  2. What's wrong with just using the curl command? It will upload the logs to one of our paste servers and it will be nicely formatted and colorful. Way easier to read.
  4. You can also build from the release version, though I'm not sure it's fully that version for everything since the build process downloads updates from the internet. https://github.com/armbian/build/releases/tag/v25.8.1 At the top of that page, you can see how many commits have been added to main since the release of v25.8.1. You can download the source code at the bottom where it says Assets.
  5. Yesterday
  6. Share your displaying configuration by running "neofetch" and post it here. If your X11 is running on top of framebuffer, instead of DRM, it wont work. I also would like to get more debug from cedrus, linux's v4l2... but at least you can add -v to mpv to get more debug You only need the ffmpeg plugins offered by the original poster of the v4l2-request thread This is tested with mpv player only. v4l2-util and -ctl are only useful for webcams and video capture devices. v4l2loopback is not involved here. I don't have it I have an orange pi zero LTS, but I havent tested it there (I would use an SPI LCD, since it doesn't have an HDMI prot)
  7. For debian problems, do what I do: Get the cheapest raspberry Recreate the problem Ask the question in the raspberry forum Apply solution to Armbian XD
  8. Oh, sorry, I didn't notice the non-existent 6 and read it as Helios64. Of course, my description of the boot method is not limited to Rockchip devices; it works on all for which a mainline U-Boot is available. I have used it on iMX6, LX2160A and S922X devices, but my remaining devices are all based on Rockchip. The solutions are too varied to present a turnkey solution here. However, I am sure that only a corresponding configuration for implementation is required to achieve the desired behavior, but for that, the U-Boot documentation must be consulted to decide which solution should be chosen.
  9. Thank you for your answer. My board is not Rockchip-based, we have been generalizing the discussion for quite a while now. Well, and this is where it would get interesting but ...
  10. Since the RK3399 U-Boot can use an HDMI display and a USB keyboard, I would simply configure a jumpstart option in the boot flow that mounts a different root filesystem. When booting, you just have to select this option. If interacting with the firmware console is too complicated, the recovery system can be placed on a removable storage device. In this way, in case of need, only the rescue media needs to be connected and the system restarted; no firmware console access is required. A completely firmware-controlled fallback mechanism is also possible, but it requires further special configuration of the firmware. Read this thread to understand what I mean by my statement.
  11. If tester is not available, I'd try powering failing ports with their respective cables but feeding them from pins powering other ports (eg with wires from some molex cable, just need to be careful with polarity and shortcuts) and then powering working ports from pins on the board feeding failing ports - to exclude failure of the power rail feeding these ports on the board. If cables are faulty, I'd check them for electrical connections and if they are ok, would replace capacitors.
  12. What I like to do in such a case is link to archive.org. some spam got posted to this thread which I removed, so I felt like I might as well add an answer at the same time
  13. fair enough, no idea where i would get the right android image from for my unknown box so I guess I am stuffed putting Armbian on my box. never mind, will repurpose an old laptop when corelec updates for the s905x2 stop thanks for the help
  14. You are missing something. The boot process starts with the uboot from the emmc (even if ultimately booting the SD card). And coreelec changes the uboot environment of the emmc in ways that are incompatible with with the armbian code. So you need to reflash a fresh android image if you want to use armbian as that will restore the basic state that armbian is expecting.
  15. the guide has a warning: Note: If you have previously run other distributions on the box such as coreelec the below installation will not work. You will need to restore the original android firmware before attempting the install. coreelec changes the boot environment in ways that are incompatible with these Armbian builds. I have run coreelec but only ever from an SD card, I don't think the firmware has ever been changed as if I remove the SD card it boots into the original android system. Is this likely to be true or am I again missing something.
  16. HP Pavilion8 core processor, 32Gig RAM laptop. I wanted to limit information to limit time for digging into it, but here they are: log-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.log.ans summary-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.md
  17. dig through the github actions, how the images are compiled is public information ;-)
  18. probably time for the serial console my suspicion tells me that it will be hard to get proper logs otherwise my suspicion is that some umounts does not come back. <- try to unmount everything you can before the reboot and see if that helps.
  19. This is great. Apparently mine didnt persist after reboot either, yours seems to be permanent and working even better. Thanks!
  20. I have looked at a lot of other 4 and 8 PIN cables and considered using multiple single SATA power connector to double connectors but I have reservations because the harness cable included with the Helios64 has those capacitors. I am not certain what their purpose is and I am concerned if I do some sort of unique solution I will damage the motherboard. Also this was being used as an offsite NAS for a production environment backup data and so stablity is essential. I've asked this question in multiple places, I am at the point that I am just going to have to order a new NAS unit that doesn't use custom cables.
  21. Oh, my bad. That does indeed look very custom-made. Just an idea, maybe get yourself a Molex 4-Pin IDE to SATA power cable (this one even has five power outlets) and then power the HDD separately? Maybe there is 12V on the board somewhere you can tap into. I am not an electrical engineer so better verify. You will likely have to come up with a unique solution at this point.
  22. spendist is the maintainer of the Nanopi Neo. Maybe he has something to say. Did you try another kernel? Another OS?
  23. I've already performed that search. The connector on the motherboard is a Mini Molex 8 Pin connector. Here is a link to the Kobol website with an image of the harness. HDD Cable Harness
  24. Awesome! Please do elaborate. Please do elaborate. What is the cargo cult practiced here at Armbian? I'm old, but I'm still interested to learn, so please do teach me.
  25. That is surprising. I don't think they are custom. Isn't this what you need? Or this one for just 1€. Search for "SATA power cable" and skip the 4-pin ones.
  26. Excerpts are often useless. Provide full logs using the curl command from the end of each run. If the used hardware isn't very powerful, yes, can be.
  27. Kobol went out of business years ago. I don't think you will be able to find replacement parts.
  28. A google search indicates that the MXQ Pro 4K 5G often uses a RK3229 quad-core CPU
