  2. @deskwizard I don't know why I refer to OPi5Max, maybe I had other tab/topic open or so, but it is clear that it is about the OPi5. Now I have the ROCK5B, just cloned the Armbian Bookworm from ROCK3A but did not write SPI yet. Power up with fixed 12V in USB-C and from SD-card with Armbian rock5b legacy U-Boot. rootfs from NVMe, SATA overlay enabled for 3.5inch HDD. 5 audio cards: root@rock5b:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: rockchiphdmi0 [rockchip-hdmi0], device 0: rockchip-hdmi0 i2s-hifi-0 [rockchip-hdmi0 i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: rockchiphdmi1 [rockchip-hdmi1], device 0: rockchip-hdmi1 i2s-hifi-0 [rockchip-hdmi1 i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 2: rockchipdp0 [rockchip-dp0], device 0: rockchip-dp0 spdif-hifi-0 [rockchip-dp0 spdif-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 4: rockchipes8316 [rockchip-es8316], device 0: dailink-multicodecs ES8316 HiFi-0 [dailink-multicodecs ES8316 HiFi-0] Subdevices: 0/1 Subdevice #0: subdevice #0 card3 (unlisted) is HDMI-input I think, but disabled all in KDE settings tray except the 3.5mm plug ('headphones'). No further settings or volume change, mpv playing an mp3 instantly. I will likely do/test with 6.15 edge, also maybe 6.12 current (and other U-Boots as well). But first several mechanical/cooling things to tweak, need to drill/cut a hole for the SATA connector in the cooling metal I think.
  3. hello guys, i hawe question, my device: orangepi 3b 8gb OS: 1.0.6 Jammy with Linux 5.10.160-rockchip-rk356x 3.3V → 3.3V → PIN 1 GND → GND → PIN 6 SCK → SPI SCK → PIN 23 MOSI → SPI MOSI → PIN 19 MISO → SPI MISO → PIN 21 SDA → CS → SPI CE0 → PIN 24 =========================== /boot/orangepiEnv.txt ``` verbosity=1 bootlogo=true extraargs=cma=128M overlay_prefix=rk356x rootdev=UUID=4b3309b6-9bbe-431d-8609-82360b5b6154 rootfstype=ext4 overlays=spi3-m0-cs0-spidev spi3-m0-cs1-spidev ``` orangepi@orangepi3b:~$ ls /dev/spidev* /dev/spidev3.0 <================= only one... cant add new spidev 3.1 and more.. for connect another mrfc522 how to fix?
  5. @xiaobao80, The official use is the closed source Mali library. Panfrost is an open-source GPU library. It should be that the Panfrost module does not yet support rk3576
  6. There are for once some inconsistencies in terms of prefixes across various soc families and for the other configng isn't perfect (yet ). Feel free to share your issue at its repository: https://github.com/armbian/configng/
  7. I have the same question regarding official Armbian and S905W2. I would like to install it on a X96 Mini.
  8. oh thanks! I didn't realize you already had an axp313 image. I've been compiling armbian with custom u-boot patches and it's been taking forever. I've been trying to adapt a dtb to my box, which one do you use? I tried including the one from miniarch but it seems like it gives warnings and I can't bypass them in the Armbian build system.
  9. Yesterday
  10. I can suggest only hard way - clear installation armbian then HA, without manipulation with driver and use rk3318-config to set device tree option
  11. @Nick A I’m using the MiniArch image that was shared here on the forum. From it, I extracted the DTBs, Image, and other boot files, and replaced them in the Armbian image. I also took the bootloader from the MiniArch image and replaced the one in Armbian. With that, I managed to boot into Armbian, but unfortunately, no network adapters were detected.
  12. Can you compare the device tree between your working system, and from the freshly installed 25.2.3/6.12.22 (write the img in a new microSD) View your device tree with: #(root) dtc -I fs -O dts /sys/firmware/devicetree/base (you need to find out which driver handles the audio, and search for that driver name in the working device tree) Also, check differences in armbianEnv.txt Also, check differences in ".config" in the /boot/ folder (specially anything related to audio) Also check the contents of "dmesg", searching for the audio driver name
  13. Try setting ZRAM_PERCENTAGE=50 where 50 would be half of available memory. Not sure if the builder picks this up. If it doesn't I'd go the customize-image.sh route and use this to modify the /etc/default/armbian-zram-config file just before assembly closure.
