  2. Hi, without owning this board, chatgpt is pointing out to an initialisation issue of the bluetooth system caused by the GPIO pin not being correctly handled at boot. [ 6.024062] WCN: marlin chip en dummy pull up -- need manually set GPIO The correct solution would be to handle the init in the dtb file, but you can try the following systemd initialisation as a workaround to see if it works. Create (as root) the following service file /etc/systemd/system/bt-gpio.service with the contents: [Unit] Description=Enable GPIO for Bluetooth chip Before=bluetooth.service [Service] Type=oneshot ExecStart=/bin/sh -c 'echo 225 > /sys/class/gpio/export || true; echo out > /sys/class/gpio/gpio225/direction; echo 1 > /sys/class/gpio/gpio225/value' [Install] WantedBy=multi-user.target Then enable it (as root): systemctl daemon-reexec systemctl daemon-reload systemctl enable bt-gpio.service Reboot and check if the bluetooth starts correctly. Post the boot log if it does not.
  4. direct boot from nvme isn't possible. Boot loader (u-boot to say) must be present on SPI, eMMC or microSD.
  5. try: sudo gpg --keyserver keyserver.ubuntu.com --recv-keys 93D6889F9F0E78D5 sudo gpg --export 93D6889F9F0E78D5 | sudo tee /etc/apt/trusted.gpg.d/armbian-configng.gpg > /dev/null
  6. sudo armbian-config
  7. Put a multi meter on the PSU you are using to power the pi a flakey PSU can cause strange intermittent issues same for router.
  8. Related issue: https://github.com/armbian/build/issues/8261 Currently resolved for the beta repository. Now it's possible to switch to beta, update base-files and switch back to `apt.armbian.com`. Fixing for stable marked as "todo".
  9. Yesterday
  10. Ok that is a promising start at least. Are the 'BUG: bad page state messages' every boot or occasionally? The route cause will probably be difficult to find, possibly a deep route kernel or hardware issue. I tend to find that sometimes I will get the bad page state messages and then on another occassion get no kind of faults. You shouldnt need to enter any credientials on first boot, that only applies to setup over network connection. Once you have been able to login and if wireless works then you can install memtester to see if that picks up an errors. not a problem, looking forward to hearing your progress Ryzer
  11. Are you trying to boot from spi with system on nvme? or trying to boot another system on a sd card?
  12. Hi pcduino2user, Nice to see a fellow Pcduino user, I guess not many people interested in over a decade old hardware at this point. I try my best, I am by no means an expert, most of my current changes are just corrections to the device tree. Anyway, there appear to breaking changes in kernel 6.12 which breaks hdmi output. The intial patches for adding the hdmi display nodes are in my pcduino2-and-3-improvements branch however they are for much older kernel versions so need to be re-created, something I plan to do within the coming week. Additional the display driver needs a minor tweak. I currently have a userpatch derived from: https://patchwork.kernel.org/project/linux-arm-kernel/patch/20241130-hdmi-mode-valid-v5-10-742644ec3b1f@linaro.org/ Thanks Ryzer
  13. Hi, Did you also make sure that you copy any ata options from your old installation? e.g. For my own Helios64 I have had similar issues and those were resolved by limiting the SATA link speed to 3Gbps: extraargs=libata.force=1:3.0G,2:3.0G,3:3.0G,4:3.0G The internets say that those ATA errors are caused by the the disk not responding to a controller request in time. Mostly it is advised to replace the [S]ATA cables and to make sure contacts are clean and no crosstalk/EMI can occur. A reduction in the ATA link speed also helps, which in my case sure did. Do keep in mind, that if you have regular spinning drives, the most throughput you will get out of your drives will be around 100~140 MB/s, which translates to roughly 1.5 Gb/s. So decreasing the linkspeed will not cause any slowdown, your drive's throughput will remain the performance bottleneck. For my Helios64, I have had some issues with the left-most (or top) disk, as the connectors did not protrude well enough, or had a little too much flex which caused the left-most disk from sometimes not being detected at all. Reseating and pressing on the connector from the rear helped that issue. As the internets mention these errors are the ATA driver complaining about not hearing from the drive(s) in time (or at all), you might want to experiment with a lower CPU frequency, or perhaps not using any of the dynamic freq scaling governors, but sticking to the powersave or performance one. Groetjes,
  14. Hi @zital debian, Some things you could also try: Replace cables - again. I've had similar issues where the NIC of SBC would drop to 10Mbe half duplex, persistently after using different cables. In the end it was all the cables i had lying around that were not of good quality. Replaced the cat "5e" ones with cat 6 and the issues went away. Disable autoneg on your NIC or only advertise 1Gbe. Try a different switch port, switch or router. Check if you have some of those green options on your router/switch enabled, i think it's called EEE. I had some issues with and my Orangepi zero SBCs in combination with those bad cat "5e" ethernet cables. Groetjes,
