  2. Hi all. Thank you all for helping on this. I have created a diagram. - Armbian not rocky. the red box is what I CAN NOT change - no access. I do have access to the Linux box - so I want to be able to ping from PC 1 to Device 1 on 10.10.10.2.
  3. Hi everyone, I need to enable the csi camera and i2c port on my zero3 development board. When I click on the management overlay, an error occurs. Is there any solution?
  4. Hi there, The `net.ipv4.ip_forward=1` will make the packets coming in on NIC1 be routed/sent to NIC2 due to the destination fitting in the network, but the device on NIC2 will not know how to send return packets to 192.168.100.*/24 as it does not have any fitting directly connected networks. Usually you could use default gateway/route to point them back to the Pi, but you said you cannot configure that. Try the following on the Pi: sudo iptables -t nat -A POSTROUTING -j MASQUERADE -o enp4s0 That should enable NAT on NIC2, which will masquerade any packet sent from NIC2 with "source address" 10.10.10.*/24 which it does know how to talk to. Btw, can you confirm the following was indeed the output of `ip route`: 10.10.10.10/24 dev enp4s0 proto kernel scope link src 10.10.10.2 metric 100 One would expect 10.10.10.0/24 as network instead of 10.10.10.10/24. Groetjes,
  5. Dear Armbians, I'm thrilled to announce the launch of this digest for our amazing community. For newcomers, Armbian is a lightweight Linux distribution that breathes life into ARM-based single-board computers, transforming tiny, affordable boards into powerful servers, workstations, and IoT devices. This newsletter is our way of keeping you in the loop, sharing the latest releases, celebrating community contributions, and diving into the technical insights that power your projects. Whether you're a tech enthusiast or just getting started with your first Orange Pi, there's something here for you. Thanks for being part of this incredible journey! Igor Armbian project manager View the full article
  6. Yesterday
  7. Hi all, I’m running Armbian 24.5 (Ubuntu Jammy CLI) on an Orange Pi 3 LTS with kernel 6.6.y, trying to use a CH341A Mini Programmer to flash an SPI EEPROM chip. But I’m stuck, the programmer isn’t detecting the chip at all. Connected the module to the chip using the correct pins (CS, MOSI, MISO, CLK). Powered the chip at 3.3V to match Armbian’s logic level. Used flashrom on Armbian (via terminal) to detect the chip, but it returns “no device” or similar errors. Tried different USB ports, different cables , same result. Do I need to match some specific SPI mode or speed for Armbian or for specific EEPROMs? Is there an issue with voltage levels or pull-up / pull-down resistors that often catches beginners? Any recommended OS commands/logs to check so I can see what’s going wrong (e.g. permissions, USB detection, lsusb output)? Thanks in advance for your help!
  8. Hi Werner I apologize for radxa zero, as I do not know which tag to choose. I have a board based on OK3568 from Forlinx. Logs https://paste.armbian.com/ohokuhozab
  9. Hi there, the 2 NICs are on my RPi Armbian. ip route output. > modified it abit to match but concept is below. default via 10.10.10.254 dev enp4s0 proto static metric 100 169.254.0.0/16 dev enp4s0 scope link metric 1000 192.168.100.0/24 dev eth0 proto kernel scope link src 192.168.100.10 metric 101 10.10.10.10/24 dev enp4s0 proto kernel scope link src 10.10.10.2 metric 100 I have only PC1 connected to NIC1 with 192.168.100.101 GW - 192.168.100.254 This PC1 can NOT be changed. Device1 on NIC2 10.10.10.100/24 < this have no Gateway as its only a slave device. I need to reach Device1 on NIC2 from the PC1 on NIC1..how is this achieved? I tried /etc/sysctl.conf net.ipv4.ip_forward=1 still missing something… I failed to mention is that I can only modify settings within the Linux box containing the 2 NICs. I need some sort of interlinking NIC1 on 192.168 to forward packets to 10.10 network…
  10. Can't say I know much about X11, but after playing around with the Cinnamon version I did get a desktop by: created file:/etc/X11/xorg.conf Section "Device" Identifier "Device0" Driver "fbdev" Option "Device" "/dev/dri/card0" EndSection So I figure something in the configuration or driver related ?. And that goes for all Debian flavors I tested. All gave the same error.
  11. Hi there, Not sure if your question is complete, are both NIC1 and NIC2 in the same PC1 ? (NIC being network interface controller/card.) If NIC1 and NIC2 are both in the same computing node, the routes should be there already, if the configuration is plain and not something funky. Can you share the output of `ip a s` and `ip route` ? Also, do you have any firewall enabled? Gr,
  12. Currently yes. A replacement for this package / service needs to be found and implement - in case you want to get involved. This isn't completely true. Armbian still does utilize CPUMIN/CPUMAX from /etc/default/cpufrequtils if present to set corresponding frequencies via the Armbian script armbian-hardware-optimization (packages/bsp/common/usr/lib/armbian/armbian-hardware-optimization). This script I believe runs at every system startup. So even without the cpufrequitls package installed, there is still some functionality in this area. Functionally that no one has likely touched or looked at in years.
