  2. What is your plan with that camera? My latest try with raspbian (armv6) trixie based failed w.r.t. V4L2. So that is with start.elf, not start_x.elf. The latter works fine on bookworm based raspbian for camara v1. Camera v3 never worked with legacy firmware mode (start_x=1), so needs libcamera. For easy handling, the latest RPL variant of libcamera named rpicam should work, but then you'll be essentially back to RaspberryPiOS. If you have standard Debian Trixie based, all that modified libcamera is not there and more important, you will have other firmware files (bootcode.bin start.elf fixup.dat). Armbian takes the version from Ubuntu AFAIK, Debian is yet another version as is the latest from RaspberryPiOS (64-bit patched Debian or 32-bit patched and re-compiled Raspbian). The package name is raspi-frmware, check which versions there are with sudo apt list -a raspi-frmware and in addition, the 3 files themselves, I did timestamp or suffix them with sha256sum in the past on order to keep track of the various ones delivered for various OSses and images. I assume the Armbian kernel is compiled from same RPi kernel tree as RaspberryPiOS, so overlays for the v3 camera should be there and functionally the same. I currently have 1 camera v1 base RPI3B+ running, still bookworm, but I might boot it with Debian Trixie/Sid and see what mainline libcamera does. Probably then Armbian bcm2711 edge kernel, at least something that provides overlays as Debian kernels have almost none, at least not for camera sensors.
  4. Hello, friends. After a long time, I managed to extract and compile a DTB file from this console. What version of Armbian should I use to run this technological marvel? I'm attaching the DTB file and logs before booting from a flash drive; maybe it'll be useful to someone... h616.txtu-boot-sunxi-with-spl.binsun50iw9.dtb
  5. There is supposed to be a package that automatically handles building a (presumably patched) version of the kernel module for this wifi/bt chip, called `aic8800-usb-dkms`, but for some reason, a kernel upgrade doesn't auto-trigger it. During the last kernel upgrade, I was able to get it working by manually doing `sudo dpkg-reconfigure aic8800-usb-dkms`, but that also does not work since 26.5.1, as it gives Deleting module aic8800-usb-4.0+git20250410.b99ca8b6-3 completely from the DKMS tree. Loading new aic8800-usb-4.0+git20250410.b99ca8b6-3 DKMS files... Building for 6.18.2-current-qcs6490 Building initial module for 6.18.2-current-qcs6490 Error! Bad return status for module build on kernel: 6.18.2-current-qcs6490 (aarch64) Consult /var/lib/dkms/aic8800-usb/4.0+git20250410.b99ca8b6-3/build/make.log for more information. And that file basically says (a bunch is redacted for brevity): DKMS make.log for aic8800-usb-4.0+git20250410.b99ca8b6-3 for kernel 6.18.2-current-qcs6490 (aarch64) Sat Jun 20 06:36:14 PM PDT 2026 make: Entering directory '/usr/src/linux-headers-6.18.2-current-qcs6490' make[1]: Entering directory '/var/lib/dkms/aic8800-usb/4.0+git20250410.b99ca8b6-3/build/USB/driver_fw/drivers/aic8800' warning: the compiler differs from the one used to build the kernel The kernel was built by: aarch64-linux-gnu-gcc (Debian 14.2.0-19) 14.2.0 You are using: gcc (Ubuntu 13.3.0-6ubuntu2~24.04.1) 13.3.0 ... gcc: error: unrecognized command-line option ‘-fmin-function-alignment=8’; did you mean ‘-flimit-function-alignment’? gcc: error: unrecognized command-line option ‘-fmin-function-alignment=8’; did you mean ‘-flimit-function-alignment’? make[4]: *** [/usr/src/linux-headers-6.18.2-current-qcs6490/scripts/Makefile.build:287: aic_load_fw/aic_txrxif.o] Error 1 ... Apparently, the kernel is now built with gcc 14 (which matches the default in Debian Trixie images but not Ubuntu Noble images which have gcc 13). Not sure how to resolve that inconsistency. 1. Install & replace gcc 13 with gcc 14 (just installing won't work as this dkms module build doesn't respect CC env vars); not sure if this will break other things in Ubuntu 24.04 2. Rebuild the kernel with gcc 13; same issue will re-occur on the next kernel upgrade 3. Or something else Just out of curiosity, did you have to mess around with gcc versions to get it to compile (or are you using Debian Trixie images)?
