  2. PR Has been merged. I rebuilt on commit 1cf20837d27a3c09d93395f075cc305c81b4663f and things look good.
  3. @Igor is probably in the best position to answer when a new image for your board might be available. This is actually fairly easy to do by building your own image: "git clone https://github.com/armbian/build.git;cd build;./compile.sh" https://docs.armbian.com/Developer-Guide_Building-with-Docker/ https://evilolaf.github.io/docupreview/Developer-Guide_Build-Preparation/ https://www.youtube.com/watch?v=kQcEFsXEJEE
  5. Hello, I am trying to enable Panfrost GPU acceleration on a new Armsom Sige5 board running the latest edge kernel (6.1.115), but glxinfo -B still shows llvmpipe. I have been troubleshooting this for some time and have discovered that the kernel module (panfrost.ko) loads correctly with modprobe, but it is not binding to the GPU hardware on boot. I believe I have found the reason why. A recent commit to the Armbian build system (https://github.com/armbian/build/commit/836def3d11699537e6289dedfbc766c2050d422d) changes the method for enabling Panfrost. It removes the panfrost overlay and adds KERNEL_TARGET_CONFIG="panfrost-all" instead. It appears that the current edge kernel available through armbian-config does not yet include this essential fix. Can you please advise when a kernel with this change will be available for download, or if there is a manual way I can apply this fix? Thank you.
  6. THIS IS NOT RECOMMENDED Bbut since I'm on edge anyway: I could not apply the patch as I did not have .dtsi file anywhere in /boot/dts/rockchip. So I tried to enable it manually by dts/dtb conversion, but that just did not work. So there is more to it than the patch alone. So I tried a different hackier route: I replaced the dtb with one from LibreElec, just to see if it would work, and it does: cd /tmp wget https://chewitt.libreelec.tv/testing/LibreELEC-RK3588.aarch64-12.90.1-nanopi-r6c.img.gz zcat LibreELEC-RK3588.aarch64-12.90.1-nanopi-r6c.img.gz > LibreELEC-RK3588.aarch64-12.90.1-nanopi-r6c.img sudo fdisk -l /tmp/LibreELEC-RK3588.aarch64-12.90.1-nanopi-r6c.img | grep img1 ## /tmp/LibreELEC-RK3588.aarch64-12.90.1-nanopi-r6c.img1 * 32768 1081343 1048576 512M c W95 FAT32 (LBA) sudo mount -o loop,offset=$((512*32768)) LibreELEC-RK3588.aarch64-12.90.1-nanopi-r6c.img /mnt sudo cp -p /boot/dtb/rockchip/rk3588s-nanopi-r6c.dtb /boot/dtb/rockchip/rk3588s-nanopi-r6c.dtb.orig sudo cp -p /mnt/rockchip/rk3588s-nanopi-r6c.dtb /boot/dtb/rockchip/rk3588s-nanopi-r6c.dtb sudo umount /mnt ## reboot the machine Hey, I got sound, yay! @The Tall Man Will this work on other boards ? Idk ymmv. But it has dtb's for orangepi-5/b/max/plus/ultra In short: the kernel has sound implemented since 6.15rc1, so its just the Device Tree that needs to be updated. Otherwise this would not have worked.
  7. Here's a very old image that worked.
  8. Has anyone here configured armbian with a Wayland desktop, and completely free of X11? How did you do it? I have compiled labwc and it works great with my orange pi zero 3, with bookworm or trixie... but I can't figure out how to configure a wayland greeter. I need to do this because my LCD driver can't work with X11 (panel-mipi-dbi-spi).
  9. no boot for Khadas-supplied Fenix 24.04.1.6.9 image, either. sha256sum: e89b80b7777fed524651b98d04e8afc0406fee76e4c5f9ccf4457df4fb6d9054
  10. Yesterday
  11. The latest Armbian IoT image for Khadas VIM4 does not boot. sha256sum: 69b10797369fd572d590aeb0dd7b28a4ebc5882cec8db8daf592db7b158bf141 Here is the log from the serial debug console.