  13. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  14. Radxa Zero has a different soc: https://radxa.com/products/zeros/zero/ Double-check what hw you actually have
  15. I am using kernel 6.12.45 with rk3568 , everything is displayed on my monitor. A colleague's computer does not work on 3 of the 4 monitors. the error is the same as in the theme / kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes , since it seems that no one is watching that topic, I decided to raise this issue. Has anyone encountered such a problem?
  16. Each attached memory disk must have its own unique UUID. This is its essence. This depends on the platform (BROM bootloader flashed into the chip) and possibly the switch soldered to the board.
  17. Hello all, I succeed to boot on sata usb by seting the UUID of the armbian_root from mmcblk1p1 to sda1 I tested several M2 SSD enclosures both NVME and NGFF most of the time, one in the middle, has a USB Hub and micro SDCARD port. Now if the USB enclosures is not connected, we are stuck in initramfs stage because the UIID partition given in /boot/ArmbianEnv.txt does not exist. I changed the UUID of emmc armbian_root (mmcblk1p1) thinking it would be overmapped with partition of S2 usb enclosure (sda1). It is not the case, it will only boot on emmc , ignoring S2 enclosures when mmcblk1p1 and sda1 shares the same UUID. I suggest USB enclosures should comes in higher boot priority than emmc after a bootable sdcard is present or not, so the end user is not lost in initramfs jungle.
  18. ``` root@opi5 /etc/apt/sources.list.d# apt-get update Hit:1 http://deb.debian.org/debian trixie-backports InRelease Hit:2 http://deb.debian.org/debian trixie InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 http://security.debian.org trixie-security InRelease Hit:5 https://github.armbian.com/configng stable InRelease Hit:6 http://mirror.vinehost.net/armbian/apt trixie InRelease Reading package lists... Done W: https://github.armbian.com/configng/dists/stable/InRelease: Policy will reject signature within a year, see --audit for details N: Missing Signed-By in the sources.list(5) entry for 'http://deb.debian.org/debian' ``` ``` root@opi5 /etc/apt/sources.list.d# apt-get update --audit Hit:1 http://deb.debian.org/debian trixie-backports InRelease Hit:2 http://deb.debian.org/debian trixie InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 http://security.debian.org trixie-security InRelease Hit:5 https://github.armbian.com/configng stable InRelease Hit:6 http://mirror.vinehost.net/armbian/apt trixie InRelease Reading package lists... Done W: https://github.armbian.com/configng/dists/stable/InRelease: Policy will reject signature within a year, see --audit for details A: https://github.armbian.com/configng/dists/stable/InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on DF00FAF1C577104B50BF1D0093D6889F9F0E78D5 is not bound: No binding signature at time 2025-09-08T18:12:20Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. N: Missing Signed-By in the sources.list(5) entry for 'http://deb.debian.org/debian' ``` **/etc/apt/sources.list.d/armbian-config.sources** ``` Types: deb URIs: https://github.armbian.com/configng Suites: stable Components: main Signed-By: /usr/share/keyrings/armbian.gpg ``` **/etc/apt/sources.list.d/armbian.sources** ``` Types: deb URIs: http://apt.armbian.com/ Suites: trixie Components: main trixie-utils trixie-desktop Signed-By: /etc/apt/trusted.gpg.d/armbian.gpg ``` **/etc/apt/sources.list.d/debian-backports.sources** ``` # Modernized from /etc/apt/sources.list Types: deb URIs: http://deb.debian.org/debian/ Suites: trixie-backports Components: main contrib non-free non-free-firmware Signed-By: ``` **/etc/apt/sources.list.d/debian.sources** ``` # Modernized from /etc/apt/sources.list Types: deb URIs: http://deb.debian.org/debian/ Suites: trixie Components: main contrib non-free non-free-firmware Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg # Modernized from /etc/apt/sources.list Types: deb URIs: http://deb.debian.org/debian/ Suites: trixie-updates Components: main contrib non-free non-free-firmware Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg # Modernized from /etc/apt/sources.list Types: deb URIs: http://security.debian.org/ Suites: trixie-security Components: main contrib non-free non-free-firmware Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg ``` How to fix it?
  19. Currently yes. A replacement for this package / service needs to be found and implement - in case you want to get involved. Thank you! It's a work of many people, impossible for me to poke into every issue or feature that exists
  20. @Igor Thanks for that, I guess I can move on to the newer tools. So does that mean that the GOVERNOR and CPUMIN params are useless and can be discarded? And BTW your Armbian tools are utterly fantastic.
