gprovost Posted March 14, 2019 Share Posted March 14, 2019 @Igor Could we imagine another mechanism than to use git as an "upload front-end" ? Using git as some kind of spool folder is really not ideal. For instance if I clone today the armbian upload git project the size of the objects is already reaching 1.2 GB for a project that is essentially just a structure of empty folders. I even see the following error during cloning Cloning into 'upload'... remote: Enumerating objects: 75, done. remote: Counting objects: 100% (75/75), done. remote: Compressing objects: 100% (61/61), done. kex protocol error: type 7 seq 49316022.52 MiB | 6.67 MiB/s remote: Total 844 (delta 33), reused 40 (delta 14), pack-reused 769 Receiving objects: 100% (844/844), 1.22 GiB | 6.03 MiB/s, done. Resolving deltas: 100% (251/251), done. The easier would be to provide a FTP service with the same structure and limited access to people you grant right to upload. Link to comment Share on other sites More sharing options...
lanefu Posted March 14, 2019 Share Posted March 14, 2019 (edited) 12 hours ago, gprovost said: @Igor Could we imagine another mechanism than to use git as an "upload front-end" ? Using git as some kind of spool folder is really not ideal. For instance if I clone today the armbian upload git project the size of the objects is already reaching 1.2 GB for a project that is essentially just a structure of empty folders. I even see the following error during cloning Cloning into 'upload'... remote: Enumerating objects: 75, done. remote: Counting objects: 100% (75/75), done. remote: Compressing objects: 100% (61/61), done. kex protocol error: type 7 seq 49316022.52 MiB | 6.67 MiB/s remote: Total 844 (delta 33), reused 40 (delta 14), pack-reused 769 Receiving objects: 100% (844/844), 1.22 GiB | 6.03 MiB/s, done. Resolving deltas: 100% (251/251), done. The easier would be to provide a FTP service with the same structure and limited access to people you grant right to upload. Is it for long term storage, or just for exchanging data.... I could setup some object storage.. i think there's even an official SFTP gateway fro s3 now. Edited March 14, 2019 by Tido fixed quote Link to comment Share on other sites More sharing options...
Igor Posted March 14, 2019 Share Posted March 14, 2019 8 hours ago, gprovost said: is really not ideal I agree with that. It was designed for quick fixes, upload via web ... and that works ... until file is not too big I realized that later that sources packages are out of range. Will do something on a long run. Link to comment Share on other sites More sharing options...
Igor Posted March 14, 2019 Share Posted March 14, 2019 16 minutes ago, lanefu said: i think there's even an official SFTP gateway fro s3 now. I can open incoming directory for direct upload, but since it's not a total urgent matter it can wait a while. 1 Link to comment Share on other sites More sharing options...
Igor Posted April 8, 2019 Share Posted April 8, 2019 On 3/14/2019 at 9:38 AM, gprovost said: The easier would be to provide a FTP service with the same structure and limited access to people you grant right to upload. Prepared. Anyone needs a (s)ftp access to repository incoming directory should send me a public key. Structure is the same as from the build script. Link to comment Share on other sites More sharing options...
gprovost Posted April 8, 2019 Author Share Posted April 8, 2019 3 hours ago, Igor said: Prepared. Anyone needs a (s)ftp access to repository incoming directory should send me a public key. Structure is the same as from the build script. Great ! Just sent you my pub key by PM ;-) Link to comment Share on other sites More sharing options...
Igor Posted April 8, 2019 Share Posted April 8, 2019 OK, gimme me some time. While adding some fixes this morning I find out troubles with repository (nothing can be added atm) and I have to rebuild it manually. For now adding will remain manual - this is just a direct drop off. Link to comment Share on other sites More sharing options...
gprovost Posted April 9, 2019 Author Share Posted April 9, 2019 Sure, no rush... on my side I don't have any package to push. BTW what will be the sftp address ? Link to comment Share on other sites More sharing options...
gprovost Posted May 27, 2019 Author Share Posted May 27, 2019 Hi @Igor Is the SFTP upload available ? Link to comment Share on other sites More sharing options...
Igor Posted May 27, 2019 Share Posted May 27, 2019 3 minutes ago, gprovost said: Hi @Igor Is the SFTP upload available ? Have to check once again. IIRC I stuck somewhere in the middle ... Link to comment Share on other sites More sharing options...