  6. Yesterday
  7. I have checked .... true.... my fix 7.1 was creted for 7.1-rc1 here we have got 7.1-rc4 so not working... Problably it needs to fix dirver aic8800 as still not supported plus compilation... usb2/usb3/ethernet are working?
  8. just as a statistics/stability report: the DTB with the NPU works very well. Uptime of the device is already a week, it's running armbian and immich on it. While immich lags sometimes because the board can be weak for video processing, but in general it already processed ~20k images with OCR and face detection based on RKNN. I consider it pretty good results.
  9. I'm struggling to get the Pi Camera 3/IMX708 detected by the Zero 2W. It's an IMX708 sensor, and that is correctly showing in dmesg, but the V4L2 devices (/dev/video0, /dev/video1) for the camera are not set up. All the normal encoder devices are fine. I'm using a custom build but it's essentially minimal (and no desktop) current with trixie and no extensions, following the standard command for building an image. The dmesg log reads as follows: [ 10.719672] imx708 10-001a: camera module ID 0x0302 [ 10.719876] imx708 10-001a: ctrl(id:0x9f0902,val:0x232aaf80) is not handled [ 10.722275] imx708 10-001a: ctrl(id:0x9e0902,val:0x2b20) is not handled But I don't think this is problematic, as stock Raspbian shows precisely the same log messages, and it does correctly set up the devices. I've added the overlay and turned off (or tried to) the camera auto detection, but the imx708 messages were being logged even before I added the overlay, so I am not sure it was needed. In any event, nothing changed. Any thoughts on ways to get this up and running?
  10. never heard of that kernel before
  11. depmod: ERROR: failed to load symbols from /lib/modules/7.1.0-rc4-next-20260518-edge-rockchip64/kernel/drivers/net/wireless/aic8800/aic8800_fdrv.ko: Invalid argument
  12. sivert
    I have wifi and it worked without building or installing anything. During the first boot I was asked if I would like to use wifi, I saw the list of SSIDs, but I was unable to connect. I used nmcli and I'm connected now. dkms status outputs: bcmdhd-spacemit-sdio/101.10.591.84.37-4, 6.18.36-current-spacemit, riscv64: installed Update: It boots from eMMC
  13. sven-ola
    As an addon to @sivert: Ubuntu has dkms "3.0.11-1ubuntu13" while Debian has the newer "3.2.2-1~deb13u1". There is a difference in /etc/kernel/prerm.d/dkms: Ubuntu starts "dkms remove..." and Debian starts "dkms kernel_prerm". Both should work normally, because if you update the kernel there are two kernels: the old one and the incoming one. If you happen to have only one kernel, and thus only one compiled dkms module version, the Ubuntu "remove" completely removes anything dkms-module related. Now Armbian is offering a kernel update to the absolute same kernel version number, thus simply overwriting linux-image. Also, a "dpkg-reconfigure linux-image-current-spacemit" (with only one Ubuntu kernel version installed) will also remove the Wifi module. I am not sure how to fix this...
  14. please help me I need firmware STB MXQPRO 4K 5G ADVANCE mainbord type IK316Q-EMCP_V4.1 221024.send me FW as the same board please,i need install for android tv.and tool I'have as I flash for 8 firmware while I install program full after reboot or shutdown then start again my stb did'nt start to menu.Thank's Best Regard brothers,
  15. sven-ola
    Hey @sivert. The Ubuntu "dkms" package is borked somehow. It removes the dkms config from the file system during kernel update. The Debian "dkms" package works as expected, it removes the modules and rebuilds them on kernel update. The bcmdhd driver is of -ähh- questionable code quality and will never made it in the official kernel. For that reason, I have added an internal package named bcmdhd-spacemit-sdio-dkms that contains driver source in /usr/src and a dkms.conf which is build and installed during Armbian compile.sh. Internal means: that package is installed during build but is not installable via Armbian package repo. Using "dpkg-reconfigure bcmdhd-spacemit-sdio-dkms" is a shorter command than the previously posted "dkms add, dkms build, dkms install" sequence. If your build does not include the bcmdhd-spacemit-sdio-dkms package and therefore does not have /usr/src/bcmdhd-spacemit-sdio-101.10.591.84.37-4/ directory, then something else is wrong here. HTH // Sven-Ola
  16. sivert
    Hi @sven-ola, thanks for the reply. Before you edited it, I have seen different set of commands to build the module. I'm not using ubuntu, I tried a debian trixie without desktop. I build the image few days ago and I have no exact command but it seems to be something like: ./compile.sh BOARD=orangepirv2 BRANCH=current RELEASE=trixie KERNEL_CONFIGURE=no BUILD_MINIMAL=no BUILD_DESKTOP=no and there is no (apt) package with bcmdhd in the name, I suppose that the older version of your post was helpful, because it was about compiling from the source. I just started a new build using: ./compile.sh BOARD=orangepirv2 BRANCH=current RELEASE=trixie KERNEL_CONFIGURE=yes KERNEL_GIT=shallow BUILD_MINIMAL=no SKIP_ARMBIAN_REPO=yes KERNEL_BTF=no INSTALL_HEADERS=yes I'll report the status later.
