  2. Hi all! I am entirely new to Armbian. I see Radxa's Rock5B RK3588 based SBC is suppored and its Armbian page is https://www.armbian.com/rock-5b/ . Can you give me a small crash course on your experience with Armbian on the Radxa Rock5B? If you have an idea of any of the points I raise below, please share. 1. Super stable? Generally to use and to upgrade Armbian, how stable has it been to you? 2. Which image should I pick? I see both Debian and Ubunto are offered. I'll pick Debian. Then there are "Desktop", "Server" and "Minimal/IOT"and "Dedicated applications" images, and some are listed as "Linux v6.1" and some as "Linux v6.12". Which one of v6.1 and v6.12 should I take? 12 means twelve and 1 means one, right, so 6.12 sounds a lot preferable. Under "Server", there is no Debian option at all. Any idea why? What does "Dedicated applications" mean here? If I would just guess my way through, I would probably take the "Desktop" variant with 6.12 kernel and then on the first boot I'd disable the GUI permanently by running "systemctl set-default multi-user.target". It sounds like "Desktop" should include a lot of drivers. Who knows, perhaps one of those drivers would be needed for a PCI or USB peripheral. In respect of drivers, "Minimal/IOT" sounds risky. Did I get it right? 3. Armbian SPI flash image with particular u-boot?? Radxa distribute a SPI flash image with their latest u-boot. Typically you flash a MicroSD card with their whole Debian distribution on it, then you run "rsetup" and pick the SPI flash option. But, their wiki contains the manual flashing instructions based on "dd" also. Ref https://docs.radxa.com/en/rock5/rock5b/download . I was told that Armbian has its own u-boot for Rock5B, is it true? Where is it, and where are the installation instructions? 4. Peripherals, drivers, all OK? Firstly what about the peripherals such as the onboard Realtek 8125 2.5gbe NIC, is it always stable? Does everyone only have good experiences with using the 22x80mm M.2 slot on the bottom which has 4x PCIe v3 lanes? All good experiences with the 22x30mm A+E key M.2 slot on the top, which has 1x PCIe v2 lane? 5. PD? About the USB-C PD power supply protocol negotiation for voltage, the main Armbian page https://www.armbian.com/rock-5b/ says "PD is broken for the 5B model (background) on most revisions that are in the wild and is causing boot loop. Workaround is to use a stupid / fixed 5-24 volts USB-C power supply." and links to https://www.spinics.net/lists/linux-usb/msg239175.html . I presume here, just using a USB-C power supply that supports up to 5A in the default 5V mode will do, normally. But to not negotiate to 20V sounds quite limited especially as the Rock5B has the hardware to take 20V DC input. Radxa themselves have implemented support for hte USB-C PD protocol negotiation in their Debian distribution. What about just bring in their code as pragmatic solution? 6. "aptitude update; aptitude upgrade" OK & safe? Is "aptitude update; aptitude upgrade" always safe on Armbian, so any kernel offered will be properly patched? Did anyone's system break down permanently after doing "aptitude update; aptitude upgrade"? 7. Kernel version? Just for recap, which kernel version is provided right now? I think someone said 6.12. Via "apt upgrade" will it pick a newer kernel automatically now or when one is released? Via "apt install" are there any optional even newer kernels avaiable? 8. URL to the Rock5B/RK3588 specific patches? Just curious, where is Armbian's sourcecode that's specific to Rock5B and RK3588 actually? 9. Mainlining status? Does anyone have a notion of what status there is to including Rock5B & RK3588 specific patches to mainline Linux? Ideally over time custom patches should go to zero, right. However also occasionally for some device it seems like the mainlining work just grinds to a halt. How is it here. 10. Armbian-Debian packages What is the relation between Debian's packages repository and Armbian's - does Armbian copy essentially everything? 11. ARM64 CPU optimizations? Are sensible ARM64 CPU optimizations enabled so generally Armbian operates at a really high speed? I'd guess yes. Many thanks.
  3. If the u-boot on the unit supports USB Boot, yes. GXL:BL1:9ac50e:bb16dc;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:800;NAND:81;SD:800;USB:8;LOOP:1;EMMC:800;NAND:81;SD:800;USB:8;LOOP:2;EMMC:800;NAND:81;SD:800;USB:8;LOOP:3;EMMC:0;READ:0;0.0;CHK:0; The above looks like USB Mode. This Mode is for flashing vendor or custom imgs to the unit via USB. This is for recovery.
