Freeze / kernel panic after upgrading to kernel 7.0.12
eselarm replied to Johannes's topic in Allwinner sunxi
Good that your bpi appears to be stable. My did hang again, no reaction on serial console, no reaction on IP networking. So I enabled the watchdog, uncommented the 'ping 192.168.1.1 line' and made it ping 192.168.1.100 and temporarily added that address to another computer: ip addr add dev br0 192.168.1.100/24 Then removing it: ip addr del dev br0 192.168.1.100/24 and after a minute or so: [ 263.929336] systemd-journald[236]: Received SIGTERM from PID 1071 (watchdog). [ 265.185973] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE) [ 265.221538] systemd[1]: Detected architecture arm. [ 269.100327] systemd[1]: Failed to fork off sandboxing environment for executing generators: Protocol error [!!!!!!] Failed to start up manager. [ 269.146571] systemd[1]: Freezing execution. This looks like HW watchdog does not work. Same trick on NanoPi-NEO, so also sunxi kernel although 7.0.12-edge-sunxi, it resets. So appears to work although no proof that it is HW reset. I have not checked live dmesg or so, just noticed it went offline and came back later when I also added that .100 IP address again. -
RK3576 - Support for full video hardware acceleration on Armbian
eselarm replied to Marus Gradinaru's topic in Nanopi M5
If you use and Armbian image with kernel '6.1.115-vendor-rk35xx' (note there are many builds over time, all same name, but you need to look in config-6.1.115-vendor-rk35xx and maybe also consider the gcc compiler version to have RKMPP based method working. I mean the API is there, you need a special ffmpeg (from jellyfin for example to use it) in order to use RKMPP based decoding and encoding in HW. That is just CLI, server use-case, works on RK3568 and RK3588. RK3576 should have the same speed/ASIC blocks as RK3588 AFAIK, but check yourself. It can do 5x realtime speed 1080p50 HEVC to H264. mpv 'uses open and agreed standards' and RKMPP is not. Also Android is completely different. Same is Windows or Apple iOS. Those are implemented by commercial/paid developers. In fact it is worse, ffmpeg open-source developers have concluded already long time ago the Rockchip downstream kernel code was copied and violates licenses. (Rockchip copied code and put their names in it.). So since a few months, ffmpeg developers requested github to remove access and that happened. So following GPL licensing, that 6.1.115 kernel is essentially illegal. How you want to deal with that is up to you. It is like it is. Anyway, 6.1.x downstream is getting old and might contain several unpatched security holes. So over time the 'problem' will solve itself as people won't trust it anymore despite being able to use every HW block in RK35xx. As already said, decoding generally is implemented as part on mainline kernel, you just need matching latest userspace. Encoding is much more complex. If you want that, only Intel/AMD is more or less viable option. Like N100, so in cheap miniPCs, certainly considering high RAM prices, is just a way better option. Plays all HW accelerated in FireFox (and mpv as well). Does also VP9 encoding for example, is a royalty free codec, so you won't see this 2 decades old patents issues for H264 and HEVC. Also note AV1 HW decoding was the first to be available in mainline kernel for RK3588. There is just not much content I think. And HW AV1 encoding is another level of new silicon, is not really an option to do in software. -
# cat /etc/NetworkManager/system-connections/br0.nmconnection [connection] id=br0 uuid=75d54cd2-cdfe-4621-ab45-0bddf3ab4e6c type=bridge interface-name=br0 zone=trusted [ethernet] cloned-mac-address=my eth0 mac address [ipv4] method=auto [ipv6] addr-gen-mode=default method=ignore # cat /etc/NetworkManager/system-connections/eth0-br0_slave.nmconnection [connection] id=eth0-br0_slave uuid=31645756-5c39-4184-a0c2-337ae09422ec type=ethernet interface-name=eth0 master=75d54cd2-cdfe-4621-ab45-0bddf3ab4e6c slave-type=bridge # cat /etc/NetworkManager/system-connections/wlan0-br0_slave.nmconnection [connection] id=wlan0-br0_slave uuid=4ff7f9f2-056e-4836-9bc7-0e77d98a989c type=wifi interface-name=wlan0 master=75d54cd2-cdfe-4621-ab45-0bddf3ab4e6c slave-type=bridge [wifi] band=bg channel=1 mode=ap ssid=mywifissid [wifi-security] key-mgmt=wpa-psk proto=rsn; psk=mypassword template, stripped, optimized, cleaned, untested
The nand-sata-install script is indeed quite old and not very actively maintained anymore. A common modern replacement on Odroid XU4 (and similar boards) is to use the Armbian installer built into armbian-config. You can run: Bash sudo armbian-config Then go to System → Install (or Install to SATA/USB/NVMe depending on your setup). Many people find it more reliable than the old nand-sata-install. Alternatively, you can do it manually with dd for U-Boot + rsync for the rootfs, but armbian-config is usually the easiest route these days. If you run into any issues with it, feel free to share the output and I can help walk you through it.