  21. Taken from desktop Gnome - works Updated the showip alias for those interested.
  22. Dear Armbians, I'm thrilled to announce the launch of this digest for our amazing community. For newcomers, Armbian is a lightweight Linux distribution that breathes life into ARM-based single-board computers, transforming tiny, affordable boards into powerful servers, workstations, and IoT devices. This newsletter is our way of keeping you in the loop, sharing the latest releases, celebrating community contributions, and diving into the technical insights that power your projects. Whether you're a tech enthusiast or just getting started with your first Orange Pi, there's something here for you. Thanks for being part of this incredible journey! Igor Armbian project manager View the full article
  23. The file exists in the sd card, as expected. root@x96q-lpddr3-v1-3:~# ls -l /boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb -rw-r--r-- 1 root root 37577 Apr 2 19:41 /boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb It also exists inside the installed eMMC filesystem (after installing -- without rebooting -- I mounted the /dev/mmcblk2 device and the file is there, in the correct place). root@x96q-lpddr3-v1-3:~# mount /dev/mmcblk2p1 /srv/ root@x96q-lpddr3-v1-3:~# ls -l /srv/boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb -rw-r--r-- 1 root root 37577 Sep 10 21:16 /srv/boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb Before rebooting, I re-ran armbian-install and used option 6 to re-write boot on eMMC just in case. Then rebooted. Then it worked!! It is booting from eMMC normally now.... Boot log from successful boot: U-Boot SPL 2025.01-armbian-2025.01-S6d41-P7151-H8869-V98f7-Bb703-R448a-dirty (Apr 02 2025 - 21:19:05 -04 00) DRAM:testing 32-bit width, rank = 2 read calibration failed! testing 32-bit width, rank = 1 DRAM:Store cfg DRAM:1st writing pattern DRAM:detecting column address bits detected 10 columns DRAM:restore cfg DRAM:reconfigure for all active rows DRAM:store cfg DRAM:2nd writing pattern DRAM:detecting row address bits detected 15 rows DRAM:restoring cfg DRAM:end of auto detect dram size MBUS port 0 cfg0 0100000d cfg1 00640080 MBUS port 1 cfg0 06000009 cfg1 01000578 MBUS port 2 cfg0 0200000d cfg1 00600100 MBUS port 3 cfg0 01000009 cfg1 00500064 MBUS port 4 cfg0 20000209 cfg1 1388157c MBUS port 5 cfg0 00640209 cfg1 00200040 MBUS port 6 cfg0 00640209 cfg1 00200040 MBUS port 8 cfg0 01000009 cfg1 00400080 MBUS port 11 cfg0 01000009 cfg1 00640080 MBUS port 14 cfg0 04000009 cfg1 00400100 MBUS port 16 cfg0 2000060d cfg1 09600af0 MBUS port 21 cfg0 0800060d cfg1 02000300 MBUS port 22 cfg0 01000009 cfg1 00640080 MBUS port 25 cfg0 0064000f cfg1 00200040 MBUS port 26 cfg0 20000209 cfg1 1388157c MBUS port 37 cfg0 01000009 cfg1 00400080 MBUS port 38 cfg0 00640209 cfg1 00200040 MBUS port 39 cfg0 20000209 cfg1 1388157c MBUS port 40 cfg0 00640209 cfg1 00200040 1024 MiB Trying to boot from MMC2 NOTICE: BL31: v2.10.14(debug):armbian NOTICE: BL31: Built : 18:07:43, Apr 2 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0b2520, model: hechuang,x96-q LPDDR3 v1.3 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.01-armbian-2025.01-S6d41-P7151-H8869-V98f7-Bb703-R448a-dirty (Apr 02 2025 - 21:19:05 -0400) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: hechuang,x96-q LPDDR3 v1.3 DRAM: 1 GiB Core: 59 devices, 20 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4021000: 3, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 No USB device found Net: apply fix for AC300 ephy bb version bug ... using AC300 emac1 ephy default config ... eth0: ethernet@5030000 starting USB... No USB controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 4641 bytes read in 1 ms (4.4 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 252 bytes read in 0 ms Load fdt: /boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb Card did not respond to voltage select! : -110 ** Bad device specification mmc 0 ** 37577 bytes read in 3 ms (11.9 MiB/s) Working FDT set to 4fa00000 Failed to load '/boot/dtb/allwinner/overlay/sun50i-h616-fixup.scr' 15483712 bytes read in 492 ms (30 MiB/s) 42621440 bytes read in 1351 ms (30.1 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x42b50000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15483648 Bytes = 14.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 4913b000, end 49fff300 ... OK Loading Device Tree to 00000000490c9000, end 000000004913afff ... OK Working FDT set to 490c9000 Starting kernel ...
  24. Last week
  25. @Andre Ruiz that’s weird uboot loaded boot.scr Check if “/boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb” exists and path is correct. Make sure it’s not 0 bytes.
  26. Dear Armbians, I'm thrilled to announce the launch of this digest for our amazing community. For newcomers, Armbian is a lightweight Linux distribution that breathes life into ARM-based single-board computers, transforming tiny, affordable boards into powerful servers, workstations, and IoT devices. This newsletter is our way of keeping you in the loop, sharing the latest releases, celebrating community contributions, and diving into the technical insights that power your projects. Whether you're a tech enthusiast or just getting started with your first Orange Pi, there's something here for you. Thanks for being part of this incredible journey! Igor Armbian project manager View the full article