  15. Servus! I'm running an "old" Helios64, still with debian buster and kernel 5.9.14-rockchip64 ... pretty much the same installation, as I had setup the Helios64 years ago. So far it is running great, with no real issues. I have ZFS running on it, with 3 disks. Today I decided to upgrade to something new - and installed Armbian 25.5.1 / Nobel - with kernel "6.12.32-current-rockchip64". Helios64 boots up and everything seems to work fine. I was able to import my ZFS pool and it was accessible - however, when I do heavy i/o, e.g. md5sum on a big file, I get a lot of these errors: Jun 08 20:06:36 helios64 kernel: ata2.00: failed command: READ FPDMA QUEUED Jun 08 20:06:36 helios64 kernel: ata2.00: cmd 60/80:90:40:3a:2f/00:00:06:00:00/40 tag 18 ncq dma 65536 in res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x12 (ATA bus error) Jun 08 20:06:36 helios64 kernel: ata2.00: status: { DRDY ERR } Jun 08 20:06:36 helios64 kernel: ata2.00: error: { ICRC ABRT } Jun 08 20:06:36 helios64 kernel: ata2: hard resetting link Jun 08 20:06:36 helios64 kernel: ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 320) Jun 08 20:06:36 helios64 kernel: ata2.00: configured for UDMA/133 Jun 08 20:06:36 helios64 kernel: ata2: EH complete Jun 08 20:07:04 helios64 kernel: ata2: limiting SATA link speed to 1.5 Gbps Jun 08 20:07:04 helios64 kernel: ata2.00: exception Emask 0x2 SAct 0x202003 SErr 0x400 action 0x6 Jun 08 20:07:04 helios64 kernel: ata2.00: irq_stat 0x08000000 Jun 08 20:07:04 helios64 kernel: ata2: SError: { Proto } Jun 08 20:07:04 helios64 kernel: ata2.00: failed command: READ FPDMA QUEUED Jun 08 20:07:04 helios64 kernel: ata2.00: cmd 60/00:00:98:55:7f/08:00:07:00:00/40 tag 0 ncq dma 1048576 in res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x12 (ATA bus error) Jun 08 20:07:04 helios64 kernel: ata2.00: status: { DRDY ERR } Jun 08 20:07:04 helios64 kernel: ata2.00: error: { ICRC ABRT } This is for ata2, but this happens also for ata3 and ata4 - so all three disk of my ZFS. Interesting so, ZFS itself does not detect any read / write errors - but if you e.g. copy files, you see a noticeable drop in throughput, disk access hangs for a moment. I have installed 25.5.1 on SD card, so I was able to switch back to my original system ... and voilá, no such errors anymore. So it seems to be related to 25.5.1. Does anyone know this problem? Is there a solution or anything I'm missing? Thanks Alex
  16. I have orange pi 3b, that has one NVME ssd. This boots hybrid from SD card and system is on NVME. I tried to make boot it without SSD but no luck as of now. my nvme is fast and supports 5GBS speed. /dev/nvme0n1 /dev/ng0n1 AA250310076 FIKWOT FN955 2TB 0x1 2.00 TB / 2.00 TB 512 B + 0 B X0430P00 Its avg benchmark speed is 415mbps which is very slower than avg. sudo lspci -vv | grep -i "LnkSta" LnkSta: Speed 5GT/s, Width x1 LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1- LnkSta: Speed 5GT/s (downgraded), Width x1 (downgraded) LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1- Not sure, if this is due to power management, or due to hybrid approach while booting or some problem with board itself. can some one help me ?
  17. now is at 1000 again, I have bought a switch to check if is about router... When it will arrive I will post again with results, thank you all zital@s-400 /tmp> rsync -avzhP --delete /tmp/a/ pi@opi5:/tmp/a/ sending incremental file list deleting D01.mp4 ./ D04-01.mp4 1,24G 100% 111,51MB/s 0:00:10 (xfr#1, to-chk=0/2) sent 1,23G bytes received 49 bytes 98,55M bytes/sec total size is 1,24G speedup is 1,00
  18. @usual user But the filesystem was never currupt and the issue was only with the boot partition which is not a journaling filesystem. The Odruids is also known to work reliably without UPS.
  19. Mmmmm no, comes back to 100, wtf [ 12.809646] systemd-journald[666]: Received client request to relinquish /var/log/journal/7e1079e7649a45d2ab1ccbdeff6468de access. [ 16.329124] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 1Gbps/Full - flow control rx/tx [ 16.329146] IPv6: ADDRCONF(NETDEV_CHANGE): end1: link becomes ready [ 16.674304] platform mtd_vendor_storage: deferred probe pending [ 18.300250] loop6: detected capacity change from 0 to 8 [ 18.667832] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2 [ 830.033971] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Down [ 849.288915] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx
  20. OK, I had the fan disconnected, I have connected the fan into gpio pins and reboot system, now is 1000Mb/s, and maybe is an GND issue as eselarm commented, thank you guys
  21. Description Update odroidxu4-current kernel to 6.6.93. How Has This Been Tested? [x] Reboot of my Odroid HC1 Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
  22. Cannot reproduce root@build:~# dmesg|grep 'rk_gmac\|model' [ 3.044416] Machine model: Orange Pi 5 [ 5.539395] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 5.539572] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 5.539584] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 5.539604] rk_gmac-dwmac fe1c0000.ethernet: supply phy not found, using dummy regulator [ 5.539686] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 5.539702] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 5.539715] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 5.539727] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 5.539745] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 5.539760] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 5.539774] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 5.539796] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 5.540029] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 5.540156] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 5.540176] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 5.540189] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 5.540202] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 5.540215] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 5.540227] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 5.540271] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 5.540283] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 5.540297] rk_gmac-dwmac