So i had figured out how to get the root shell access on this specific type of box(fx6), and unfortunately, nope. You cant run any other os than the official firmware linux(buildroot) because of secure boot and locked bootloader(nope, you can't unlock it with fastboot). But, you can use chroot to run ubuntu or another os. Heres some images for proof. So, you cant run armbian, have to stick with buildroot, you can modify it the way you like with root permission, just dont modify the root parttion, if you do, it wont boot and it will be bricked
Theoretically no, because the game won't occupy all the ram, so when you start to fill it up, the kernel should start compressing and move other stuff to zram, but theory is not always how it works in practicality. As for how to disable zram, add zswap.enabled=0 to your kernel parameters and it won't be available after a reboot. To stop zram during operation, IIRC, stop (not disable) systemd-zram-setup@zram0.service. If it's not you should be able to figure out what to stop by listing relevant unit files with systemctl --type swap
Last photo just to the right of the rk3528 at 3 o'clock are the most likely (the two round gold pins). With power off check with a multi meter if one of them is connected to ground. Then with power applied use an oscilloscope to check if the other one has a clock signal on it. If it has these are probably the maskrom pins. Credit to @Hqnicolas
AI development is shifting from implementing models from scratch to composing powerful capabilities via APIs, enabling developers to integrate speech recognition, language models, and tool execution into useful applications with far less effort. View the full article
Greetings! My first foray into Armbian. Apparently the Link Star H68K is hardware equivalent to the Hinlink H68K. I'm trying to install one of the community supported Armbian images (Debian Trixie, Ubuntu 26.04) for the Hinlink onto a Link Star H68K, using the RKDevTool from the Seeed Studio wiki. And failing. The only image that loads into RKDevTool is the Lubuntu 20.04 from the Seeed Studio wiki. It's just a tad out of date. Any pointers on getting a more up-to-date OS installed would be most welcome. AFAIK my device is OG, not V2. I've also tried booting from TF card, but the device refuses to boot at all with a TF card inserted. Some Googling suggests that a current TF card is too fast for the device and causes boot failure. Card spec is Class 10 / UHS-1. I've sourced some Sandisk Class 4 cards and currently awaiting delivery, to see if that solves the boot issue and gives me a path to transfer the OS from TF to EMMC. Any thoughts/advice most welcome.