  12. @ebin-dev could you perhaps update your post 1 and post your latest instructions and upload the files there? That would make it much easier to find the stable files.
  13. Hello everyone, I need help. I have an HK1MAX device with an RK3318 chipset. I need a firmware that can be installed using the loader, as my device is stuck with a red WiFi light (model number: HK6334Q).
  14. @pochopsp - you can buy two tv-boxes of the same type at once from the same seller and they might have different hardware internally still - that is the reason why it is not prossible to provide really good images for tv boxes: the hardware is simply too random and often also low quality
  15. I would put boot and system on the eMMC. Then it will run with or without the SSD, which I would reserve for data. Things like VMs and containers that get a lot of writes can go on the SSD and be symbolically linked to their system folders.
  16. @AHMEDLORI try these the transpeed or x98h image. https://github.com/NickAlilovic/build/releases/tag/20250306
  17. @Luckyisnotcoolest try the x96q images here. https://github.com/NickAlilovic/build/releases/tag/20250306
  18. @emor acid could be your gpio settings for mmc0. Try the x98h image. If that doesn’t work you need to extract your android dts or use the one from the working Ubuntu.
  19. Just wonder if there is a good guide how to make dri work and allt the supported code´s work in wayland / xorg or other / Thanks
  20. Hi Keith, I'm not too familiar with the in and outs of armbian-config. Just navigate around and see what's available. The kernel being Edge makes it easiest to install to a different device (i.e. if that's eMMC), so you're goo there. And remember, if you break the operating system, you can always start again with a clean install. So don't be afraid to experiment. It's how we learn. But I am very careful with the 16 MB SPI-NOR, and not to mess with that. I'm not sure if overwriting that with junk would brick the machine or not. Perhaps someone else who knows more about that can comment. But otherwise just follow your instincts as best you can and do what makes sense to you. Armbian-config is meant to be pretty straight-forward.
  21. The kernel 6.17 release benefits from improvements in the graphics subsystem, hardware enablement, and more! See where Collabora's kernel team contributed to this release. View the full article
  22. So I now got Edge 6.16.4 Kernel on my SD card, and I want to boot from either EMMC or SATA to take advantage of the extra speed. Arbian-config presents several options. Which option is generally recommended, from the 5 shown in Armbian-config?. For me, Option 3 (boot from EMMC, System on SATA, USB or NVMe) seems to be what I want, but I am interested to hear any recommendations or problems, since this is and Edge Kernel. Tanks, Keith
  23. leave a link for other users like @John Taylor to continue your work, also @fedes_gl could give a hand
  24. I already said i cant and dont want to. Anyway, in the meantime, I tried to port to latest version of armbian and didn't managed to finish because of some issues with devicetree. I gave up because no time for the moment (and found nomore fun in debugging for something i dont need) Final goal was to port haos to it anyway. Armbian was only a step for me.
  25. I know an expert in rk3528, his name is @fensoft we are depending on him finding a weekend to dedicate to the community https://github.com/ilyakurdyukov/rk3528-tvbox he will help us by taking this repository and including it in armbian with a wonderful pull request I would like to buy this board and join the fun that you have, but my country has literally started an embargo on all TV boxes
  26. Thanks for that , TallMan. You told me I needed 6.16.4 - and it took me a while to realise that I could probably find it using the Armbian-config. I thought I did pretty much as you describe, but it wouldn't boot, so I guess I did something wrong, (Probably picked up the faulty card mentioned above!). but didn't have time yesterday to try again - so thats for this evening. I'll get there eventually, I hope. At the moment I guess I'm still scared I'm going to do something irrepairable, because up til now I've always been a user, so not too adventurous yet. Keith
  27. @fensoft please make this https://github.com/ilyakurdyukov/rk3528-tvbox as a pull request, you have the dq08 tvbox board, you're embedded in the community, you've tested everything, you seem like the perfect guy
  28. Hi, I tested with the version 25.11.0-trunk.129 and the second network port worked with this. https://paste.armbian.com/hasewoloti