fe1c0000.ethernet: Enabled L3L4 Flow TC (entries=2) [ 5.540310] rk_gmac-dwmac fe1c0000.ethernet: Enabled RFS Flow TC (entries=10) [ 5.540323] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 5.540335] rk_gmac-dwmac fe1c0000.ethernet: Using 32/32 bits DMA host/device width [ 12.372333] rk_gmac-dwmac fe1c0000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 12.376013] rk_gmac-dwmac fe1c0000.ethernet eth0: PHY [stmmac-1:01] driver [YT8531 Gigabit Ethernet] (irq=POLL) [ 12.376537] rk_gmac-dwmac fe1c0000.ethernet eth0: No Safety Features support found [ 12.376546] rk_gmac-dwmac fe1c0000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported [ 12.376657] rk_gmac-dwmac fe1c0000.ethernet eth0: registered PTP clock [ 12.376832] rk_gmac-dwmac fe1c0000.ethernet eth0: FPE workqueue start [ 12.376837] rk_gmac-dwmac fe1c0000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 16.441134] rk_gmac-dwmac fe1c0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ 496.767911] rk_gmac-dwmac fe1c0000.ethernet eth0: Link is Down [13273.107988] rk_gmac-dwmac fe1c0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx root@build:~# uname -a Linux build 6.1.115-vendor-rk35xx #1 SMP Tue Apr 15 18:23:00 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux
  23. I have had various sorts of issues like this since there is twistedpair ethernet RJ45 (and more troubles with coax BNC). 'PC' is radically different hardware/chips than OPi5, in the end is is analog signals and simbols and channal coding, many leavels were 1 device can do or make slightly different decisions then another one. You only know if you debug kernel and also have dedicated equipment for testing ethernet. But a simple slight less conducting RJ45 pin connector 4 or 5 or 7 or 8 can already make the difference. Can be corrosion or so or not enough pressure in s certain (up or down) direction. Or RF interference difference between PC and OPi5 situation. Or GND connected or not. Or metal surroundings or not. I have made most Armbian installations multi-kernel bootable/selectable (serial console cable en extlinux.conf or GRUB when UEFI) so I would first do a temporary test boot with latest greatest mainline based kernel. It might also mean other U-Boot, I do not know details of OPi5, but my ROCK3A cannot work correct with every U-Boot an kernel combination (only Radxa U-Boot 2017 and Armbian vendor kernel 6.1.115). My ROCK5B is more flexable although if I want to use vendor 6.1.115 I also have to change setting in EDK2-UEFI v1.1 SPI bootloader that I am currently using/testing. And ROCK5B does not use on-chip GMAC ethernet, is has external RTL 2.5GbE chip. Maybe easiest to temporary boot with some fresh downloaded Armbian image on test SD-card and make sure also U-Boot is started from there.
  24. Here is the ethernet part: [ 23.232550] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx [ 23.232577] IPv6: ADDRCONF(NETDEV_CHANGE): end1: link becomes ready [ 109.364852] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Down [ 131.659974] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 1Gbps/Full - flow control rx/tx [ 132.671410] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Down [ 137.739538] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx Michael Robinson but why with the same cable that is using 1000 in another pc in the same port?
  25. I come back to kernel 6.1.115-vendor-rk35xx due to ffmpeg hardware encoding to use owncast, anyway here is the output of the armbianmonitor: ### lsusb: Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M ### lspci: 0004:40:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3588 (rev 01) 0004:41:00.0 Non-Volatile memory controller: Silicon Motion, Inc. SM2263EN/SM2263XT SSD Controller (rev 03) ### Userland generated with Armbian Build Framework: PRETTY_NAME="Armbian 25.5.1 bookworm" ARMBIAN_PRETTY_NAME="Armbian 25.5.1 bookworm" ### Installed packages: ii armbian-bsp-cli-orangepi5-legacy 24.5.1 arm64 Armbian CLI BSP for board 'orangepi5' branch 'legacy' ii armbian-config 25.8.0-trunk.100.0603.081117 all Armbian config: The Next Generation ii armbian-firmware 25.5.1 all Armbian - Linux firmware ii armbian-plymouth-theme 25.5.1 all boot animation, logger and I/O multiplexer - Armbian theme ii armbian-zsh 25.5.1 all Armbian improved ZShell (oh-my-zsh...) ii ladspa-sdk 1.17-1+b1 arm64 sample tools for linux-audio-dev plugin architecture ii linux-base 4.9 all Linux image base package ii linux-dtb-vendor-rk35xx 25.5.1 arm64 Armbian Linux vendor DTBs in /boot/dtb-6.1.115-vendor-rk35xx ii linux-headers-vendor-rk35xx 25.5.1 arm64 Armbian Linux vendor headers 6.1.115-vendor-rk35xx ii linux-image-vendor-rk35xx 25.5.1 arm64 Armbian Linux vendor kernel image 6.1.115-vendor-rk35xx ii linux-libc-dev:arm64 23.02.2 arm64 Armbian Linux support headers for userspace development ii linux-u-boot-orangepi5-legacy 24.5.1 arm64 Das U-Boot for orangepi5 ### Loaded modules: Module Size Used by xt_multiport 16384 3 xt_nat 16384 3 xt_addrtype 16384 2 xt_mark 16384 1 xt_conntrack 16384 7 veth 28672 0 bridge 245760 0 stp 16384 1 bridge llc 16384 2 bridge,stp tun 45056 2 overlay 118784 0 nft_chain_nat 16384 7 zram 28672 3 zsmalloc 20480 1 zram xt_MASQUERADE 16384 10 nf_nat 36864 3 xt_nat,nft_chain_nat,xt_MASQUERADE xt_comment 16384 30 nft_compat 20480 56 binfmt_misc 20480 1 squashfs 53248 6 rk805_pwrkey 16384 0 panfrost 61440 0 nvmem_rockchip_otp 20480 0 drm_shmem_helper 20480 1 panfrost gpu_sched 32768 1 panfrost rockchip_cpuinfo 16384 1 nvmem_rockchip_otp uio_pdrv_genirq 16384 0 uio 20480 1 uio_pdrv_genirq fuse 114688 1 dm_mod 110592 0 ipv6 458752 155 bridge ext4 684032 2 mbcache 16384 1 ext4 jbd2 118784 1 ext4 adc_keys 16384 0 ### Current system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 09:05:31 