  2. Thank you for that information, @Mechano. Did you ever get this board to work, with armbian or another image?
  3. looks like a really cool machine. unfortunately, no maintainer in armbian and I am not aware if any of the regular developpers has that SBC. It seems to be based on the H618 which it shares with the Orange Pi Zero3 which is reported working with the latest Armbian release. Did this board ever work with an older release? Is this a regression? I see somebody else mentioning they have issues with the board booting, , apparently due to issues with thermal management. And your crash apparently started in pstate.
  5. Nice. To help other users of the forum, it would be good if you shared what fixed the issue.
  6. To be honest, I'm confused. You reference three different systems and it is unclear to me which one it is that FTBFS for you. Let's take a step back. Do you have the latest git tree of armbian/build? Do you have any local changes? What is the exact command you for compile.sh? I will try to reproduce the problem here.
  7. Sparking between the wires on the poles produces high-frequency pulses of high power and transmits them through the wires to consumers of electricity. Household consumers such as a TV, vacuum cleaner, refrigerator do not have a built-in high-frequency protection filter and very often fail. As for the orange, it is not protected at all. My orange was just lying on the table and was connected by an Ethernet cable to the router. Both were not power up. Lightning struck a nearby building. The Ethernet cable caught an electromagnetic pulse. The orange burned down completely and the router has only 1 port damaged. You can draw your own conclusions.
  8. Either ignore expired cert or wait until we fixed it.
  9. This mode needs 80MHz pixel clock which is not in the table for clk-rk3568.c driver. You need a patch similar to https://lkml.org/lkml/2025/3/18/1337 to add this rate. FWIW 1280x800@63.59Hz isn't a very common mode
  10. Yesterday
  11. @jwillb00In this patch. Try changing 16 to 0. In both locations. Maybe I uploaded the image with these changes. https://github.com/NickAlilovic/build/blob/v20250306/patch/u-boot/u-boot-h616/153-add-tanix_tx6s_axp313_defconfig.patch +&mdio1 { + rmii_phy: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; +}; +
  12. /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.5.1 for Orange Pi Zero3 running Armbian Linux 6.12.23-current-sunxi64 Packages: Ubuntu stable (noble) Support: DIY (community maintained) IPv4: (LAN) 192.168.***.*** (WAN) ***.***.***.*** IPv6: *** Performance: Load: 4% Up time: 16 min Local users: 3 Memory usage: 45% of 971M Zram usage: 47% of 485M CPU temp: 46°C Usage of /: 11% of 58G RX today: 98 MiB Commands: Configuration : armbian-config Monitoring : htop *** System restart required *** Some packages require a reboot (gnome-shell) orangepi@orangepizero3:~$
  13. I would like to use my device as a VPN client, i.e. connect to a remote OpenVPN server. How can I enable the Tun/Tap module on my board?
  14. Yes. And we will keep fork maintained as long as possible. https://community.home-assistant.io/t/feedback-requested-deprecating-core-supervised-i386-armhf-armv7/880968/313
  15. Any up to date Armbian image using vendor kernel should include rknpu kernel driver oob. Mainline npu driver is still pending. You can try to backport it. Check rockchip kernel mailing list.
