I don't know if this is related to Linux kernel 5.0 but I didn't have this problem with 4.20
I used linux-headers-dev-.._arm64.deb kernel header files to compile mali kernel drivers on board
I don't know if armbian changed something or it is kernel 5.0 related
now I can't
as linux-headers-dev debian/postinst script
don't generate scripts/mod/modpost
and only scripts/basic/fixdep
any idea?
this is output from
make -d -s scripts
http://paste.ubuntu.com/p/fbhr37q8GF/
I can confirm that 4.19 4.20 is fine and make -s scripts generate modpost and fixdep
but 5.0 don't
on sunxi64 at last
Probably nobody knows ... it's early WIP. If you figure out where is the problem, welcome to help.
I am looking at ubuntu 19.04
linux-headers-5.0.0-7-generic -contains builded versions of modpost and fixdep
linux-headers-5.0.0-7   - contains kernel headers
@Igor
do you remember where do you get inspiration for armbian based kernel headers package structure  and scripts ?
so
make -s scripts -s prepare0
fixed problem
I will make pull request
and it is working fine on linux 4.20 and 5.0
I didn't check  linux 3
But as it first run scripts part from makefile and then prepare0 it should be fine
it don't solve my problem
now when I build mali kernel driver
and when I ismod mali.ko
I get this
 version magic '5.0.4 SMP mod_unload aarch64' should be '5.0.4-sunxi64 SMP mod_unload aarch64'
Works fine on meson
but on sunxi64
for some reason in some part KERNELVERSION is 5.0.4 and in some other part 5.0.4-sunxi64
@Igor
How armbian add suffix to kernel version?
in .config CONFIG_LOCALVERSION is empty
in Makefile EXTRAVERSION = is also empty
As when I set proper suffix in .config everything is working fine
Not working on meson64
    Must remake target 'scripts/kconfig/zconf.tab.o'.
    Successfully remade target file 'scripts/kconfig/zconf.tab.o'.
   Finished prerequisites of target file 'scripts/kconfig/conf'.
   Prerequisite 'FORCE' of target 'scripts/kconfig/conf' does not exist.
   Prerequisite 'scripts/kconfig/conf.o' is older than target 'scripts/kconfig/conf'.
   Prerequisite 'scripts/kconfig/zconf.tab.o' is older than target 'scripts/kconfig/conf'.
  Must remake target 'scripts/kconfig/conf'.
  Successfully remade target file 'scripts/kconfig/conf'.
 Finished prerequisites of target file 'syncconfig'.
Must remake target 'syncconfig'.
Putting child 0xaaaadc8b0780 (syncconfig) PID 31872 on the chain.
Live child 0xaaaadc8b0780 (syncconfig) PID 31872
net/Kconfig:89: can't open file "net/wireguard/Kconfig"
Reaping losing child 0xaaaadc8b0780 PID 31872
scripts/kconfig/Makefile:69: recipe for target 'syncconfig' failed
make[2]: *** [syncconfig] Error 1
Removing child 0xaaaadc8b0780 PID 31872 from chain.
Reaping losing child 0xaaaaf940e1f0 PID 31871
Makefile:539: recipe for target 'syncconfig' failed
make[1]: *** [syncconfig] Error 2
Removing child 0xaaaaf940e1f0 PID 31871 from chain.
Reaping losing child 0xaaaaf5ebaec0 PID 31798
Makefile:635: recipe for target 'include/config/auto.conf' failed
make: *** [include/config/auto.conf] Error 2
Removing child 0xaaaaf5ebaec0 PID 31798 from chain.
root@odroidc2:/usr/src/linux-headers-4.19.20-meson64# make -s scripts -s prepare0
ok commented /usr/src/linux-headers-4.19.20-meson64/net/Kconfig works:
if INET
#source "net/wireguard/Kconfig"
source "net/ipv4/Kconfig"
source "net/ipv6/Kconfig"
source "net/netlabel/Kconfig"
endif # if INET
what a mess
You can also simply provide this argument to compile.sh while building an Armbian image : WIREGUARD=no
Wireguard is broken on sources that are in repository, while if you use self made, it works.
A rebuild of all packages should be done. The question is - is it safe enough?