1800/2256 MHz 0.06 11% 3% 5% 0% 0% 1% 37.9 °C 0/7 09:05:32 1800/2256 MHz 0.06 2% 1% 0% 0% 0% 0% 37.9 °C 0/7 09:05:32 1800/2256 MHz 0.06 2% 1% 0% 0% 0% 0% 37.9 °C 0/7 09:05:32 1800/2256 MHz 0.06 1% 1% 0% 0% 0% 0% 37.9 °C 0/7 09:05:33 1800/2256 MHz 0.06 1% 1% 0% 0% 0% 0% 37.9 °C 0/7 09:05:36 1800/2256 MHz 0.77 11% 3% 5% 0% 0% 1% 51.8 °C 0/7 09:05:36 1800/2256 MHz 0.77 10% 1% 9% 0% 0% 0% 45.3 °C 0/7 09:05:37 1800/2256 MHz 0.77 1% 1% 0% 0% 0% 0% 44.4 °C 0/7 09:05:37 1800/2256 MHz 0.77 1% 0% 0% 0% 0% 0% 43.5 °C 0/7 09:05:37 1800/2256 MHz 0.77 2% 1% 0% 0% 0% 0% 42.5 °C 0/7 ### resolv.conf -rw-r--r-- 1 root root 53 Jun 7 21:39 /etc/resolv.conf # Generated by NetworkManager nameserver XXX.XXX.2.1 ### Current sysinfo: Linux 6.1.115-vendor-rk35xx (opi5) 06/08/2025 _aarch64_ (8 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 5.82 0.00 5.12 0.56 0.00 88.51 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd ram0 0.00 0.00 0.00 0.00 0 0 0 mtdblock0 0.00 0.01 0.00 0.00 336 0 0 nvme0n1 104.12 8169.92 12048.34 3447.60 337477214 497684183 142411156 nvme0n1p1 0.01 0.15 0.00 0.00 5993 7 0 nvme0n1p2 104.11 8169.69 12048.34 3447.60 337467545 497684176 142411156 zram0 0.07 0.07 0.19 0.00 3036 7980 0 zram1 0.13 0.14 2.89 0.00 5704 119464 0 zram2 0.00 0.00 0.00 0.00 0 0 0 --procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- ----------cpu---------- r b swpd free buff cache si so bi bo in cs us sy id wa st gu 1 0 7936 167084 115648 6250428 0 0 1057 1558 1734 1774 6 5 89 1 0 0 total used free shared buff/cache available Mem: 7.7Gi 1.6Gi 162Mi 40Mi 6.1Gi 6.1Gi Swap: 7.7Gi 7.8Mi 7.7Gi NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 125M 70.1M 15.5M 16.7M 8 /var/log /dev/zram0 lzo-rle 7.7G 6.5M 1.8M 2.2M 8 [SWAP] 09:05:38 up 11:28, 1 user, load average: 0.77, 0.20, 0.22 [ 9.075824] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop... [ 9.078049] systemd[1]: Starting nftables.service - nftables... [ 9.078526] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 9.085106] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com [ 9.089823] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... [ 9.091790] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems... [ 9.093942] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 9.097421] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System. [ 9.097922] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 9.098297] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 9.098661] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System. [ 9.099358] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ 9.099866] fuse: init (API version 7.38) [ 9.100218] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 9.100573] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ 9.101121] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [ 9.101397] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [ 9.102091] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 9.102330] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 9.102817] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 9.103045] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 9.103506] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 9.103743] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [ 9.104217] systemd[1]: modprobe@loop.service: Deactivated successfully. [ 9.104445] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop. [ 9.107064] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 9.109345] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System... [ 9.109595] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met. [ 9.115063] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ 9.116800] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock. [ 9.117512] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [ 9.128165] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [ 9.134222] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none. [ 9.168285] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 9.176241] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems. [ 9.176905] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 9.179577] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed... [ 9.182201] systemd[1]: Starting systemd-sysusers.service - Create System Users... [ 9.213209] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables. [ 9.221111] systemd[1]: Finished nftables.service - nftables. [ 9.222696] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed. [ 9.223018] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes). [ 9.229562] systemd[1]: Finished systemd-sysusers.service - Create System Users. [ 9.258399] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev... [ 9.260467] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout. [ 9.299064] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev. [ 9.300412] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems. [ 9.307285] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files... [ 9.347589] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ 9.354797] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown... [ 9.402035] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files. [ 9.434047] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen... [ 9.445685] systemd[1]: Found device dev-ttyFIQ0.device - /dev/ttyFIQ0. [ 9.500738] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen. [ 9.501527] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid). [ 9.501872] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch. [ 9.502038] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes. [ 9.502153] systemd[1]: Reached target paths.target - Path Units. [ 9.585344] rkcifhw fdce0000.rkcif: Adding to iommu group 17 [ 9.593135] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 