  16. Hi We all started at some point. But overall prepare for some frustration We don't support this device. Support was added via community effort. May work, maybe not. We don't know nor do we track status of such configurations. Regarding OPi5+. It is using - in terms of ARM socs - a fairly recent SoC, the Rockchip RK3588. Mainline support is far from feature-complete. Will take a few additional years to complete. If you need an almost feature-complete kernel, you have to use vendor branch which is based on Rockchip BSP. current (Linux 6.12.y LTS at this time) has basic support for rk3588 and is good enough for general server application, though for your usecase might not be enough. This branch will receive fixes only but no new features. edge may be sufficient. When using some graphics related I suggest to use an image with mesa-vpu extension included. Also there a two ways to make use of it: - We backported the open source Panthor driver into vendor. Can be enabled via device tree overlay (check code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } armbian-config) - Using proprietary mali blobs is also possible. I think Jellyfin has a tutorial how to setup those: https://jellyfin.org/docs/general/post-install/transcoding/hardware-acceleration/rockchip/
  17. I've extracted dtbs from my rooted device bqeel K12, could it be useful share them? @RuDy_74 I've used "Magicsee C400 Plus" dtb (I don't remember the exact name) and I got also wifi and bluetooth working. The only issue is ethernet working at 100Mbit instead of 1Gbit
  18. Still the same with armbian 25.2.3 kernel: 6.12.22-current-rockchip64 #1 SMP PREEMPT Mon Apr 7 08:08:37 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux u-boot-version: # cat /dev/mtd/by-name/U-Boot | strings | grep -B1 "u-boot,version" 2025.01-armbian-2025.01-S6d41-P41ad-H4cab-V390e-Bb703-R448a u-boot,version WARNING: could not set u-boot,version %s. # iperf3 -R -c odroidm1 Connecting to host odroidm1, port 5201 Reverse mode, remote host odroidm1 is sending [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 79.2 KBytes 649 Kbits/sec [ 5] 1.00-2.00 sec 84.8 KBytes 695 Kbits/sec [ 5] 2.00-3.00 sec 206 KBytes 1.69 Mbits/sec [ 5] 3.00-4.00 sec 228 KBytes 1.87 Mbits/sec [ 5] 4.00-5.00 sec 115 KBytes 938 Kbits/sec [ 5] 5.00-6.00 sec 181 KBytes 1.48 Mbits/sec [ 5] 6.00-7.00 sec 163 KBytes 1.33 Mbits/sec ^C[ 5] 7.00-7.36 sec 9.90 KBytes 226 Kbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-7.36 sec 0.00 Bytes 0.00 bits/sec sender [ 5] 0.00-7.36 sec 1.04 MBytes 1.19 Mbits/sec receiver when changing u-boot back to older u-boot (same kernel), it works as expected # cat /dev/mtd/by-name/U-Boot | strings | grep -B1 "u-boot,version" 2023.04-00035-g7dd5eb0228 u-boot,version WARNING: could not set u-boot,version %s. # iperf3 -R -c odroidm1 Connecting to host odrdoidm1, port 5201 Reverse mode, remote host odroidm1 is sending [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 110 MBytes 921 Mbits/sec [ 5] 1.00-2.00 sec 110 MBytes 926 Mbits/sec [ 5] 2.00-3.00 sec 110 MBytes 926 Mbits/sec [ 5] 3.00-4.00 sec 110 MBytes 921 Mbits/sec [ 5] 4.00-5.00 sec 111 MBytes 929 Mbits/sec [ 5] 5.00-6.00 sec 111 MBytes 927 Mbits/sec [ 5] 6.00-7.00 sec 110 MBytes 919 Mbits/sec ^C[ 5] 7.00-7.79 sec 87.0 MBytes 925 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-7.79 sec 0.00 Bytes 0.00 bits/sec sender [ 5] 0.00-7.79 sec 858 MBytes 924 Mbits/sec receiver iperf3: interrupt - the client has terminated ethtool output: ~# ethtool end0 Settings for end0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supported pause frame use: Symmetric Receive-only Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Link partner advertised pause frame use: No Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 1000Mb/s Duplex: Full Auto-negotiation: on master-slave cfg: preferred slave master-slave status: slave Port: Twisted Pair PHYAD: 0 Transceiver: external MDI-X: Unknown Supports Wake-on: ug Wake-on: d Current message level: 0x0000003f (63) drv probe link timer ifdown ifup Link detected: yes
