  2. Hello! @rosic Yes I took a look at the components of the board and eventually managed to find the resistor that interferes with the emmc clock. Shorting it will put the box in Maskrom mode and enable you to flash the original firmware using the official tutorial from the Linknlink wiki even if you cannot get into Loader mode by pressing the reset button insode the audio jack. I used a metal clamp to short it while I plugged the USB-A to USB-A cable into the 2nd usb port. You can see images here Official instruction here
  3. My bad I didn't specify. On Windows. I lost 4h on it. I needed to use dd on a Mac to create a bootable SD card. Arbian Imager didn't help, it killed my Window stuck on storage finding and couldn't be killed. on Mac made a bad job of flashing, didn't even started boot. Btw on Windows, all methods I used (Raspberry Imager, Etcher, Rufus) all made like 50ish small 0 bite partitions and one big unallocated. Somehow it started booting, Armbian logo on, but then it failed.
  4. The install process is the same from the beginning of the project, you're confused.
  5. https://paste.armbian.com/hicilanono Works just fine
  6. Hi, Just an update on this issue. Upgraded to kernel-7.0.0-edge-rockchip64-26.2.0-trunk.733, still no audio output on Analog Headphone/Audio Jack.
  7. Yesterday
  8. Hey there, I try to install Armbian on my Arduino UNO Q (2 GB), but it fails with all three images Armbian_community_26.2.0-trunk.703_Arduino-uno-q_trixie_edge_6.19.0_minimal.tar.xz Armbian_community_26.2.0-trunk.703_Arduino-uno-q_noble_edge_6.19.0_gnome_desktop.tar.xz Armbian_community_26.2.0-trunk.703_Arduino-uno-q_noble_edge_6.19.0_kde-neon_desktop.tar.xz The error message: .\arduino-flasher-cli.exe flash .\Armbian_community_26.2.0-trunk.703_Arduino-uno-q_trixie_edge_6.19.0_minimal.tar.xz WARNING: flashing a new Linux image will erase any existing data that you have on the board. Do you want to proceed and flash .\Armbian_community_26.2.0-trunk.703_Arduino-uno-q_trixie_edge_6.19.0_minimal.tar.xz on the board? (yes/no) yes Unzipping Debian image arduino-images/ arduino-images/disk-sdcard.img.esp arduino-images/disk-sdcard.img.root arduino-images/flash/ arduino-images/flash/imagefv.elf arduino-images/flash/zeros_1sector.bin arduino-images/flash/multi_image.mbn arduino-images/flash/gpt_main0.bin arduino-images/flash/gpt_backup2.bin arduino-images/flash/featenabler.mbn arduino-images/flash/boot.img arduino-images/flash/prog_firehose_ddr.elf arduino-images/flash/tz.mbn arduino-images/flash/xbl.elf arduino-images/flash/rawprogram0.xml arduino-images/flash/gpt_both0.bin arduino-images/flash/gpt_empty0.bin arduino-images/flash/gpt_backup1.bin arduino-images/flash/xbl_feature_config.elf arduino-images/flash/rawprogram0.nouser.xml arduino-images/flash/gpt_main2.bin arduino-images/flash/km4.mbn arduino-images/flash/gpt_backup0.bin arduino-images/flash/zeros_33sectors.bin arduino-images/flash/gpt_main1.bin arduino-images/flash/abl.elf arduino-images/flash/rpm.mbn arduino-images/flash/storsec.mbn arduino-images/flash/devcfg.mbn arduino-images/flash/cdt.bin arduino-images/flash/hyp.mbn arduino-images/flash/qupv3fw.elf arduino-images/flash/patch0.xml arduino-images/flash/uefi_sec.mbn panic: runtime error: index out of range [0] with length 0 goroutine 1 [running]: github.com/arduino/arduino-flasher-cli/internal/updater.Flash({0x7ff7f72e8c08, 0xc0000e9e50}, 0xc000288130, {0xc0000a8060, 0x54}, 0x1?, 0x0, {0x0, 0x0}, 0x0) D:/a/arduino-flasher-cli/arduino-flasher-cli/internal/updater/flasher.go:95 +0x757 github.com/arduino/arduino-flasher-cli/cmd/arduino-flasher-cli/flash.runFlashCommand({0x7ff7f72e8c08, 0xc0000e9e50}, {0xc000288110, 0x1?, 0x1?