9.600571] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 9.600579] rockchip-cpuinfo cpuinfo: Serial : 5503dfd10dbecd6b [ 9.643578] systemd[1]: Found device dev-disk-by-uuid-F25A-330A.device - NVME SSD 1TB armbi_boot. [ 9.643936] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid). [ 9.667351] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod... [ 9.671525] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 9.674406] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop... [ 9.674533] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 9.675803] systemd[1]: Starting systemd-fsck@dev-disk-by-uuid-F25A-330A.service - File System Check on /dev/disk/by-uuid/F25A-330A... [ 9.676384] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [ 9.676585] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [ 9.676970] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 9.677152] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 9.677317] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 9.681523] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget. [ 9.684343] systemd[1]: modprobe@loop.service: Deactivated successfully. [ 9.684544] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop. [ 9.686153] systemd[1]: Started systemd-fsckd.service - File System Check Daemon to report status. [ 9.686542] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met. [ 9.702655] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 9.714279] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.6.auto/input/input6 [ 9.764569] systemd[1]: Finished systemd-fsck@dev-disk-by-uuid-F25A-330A.service - File System Check on /dev/disk/by-uuid/F25A-330A. [ 9.810208] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown. [ 10.141111] systemd[1]: Mounting boot.mount - /boot... [ 10.147298] systemd[1]: Mounting snap-core20-2573.mount - Mount unit for core20, revision 2573... [ 10.152392] systemd[1]: Mounting snap-core20-2585.mount - Mount unit for core20, revision 2585... [ 10.165271] systemd[1]: Mounting snap-core24-892.mount - Mount unit for core24, revision 892... [ 10.165357] loop0: detected capacity change from 0 to 121968 [ 10.168718] systemd[1]: Mounting snap-core24-992.mount - Mount unit for core24, revision 992... [ 10.171084] loop1: detected capacity change from 0 to 121960 [ 10.173917] systemd[1]: Mounting snap-snapd-23772.mount - Mount unit for snapd, revision 23772... [ 10.176526] systemd[1]: Mounting snap-snapd-24509.mount - Mount unit for snapd, revision 24509... [ 10.176553] loop2: detected capacity change from 0 to 126584 [ 10.177160] loop3: detected capacity change from 0 to 79224 [ 10.177293] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 10.177790] loop4: detected capacity change from 0 to 126592 [ 10.179726] systemd[1]: Mounting tmp.mount - /tmp... [ 10.184540] loop5: detected capacity change from 0 to 90640 [ 10.191049] systemd[1]: Mounted boot.mount - /boot. [ 10.191632] systemd[1]: Mounted snap-core20-2573.mount - Mount unit for core20, revision 2573. [ 10.192108] systemd[1]: Mounted snap-core20-2585.mount - Mount unit for core20, revision 2585. [ 10.192547] systemd[1]: Mounted snap-core24-892.mount - Mount unit for core24, revision 892. [ 10.193017] systemd[1]: Mounted snap-core24-992.mount - Mount unit for core24, revision 992. [ 10.193468] systemd[1]: Mounted snap-snapd-23772.mount - Mount unit for snapd, revision 23772. [ 10.193964] systemd[1]: Mounted snap-snapd-24509.mount - Mount unit for snapd, revision 24509. [ 10.194401] systemd[1]: Mounted tmp.mount - /tmp. [ 10.195131] systemd[1]: Reached target local-fs.target - Local File Systems. [ 10.197907] systemd[1]: Starting apparmor.service - Load AppArmor profiles... [ 10.200342] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config... [ 10.202741] systemd[1]: Starting console-setup.service - Set console font and keymap... [ 10.205177] systemd[1]: Starting netfilter-persistent.service - netfilter persistent configuration... [ 10.207269] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data... [ 10.211778] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats... [ 10.211989] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 10.218544] systemd[1]: Finished console-setup.service - Set console font and keymap. [ 10.221537] systemd[1]: Received SIGRTMIN+20 from PID 307 (plymouthd). [ 10.226820] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data. [ 10.235871] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 534 (systemd-binfmt) [ 10.240431] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System... [ 10.289849] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System. [ 10.301282] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats. [ 10.340585] audit: type=1400 audit(1749325038.903:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=554 comm="apparmor_parser" [ 10.343421] audit: type=1400 audit(1749325038.906:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=556 comm="apparmor_parser" [ 10.343517] audit: type=1400 audit(1749325038.906:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=551 comm="apparmor_parser" [ 10.343532] audit: type=1400 audit(1749325038.906:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=551 comm="apparmor_parser" [ 10.343836] audit: type=1400 audit(1749325038.910:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=550 comm="apparmor_parser" [ 10.344671] audit: type=1400 audit(1749325038.910:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=552 comm="apparmor_parser" [ 10.344685] audit: type=1400 audit(1749325038.910:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=552 comm="apparmor_parser" [ 10.344696] audit: type=1400 audit(1749325038.910:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=552 comm="apparmor_parser" [ 