  5. Okay, got it, will use Armbian now but my question is open. Is it possible to boot Armbian from USB ?
  6. @Antom You are not using Armbian. ophub is a fork of Armbian that uses the Armbian name without permission. They do not contribute to Armbian development nor participate in these forums. You need to direct your question to their forums, not here.
  7. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  8. @mvpwar for RK3566 NPU you will need to use an armbian fork from Joshua Riek https://forum.armbian.com/topic/28895-efforts-to-develop-firmware-for-h96-max-v56-rk3566-8g64g/page/16/#findComment-211031 I think you will need to fork and rebuild it, the files got expired
  9. Forget about it. The problem was the switch at my work desk which seems to be dead. So no physical connection...
  10. Hi, I wanted to give my Odroid M1 new life by installing a fresh Armbian 25.5.1. Previously it was running on an old Odroid Ubuntu Image. After starting from SD I have no ethernet connection. The eth0 interface is DOWN. I tried using a USB3 2.5G ethernet adapter, but the new network interface also shows DOWN. I have tried Debian and Ubuntu Minimal images with the same results. What could be the cause and how do I get a working ethernet connection? Thanks Malz
  11. A have TVBOX on Amlogic S905l, but this tvbox don't have sdcard, is it possible to boot this board from armbian burned to USB, if yes, can someone share documentation ? I mean to boot from USB before booting from EMMC. I shorted the contacts on the board to disable emmc and I see this message in the TTL logs: GXL:BL1:9ac50e:bb16dc;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:800;NAND:81;SD:800;USB:8;LOOP:1;EMMC:800;NAND:81;SD:800;USB:8;LOOP:2;EMMC:800;NAND:81;SD:800;USB:8;LOOP:3;EMMC:0;READ:0;0.0;CHK:0; looks like chip is asking for USB, but I'm not sure that it can boot from Maybe I need to create a specific bootable USB? I used an image https://github.com/ophub/amlogic-s9xxx-armbian Link: https://github.com/ophub/amlogic-s9xxx-armbian/releases/download/Armbian_bookworm_save_2025.06/Armbian_25.08.0_amlogic_s905l-mg101_bookworm_6.12.31_server_2025.06.01.img.gz Please help me
  12. Where exactly is it? Can you send me a download link? I have already damaged many units, according to your instructions git clone --depth=1 https://github.com/armbian/build.git cd build ./compile.sh 构建 BOARD=rk3328-heltec BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no EXPERT=no KERNEL_CONFIGURE=yes KERNEL_GIT=shallow RELEASE=bookworm
  13. https://zuckerbude.org/armbian-using-kernel-config/
  14. Thanks for the logs. Do you have tested PCIe extension ? My personal project is to create one NAS with one PCIe-to-SATA add on
  15. How to select this menu when compiling
  16. I used the default rk3328 to flash the device, but it didn't turn on and turned into a brick
  17. I've got Orange Pi 2W board and installed Debian 12 Home Assistant image to it (image link). There is a huge problem with it. Very often there is no bluetooth module appeared in system. I need to reboot system for 10-15 timer to make it work. What can be a reason? I attached 2 boot logs (with good BT appears and no BT appears), I hope it will help to find out the issue. boot_log_bt_good_02.zip boot_log_bt_bad_02.zip
  18. I gave this a try but after creating the /etc/apt/sources.list, when running sudo apt update it returns this error The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
  19. Packages `base-files` 25.* are not not built for Debian Trixie, which prevents upgrades and in my case installing new software. Managed to upgrade my system with some manual labour, but apt.armbian.com/pool/trixie-utils/b/base-files/ Results in errors like: /etc/armbian-image-release:
  20. Yesterday
  21. You are going down the wrong path. You should start here with understanding the Armbian build framework: https://docs.armbian.com/Developer-Guide_Overview
  22. I would suggest you to download clean Debian minimal image and proceed this way: https://docs.armbian.com/User-Guide_Armbian-Software/HomeAutomation/#home-assistant EVCC can be installed this way - official Docker container: https://docs.armbian.com/User-Guide_Armbian-Software/HomeAutomation/#evcc How to deal with EVCC from HA, no idea. This is application level knowledge and I am just an average user of HA. I assume addon will want to connect to the service which runs on some IP address and some port. IMO this part is similar as official HAOS image. Current application images are not yet rebuild with latest stable base, so until then its better going clean Debain + armbian-config way.
