  2. Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 72807b6b9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases) + DXVK-stripped v1.7.1 50~60fps@1080p (no AA) box64 environment variables: FlatOut 2 Enhanced
  4. Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 72807b6b9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases) + DXVK-stripped v1.6.1 ~60fps@1080p (no AA) box64 environment variables: FlatOut Enhanced
  5. @Nick A I flashed your latest build in Dec.2025 which is named to use for Transpeed, and in addition, manually added brcmfmac4334 firmware. Wifi is working now but bluetooth. Other malfunction in previous rom version April.2025 also disappear. Thank for your time to advise me
  6. I downloaded image today using Armbian Imager, and it asked me to run something like armbian-update. I installed the system afterward, but it didn’t work.
  7. Ordered 2 more X96Qs off aliexpress. will see what versions i get. Will build images for them if they're different.
  8. @SuzSinclair Start by reading the first post of this thread, which has all the information you should need to get started.
  9. Igor
    Orange Pi CM4
    There is no way. You need a dedicated image for your hardware. https://docs.armbian.com/User-Guide_FAQ/
  10. Yesterday
  11. @Torte continued to help on his github site. The boot.img of the OEM firmware appears to set up a serial framebuffer screen and some shenanigans with the camera. I'm pausing the thread for now - need to figure out a path to reverse engineer the boot.img. Otherwise, alternative boards will need to be adapted.
  12. Coming late to the party, but I have observed a similar thing with moderm kernels on PCduino 3 nano. To know what is happeneing, have you tried connecting to UART? That gives you more info about what is going on. Now I have trouble with the OTG port. I am unable to configure it for mass storage.
  13. Test automation doesn't detect any issues https://github.com/armbian/configng/actions/runs/21465331853 and since I had freshly build Armbian Trixie on Nanopi R6S (same arch) I run install: Works like charm. Make sure to do apt update + apt upgrade before you start.
  14. Did you used most up2date armbian-config? Few days ago some critical bugs were fixed - i tested it several times and it worked ...
  15. can someone please help thanks
  16. Mine is M1, no plus, so no WiFi. I used the following 2 years ago when I got the SBC: https://fi.mirror.armbian.de/oldarchive/bananapi/archive/Armbian_23.11.1_Bananapi_bookworm_current_6.1.63.img.txt
  17. I installed pihole and unbound with Armbian's ready-made config installation, but I can't access the interface of the pihole.
  18. Okay, that explains why the SATA connection works on the BPI M3 but not on the BPI M1+. So, does anyone know of an image that supports the SATA connection on the BPI M1+ and is newer than Ubuntu 16.04, which is currently running on my BPI M1+?
  19. What is this topic about? M3 - it has Allwinner A83T and no SATA on the SoC but added via USB2 see https://banana-pi.org/en/banana-pi-sbcs/51.html M1(+) - it has Allwinner A20 and SATA on the SoC see https://banana-pi.org/en/banana-pi-sbcs/10.html Mine is the latter.
  20. @kvvvp I don't have any issues building from branch v20250306. Do you have docker installed?
  21. Hello I've now tested the image: Armbian_community_26.2.0-trunk.332_Bananapim3_forky_current_6.12.67_minimal.img on the BPI M3 and I'm happy... SATA works really well. Maybe this will help.
  22. @Nguyễn Lân The HK6334Q Wi-Fi/BT chip uses the brcmfmac4334 firmware. If your Wi-Fi chip is detected by the kernel, the dmesg log will show the names of the .bin and .txt files it is looking for.
  23. Just to note some more: I use none of those images, instead is it in-place upgraded Armbian, originally: root@banlipi:/tmp# grep VERSION /etc/armbian-image-release VERSION=23.11.1 Now Trixie: root@banlipi:/tmp# cat /etc/os-release PRETTY_NAME="Armbian 25.8.1 trixie" NAME="Debian GNU/Linux" VERSION_ID="13" VERSION="13 (trixie)" VERSION_CODENAME=trixie DEBIAN_VERSION_FULL=13.0 ID=debian HOME_URL="https://www.armbian.com/" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian 25.8.1 trixie" I log some stuff to terminal in my backup script; I see: U-Boot SPL 2024.01-armbian-2024.01-S866c-P7738-Hb9d3-Vf23c-Bb703-R448a (Jun 21 2025 - 02:53:13 +0000) Maybe also good to know, I use extlinux on real HW, grub on KVM root@banlipi:/boot/efi/extlinux# cat extlinux.conf menu title Select the kernel variant DEFAULT default TIMEOUT 80 LABEL default KERNEL zImage INITRD uInitrd FDT sun7i-a20-bananapi.dtb FDTOVERLAYS sun7i-a20-analog-codec.dtbo APPEND root=LABEL=armbianrfs rootwait rw earlyprintk console=ttyS0,115200 But I am not sure how valid the release info is, will need to look at lists files etc and also run update to it is latest Debian 13.3 I think. I just ran apt update && apt full-upgrade and now it is 'latest debian trixie' but I use apt pinning and I see it is too strict and also an error, so os-release not changed It is essentially Debian Trixie armhf up to date with manually written U-Boot and manually copied sunxi kernel.