10.345786] audit: type=1400 audit(1749325038.910:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oosplash" pid=553 comm="apparmor_parser" [ 10.352229] audit: type=1400 audit(1749325038.916:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=560 comm="apparmor_parser" [ 10.443659] zram: Added device: zram0 [ 10.444075] zram: Added device: zram1 [ 10.444571] zram: Added device: zram2 [ 10.507340] zram0: detected capacity change from 0 to 16237424 [ 10.526394] systemd[1]: Finished apparmor.service - Load AppArmor profiles. [ 10.533104] Adding 8118708k swap on /dev/zram0. Priority:5 extents:1 across:8118708k SSFS [ 10.547534] systemd[1]: Starting snapd.apparmor.service - Load AppArmor profiles managed internally by snapd... [ 10.583912] systemd[1]: Finished netfilter-persistent.service - netfilter persistent configuration. [ 10.683483] zram1: detected capacity change from 0 to 256000 [ 10.729789] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config. [ 10.775016] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging... [ 10.833194] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none. [ 11.171634] systemd[1]: Finished snapd.apparmor.service - Load AppArmor profiles managed internally by snapd. [ 14.129835] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging. [ 14.168541] systemd[1]: Starting systemd-journald.service - Journal Service... [ 14.339576] systemd[1]: Started systemd-journald.service - Journal Service. [ 14.397661] systemd-journald[678]: Received client request to flush runtime journal. [ 15.130594] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller [ 15.130711] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 7 [ 15.130789] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0002008002010010 [ 15.130813] xhci-hcd xhci-hcd.11.auto: irq 122, io mem 0xfc000000 [ 15.130872] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller [ 15.130877] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 8 [ 15.130881] xhci-hcd xhci-hcd.11.auto: Host supports USB 3.0 SuperSpeed [ 15.130947] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 15.130951] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 15.130954] usb usb7: Product: xHCI Host Controller [ 15.130957] usb usb7: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 15.130959] usb usb7: SerialNumber: xhci-hcd.11.auto [ 15.135848] hub 7-0:1.0: USB hub found [ 15.135867] hub 7-0:1.0: 1 port detected [ 15.136038] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [ 15.136082] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01 [ 15.136086] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 15.136089] usb usb8: Product: xHCI Host Controller [ 15.136092] usb usb8: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 15.136095] usb usb8: SerialNumber: xhci-hcd.11.auto [ 15.136420] hub 8-0:1.0: USB hub found [ 15.136435] hub 8-0:1.0: 1 port detected [ 15.524479] systemd-journald[678]: Received client request to relinquish /var/log/journal/7e1079e7649a45d2ab1ccbdeff6468de access. [ 17.153936] rk_gmac-dwmac fe1c0000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 17.159106] rk_gmac-dwmac fe1c0000.ethernet end1: PHY [stmmac-1:01] driver [YT8531 Gigabit Ethernet] (irq=POLL) [ 17.159632] dwmac4: Master AXI performs any burst length [ 17.159643] rk_gmac-dwmac fe1c0000.ethernet end1: No Safety Features support found [ 17.159657] rk_gmac-dwmac fe1c0000.ethernet end1: IEEE 1588-2008 Advanced Timestamp supported [ 17.159878] rk_gmac-dwmac fe1c0000.ethernet end1: registered PTP clock [ 17.160125] rk_gmac-dwmac fe1c0000.ethernet end1: FPE workqueue start [ 17.160131] rk_gmac-dwmac fe1c0000.ethernet end1: configuring for phy/rgmii-rxid link mode [ 19.764001] platform mtd_vendor_storage: deferred probe pending [ 21.057665] loop6: detected capacity change from 0 to 8 [ 21.334602] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2 [ 21.386445] kauditd_printk_skb: 8 callbacks suppressed [ 21.386448] audit: type=1400 audit(1749325049.950:20): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/snap/snapd/24509/usr/lib/snapd/snap-confine" pid=2025 comm="apparmor_parser" [ 21.386457] audit: type=1400 audit(1749325049.950:21): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/snap/snapd/24509/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=2025 comm="apparmor_parser" [ 23.232550] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx [ 23.232577] IPv6: ADDRCONF(NETDEV_CHANGE): end1: link becomes ready [ 109.364852] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Down [ 131.659974] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 1Gbps/Full - flow control rx/tx [ 132.671410] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Down [ 137.739538] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx [ 389.739035] tun: Universal TUN/TAP device driver, 1.6 [ 390.169076] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 390.193136] cni-podman7: port 1(veth50f9419a) entered blocking state [ 390.193152] cni-podman7: port 1(veth50f9419a) entered disabled state [ 390.193330] device veth50f9419a entered promiscuous mode [ 390.475158] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 390.475321] IPv6: ADDRCONF(NETDEV_CHANGE): veth50f9419a: link becomes ready [ 390.475464] cni-podman7: port 1(veth50f9419a) entered blocking state [ 390.475477] cni-podman7: port 1(veth50f9419a) entered forwarding state [ 391.242869] cni-podman7: port 2(vethbbedf056) entered blocking state [ 391.242896] cni-podman7: port 2(vethbbedf056) entered disabled state [ 391.243123] device vethbbedf056 entered promiscuous mode [ 391.243249] cni-podman7: port 2(vethbbedf056) entered blocking state [ 391.243259] cni-podman7: port 2(vethbbedf056) entered forwarding state [ 391.254592] IPv6: ADDRCONF(NETDEV_CHANGE): vethbbedf056: link becomes