  17. @Alex Ling Yeah, I hope it will boost the performance or compatibility even more.
  18. I don't have this device so I can only give generic advice. Set verbosity to 7 in /boot/armbianEnv.txt to get more details besides this unhandled SMC message. From what I've read over the years is that this device seems quite fragile and has lots of quirks in to get it halfway decently running. It would be not uncommon that (on first glance unrelated) upstream changes break something.
  19. Today I upgraded my Helios64, and after reboot it didn't come back. (Waited for 5 minutes or so) After connecting a serial cable (via the USB-C connector), and rebooting, I saw a normal bootloader log (as far as I can see), but no kernel log, just a repeated 'ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003)'. I rebooted again, to create a bootlog file, and I saw the same. Then suddenly, after a minute or so, I saw network activity, and my Helios64 was back. Now I have 3 questions. 1) Why didn't it boot twice, and then succeeded? 2) Why is there no kernel bootlog? 3) What is an unhandled SMC? The log ended with ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) p104^Gp104^G Armbian 26.5.1 trixie ttyS2 helios64 login: So apparently the serial port is ttyS2. dmesg gave me this info: sudo dmesg | grep tty [ 0.000000] Kernel command line: root=UUID=d03fc106-73e9-4465-89a6-b23dbd26eddd rootwait rootfstype=btrfs splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory [ 0.001587] printk: legacy console [tty1] enabled [ 1.986600] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 31, base_baud = 1500000) is a 16550A [ 1.988766] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 32, base_baud = 1500000) is a 16550A [ 1.988911] printk: legacy console [ttyS2] enabled [ 7.930510] systemd[1]: Created slice system-getty.slice - Slice /system/getty. [ 7.934926] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [ 7.938724] systemd[1]: Expecting device dev-ttyS2.device - /dev/ttyS2... [ 8.771412] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2. Is it normal that there are 2 legacy consoles enabled? minicom.cap
  20. In addition, there's a develop branch for the VK_EXT_transform_feedback extension. It is another important requirement for DXVK.
  21. I see no clear error, only something with hdmi-audio-codec, but that is somehow expected AFAIK with mainline based rockchip64 kernel. I think Xfce is X11 and others default to wayland. You can try KDE in X11. 4K is not fully mainlined AFAIK, but you need to check yourself. You can try an edge kernel, is 7.1.x based, maybe it fixes things. I have seen many such issues (RK3588 SoC) in the past, but thing are remarkably fine with 'latest Linux' (KDE6 1080p60, don't have a 4K monitor/TV).
  22. I see several time the following log line: rk-pcie fe180000.pcie: PCIe Linking... LTSSM is 0x2 I do not know what it means, but the fact that is is listed quite often is a hint I would say. There is also an earlier failure w.r.t. PCIE Usually is it power of some incompatibility of the NVME SSD in conjunction with the RK3588 based board. OrangePi5 Pro has questionable device-tree support, that is what I remember. It might be better nowadays, but I guess you will need to try an see if you can get any OS working/recognizing the SSD.
