Giuseppe93 replied to Giuseppe93's topic in NanoPi R4S
@laibsch thank you for reaching out. I apologize for the delay in responding. I want to inform you that I am actively seeking assistance from the community and am willing to contribute by developing code to address the issues I've observed on this board. However, despite my efforts to engage with the community, I have not received any responses and am not sufficiently experienced to thoroughly troubleshoot and resolve these problems on my own. Although I have some knowledge of programming languages, I am not well-versed in Linux. For example, this morning, I suggested a potential solution to the Bluetooth issue on the IRC channel but received no feedback. For the GPU, it appears that acceleration is now present, as the CPU is no longer at 100%. However, I am unable to set the resolution to 4K without encountering screen artifacts, and I can only achieve Full HD resolution. -
Next week, Collabora will be taking part in the 2025 edition X.Org Developer's Conference! Taking place in Vienna, our engineers will be presenting 6 talks and a workshop to help local students discover the embedded graphics stack! Join us! View the full article
Kernel packages comes from the same (main) repository. This won't cause you problems, if you upgrade from bookworm to trixie, but we can't guarantee for packages that comes from Debian. You might try this way: https://docs.armbian.com/User-Guide_Armbian-Config/System/#stable-distro-upgrade Note that you might need to download updated Armbian key: wget -qO - https://apt.armbian.com/armbian.key | gpg --dearmor | \ sudo tee /usr/share/keyrings/armbian.gpg > /dev/null cat << EOF | sudo tee /etc/apt/sources.list.d/armbian-config.sources > /dev/null Types: deb URIs: https://github.armbian.com/configng Suites: stable Components: main Signed-By: /usr/share/keyrings/armbian.gpg EOF
About a year ago, I installed the OpenMediaVault image for CM3588-NAS from here: https://www.armbian.com/nanopc-cm3588-nas/ The image is debian-bookworm, which has since become oldstable, while trixie is the new stable. Is it possible to upgrade the distribution and move to trixie packages, even though there are no trixie images for CM3588-NAS? In theory this seems completely feasible as my apt configurations seem completely standard with something like deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware and deb [signed-by=/usr/share/keyrings/armbian.gpg] http://apt.armbian.com bookworm main bookworm-utils bookworm-desktop If I attempt the upgrade, will I run into problems with some packages (like armbian-bsp-cli-cm3588-nas-vendor or linux-image-vendor-rk35xx) not actually existing for the target release and platform and just end up bricking my system?
Hard to tell without any logs whatsoever In general it works on x86 since a few month ago I used it to move the OS from an old NUC-like pc from sd to built-in emmc which was flawless (besides I had to get rid of Ventoy since it messes up Armbian boot).
has any progress been made toward fixing this -
RealAn replied to Hqnicolas's topic in Rockchip CPU Boxes
here is my dts for android rkr7.1 sdk 6.1.141 with everything working usb2 host usb3 otg/host hdmi ethernet 3.5mm spdif IR + wakeup wifi BT collect info for adding your remote to dts echo 1 > /sys/module/rk_pwm_remotectl/parameters/code_print m9.dts -
Hi @jock, Thanks for suggestion, led me to dig down and found your update on R29 GPIO. Since multitool hdmi was working, I used it's bash to mount emmc and add overlays=led-config7 to armbianEnv.txt. It worked!!!! Thanks a lot for all your contribution!
Install on SSD dont work
Timm0 G-Punkt replied to Timm0 G-Punkt's topic in UEFI x86 / qemu x86 / arm64
thanks, it works - with a lot of time on google 😉 can you say why the armbian-install script dont work? A bug or a bad constellation of hardware e.g.? -
login via ssh
Hi @fabiobassa Thanks for your input. I believe this board has eMMC only—the storage chip is KLMAG1JENB-B041 (image attached, RAM visible too). Multitool also confirms eMMC when attempting to burn an image. Interestingly, CPU-Z shows Rockchip 3066 logo, while ADB reports RK3229. I trusted the ADB output more, and seeing Multitool running, I believe it’s an RK3229 only. I haven’t removed the heatsink yet to verify physically. I am attaching hardware report that i could extract using adb. Any idea why Multitool runs fine but no Armbian image boots? I’ve tried 2024 Ubuntu/Debian builds and a latest self-compiled Armbian image using Armbian Build, tried both flashing to eMMC and run from SD, including using the hidden button, nothing works—LED blinks, but no HDMI output. I really want to run linux on this Again thanks for all your contribution in the thread. Edit1- Attaching Multitool Dmesg too, if it helps. rk3229_hardware_profile.txt dmesg.multitool.log
@Kiranmoy Saha I guess you have a box with NAND , not emmc You must use an old image that supports nand , typiclly kernel 4.4.xxx and follow 1st post jump start on nand Any newer kernel doesn't have nand support
I don't know and I won't spend time investigating. We cannot provide support for 3rd party images/software. Moved to off-topic since OP is not using Armbian.