ready [ 393.993183] cni-podman6: port 1(veth389748ad) entered blocking state [ 393.993200] cni-podman6: port 1(veth389748ad) entered disabled state [ 393.993363] device veth389748ad entered promiscuous mode [ 394.002409] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 394.002459] IPv6: ADDRCONF(NETDEV_CHANGE): veth389748ad: link becomes ready [ 394.002490] cni-podman6: port 1(veth389748ad) entered blocking state [ 394.002494] cni-podman6: port 1(veth389748ad) entered forwarding state [ 394.388742] cni-podman6: port 2(veth1892f651) entered blocking state [ 394.388753] cni-podman6: port 2(veth1892f651) entered disabled state [ 394.388845] device veth1892f651 entered promiscuous mode [ 394.388887] cni-podman6: port 2(veth1892f651) entered blocking state [ 394.388892] cni-podman6: port 2(veth1892f651) entered forwarding state [ 394.396665] IPv6: ADDRCONF(NETDEV_CHANGE): veth1892f651: link becomes ready [ 394.987273] cni-podman6: port 1(veth389748ad) entered disabled state [ 394.988166] device veth389748ad left promiscuous mode [ 394.988180] cni-podman6: port 1(veth389748ad) entered disabled state [ 395.404461] cni-podman4: port 1(veth2ef9338b) entered blocking state [ 395.404482] cni-podman4: port 1(veth2ef9338b) entered disabled state [ 395.404665] device veth2ef9338b entered promiscuous mode [ 395.404778] cni-podman4: port 1(veth2ef9338b) entered blocking state [ 395.404787] cni-podman4: port 1(veth2ef9338b) entered forwarding state [ 395.413237] IPv6: ADDRCONF(NETDEV_CHANGE): veth2ef9338b: link becomes ready [ 395.735421] cni-podman6: port 1(veth8f6535ac) entered blocking state [ 395.735429] cni-podman6: port 1(veth8f6535ac) entered disabled state [ 395.735524] device veth8f6535ac entered promiscuous mode [ 395.735553] cni-podman6: port 1(veth8f6535ac) entered blocking state [ 395.735556] cni-podman6: port 1(veth8f6535ac) entered forwarding state [ 395.742951] IPv6: ADDRCONF(NETDEV_CHANGE): veth8f6535ac: link becomes ready [ 396.188009] cni-podman4: port 2(vethb8fc1132) entered blocking state [ 396.188019] cni-podman4: port 2(vethb8fc1132) entered disabled state [ 396.188117] device vethb8fc1132 entered promiscuous mode [ 396.188155] cni-podman4: port 2(vethb8fc1132) entered blocking state [ 396.188159] cni-podman4: port 2(vethb8fc1132) entered forwarding state [ 396.198232] IPv6: ADDRCONF(NETDEV_CHANGE): vethb8fc1132: link becomes ready [ 397.070802] cni-podman4: port 3(veth716e0e39) entered blocking state [ 397.070826] cni-podman4: port 3(veth716e0e39) entered disabled state [ 397.071066] device veth716e0e39 entered promiscuous mode [ 397.082498] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 397.082578] IPv6: ADDRCONF(NETDEV_CHANGE): veth716e0e39: link becomes ready [ 397.082630] cni-podman4: port 3(veth716e0e39) entered blocking state [ 397.082637] cni-podman4: port 3(veth716e0e39) entered forwarding state [ 1349.306179] TCP: eth0: Driver has suspect GRO implementation, TCP performance may be compromised. [ 8574.898037] systemd-journald[678]: Received client request to flush runtime journal. [ 8575.027019] systemd-journald[678]: Received client request to relinquish /var/log/journal/7e1079e7649a45d2ab1ccbdeff6468de access. ### interrupts: CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer 13: 7232326 4571545 2497686 2420429 3346080 3319816 3370715 3386094 GICv3 26 Level arch_timer 14: 1539993 467885 1145522 1345384 1144496 1156844 1133118 1324265 GICv3 321 Level rk_timer 20: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal 21: 0 0 0 0 0 0 0 0 GICv3 365 Level debug 22: 970 0 0 0 0 0 0 0 GICv3 429 Level rockchip_thermal 23: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu 24: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy 25: 2 0 0 0 0 0 0 0 GICv3 423 Level rockchip_usb2phy 26: 2 0 0 0 0 0 0 0 GICv3 424 Level rockchip_usb2phy 28: 0 0 0 0 0 0 0 0 GICv3 285 Level pcie-sys 30: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller 31: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller 32: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller 33: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller 34: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller 35: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller 37: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu, fdab0000.npu 38: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu, fdab0000.npu 39: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu, fdab0000.npu 40: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu 41: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3 42: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3 43: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu 44: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu 45: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu 46: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu 47: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu 48: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep 49: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu 50: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu 51: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu 52: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu 53: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu 54: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu 55: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu 56: 0 0 0 0 0 0 0 0 GICv3 164 Level fdcb7f00.iommu 57: 0 0 0 0 0 0 0 0 GICv3 168 Level fdcc7f00.iommu 58: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu 59: 0 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu, fdd90000.vop 60: 0 0 0 0 0 0 0 0 GICv3 193 Level fde50000.dp 61: 0 0 0 0 0 0 0 0 GICv3 392 Level dw-hdmi-qp-hpd 62: 0 0 0 0 0 0 0 0 GICv3 201 Level fde80000.hdmi 63: 0 0 0 0 0 0 0 0 