}, 0x0, 0x0, {0x0, 0x0}) D:/a/arduino-flasher-cli/arduino-flasher-cli/cmd/arduino-flasher-cli/flash/flash.go:117 +0x349 github.com/arduino/arduino-flasher-cli/cmd/arduino-flasher-cli/flash.NewFlashCmd.func1(0xc00002c908, {0xc000288110, 0x1, 0x1}) D:/a/arduino-flasher-cli/arduino-flasher-cli/cmd/arduino-flasher-cli/flash/flash.go:74 +0x94 github.com/spf13/cobra.(*Command).execute(0xc00002c908, {0xc0002880e0, 0x1, 0x1}) C:/Users/runneradmin/go/pkg/mod/github.com/spf13/cobra@v1.9.1/command.go:1019 +0xae7 github.com/spf13/cobra.(*Command).ExecuteC(0xc00002c608) C:/Users/runneradmin/go/pkg/mod/github.com/spf13/cobra@v1.9.1/command.go:1148 +0x465 github.com/spf13/cobra.(*Command).Execute(...) C:/Users/runneradmin/go/pkg/mod/github.com/spf13/cobra@v1.9.1/command.go:1071 github.com/spf13/cobra.(*Command).ExecuteContext(...) C:/Users/runneradmin/go/pkg/mod/github.com/spf13/cobra@v1.9.1/command.go:1064 main.main() D:/a/arduino-flasher-cli/arduino-flasher-cli/cmd/arduino-flasher-cli/main.go:71 +0x3f0 .\arduino-flasher-cli.exe flash latest works as expected, so it seems to be an issue with these images. Or do I use the wrong installation method? The problem is reproducible under Windows 11 and Linux. Installation over Armbian Imager also fails https://paste.armbian.com/fowidugipo https://paste.armbian.com/ogekaqalaq
  9. @usual user can we achieve in browser video hardware acceleration now, and how? I tried many combinations with no success. Any suggestions are highly appreciated!
  10. Hi, did you find any legacy rk3318 image?
  11. Yeah, I’ve looked into the patch file. It doesn’t work with latest u-boot at all. It looks for dtb file, whereas latest u-boot includes mostly dtbi files. I think I’ll have to look into slightly newer than 2020.07 u-boot. I’m guessing it would be easier to port that patch.
  12. Zero 3E, all images, same UUID/initramfs error on boot. Tried different flashing methods, sd cards. All the same fail. Board works with the old Joshua riek dist.
  13. Thank you very much for your reply, Werner - and indeed for all the tremendous work you do! The drive is listed as an /dev/nvme0n1p1, so I think I did choose the right overlay. Rootfs UUID is correct. I tested SPI/MTD boot with Armbian 26.2.1, rootfs on NVMe. I erased and reflashed the SPI flash manually: ``` shell sudo flash_eraseall /dev/mtd0 sudo dd if=/usr/lib/linux-u-boot-vendor-orangepi5/u-boot-rockchip-spi.bin \ of=/dev/mtdblock0 bs=1M conv=fsync status=progress sync ``` I then verified that the running system was still using /boot from the SD card: ``` shell findmnt /boot ``` which returned: ``` shell /boot /dev/mmcblk1p1[/boot] ``` I mounted the NVMe rootfs and compared /boot on SD vs NVMe: ``` shell sudo mkdir -p /mnt/nvme sudo mount /dev/nvme0n1p1 /mnt/nvme ls -la /boot ls -la /mnt/nvme/boot ``` The NVMe /boot contents were older/stale compared with the SD /boot, so I synchronized them: ``` shell sudo rsync -aHAX --delete /boot/ /mnt/nvme/boot/ sync ``` I then powered the board off completely, removed the SD card, and tested booting from SPI + NVMe again but it still won't boot without the SD card. I watched your video on UART debugging, but unfortunately, my serial cable is too slow, so I'll get one of those you recommend and try again. Thanks again!
  14. The install process seems to have changed a lot and the automated setup lets you pick mxq specifically, do I still follow the steps in this thread or is the automatic setup good enough now?
  15. You need to apply the patch to newer sources to build a newer uboot. But the patch will need to be modified (ported) to newer sources as code in uboot changes. That is the whole point of the suggestions I'm this thread. Port the patch to newer uboots and build them to see if newer uboots fix the problem.