  23. sven-ola
    Hi @sivert! The downloadable Ubuntu noble image has a bcmdhd module for Wifi, so basically Wifi is working. While checking, I discovered that the bcmdhd kernel module is removed and not rebuilt during kernel update. You need to re-add it manually until I know whats wrong with that: dpkg-reconfigure bcmdhd-spacemit-sdio-dkms The bcmdhd automatic rebuild seems to work with the Debian Trixie image. Also, that "edge" Image is meant for devel. No UART, no devel so to speak 😉 HTH // Sven-Ola
  24. Hi everyone, I am developing an industrial system using a Raspberry Pi 5 (Raspberry Pi OS Bookworm). Because it is deployed in an environment with abrupt power cutoffs, I am facing an issue where the default pink and white splash screen randomly reappears during boot, overriding my configuration. Here is what I have already implemented to prevent this: Disabled Splash Screen: Added disable_splash=1 to /boot/firmware/config.txt. Read-Only File System: Enabled the native Overlay File System via raspi-config to protect the boot and root partitions from corruption. Industrial Hardware: Tested with high-end storage to rule out basic SD card degradation. The Problem: The system boots cleanly with no display text or logo for several cycles. However, after a few abrupt hardware power cutoffs, the pink and white splash screen unexpectedly pops back up during boot. Since the Overlay FS is active, config.txt should theoretically be protected from corruption or modification. My Questions: Does the Raspberry Pi 5 EEPROM/bootloader force the fallback splash screen if it detects an improper shutdown flag, completely bypassing the config.txt directive? Is there a specific EEPROM configuration parameter (via sudo rpi-eeprom-config -e) that permanently disables this splash image at the firmware level, rather than relying on the OS partition? Are there any known bugs with the Raspberry Pi 5 firmware where an unclean power-off resets certain video/boot states? Any insights into the Pi 5 bootloader behavior regarding dirty shutdowns would be greatly appreciated. Thanks!
  25. It would be super handy whilst also preconfiguring network / users / timezone ... that hostanem was in there also
  26. Last week
  27. Hi, I have X88 Pro 13 hardware revision 1.7 and tested both Armbian releases v0.6 and v0.7 from the repository. Unfortunately, neither WiFi nor USB 3.0 are working. Hardware info: Device: X88 Pro 13 (Rev 1.7) WiFi chip: AIC8800 (device ID 0x6621, SDIO) Tested images: v0.6 and v0.7 What I tried: USB 3.0: DTB already has maximum-speed = "super-speed" configured USB 3.0 controller exists (Bus 002, 5000M) But only USB 2.0 PHY available (usb2-phy only, no usb3-phy) All USB devices connect to Bus 001/003 (480M) instead of Bus 002 USB Ethernet adapter limited to 100 Mbps Result: USB 3.0 not functional (no PHY in RK3528?) WiFi (AIC8800): Firmware present in /lib/firmware/aic8800/ Drivers load: aic8800_bsp_sdio, aic8800_fdrv_sdio SDIO device detected: mmc2:0001:1, device 0x6621 Error: aicbsp_platform_power_on fails with "fail to set AIC_WIFI power state to 1" No wlan0 interface appears Tried manual GPIO reset (GPIO1_6 = pin 38) - no effect WiFi (EA6621q/SKW drivers): Applied DTB patches from user 8lall0 (GPIO remapping for seekwcn_boot) Built ea6621q DKMS drivers successfully DTB patches verified correct: gpio_chip_en = GPIO1_6 Error: Kernel segmentation fault when loading/unloading SKW modules SDIO scan timeout: "wait scan card time out" Current status: ✅ Armbian boots successfully from SD card ✅ Ethernet via USB adapter works (100 Mbps) ❌ WiFi not working (power-on failure) ❌ USB 3.0 not working (no PHY available) Questions: Is Rev 1.7 supported? Are there different GPIO configurations needed? Does RK3528 actually have USB 3.0 PHY or only controller? Any suggestions for WiFi power issue with AIC8800? Thanks for any help!
  28. sivert
    Hi, I'm new here. I tested official Orange PI image and it worked. Then I tried Armbian, the current version with 6.18.35 worked, but without WiFi. I tried the edge few times (today, yesterday) and every time there was no HDMI signal or the screen was blank - the green LED was blinking so I assumed that that the system booted. I have no UART converter to debug this now, but I noticed that few users had similar issue - I haven't found a solution. Did I missed something?
