, 2019 Posted April 8, 2019 OK, gimme me some time. While adding some fixes this morning I find out troubles with repository (nothing can be added atm) and I have to rebuild it manually. For now adding will remain manual - this is just a direct drop off.
gprovost Posted April 9, 2019 Author Posted April 9, 2019 Sure, no rush... on my side I don't have any package to push. BTW what will be the sftp address ?
Igor Posted May 27, 2019 Posted May 27, 2019 3 minutes ago, gprovost said: Hi @Igor Is the SFTP upload available ? Have to check once again. IIRC I stuck somewhere in the middle ...
