  2. current isn't a good option for rk3588/s devices. At this point of time barely any support for this SoC was mainlined. And it seems like later revisions introduced a regression causing a crash. Since 6.18 may become next LTS kernel it will replace current current kernel at some point. So better go for an edge based image instead.
  4. orangepi5 and 6 have nothing in common. double-check what you are actually talking about. Also there is no 0.9.9 rknpu stuff. 5.10 bsp has been abandoned long ago.
  5. Hey folks, Been daily-driving OrangePi 6 / 6B with latest Armbian noble-edge (6.12-rc kernel + rknpu 0.9.9-8) for local LLM inference. Even after manually loading the closed-source RKNPU DDK 0.9.9, switching to the "new" rknpu.ko from Rockchip’s 5.10 BSP, and forcing INT4 quantization via llama.cpp built with -DRKNN_RT=ON, the NPU utilization reported by rk_nn_tool tops out around 36-42% when running Q4_K_M 70B-class models (tokens/s barely hits ~19-21 t/s). CPU is almost idle, no thermal throttling, 16GB LPDDR4X fully available. Is this still the known "18 TOPS theoretical vs real ~7-8 TOPS usable" ceiling, or did anyone manage to push past 65%+ utilization on mainline-ish kernels in late 2025? Happy to share my build scripts and rk_nn_tool logs if anyone wants to dig deeper. Bonus question: has anyone successfully coerced the NPU into handling 2+ concurrent contexts without dropping to zero utilization (the infamous "second model load kills the first" bug)?
  6. ok same error. The maxio module works with this snippet though : mdio { compatible = "snps,dwmac-mdio"; #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0xee>; ethernet-phy@0 { compatible = "ethernet-phy-id7b74.4411", "ethernet-phy-ieee802.3-c22" reg = <0x00>; status = "okay"; phandle = <0x51>; }; };
  7. yes. Things that can be tried: - DTS phy-mode = "rgmii-id"; or phy-mode = "rgmii-rxid"; - UBOOT CONFIG_PHY_REALTEK=y CONFIG_DWC_ETH_QOS=y CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y
  8. OK do you mean boot with ethernet working using the maxio module then change DTB and reboot?
  9. Can you boot in a working ethernet and then reboot to this trial?
  10. I have a very similar if not the same issue on my Odroid M1. When doing a reboot it won't detect the SATA hdd. The NVME is working fine and I am booting the device via a sdcard anyway. Aparantly it has something to do with the kernel. Once I shut down the odroid and power it on again (cold reboot) the SATA device is just working fine again. I did not find a solution for this so far but I keep on digging...
  11. @makaOK I corrected my error and tried your suggestion but i get in dmesg : [ 47.378829] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 47.380072] rk_gmac-dwmac fe010000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19)
  12. Hello comunity members, I've installed and run Armbian_community_25.11.0-trunk.437_Tanix-tx6_trixie_current_6.12.47_minimal Since my Tanix TX 6 is running pretty hot in my opinion I want to reduce the operating frequency. Please help me with some instructions how to do so, since I couldn't find any. Thank you in advance.
  13. I know that told you the ID of your chip but also told you to switch to phy1 but you didn't. I think It is possible to use the generic driver but don't know if It will work. Changes in dtb must be accurate.
  14. Thank you! I'm still in the middle of a long build (chromium). I'll be able to check the flash-image-DDR4-1g_1cs_5-1200_750 image with the specific device I own with frequency scaling enabled and report if it is stable or not. It will crash pretty reliably if the firmware doesn't have the change I submitted here: https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell/commit/622677674cf34ef8fdf75b0c580d27efc8628ae8
  15. Apologies, I somehow missed this comment until after I'd posted mine Would have saved me a fair bit of searching had I read it
  16. @maka Thanks for this suggestion. I'll look further into this. The reason I made that change was because you suggested it here : It works well to auto load the maxio module on startup without resorting to manual modprobe commands. Is it really possible to use a generic driver for this maxio NIC chip?