  16. This one. The patch from “/build-u-boot/“ directory. That contains mentioned readme.txt. Tried to build u-boot with that patch and newer binaries of u-boot. It failed though. I’m going to try with older version maybe later. As long as Armbian boots from SD card, I’m fine. Justwas curious about it, when it failed to flash into emmc.
  17. @tiobily no worries. you can still interrupt u-boot. In u-boot shell you can try calculating crc32 of memory regions to test memory. memtester tool does not seem to be working.
  18. Please be specific, what patch are you referring to?
  19. @tiobily https://radxa.com/community Try these forums.
  20. @qq20739111 thks, official community = github? https://github.com/radxa-docs/docs/ i asked claude to make a summary of my project with npu: We use the vendor's ACUITY toolkit inside a Docker container (ubuntu-npu:v2.0.10.1) to convert ONNX → quantized .nb files. - Pipeline: onnxsim → pegasus_import → pegasus_quantize → pegasus_export, uint8 quantization, deployed to ~/npu_models/ via push.sh. - Runtime: custom npu_server.c (pre-allocated input buffer, no per-call mmap) that the Python app talks to. - Hard lesson #1 — quantization: only pure Conv+BN+ReLU survives uint8. Attention, SE blocks, hard-swish, LayerNorm all collapse to constant outputs. So no MobileNetV3+, no transformers. - Hard lesson #2 — concurrency hang: NPU IRQs get lost when camera ISP DMA runs in parallel (shared memory bus). Fix: suppress GStreamer buffer copies during inference. Never STREAMOFF/ON the sunxi-vin driver — instant kernel crash. - Result: 12 models running (9 NPU + 3 CPU) at ~40ms/inference.
  21. Hello Armbian Community, I am currently running the following image on my Orange Pi 5 Max: Armbian_community_26.2.0-trunk.668_Orangepi5-max_noble_edge_7.0.0-rc6_kde-neon_desktop Unfortunately, I'm struggling with WiFi and Bluetooth issues: WiFi: No wireless interfaces are detected (no option in network settings). Bluetooth: The service is active, but it cannot scan or find any devices. What I’ve tried so far: Installed armbian-firmware and full-mirror-armbian-firmware. Verified that common wireless tools and relative packages are up to date. Checked rfkill list, but the adapters don't seem to be initialized correctly. I noticed a similar discussion on the DietPi forums regarding the OPi 5 Max Bluetooth (link:DietPi), but I'm unsure if those specific workarounds apply to the current Armbian Edge kernel (7.0-rc6). I understand that maintaining support for newer boards and edge kernels is a huge task. Could anyone point me in the right direction? Are there specific firmware blobs or device tree overlays I need to manually enable for this board? Thank you for your time and for all the hard work on the Armbian project!
  22. BitNet-style ternary brings LLM inference to ExecuTorch via its Vulkan backend, enabling much smaller, bandwidth-efficient models with portable GPU execution on edge devices. Presented at PyTorch Conference Europe 2026. View the full article
  23. @tiobily You can post your issue on the official community as long as you haven't done any hardware modifications yourself. By the way, How did you get the NPU running on this board?
  24. But wifi does not work, although armbian-config sees my wifi network and saves password for it. rk322x-config shows Wifi device: unknown - Device ID: 024c:b723. dmesg: r8723bs: module is from the staging directory, the quality is unknown... r8723bs: unknown parameter 'rtw_enusbss' ignored lsmod shows module as unused: r8723bs 405504 0 Could changing led-confs help?
  25. Hello, I’ve got the same issue with s905x. After going through this topic, I’ve compiled u-boot with newer sources, and it seems not resolving this at all. There was patch mentioned. Do I use it to compile u-boot (instead of the one provided in the u-boot repo) ?
  26. @MMGen First, thanks for a great tutorial! I have a question about gpt. I maintain shrink-backup and I use dd to copy "boot sector" and rsync the rest (VERY easily described) But I do not distinguish any difference between if it's mbr or gpt when using dd, I just copy everything before root partition with dd (and a few MiB extra) then format root, rsync, yadayadayada... (not important) So I got curious why you skip the first 64 512b blocks in the dd for gpt? (for others reading, the 512 is because fdisk ALWAYS returns 512b blocks, even though gpt is actually 4k blocks) dd if=$(echo *.img) of=/dev/sda bs=512 skip=64 seek=64 count=32704 Can you explain why? I tried to find something online referencing the first 64 512b blocks of a gpt partition table, but could not find anything. I would really appreciate you educating me, or some links where I can read up on the reason. Thank you!