  19. I upgraded my ROCK5B in-place from Armbian Bookworm beta to Armbian Testing/Trixie beta and it turns out that no Ambian packages are seen (so not updated). The Debian Trixie packages do upgrade, as for example I just saw while doing full-upgrade: libavif16:arm64 (1.2.1-1.2) over (1.2.1-1.1) ... I thought something with my install, but also downloaded 'Armbian_25.8.0-trunk.50_Rock-5b_trixie_vendor_6.1.115_minimal.img' yesterday and it has the same issue (quick test via systemd-nspawn container on loopdev mounted image). My goal is at least to figure out what is best bootloader and kernel for the ROCK5B. So far I simply copied/cloned Armbian Bookworm rootfs from ROCK3A+NanoPi-R6C and did some ROCK5B specific changes like U-Boot, but not much more and it actually is already good enough. But before the ROCK5B becomes a 24/7 headless workhorse with long uptime, I thought better to prepare/check for newer Linux or potential issues. I already upgraded some other devices from Bookworm->Trixie and that is quite an improvement, for example KDE 6 performs much better/nicer than KDE5 in Bookworm. It currently uses U-Boot 'edge' and 'current' kernel and very important for me, both the 'vendor' and 'mainline current/edge' overlay for SERDES multi-PHY SATA on the M.2 E-key work (and also the NVMe keeps working). I need to drill a hole in the Radxa aluminum cooling case for the SATA cable (and serial console cable), that needs some time first. I can build and install U-Boot and kernel etc manually of -course, but i wonder why Armbian packages are not visible. Is it as expected or is something wrong? I assume it is just too early yet and that it is work in progress. I think maybe policies are an issue, but don't understand what it could be. Maybe someone has a hint. root@rock-5b:~# apt policy Package files: 100 /var/lib/dpkg/status release a=now 500 http://deb.debian.org/debian trixie/non-free-firmware arm64 Packages release o=Debian,a=testing,n=trixie,l=Debian,c=non-free-firmware,b=arm64 origin deb.debian.org 500 http://deb.debian.org/debian trixie/non-free arm64 Packages release o=Debian,a=testing,n=trixie,l=Debian,c=non-free,b=arm64 origin deb.debian.org 500 http://deb.debian.org/debian trixie/contrib arm64 Packages release o=Debian,a=testing,n=trixie,l=Debian,c=contrib,b=arm64 origin deb.debian.org 500 http://deb.debian.org/debian trixie/main arm64 Packages release o=Debian,a=testing,n=trixie,l=Debian,c=main,b=arm64 origin deb.debian.org 500 https://beta.armbian.com trixie/trixie-desktop all Packages release o=Armbian,a=trixie,n=trixie,l=Armbian,c=trixie-desktop,b=all origin beta.armbian.com 500 https://beta.armbian.com trixie/trixie-desktop arm64 Packages release o=Armbian,a=trixie,n=trixie,l=Armbian,c=trixie-desktop,b=arm64 origin beta.armbian.com 500 https://beta.armbian.com trixie/trixie-utils all Packages release o=Armbian,a=trixie,n=trixie,l=Armbian,c=trixie-utils,b=all origin beta.armbian.com 500 https://beta.armbian.com trixie/trixie-utils arm64 Packages release o=Armbian,a=trixie,n=trixie,l=Armbian,c=trixie-utils,b=arm64 origin beta.armbian.com 500 https://github.armbian.com/configng stable/main arm64 Packages release o=armbian.github.io/configurator,n=stable,l=armbian.github.io/configurator,c=main,b=arm64 origin github.armbian.com Pinned packages:
  20. Last week
  21. I tried the image from "armbian.atomonetworks.com" and the exact same thing happens. Thanks, I'll compare the images.
  22. The latest Linux kernel brings expanded hardware support for MediaTek and Rockchip, enhanced graphics drivers, and more. Collabora played a key role in this release, with no less than 20 authored contributors! View the full article
  23. ZFS-DKMS doesn't work on vanilla image https://dl.armbian.com/longanpi-3h/Bookworm_current_minimal Image is freshly burnt to the SD card. root@longanpi-3h:~# apt update root@longanpi-3h:~# apt install zfs-dkms root@longanpi-3h:~# modprobe zfs modprobe: ERROR: could not insert 'zfs': Exec format error root@longanpi-3h:~# modinfo zfs | grep -v parm filename: /lib/modules/6.12.23-current-sunxi64/updates/dkms/zfs.ko version: 2.3.1-1~bpo12+1 license: CDDL license: Dual BSD/GPL license: Dual MIT/GPL author: OpenZFS description: ZFS alias: zzstd alias: zcommon alias: zunicode alias: znvpair alias: zlua alias: icp alias: zavl alias: devname:zfs alias: char-major-10-249 srcversion: 2742833EE1C14D857611F06 depends: spl name: zfs vermagic: 6.12.23-current-sunxi64 SMP mod_unload aarch64 root@longanpi-3h:~# file /lib/modules/6.12.23-current-sunxi64/updates/dkms/zfs.ko /lib/modules/6.12.23-current-sunxi64/updates/dkms/zfs.ko: ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), BuildID[sha1]=f87455b001529d816f09e1498e63a902d1af9be5, not stripped root@longanpi-3h:~# uname -a Linux longanpi-3h 6.12.23-current-sunxi64 #1 SMP Thu Apr 10 12:39:41 UTC 2025 aarch64 GNU/Linux logs After doing apt upgrade, reinstalling dkms module result is the same.
  24. Awesome work as always. Cant wait until the 25.05 upgrade is available for my Rock5b
  25. That was installed on my test machine which wasn't upgraded to latest (.115) yet.
  26. If Rockchip reads this: knock it off and use a reasonable speed for console on your devices!
  27. You delete all files in that folder.