  17. Yesterday
  18. I would always go RPi, as I have been burned going with a different board in the past. This may not be a fair reflection on the Orange Pi, as I can only speak for having purchased an Odroid C1+ many years ago. The C1+ was a very capable board, and definitely more capable than the RPi offering at the time. However, there just is no substitute for the support and community around the RPi. I now have 3, and even my original RPi 1 Model B+ is still supported by the RPi foundation, and still gets modern kernel and OS updates. This is a board running off just 512MB RAM, A 700 MHz single-core 32-bit processer and released over 11 years ago. No one could complain if they had dropped support long ago, but they didn't, and they still show no signs of dropping support any time soon. Hardkernel, on the other hand, pretty much dumped support for the Odroid C1+ as soon as it released, so it is stuck on a 3.x kernel and a uBoot from 2011. If it wasn't for the Armbian project this board just would not be useable, and even then, we are still stuck on a 15 year old uBoot solution. None of this may be important to you, and like I say, my experience is not likely a like-for-like comparison with the Orange Pi, but the long term support you get from the RPi foundation and the wider community around it is not even close to being matched by any other vendor, and (personally) I don't like supporting vendors who effectively manufacture e-waste.
  19. @Shubham Singh To check if KVM is compiled into the kernel, use the following command: grep CONFIG_KVM /boot/config-$(uname -r) CONFIG_KVM=y CONFIG_KVM_MMIO=y CONFIG_KVM_VFIO=y CONFIG_KVM_GENERIC_DIRTYLOG_READ_PROTECT=y CONFIG_KVM_XFER_TO_GUEST_WORK=y You also need to ensure your CPU supports virtualization. Check with: egrep -c '(vmx|svm)' /proc/cpuinfo 0 A return value greater than 0 indicates virtualization support is present. CPU doesn't support virtualization. Check the official Radxa image. Using these commands. I doubt it works. I'm using the same kernel config and Board support package.
  20. HI, I'm trying Mint forum. I am receiving this notification on every system startup. 19/11/2025,16:18:34 Problems during Cinnamon initialization Cinnamon started successfully, but it was not possible to load one or more applets, desklets or extensions. Check the system logs and the LookingGlass log for any issues in Cinnamon. You can disable all extension(s) in Cinnamon Settings to prevent this message from appearing repeatedly. Please contact the developer. and Looking Glass log error t=2025-11-19T03:20:50Z [menu@cinnamon.org]: Util.latinise is not a function [menu@cinnamon.org]: Failed to evaluate 'main' function on applet: menu@cinnamon.org/0 error t=2025-11-19T03:20:50Z [menu@cinnamon.org]: Applet menu@cinnamon.org: Could not create applet object.