It looks that it kicks in on 100% at 55C, and it's shuts the fan on 44C. I will try the one You sent, thanks.
split off the issue from the original into a separate thread Essentially the problem here is that one of the mirrors is apparently redirecting from https to http. This has been a problem in the past and was supposedly fixed, in fact more than once. Obviously, it's never been fixed properly for all cases or there was a regression.
Brave browser supports arm64 and has a "New private window with Tor" option. Might be worth checking out.
what filesystem your drive using? usually if its WIndows Filesystem, that's where you get some performance penalty and NTFS is the one being the worst of all. Last time I tried using a ext4 formatted usb3 flash drive and was able to read/write to drive at 11MB/sec over wired LAN, no tweaks on samba server were done other than setting up some shares.
@Igor Thanks. The weird noise is resolved. It was HDMI cable.
Aliexpress randomly assembled electronics is expected to fail - you need to lower expectations, count on luck, read forum for clues, DIY. Little better are single board computers, then what is declared as supported, best what is platinum supported (for this use case FriendlyElec R3S would be perfect) following by Raspbbery Pi and x86 hardware. If you are looking for top first time experience buying a server, you should stick to https://www.supermicro.com/en/ I can assure you that Armbian works perfectly on any of servers they sell. But yes, price does not match.
I can confirm: https://paste.armbian.de/oxupahozud
@Mike H This is a community forum, and your message is for everyone. Armbian maintainers are part of this community, but please keep in mind that support here is provided on a best‑effort basis by volunteers and maintainers who give their time when they can. In open‑source projects, especially those maintained by communities, work is prioritized based on available time, skills, and resources. Sometimes an issue might be addressed quickly; other times it may take months — or it may not be addressed at all if the effort required is too great compared to the benefit. This is a normal reality in community‑driven software development. The concept of sunk cost often plays a role in deciding whether to invest effort in fixing certain issues. It’s worth noting that even in large, well‑funded projects, some bugs remain unresolved for years. In our case, resources are far more limited — for example, Raspberry Pi OS has a budget exceeding €1M annually for one platform, while Armbian supports many platforms with a fraction of that funding, outside few boards we have some small maintaining budget, there is only a beer money, and far fewer people. Best-effort is the only promise that can be provided under such circumstances. We appreciate bug reports, even they have nothing to do with our work as we understand users often can't judge that, but we ask that no pressure be placed on contributors to resolve them on demand. In some cases, solving an issue can take weeks or even months of work, which is not something users can reasonably expect from volunteers. And there are thousands of bugs already in the to do list. Finally, please understand that part of the challenge we face is that some projects already monetize or re‑brand our work while presenting it as inexpensive and easy to maintain — when in reality, it’s not. This can create misunderstandings about the real cost and effort behind keeping a complex software stack running. Your report is welcome, but we ask for patience, understanding, and respect for the time and resources of those trying to help. Pressuring volunteers to prioritize some issue, or expecting them to personally fund the work, is neither reasonable nor effective way to fix bugs.
Coming back to this... I'm not having any luck getting overlays to work, but I'll need to get out my serial logger to see what's wrong I guess. I'm trying to get the USB-C into host mode on my RockPi-S. I can do it by editing the rk3308-rock-pi-s.dtb file directly, but not using an overlay file. Here's the overlay file I've tried (usbc-host.dts): /dts-v1/; / { fragment@0 { target-path = "/usb@ff400000"; __overlay__ { dr_mode = "host"; }; }; }; and /dts-v1/; /plugin/; / { fragment@0 { target-path = "/usb@ff400000"; __overlay__ { dr_mode = "host"; }; }; }; Tried using: armbian-add-overlay usbc-host.dts as well as compiling the overlay to a .dtbo and adding the line directly into armbianEnv.txt No joy either way... Also, does anyone know why some .dtbo files also have the line /plugin/; below /dts-v1/; ?
There is no official support for offline work. You can try OFFLINE_WORK=yes but no clue if it still works.
I ordered a NVMe HAT and the SSD works fine now. Thank you. Regards
R-TV Box S10 I know this is an old topic but I am trying to get this S10 box going for a old colleague which updated and now no longer starts but stays in the animation and not booting into android. Cannot find any firmware download. Thanks in advance
The latest Linux kernel brings enhanced MediaTek Platform enablement, Rockchip performance, and more. Collabora contributed to this release with no less than 22 authored contributors! View the full article
Rock 5C (Lite) - Wifi is not working or driver not found
ajvuik replied to PHYO ZIN KHANT's topic in Radxa Rock 5C
resolution: https://github.com/armbian/build/issues/8400#issuecomment-3136454158
labwc (wayland) crashes on exit
robertoj replied to robertoj's topic in Software, Applications, Userspace
Yes. Correct. Start with an armbian minimal or xcfe image that you build, with linux edge. Then install all the compilation dependencies mentioned in https://github.com/labwc/labwc/wiki and https://github.com/swaywm/sway/wiki/Debian-10-(Buster)-Installation#install-wlroots Some are mentioned as indicated for raspberry, but I installed them as well Do not install the debian bookworm libwlroots10 !! (this old wlroots interferes with the wlroots that will be installed now) Do not install libelogind-dev (it tried to modify my initramfs, it messed up the boot process, I didnt actually need it) You need a meson compiler more recent than bookworm provides. Install the backports repo: https://backports.debian.org/Instructions/ $ sudo apt install meson/bookworm-backports $ meson -v 1.7.0 Getting the labwc source code, and building: $ sudo apt install foot seatd (a minimal xterm for wayland, and a "seat manager" (may not be needed)) $ git clone https://github.com/labwc/labwc $ cd labwc $ meson setup build <-check that you have at least the GLES2 or EGL renderer If not, check that you have these dependencies: libegl-dev, libegl1-mesa-dev, libgles2-mesa-dev, libgles-dev If xwayland is desired, install xwayland from the bookworm repo After installing extra dependencies, run reconfiguration: $ meson setup --reconfigure build You will notice that the labwc build process auto-downloads and compiles a recent wlroots Finally compile (it took less than 5 minutes in my orange pi zero 3) $ meson compile -C build If it finishes compiling, check that the produced labwc works with: $ ./build/labwc -s foot If there's an error about memory allocation, add to armbianEnv.txt "extraargs=cma=256M", then reboot To install globally: $ sudo meson install -C build Test by exiting the labwc folder: cd ~ $ labwc -s foot Tomorrow, I will continue installing a display manager and greeter that works with wayland... since I am trying to avoid X11, due to my SPI LCD driver But all of you who try getting labwc in bookworm, hopefully the meson install command does something that lets lightdm see it is available as an option (I started with a minimal image) -
Banana Pi M2 Ultra boot freezing trying to scan the EMMC
赵凌 replied to goosnarrggh's topic in Allwinner sunxi
Actually, on my board, this value can be set to either 1 or 4. Setting it to 4 provides a significant boost to read/write performance, while a value of 8 fails the test. -
Thanks everyone. I went with another phone and distro (ubuntu touch) since i found a fully supported one.
As @Werner said and then just ask any specific questions you may have. Welcome to the Armbian community, @Sahil Usmani.
You are asking for help. Have you actually followed the guidance you were given, though? Have you been successful to compile an image for any target (virtual or otherwise)?