GICv3 202 Level dw-hdmi-qp-cec 64: 0 0 0 0 0 0 0 0 GICv3 203 Level fde80000.hdmi 65: 0 0 0 0 0 0 0 0 GICv3 204 Level fde80000.hdmi 66: 37916 0 0 0 0 0 0 0 GICv3 360 Level feb20000.spi 67: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 7 Level rk806 68: 0 0 0 0 0 0 0 0 rk806 0 Edge rk805_pwrkey_fall 69: 0 0 0 0 0 0 0 0 rk806 1 Edge rk805_pwrkey_rise 70: 674 0 0 0 0 0 0 0 GICv3 238 Level fe2b0000.spi 71: 267567533 0 0 0 0 0 0 0 GICv3 266 Level end1 72: 0 0 0 0 0 0 0 0 GICv3 265 Level end1 73: 0 0 0 0 0 0 0 0 GICv3 254 Level xhci-hcd:usb1 74: 0 0 0 0 0 0 0 0 GICv3 247 Level ehci_hcd:usb3 75: 0 0 0 0 0 0 0 0 GICv3 250 Level ehci_hcd:usb5 76: 0 0 0 0 0 0 0 0 GICv3 248 Level ohci_hcd:usb4 77: 0 0 0 0 0 0 0 0 GICv3 251 Level ohci_hcd:usb6 78: 206468 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c 79: 174 0 0 0 0 0 0 0 GICv3 351 Level feaa0000.i2c 80: 522 0 0 0 0 0 0 0 GICv3 355 Level fec80000.i2c 81: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 27 Level fsc_interrupt_int_n 82: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 8 Level hym8563 83: 0 0 0 0 0 0 0 0 GICv3 356 Level fec90000.i2c 84: 0 0 0 0 0 0 0 0 GICv3 175 Level rockchip-mipi-csi2-hw 85: 0 0 0 0 0 0 0 0 GICv3 176 Level rockchip-mipi-csi2-hw 86: 0 0 0 0 0 0 0 0 GICv3 177 Level rockchip-mipi-csi2-hw 87: 0 0 0 0 0 0 0 0 GICv3 178 Level rockchip-mipi-csi2-hw 88: 0 0 0 0 0 0 0 0 GICv3 179 Level rockchip-mipi-csi2-hw 89: 0 0 0 0 0 0 0 0 GICv3 180 Level rockchip-mipi-csi2-hw 90: 0 0 0 0 0 0 0 0 GICv3 181 Level rockchip-mipi-csi2-hw 91: 0 0 0 0 0 0 0 0 GICv3 182 Level rockchip-mipi-csi2-hw 92: 0 0 0 0 0 0 0 0 GICv3 183 Level rockchip-mipi-csi2-hw 93: 0 0 0 0 0 0 0 0 GICv3 184 Level rockchip-mipi-csi2-hw 94: 0 0 0 0 0 0 0 0 GICv3 185 Level rockchip-mipi-csi2-hw 95: 0 0 0 0 0 0 0 0 GICv3 186 Level rockchip-mipi-csi2-hw 96: 0 0 0 0 0 0 0 0 GICv3 163 Level rkisp_hw 97: 0 0 0 0 0 0 0 0 GICv3 165 Level rkisp_hw 98: 0 0 0 0 0 0 0 0 GICv3 166 Level rkisp_hw 99: 0 0 0 0 0 0 0 0 GICv3 167 Level rkisp_hw 100: 0 0 0 0 0 0 0 0 GICv3 169 Level rkisp_hw 101: 0 0 0 0 0 0 0 0 GICv3 170 Level rkisp_hw 102: 0 0 0 0 0 0 0 0 GICv3 347 Edge feaf0000.watchdog 112: 0 0 0 0 0 0 0 0 ITS-MSI 570425352 Edge PCIe PME 113: 0 25 0 0 0 0 0 0 ITS-MSI 570949632 Edge nvme0q0 114: 97019 0 0 0 0 0 0 0 ITS-MSI 570949633 Edge nvme0q1 115: 0 73910 0 0 0 0 0 0 ITS-MSI 570949634 Edge nvme0q2 116: 0 0 122769 0 0 0 0 0 ITS-MSI 570949635 Edge nvme0q3 117: 0 0 0 54385 0 0 0 0 ITS-MSI 570949636 Edge nvme0q4 118: 0 0 0 0 979184 0 0 0 ITS-MSI 570949637 Edge nvme0q5 119: 0 0 0 0 0 733979 0 0 ITS-MSI 570949638 Edge nvme0q6 120: 0 0 0 0 0 0 1206645 0 ITS-MSI 570949639 Edge nvme0q7 121: 0 0 0 0 0 0 0 1017754 ITS-MSI 570949640 Edge nvme0q8 122: 0 0 0 0 0 0 0 0 GICv3 252 Level xhci-hcd:usb7 123: 399417 0 0 0 0 0 0 0 GICv3 430 Level fec10000.saradc 124: 0 0 0 0 0 0 0 0 GICv3 217 Level i2s 125: 0 0 0 0 0 0 0 0 GICv3 212 Level i2s 126: 0 0 0 0 0 0 0 0 GICv3 213 Level i2s 127: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 29 Edge headset_detect 128: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2 129: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb51000.avsd-plus, fdb50400.vdpu 130: 0 0 0 0 0 0 0 0 GICv3 152 Level fdb50000.vepu 131: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core 132: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core 133: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core 134: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core 135: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd 136: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core 137: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core 138: 380118 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core 139: 250139 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core 140: 0 0 0 0 0 0 0 0 GICv3 140 Level fdc70000.av1d 142: 1 0 0 0 0 0 0 0 GICv3 124 Level fb000000.gpu 143: 1 0 0 0 0 0 0 0 GICv3 125 Level fb000000.gpu 144: 3 0 0 0 0 0 0 0 GICv3 126 Level fb000000.gpu 145: 0 0 0 0 0 0 0 0 GICv3 235 Level dw-mci 146: 1454 0 0 0 0 0 0 0 GICv3 105 Level dmc 147: 0 0 0 0 0 0 0 0 GICv3 187 Level rkcifhw IPI0: 222765 594333 326752 286201 389220 385042 301836 288139 Rescheduling interrupts IPI1: 5083251 172366207 29343396 11967742 7021329 4809483 3703373 3045281 Function call interrupts IPI2: 0 0 0 0 0 0 0 0 CPU stop interrupts IPI3: 0 0 0 0 0 0 0 0 CPU stop (for crash dump) interrupts IPI4: 36574 57958 132176 164098 136750 150896 166299 191886 Timer broadcast interrupts IPI5: 24835 34122 19984 19109 86555 79402 82008 80430 IRQ work interrupts IPI6: 0 0 0 0 0 0 0 0 CPU wake-up interrupts Err: 0
  26. But my "overlays" have something very important provided by armbian - Panfrost GPU support. Is there really no way to make them work together?
  27. https://dl.armbian.com/orangepizero2/Bookworm_current_minimal Armbian_community_25.8.0-trunk.90_Orangepizero2_bookworm_current_6.12.30_minimal I am getting following error while trying to update. root@orangepizero2:~# sudo apt-get update Hit:1 http://security.debian.org bookworm-security InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Get:5 https://github.armbian.com/configng stable InRelease [3,992 B] Err:5 https://github.armbian.com/configng stable InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 Hit:6 https://netcup-03.armbian.com/beta bookworm InRelease Reading package lists... Done W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://github.armbian.com/configng stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 W: Failed to fetch https://github.armbian.com/configng/dists/stable/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 W: Some index files failed to download. They have been ignored, or old ones used instead.
  28. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