Hi @jock, Thanks for the quick response. I’ve opened the box and attached the board images. On the back it says R29-MXQ-V2.1-221#. Sorry if I’m missing something—I’m a beginner. I thought rk322x-config runs only after Armbian boots. In my case, after flashing the image to eMMC and removing the SD, the box just blinks LED with no HDMI output. Only Multitool runs fine from SD. How can I run rk322x-config in this situation? Thanks again.
These drivers should not differ much from each other, right? Anyway, I found a reasonable patch to fix this behavior. I couldn't see this in the Armbian kernel, but what I need is: patch.
Not an Armbian kernel. You should ask at the place where you go the image with this kernel from.
If the armbian-install way does not work, you can also write the image directly to the ssd, either with a different computer or, since you were already successfully booting from usb, download the image again and dd it to the ssd. No need to do partitioning beforehand, just write to the raw device since the image already contains the partition table iirc.
Hello, Armbian 25.8.1 on Helios64 BookWorm with Linux 6.12.42-current-rockchip64. I have my system booting from SD with OMV7 installed and several docker containers running. Everything is OK. Now I want to boot from emmc. Used armbian-install selecting option boot from emmc - system on emmc. Formatting and copying goes Ok, but when I reboot from emmc (extracting th SD card), OMV7 presents the web frontend, but can't log in. journalctl reports errors accessing the drives, and looking on /etc/fstab, there's only the / partition mounted. Inserting and mounting the SD card in /mnt/sdcard I can see that in /mnt/sdcard/etc/fstab there's a lot of drives ready to be mounted : eclapton@helios64:~$ cat /mnt/sdcard/etc/fstab UUID=a398270d-9378-4f2c-bedd-590b08234484 / ext4 noatime,nodiratime,defaults,commit=120,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 # >>> [openmediavault] /dev/disk/by-uuid/60c885fa-6af1-462c-bfa6-dc7fe706262f /srv/dev-disk-by-uuid-60c885fa-6af1-462c-bfa6-dc7fe706262f ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/a79a14c0-3cf4-4fb9-a6c6-838571351371 /srv/dev-disk-by-uuid-a79a14c0-3cf4-4fb9-a6c6-838571351371 ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/7b71362f-4bb4-48b6-8867-37faaedef2eb /srv/dev-disk-by-uuid-7b71362f-4bb4-48b6-8867-37faaedef2eb ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/1f1ea692-d1bb-4539-a578-0647ef752770 /srv/dev-disk-by-uuid-1f1ea692-d1bb-4539-a578-0647ef752770 ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/fac27973-2eba-43b4-acd3-2c3c2b10a5d7 /srv/dev-disk-by-uuid-fac27973-2eba-43b4-acd3-2c3c2b10a5d7 ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 # <<< [openmediavault] So, I thought the actual fstab was going to be copied over, unless it has to be recreated each boot by OMV. Also, I tried to copy /srv/salt and /srv/pillar from the old system on the SD card to the new one on the emmc, as instructed un Kobol's webpage, and it helps making openmediavault-issue start, but the webpage doesn't still work. sudo systemctl status shows nginx is not able to start : eclapton@helios64:~$ sudo systemctl status nginx × nginx.service - A high performance web server and a reverse proxy server Loaded: loaded (/lib/systemd/system/nginx.service; enabled; preset: enabled) Active: failed (Result: exit-code) since Mon 2025-09-22 23:07:25 CEST; 57s ago Docs: man:nginx(8) Process: 40902 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE) CPU: 82ms sep 22 23:07:25 helios64 systemd[1]: Starting nginx.service - A high performance web server and a reverse proxy server... sep 22 23:07:25 helios64 nginx[40902]: 2025/09/22 23:07:25 [emerg] 40902#40902: open() "/var/log/nginx/error.log" failed (2: No such file or > sep 22 23:07:25 helios64 nginx[40902]: nginx: configuration file /etc/nginx/nginx.conf test failed sep 22 23:07:25 helios64 systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE sep 22 23:07:25 helios64 systemd[1]: nginx.service: Failed with result 'exit-code'. sep 22 23:07:25 helios64 systemd[1]: Failed to start nginx.service - A high performance web server and a reverse proxy server. I suspect there's somewhere I have to change /dev/mmcblk1p1 for /dev/mmcblk0p1... but where? What am I missing? Thanks for your help.
hi, i try to install the current IOT/minmal image on the intern ssd on a old thinclient. USB-Drive will ident as sda and the ssd as sdb. if i use on armbian-config the install script for install, he create two partitions (sdb1 &2 / efi & linux) but it only boot with usb drive. On the usb drive i has a BIOS boot partition, must i swaphis somehow to the ssd drive?
PR: included fd6551 https://github.com/armbian/build/pull/8666 -
nice work @Eks Ma thanks for sharing!
Open the box, read the silkscreen on the board, run rk322x-config and configure according to silkscreen name. Probably you have a r29/h20 board
h96-m9s-rk3576_defconfig rk3576-h96-m9s.dts rk3576-h96-m9s1.dts rc.local h96-m9.config rk3576-h96-m9s.dts h96-m9.tvb Compile-configuration.zip