  14. Well, folks say it is being worked on - https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?id=71025ec7f7767 Decoding works so I was hoping it did progress but may be not.
  15. I have device X10 Plus TV BOX 4/32 same smae Rtv 10x 4/32 How to get file image or build for device It run Allwinner H6 Link product I find fourm but cannot get the file
  16. Hello, we have tried wifi and it is working fine https://www.armbian.com/armsom-sige5/
  17. AFAIR someone on this forum also experienced booting issue with orange pi board though 4 not 5 with quite similar symptoms. May be worth contacting that person for his results so far - might give some hints on what's going on and whether it's a manufacturing fault
  18. Hm if an image works but self-made won't either means something has been messed up which I doubt since it fails at uboot level. Or a change in the code broke it in the mean time. Also interesting that kernel building fails when RKNPU is a module rather than built-in. I guess that goes to poor implementation on Rockchip's side. Which exact pre-built image did you test that works well? This is quite old. We had a few version bumps in the mean time. More recent vendor kernels should already contain 0.9.8 What you could also try is to integrated the most recent patch series for mainline npu driver into edge kernel: https://patchwork.kernel.org/project/linux-rockchip/cover/20250519-6-10-rocket-v4-0-d6dff6b4c0ae@tomeuvizoso.net/
  19. Yes, DB9 won't work. But if, as eselarm mentions, a proper chip is on board already a simple usb-a to usb-c or c-to-c cable should do. Check dmesg when connection to see what pops up.
  20. These things can happen, yes. Sometimes old vendor-style uboot cannot process a modern mainline kernel and vice versa. Glad to hear it worked well this time.
  21. Last week
  22. and I must say that not only your passion, but also your dedication and commitment are truly inspiring for the whole community! One just cannot thank you guys for everything you have done! @fabiobassa @jock @ilmich Since @jock provided the experimental image on May 12th, i've been playing non-stop with this device, doing numerous flashing attempts and testing things out, just for fun... I must have spent 30+ hours on this ever since, mostly trying to compile things myself to run in the box, playing with the different overlays to test what works and what doesn't and learning about Tee, trust, op-tee,... You know those kids that when get their toys, they tear it apart instead? well... same feeling... the discovery passion thing... I'm preparing a report on my findings for my specific "MXQ-EP-2-V1.0" MoBo model, specially around on the working overlays, perhaps I can post it in the weekend.... And responding to my own question earlier about armbian minimal, in the armbian-config tool from the experimental image, there is an option to disable desktop... it gives you a system with only 25 tasks running and lower RAM usage than a DietPi. Now I begin to become interested on (re)assembling ROM images... I've been trying to replace some internet roms with the Trust Partitions and u-boot from the ROM I know it works... No successful test yet, but not sure if I'm repacking them correctly... Anyway, I'm learning a lot and that's great thanks to this community!
  23. Thank you, I tried. But this is not my level, it is too difficult for me. I'll probably wait for your next release.
  24. I believe I have the same issue with an unbootable Rock64 after the kernel update from 6.6.x to 6.12.x.
  25. Good day, I've installed ARMBIAN to my old TV box. It's running fine as I ussually use it headles with a ssh connection to it. BUT NOW I've attached it to the hdmi TV and I want to remotely use that HDMI screen w/o local keyboard and mouse. I don't know how to do that. Please give me a help?
  26. Yeah, I noticed it was not rebuilt on the next calls to compile.sh. Might not solve the problem for CI/CD environments, but for development it should work. Thanks!
  27. Hello @mvpwar Download image Unzip
  28. Finally someone has the question I wanted to ask right now.. Thank you for the solution you found. I will try it sir..
  29. Makes sense, thanks for pointing that out. I had similar issues and I’ll check which package holds it on my setup and try replacing it. Hopefully that clears it up.. Thank you..