[menu@cinnamon.org]: Error importing applet.js from menu@cinnamon.org error t=2025-11-19T03:20:51Z [menu@cinnamon.org]: Util.latinise is not a function [menu@cinnamon.org]: Failed to evaluate 'main' function on applet: menu@cinnamon.org/0 error t=2025-11-19T03:20:51Z [menu@cinnamon.org]: Applet menu@cinnamon.org: Could not create applet object. [menu@cinnamon.org]: Error importing applet.js from menu@cinnamon.org info t=2025-11-19T03:20:51Z AppletManager started in 15564 ms info t=2025-11-19T03:20:51Z Cinnamon took 15834 ms to start info t=2025-11-19T03:20:51Z Adding systray: blueman-tray (1x1px) info t=2025-11-19T03:20:51Z Adding systray: solaar (1x1px) info t=2025-11-19T03:20:51Z Adding systray: indicator-solaar (1x1px) info t=2025-11-19T03:20:51Z GPU offload supported: false Captured from my system: cury@orangepi5-plus:~$ inxi -Fxxxz System: Kernel: 6.1.115-vendor-rk35xx arch: aarch64 bits: 64 compiler: gcc v: 11.4.0 clocksource: arch_sys_counter Desktop: Cinnamon v: 6.4.10 wm: Muffin v: 6.4.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Armbian GNU/Linux 13 (trixie) Machine: Type: ARM System: Orange Pi 5 Plus details: N/A CPU: Info: 8-core model: N/A variant-1: cortex-a76 variant-2: cortex-a55 bits: 64 type: MCP smt: <unsupported> arch: ARMv8 rev: 0 cache: L1: 768 KiB L2: 2.5 MiB L3: 3 MiB Speed (MHz): avg: 1800 min/max: 408/1800:2256 cores: 1: 1800 2: 1800 3: 1800 4: 1800 5: 1800 6: 1800 7: 1800 8: 1800 bogomips: N/A Features: Use -f option to see features Graphics: Device-1: display-subsystem driver: rockchip_drm v: N/A bus-ID: N/A chip-ID: rockchip:display-subsystem class-ID: display-subsystem Device-2: rk3588-dw-hdmi driver: dwhdmi_rockchip v: N/A bus-ID: N/A chip-ID: rockchip:fde80000 class-ID: hdmi Device-3: rk3588-dw-hdmi driver: dwhdmi_rockchip v: N/A bus-ID: N/A chip-ID: rockchip:fdea0000 class-ID: hdmi Display: x11 server: X.Org v: 21.1.16 driver: X: loaded: modesetting unloaded: fbdev dri: rockchip gpu: rockchip_drm,dwhdmi_rockchip, dwhdmi_rockchip display-ID: :0 screens: 1 Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93") Monitor-1: HDMI-A-1 mapped: HDMI-1 model: LG (GoldStar) FHD serial: <filter> res: mode: 1920x1080 hz: 100 scale: 100% (1) dpi: 82 size: 597x336mm (23.5x13.23") diag: 685mm (27") modes: max: 1920x1080 min: 640x480 API: EGL v: 1.5 platforms: device: 0 drv: panthor device: 1 drv: rknpu device: 2 drv: rockchip device: 3 drv: swrast gbm: drv: panthor surfaceless: drv: panthor x11: drv: rockchip inactive: wayland API: OpenGL v: 4.5 compat-v: 3.1 vendor: mesa v: 25.0.7-2 glx-v: 1.4 direct-render: yes renderer: Mali-G610 (Panfrost) device-ID: ffffffff:ffffffff Info: Tools: api: eglinfo,glxinfo x11: xdriinfo, xdpyinfo, xprop, xrandr Audio: Device-1: hdmi driver: rk_hdmi_sound bus-ID: N/A chip-ID: rockchip:dp0-sound class-ID: dp0-sound Device-2: rk3588-dw-hdmi driver: dwhdmi_rockchip bus-ID: N/A chip-ID: rockchip:fde80000 class-ID: hdmi Device-3: rk3588-dw-hdmi driver: dwhdmi_rockchip bus-ID: N/A chip-ID: rockchip:fdea0000 class-ID: hdmi Device-4: hdmi driver: rk_hdmi_sound bus-ID: N/A chip-ID: rockchip:hdmi0-sound class-ID: hdmi0-sound Device-5: hdmi driver: rk_hdmi_sound bus-ID: N/A chip-ID: rockchip:hdmi1-sound class-ID: hdmi1-sound API: ALSA v: k6.1.115-vendor-rk35xx status: kernel-api Server-1: PulseAudio v: 17.0 status: active Network: Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: 1000 bus-ID: 0003:31:00.0 chip-ID: 10ec:8125 class-ID: 0200 IF: enP3p49s0 state: down mac: <filter> Device-2: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: 100000 bus-ID: 0004:41:00.0 chip-ID: 10ec:8125 class-ID: 0200 IF: enP3p49s0 state: down mac: <filter> Device-3: wlan-platdata driver: wlan_platdata v: N/A bus-ID: N/A chip-ID: wlan-platdata:wireless-wlan class-ID: wireless-wlan IF-ID-1: dummy0 state: down mac: <filter> IF-ID-2: enP4p65s0 state: down mac: <filter> IF-ID-3: wlx90de807f1947 state: up mac: <filter> Bluetooth: Device-1: Realtek 802.11ac NIC driver: btusb,rtw_8822bu type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 bus-ID: 1-1.4:3 chip-ID: 0bda:b82c class-ID: e001 serial: <filter> Report: hciconfig ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes address: <filter> Drives: Local Storage: total: 1.04 TiB used: 107.07 GiB (10.0%) ID-1: /dev/nvme0n1 vendor: Reletech model: P600 M.2 PCIE3.0 1TB size: 953.87 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SN10660 temp: 39.9 C scheme: GPT ID-2: /dev/sda vendor: Kingston model: DataTraveler 3.0 size: 115.47 GiB type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 tech: N/A serial: <filter> fw-rev: 0000 scheme: MBR Partition: ID-1: / size: 576.47 GiB used: 12.63 GiB (2.2%) fs: ext4 dev: /dev/nvme0n1p1 ID-2: /var/log size: 46.8 MiB used: 7.4 MiB (15.9%) fs: ext4 dev: /dev/zram1 Swap: ID-1: swap-1 type: partition size: 19.14 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2 ID-2: swap-2 type: zram size: 7.79 GiB used: 0 KiB (0.0%) priority: 5 dev: /dev/zram0 Sensors: System Temperatures: cpu: 49.0 C mobo: N/A Fan Speeds (rpm): N/A Info: Memory: total: N/A available: 15.58 GiB used: 4.38 GiB (28.1%) Processes: 313 Power: uptime: 1h 17m states: freeze,mem suspend: deep wakeups: 0 Init: systemd v: 257 default: graphical Packages: pm: dpkg pkgs: 1548 Compilers: clang: 19.1.7 gcc: 14.2.0 Shell: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.38 cury@orangepi5-plus:~$
  21. Yes, I removed that as well quite quickly. Now the printer is ready in 30s after power-on.
  22. @djoness you need to Disable Armbian kernel/firmware upgrades using the armbian-config tool. System -> Updates -> UPD002 - Disable Armbian firmware upgrades -> Disable Armbian kernel/firmware upgrades X96Q has many different variations of the same box. Read the bottom of this thread. https://github.com/warpme/miniarch/issues/102 If you want a well supported box get a Transpeed 8K618-t.
  23. This issues has had me sticking with the old BTT images for ages, then I found a different issue with those so was forced to come back to try again with Armbian. After going down many rabbit holes a friend said just install KlipperScreen earlier than you normally would when running up a Klipper install, that will pull in network manager. It was so simple for my use case I hadn't even considered it. Worked a treat, I could set up the wifi on the touchscreen and it survived reboots. I then found a slow down in the boot process because networkd was still waiting for a connection, a solution to that wasn't as hard to find I ran these two commands in the terminal and now it doesn't slow anything down during boot up. I have no idea if this is the correct way but I'll post it in case it helps anyone else following the same breadcrumbs I've been chasing. sudo systemctl disable systemd-networkd-wait-online.service sudo systemctl mask systemd-networkd-wait-online.service