  23. CONFIG_PREEMPT_RT=y. I was hoping to use the OrangePi5 Pro - with Linuxcnc - for machine controls - This would require predictable response times for precision cutting routines. The kernel build settings in the current release do not include the Setting for PREEMPTIVE_RT. Debian for X86 defaults to having it setup to support a Fully Preemptive mode. I am wondering why this hasn't trickled down to SBC builds. Byte2bot sells a shield card for converting the Pi 20 pin header to a Parallel port for connecting to CNC motion control cards - roughly $50 without having any manual wiring. Really slick - but at the moment - its would be good for Raspberry pi 4 and 5 as they have the Realtime kernel build available. I have a Tower PC with PCIe parallel on debian bookwork setup for machine control for a milling machine. So the Orange_Pi_5 is a much better solution . Please let me know how if I am on the correct track. I will copy the config file to the .config file in the kernel build directory -- This should be found in the /boot directory or the /proc directory - and add in the PREEMPT commands for fully PREEMTIVE that I found listed in the Kconfig file. Then I have to figure out where to place the orangepi5pro.csc file you pointed me to. At that point I should try to find some reference material about the Preemption settings the make process is going to ask me about. make should complete, and then "make module_install" - Then "make modules" At that point - the build is done. I will have to sort out how the /boot files need to be modified. Sorry for all the questions - If there is some reference material - that is clear about the Image Uinitram the Armbian Environment - and other boot related topics please point them out.
  24. update: if disconnect TX from USB-UART adaptor - then there is infinite output that changes every microsecond with more strings: ESC[1;47rESC[46;1H[ 45.827723][ Tible6] [dhd-wlan0] w l_ext_iapsta_evefs.readdy=1 (/system/etcb/init/hw/init.uo sr not foun db^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1Hnt : [S] Link UP with c8::ca:98^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1HESC[1;46rESC[46;1H ESC[1;47rESC[46;1H[ 45.827747][ T6] [dhd-wlan0] wconsole:/ $ ^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1Hl_notify_connect_status : wl_bss_conn.127^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1Hect_done succeeded with c8:ca:98 ^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1HESC[1;46rESC[46;1H ESC[1;47rESC[46;1H[ 45.843270][ T6] [dhd-wlan0] wl_notify_connect_sonso le:/ $ c^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1Htatus : wl_bss_connect_done succeeded127|^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1H with c8:7f:54:e0:ca:98 vndr_oui: 00-90-127|^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1H4C 00-0C-43 00-0C-E7 ^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1HESC[1;46rESC[46;1H ESC[1;47rESC[46;1H[ 45.881840][ T165] type=1400 audit(1699712132.610:14conssole:/ $ ^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1H4): avc: denied { open } for comm="FD655_Demo" path="/sys/class/fd655/fd65console:/ $ ^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1H5_vpause_127|y^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1Hflag" dev="s127fig=|^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1Hysfs" ino=19647 sc[ 82.040633][ T386] read descriptors^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1H[ 82.040698][ T386] read strings^MESC[1;46rESC[46;1H ESC[1;47rESC[46;1H[ 82.043097][ T1] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) f82.045159][ T1] init: Co mmand 'symlink /coESC[46;159HnESC[46;159HfESC[46;159HiESC[46;159HgESC[46;159H But still no active shell session
  25. Werner - thanks - I did check the community and only found builds for 6.1 -- I did a build and had added three lines in the .conf file CONFIG_ PREEMPTICE_RT=y CONFIG_PREEMPTION=y and CONFIG_PREEMPT=y as I recall. did the "make" "make modules_install" and then the "make module" and there were a string of questions - during the make about some of the pre-emption options, which I was unprepared to answer. Not worried about those. I was concerned that the modules_install and the module make commands were installing the necessary routines. I do not understand how the orangepi5pro.csc file gets incorporated into the build process. I was on an Orangepi os to run the krtnrl build. Now moving back to Armbian 6.1.115. I am downloading a Armbian community supported 6.1.115 download for orange pi pro. I will then download the rockchip-rk3588.conf file - and the orangepi5pro.csc file - not sure where the board config file goes and how it ties into the kernel build process - might need a pointer for that Jim
  26. Hello, finally CH340G usb-uart has arrived - I have checked it performs data transfer on 1.5M speed in RX/TX loop normally. But when connecting to board - there is no output to console at all. Have tried RX/TX changing still no output, just regular start of android TV box. Please suggest does UART needs to be enabled in some screen/menu?
  27. just wanted to check if there is plan to have an image for the Rock 3B model? update: just tested the latest image for Rock 3A, and it is working ok. version: Armbian 25.2.1 Bookworm Minimal/IOT Kernel: 6.12.13, Size: 266.4 MB, Release date: Feb 13, 2025 I will run a few docker containers to see if there are any issues.