This week's cycle emphasizes broad U-Boot modernization, new board and SoC enablement, and kernel and wireless driver consolidation. A large-scale U-Boot bump moves sunxi 32-bit and 64-bit targets from v2024.01 to v2026.07-rc4, with follow-on updates for self-pinned H616/H618 boards (Zero2W, Zero3, Longan Pi 3H), Mixtile Edge2, NanoPi R5S (now patch-less), and the Youyeetoo YY3588 switching to mainline v2026.04. The imx6 line (UDOO, Cubox-i) was modernized to U-Boot v2026.07 with legacy 6.12, current 6.18, and edge 7.1 kernels. Related toolchain work fixes ODROID-C1, ODROID-XU4, Recore, and X96Q builds under Trixie's GCC 14, and resolves errexit failures on Rockchip SPI boards. Platform expansion introduces community support for the Allwinner A733-based Radxa Cubie A7Z and Orange Pi Zero 3W, Rockchip Graperain G3568 v2, and Anbernic RG Vita Pro and Lubancat-5IO image entries. BeagleY-AI gained USB, PCIe, ISP + IMX219, and VPAC patches on the vendor kernel, alongside GPU acceleration fixes for TI K3 targets and TI Wave5 VPU firmware. Rockchip RV1106 support was split into distinct RV1103G and RV1103B families, and new SPI/NVMe boot and Maskrom recovery paths were added. On the kernel and driver side, sunxi received an H3/H5 DVFS RCU-stall fix, MMC/I2C PM deadlock resolution, MGLRU enablement, and LTE modem USB serial support. Meson64 gained a GPIO pinctrl cansleep series and v7.2-rc1 via bleedingedge, while SpacemiT K1 was updated to linux-7.2.y. The RTL8189ES, RTL8189FS, and RTL8192EU wireless drivers were migrated to dedicated forks with 7.2 compatibility and patch cleanup, and an RTW88 SDIO interrupt storm was addressed. User-visible improvements include swapfile creation fixes, useradd-based first-login provisioning, and video-group access to Rockchip MPP codec devices. #Armbian #EmbeddedLinux #UBoot #Rockchip #Allwinner Changesboard: visionfive2: optimize config for modern U-Boot and single-partition booting. by @zevlaoxie2010 in armbian/build#10097Add Anbernic RG Vita Pro board image. by @crackerjacques in armbian/armbian.github.io#351Add Lubancat-5IO board image and vendor logo. by @lch08 in armbian/armbian.github.io#348Add TI Wave5 VPU firmware. by @Grippy98 in armbian/firmware#132beaglebadge: drop vendor-edge u-boot target (not in ti-u-boot-2026.01). by @igorpecovnik in armbian/build#10126BeagleY-AI Add Patches for ISP + IMX219 & VPAC. by @Grippy98 in armbian/build#10129board: anbernic-rg-ds: make OTG-C port dual-role so USB hubs work. by @crackerjacques in armbian/build#10124Build-Switches: document KERNEL_DO_STUBBLE. by @iav in armbian/documentation#928Bump/rk uboot swig fleet mkspi 2. by @redrathnure in armbian/build#10122chore(deps): patch vulnerable transitive deps. by @SuperKali in armbian/website#33ci(docs-preview): skip publish/comment steps on fork PRs. by @iav in armbian/documentation#934ci: auto-regenerate build lists when image-info.json changes. by @igorpecovnik in armbian/armbian.github.io#349ci: bump image build cap 30m → 45m. by @igorpecovnik in armbian/os-ci-test#24ci: widen auto-retry budget and the systemic-failure threshold. by @igorpecovnik in armbian/os-ci-test#23clk: sunxi-ng: ccu_common: Replace ktime-dependent lock wait loop with udelay. by @deece in armbian/build#10119config: rockpi-e: change rkbin repository and use spl-blobs. by @chenxmqqqq in armbian/build#10027cubie-a7z: Add community support for Radxa Cubie A7Z (Allwinner A733). by @shkolnik in armbian/build#10036docs: add Datacenter access section (Netbird VPN + board access). by @igorpecovnik in armbian/documentation#936docs: document PREFER_NATIVE_ARMHF and enrich arm64-compat-vdso entry. by @iav in armbian/documentation#921docs: exclude docs/README.md from mkdocs build. by @iav in armbian/documentation#933docs: use unpinned python3-dev in setup instructions. by @igorpecovnik in armbian/documentation#935Drop testing-wireless-performance-test.yml. by @igorpecovnik in armbian/armbian.github.io#350Enable USB and PCIe on BeagleY-AI vendor kernel. by @Grippy98 in armbian/build#10115fake-ubuntu-advantage-tools: provide ubuntu-pro-client. by @Grippy98 in armbian/build#10116family-rv1106: Split RV1103G and RV1103B, cleanup overrides. by @vidplace7 in armbian/build#10011feat(api): serve QDL board metadata and proxy-cache firehose assets. by @SuperKali in armbian/website#31feat(qdl): serve the board registry from the API. by @SuperKali in armbian/imager#163firstlogin: use useradd/groupadd instead of the adduser suite. by @igorpecovnik in armbian/build#10127Fix swapfile creation. by @pierg75 in armbian/build#10065Fix TI K3 Suite Matching for Ubuntu Hosts and Enable GPU Acceleration for BeagleBoards. by @Grippy98 in armbian/build#10112fix: stop setting LC_ALL in armbian-lang.sh. by @saschabuehrle in armbian/build#10132Guard config-disabled static helpers to silence -Wunused-function. by @iav in armbian/wifi-rtl8852bs#9Import long-carried armbian/build regd-init fix, with authorship. by @iav in armbian/wifi-rtl8852bs#8imx6 modernization: udoo + cubox-i u-boot v2026.07 + kernel (legacy 6.12 / current 6.18 / edge 7.1). by @igorpecovnik in armbian/build#10098kernel-rust: ship prebuilt Rust crate artifacts in linux-headers. by @iav in armbian/build#10117Makena: add SC8280XP firehose and Radxa Dragon Q8B UFS provisioning. by @SuperKali in armbian/qcombin#3meson64: add GPIO shared-proxy/pinctrl cansleep series (upstream v3). by @adeepn in armbian/build#10090meson64: enable v7.2-rc1 via bleedingedge. by @EvilOlaf in armbian/build#10079mixtile-edge2: u-boot: main: bump (generic) u-boot to v2026.07-rc5. by @rpardini in armbian/build#10071nanopi-r5s: u-boot: main: bump u-boot to v2026.07-rc5 + make it patch-less. by @rpardini in armbian/build#10072odroidc1: fix u-boot build on trixie (GCC 14) via config.mk -fpermissive. by @igorpecovnik in armbian/build#10111odroidxu4: fix u-boot build on trixie (GCC 14 implicit-decl errors). by @igorpecovnik in armbian/build#10110orangepizero3w: Add community support for Orange Pi Zero 3W (Allwinner A733). by @shkolnik in armbian/build#10103recore: fix ATF v2.8.0 build - drop -Wl, prefix from LD flag. by @igorpecovnik in armbian/build#10100refactor(api): drop min_imager_version from QDL enrichment. by @SuperKali in armbian/website#32rockchip64: fix errexit build failure on SPI boards (undefined hook). by @igorpecovnik in armbian/build#10101rockchip64_common: add board_uboot postprocess hooks. by @mingzhangqun in armbian/build#10031rockchip: add support for Graperain G3568 v2. by @rbqvq in armbian/build#10056rockchip: udev: grant video group access to MPP codec devices and DMA-heaps. by @yisding in armbian/build#10085rtl8189es: switch fork, clean up patches, bump to 7.2. by @EvilOlaf in armbian/build#10086rtl8189fs: switch to own fork, add 7.2 compatibility, drop patches from misc. by @EvilOlaf in armbian/build#10092rtl8192eu: switch to own fork, add 7.2 compat, remove integrated patches from misc. by @EvilOlaf in armbian/build#10095shellfmt: run lib/tools/shellfmt.sh, no changes. by @rpardini in armbian/build#10087SpacemiT K1: Update EDGE to linux-7.2.y. by @pyavitz in armbian/build#10123sunxi (32+64-bit): bump