  24. I have this SBC and it is still nice one as it includes LiPo charging/operation and SATA. I changed Armbian OS drastically, such that the raw SD-card as blockdevice/image also runs as KVM on my ROCK3A or RPi4 for example as standard UEFI machine. I have not tested that yet, but done several similar for NanoPi-NEO and some RPi3. Last thing done was use kernel 6.18 as default. Had not tested/connected a SATA recently, so good time to do it now; It works, see below: root@banlipi:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 119.2G 0 disk ├─sda1 8:1 0 512M 0 part └─sda2 8:2 0 118.7G 0 part mmcblk0 179:0 0 59.6G 0 disk ├─mmcblk0p1 179:1 0 256M 0 part /boot/efi ├─mmcblk0p2 179:2 0 6G 0 part /.snapshots │ /local/fsroot │ / ├─mmcblk0p3 179:3 0 1G 0 part [SWAP] └─mmcblk0p4 179:4 0 52.4G 0 part /local/sdata root@banlipi:~# dmesg | grep ata [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] printk: log buffer data + meta data: 131072 + 409600 = 540672 bytes [ 0.045731] Memory: 859656K/1015868K available (11264K kernel code, 1761K rwdata, 9604K rodata, 1024K init, 377K bss, 53644K reserved, 98304K cma-r eserved, 229436K highmem) [ 0.742930] libata version 3.00 loaded. [ 1.268996] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator [ 1.269351] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator [ 1.269470] ahci-sunxi 1c18000.sata: supply target not found, using dummy regulator [ 1.311601] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP [ 1.311632] ahci-sunxi 1c18000.sata: forcing PORTS_IMPL to 0x1 [ 1.311727] ahci-sunxi 1c18000.sata: AHCI vers 0001.0100, 32 command slots, 3 Gbps, platform mode [ 1.311748] ahci-sunxi 1c18000.sata: 1/1 ports implemented (port mask 0x1) [ 1.311762] ahci-sunxi 1c18000.sata: flags: ncq sntf pm led clo only pio slum part ccc [ 1.316206] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 34 lpm-pol 0 [ 1.630949] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 1.632905] ata1.00: ATA-9: SanDisk SDSSDP128G, 1.0.0, max UDMA/133 [ 1.632934] ata1.00: 250069680 sectors, multi 1: LBA48 NCQ (depth 32) [ 1.633567] ata1.00: configured for UDMA/133 [ 11.515496] systemd[1]: Expecting device dev-disk-by\x2dlabel-sdata.device - /dev/disk/by-label/sdata... [ 22.764093] BTRFS: device label sdata devid 1 transid 36 /dev/mmcblk0p4 (179:4) scanned by mount (378) [ 23.002238] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. root@banlipi:~# uname -a Linux banlipi 6.18.2-edge-sunxi #1 SMP Thu Dec 18 13:03:43 UTC 2025 armv7l GNU/Linux root@banlipi:~# cd /tmp root@banlipi:/tmp# mkdir 1 2 root@banlipi:/tmp# mount /dev/sda1 1 root@banlipi:/tmp# mount /dev/sda2 2 -osubvolid=0 root@banlipi:/tmp# ddrescue -f /dev/sda /dev/null GNU ddrescue 1.29 Press Ctrl-C to interrupt ipos: 1731 MB, non-trimmed: 0 B, current rate: 75366 kB/s opos: 1731 MB, non-scraped: 0 B, average rate: 133 MB/s non-tried: 126304 MB, bad-sector: 0 B, error rate: 0 B/s rescued: 1731 MB, bad areas: 0, run time: 12s pct rescued: 1.35%, read errors: 0, remaining time: 15m time since last successful read: n/a Copying non-tried blocks... Pass 1 (forwards)^C Interrupted by user So I can browse the filesystems on the SSD, seems I had used it for conversion of RPi Trixie Ext4 to Btrfs. Raw speed is fine I see. So I still can use it also with large 3.5inch HDDs, that is what I prepared the surrounding 12V powersupply for.
  25. Probably, my guess, issue with a boot loader - fail to / disabled by mistake power SATA port? We don't have anyone actively maintaining this kind of (10+years) hardware anymore. Support is "community / upstream" maintained "as is". But this forum / community can provide assistance to fix this. I gave a tip - where I think is the problem. Not working feature on particular hardware is not Armbian problem. This is custom hardware world and our work is tooling https://github.com/armbian/build and best effort hardware maintenance on this principle https://docs.armbian.com/User-Guide_Board-Support-Rules/ If we try to fix everything, everyone would be long burned out ...
  26. OK so how can I help to fix this issue?
  27. fdisk -l Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/mmcblk0: 14.84 GiB, 15931539456 bytes, 31116288 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x4c58faaa Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 8192 30801920 30793729 14.7G 83 Linux Disk /dev/zram0: 483.1 MiB, 506564608 bytes, 123673 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/zram1: 50 MiB, 52428800 bytes, 12800 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Out of desperation, I plugged in an SSD via USB adapter, and it is recognized as: /dev/sda: Detected One might think the SATA connection is defective, but when I boot with the Ubuntu 16.04 image without changing anything, the SATA SSD is recognized! So the SATA connection on the BPI M1+ works, and so does the SSD. It's definitely the Armbian image that's the problem, but where exactly is it?
  28. Userspace has nothing to do with hardware features. I don't know what is the case for A20, but for many others, OTG functionality is driven with overlays. If there are no overlays, you need to edit device tree and change its role. If that doesn't help, it is more complex problem. More complex, perhaps days / weeks to debug and fix. Most of (Armbian) kernel developers are long gone from this 10+ years old platform and users can't help. Also look into previous builds. Finding out when this broke is half of the solution https://fi.mirror.armbian.de/oldarchive/ or by finding a kernel that works https://docs.armbian.com/User-Guide_Armbian-Config/System/#alternative-kernels With any userspace (trixie/noble/jammy ...) Probably all A10 and A20 boards share this problem.