u-boot v2024.01 -> v2026.07-rc4. by @igorpecovnik in armbian/build#10089sunxi, sunxi64, sun60iw2: enable MGLRU in kernel config. by @ValdikSS in armbian/build#10133sunxi-6.18: fix H3/H5 RCU stall / CPU hang during DVFS (current kernel). by @igorpecovnik in armbian/build#10083sunxi64: bump self-pinned H616/H618 boards to v2026.07 (zero2w, zero3, longanpi-3h). by @igorpecovnik in armbian/build#10102sunxi64: enable USB_SERIAL_OPTION (module) for GSM/UMTS/LTE modem support. by @pumuckly in armbian/build#10050sunxi: pin mmc and i2c controllers to active to break circular PM deadlock. by @deece in armbian/build#10120uboot: add SPI/NVMe boot support and Maskrom SD-card/flash fixes. by @mingzhangqun in armbian/build#10030wifi: rtw88: sdio: Fix unhandled RX request interrupt storm. by @deece in armbian/build#10121WifiPerformance: update infrastructure section to autotests framework. by @igorpecovnik in armbian/documentation#931x96q: fix u-boot build hang — add missing CONFIG_DRAM_SUNXI_TPR6. by @igorpecovnik in armbian/build#10114youyeetoo-yy3588: switch to mainline U-Boot v2026.04. by @SuperKali in armbian/build#10125youyeetoo: fix 7" touch with TPC2059 config, add YY3588 display overlays. by @SuperKali in armbian/linux-rockchip#507yy3588: fix eDP video port and timing, document panel requirement. by @SuperKali in armbian/linux-rockchip#508View the full article
I was wrong, the dafault baudrate is 100 kHz - the sensor is not responding at first try, when it is in sleep mode.
Hi Dodeval, so I am having trouble accessing Gemini 3.1 pro chat about this but this sounds vaguely familiar. Things that could be the cause are the "mkfs.ext4 -b 4096" option and "debootstrap --arch=arm64". Try some of these top tier models https://artificialanalysis.ai/leaderboards/models they should be able to crack the code even though you might have to wrestle a bit to get them to produce the right solution. Most things seem to work like magic I guess it is about the device tree, battery management seems fine etc.. touch needs drivers, no audio from internal speakers which is no big deal anyway as bluetooth audio works everything there works as expected. I did get this aliexpress.com/item/1005009649297050.html at a discount but I not completely get the touchpad to work comfortably with a patched input driver, a lot of miss-clicks goosh nice keyboard but still need bluetooth mouse in reality. Rii i4 Mini Bluetooth would be fine but then again it is not quite the desktop experience I was looking for. -
Your previous post reminded me that the board supplier changed the BOM of the ODROID-N2+ by using a different SPI flash vendor. He hacked the support for it into his legacy firmware build without making any further note about it. It took some effort of reverse engineering to figure that out. Mainline hasn't picked up this additional driver activation to this day, but I still keep it in my builds anyway. In my latest build for the ODROID-HC4, I also included this driver to see if they might have gone about it in the same way. But your confirmation shows that this is probably not the case. Since I don't have an ODROId-HC4 with the behavior you described on hand, I can't analyze any further what the cause of it is. These days, I also mostly avoid devices with Amlogic SoCs because of their strict closed-source policy and lack of mainline support. And the board manufacturer isn't much more helpful on this point either. Devices powered by Rockchip are much more appealing objects. So you have to help yourself if you want to find a solution.
How to receive MIDI messages to a cli app
Vivichrist replied to Vivichrist's topic in Software, Applications, Userspace
I don't have a Desktop installed on this device (OrangePi 4LTS). I resorted to using the rtmidi C interface instead, I made a wrapper. The Pipewire documentation is hard to figure out. I guess there should be some sort of session management for Non-Desktop sessions to load stuff? -
@Morales MoralesThe older build where ethernet is working: https://github.com/sicXnull/armbian-build/releases/download/mxqpro/Armbian-unofficial_26.02.0-trunk_Mxqpro-h313_trixie_current_6.12.74_cinnamon_desktop.img.xz The semi-official one where it's not: https://armbian.com/boards/x96q
Hi, I think swapon is not visible because you are not root. It should already be there via required package "mount". Try tu "su -" then you will "see" the command.
ErinBong replied to ずっと一人's topic in Orange Pi 5 Plus
Hey! i had similar issues with the ES8388 analog and HDMI output path alignment on my OPi5 Plus under recent edge/mainline kernels. Sometimes the card states look fine in ALSA/pavucontrol but the streams just don't bridge to the hardware mapping properly, or the default audio levels are hitting gain issues. To test if it’s just a software-side compression or file amplification issue before diving too deep into modifying the device tree (.dts), try running a quick format check with a known sample using explicit routing- aplay -D plughw:1,0 your_audio.wav If your test files are inherently too quiet or failing to hit the threshold cleanly, you can boost them up beforehand via tools like MP3Louder just to make sure you aren't fighting low baseline source levels on top of the kernel driver bugs. If it completely stays dead silent even with clean, forced audio files, then it's definitely the device tree overlay parameters (simple-audio-card) not toggling correctly on your specific build version. Which image build date and kernel version are you currently on? -
The post is from nov 2022, and OP reported it worked 2 weeks later... But good advice non the less... xD
xunicatt replied to chapeaufer's topic in Allwinner sunxi
Here is the commit: https://github.com/Guation/radxa-cubie-a5e-armbian-build/commit/202f1bf3943e2a583e10405f54b206fae9991a98 -
@0757myt: Thank you so much for your clarification. I am really sorry that some parts of the guide are written too briefly. Sometime I don't know how to explain all of this messy things to new users. @hmoob I looked at your board and it seems your board doesn't have a power IC. There are just some diodes and capacitors near the DC port. May be one of them get shorted or burned but they are not really important. If you are good at soldering, you can definitely find the points for + and - pin to power the board so we will have 1 more USB port. Home Assistant need docker supports. Make sure that you are using the latest image (v1.1): https://github.com/chieunhatnang-personal/RK3128-Linux-SupportingScripts/releases/tag/kernel-6.6-armbian-26-v1.1 -
Since you cannot trust this EMMC, @magixx256 Here is how to get log2ram up and running, plus a quick way to double-check your storage health. 1. Install log2ram Manually Run these commands to pull the official repository, install it, and get it running: # Download and extract the latest release curl -L https://github.com/azlux/log2ram/archive/master.tar.gz | tar zx # Move into the folder and run the installer cd log2ram-master sudo ./install.sh # Clean up the installer files cd .. && rm -rf log2ram-master Reboot to Activate It For log2ram to properly hijack the logging system and mount it into RAM, you need to reboot the machine: sudo reboot Verify It's Working Once the box boots back up, run your status command again: systemctl status log2ram You should see an active (exited) status (which is normal for this service, as it just runs a script at boot to create the RAM disk). You can also verify it's actively mounting by checking your system disks: df -h | grep log2ram You'll see a line showing /var/log mapped to log2ram with a size of about 40MB or 50MB. 2. A Quick Note on System Stability Since log2ram holds your logs in memory and only writes them to your eMMC/SD card once a day (or right before a clean shutdown), a sudden power pull means you lose the logs from that day. -
(FIX) SV6051/P WIFI DRIVERS FOR ARMBIAN
SteeMan replied to rayhanoriginal's topic in Amlogic CPU Boxes
Please note that ophub is not Armbian. They use the Armbian name without permission, do not contribute to Armbian development nor participate in these forums. Having said that, android TV boxes are a community supported effort under Armbian. It would be appreciated if you took the time to submit a PR to include your efforts into Armbian.