  24. Hello, my Orange Pi 5 works well with the stock OS (1.22, Ubuntu Jammy, BSP kernel 6.1.99), using the SD as a boot device. It also works ok with Armbian Minimal-IoT / Debian 13 / 6.1: v25.8.2 for Orange Pi 5 running Armbian Linux 6.1.115-vendor-rk35xx But I prefer Ubuntu and wanted to try 6.12, so I downloaded 25.8.2 / Ubuntu Server / 6.12. Wrote to SD, hooked up the debug UART and powered on. The bootloader is fine, the kernel starts, but at a certain point it panics: [ OK ] Reached target sockets.target - Socket Units. Starting armbian-hardware-monitor.…ce - Armbian hardware monitoring... Starting armbian-hardware-optimize… - Armbian hardware optimization... Starting armbian-led-state.service - Armbian leds state... Starting armbian-resize-filesystem…vice - Armbian filesystem resize... armbian-hardware-monitor.service [ OK ] Finished armbian-hardware-monitor.…vice - Armbian hardware monitoring. [ OK ] Finished armbian-led-state.service - Armbian leds state. armbian-led-state.service [ OK ] Finished armbian-hardware-optimize…ce - Armbian hardware optimization. armbian-hardware-optimize.service [ OK ] Finished console-setup.service - Set console font and keymap. console-setup.service sys-kernel-debug-tracing.mount [ 158.363359] rockchip-pm-domain fd8d8000.power-management:power-controller: failed to get ack on domain 'gpu', val=0xa9fff [ 158.364324] SError Interrupt on CPU7, code 0x00000000be000411 -- SError [ 158.364327] CPU: 7 UID: 0 PID: 462 Comm: (udev-worker) Tainted: G M C 6.12.49-current-rockchip64 #1 [ 158.364332] Tainted: [M]=MACHINE_CHECK, [C]=CRAP [ 158.364333] Hardware name: Xunlong Orange Pi 5 (DT) [ 158.364334] pstate: 404000c9 (nZcv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 158.364336] pc : _raw_spin_lock_irqsave+0x38/0x8c [ 158.364342] lr : regmap_lock_spinlock+0x18/0x2c [ 158.364347] sp : ffff800083f03660 [ 158.364348] x29: ffff800083f03660 x28: 0000000000000000 x27: ffff800083f03c60 [ 158.364351] x26: 0000000000000000 x25: ffff710bf0c4c080 x24: ffff710bf0f64098 [ 158.364354] x23: 0000000000000000 x22: 0000000000000001 x21: 0000000000000000 [ 158.364356] x20: 000000000000000c x19: 0000000000000000 x18: ffffffffffffffff [ 158.364358] x17: 66203a72656c6c6f x16: 72746e6f632d7265 x15: 776f703a746e656d [ 158.364361] x14: 6567616e616d2d72 x13: 00000000000002ac x12: 00000000ffffffea [ 158.364363] x11: 0000000000000001 x10: 0000000000000001 x9 : ffffc80dcfdf9250 [ 158.364365] x8 : 000000000002ffe8 x7 : c0000000ffffdfff x6 : 00000000000affa8 [ 158.364368] x5 : ffffc80dce6c1b54 x4 : 0000000000000008 x3 : ffffc80dce6c15c8 [ 158.364370] x2 : 0000000000000001 x1 : 0000000000000000 x0 : ffff710bf0f65c00 [ 158.364373] Kernel panic - not syncing: Asynchronous SError Interrupt [ 158.364374] CPU: 7 UID: 0 PID: 462 Comm: (udev-worker) Tainted: G M C 6.12.49-current-rockchip64 #1 [ 158.364377] Tainted: [M]=MACHINE_CHECK, [C]=CRAP [ 158.364378] Hardware name: Xunlong Orange Pi 5 (DT) [ 158.364379] Call trace: [ 158.364380] dump_backtrace+0x94/0x114 [ 158.364383] show_stack+0x18/0x24 [ 158.364385] dump_stack_lvl+0x38/0x90 [ 158.364387] dump_stack+0x18/0x24 [ 158.364389] panic+0x39c/0x3f4 [ 158.364392] nmi_panic+0x40/0x8c [ 158.364394] arm64_serror_panic+0x70/0x80 [ 158.364396] do_serror+0x3c/0x78 [ 158.364398] el1h_64_error_handler+0x30/0x48 [ 158.364401] el1h_64_error+0x64/0x68 [ 158.364402] _raw_spin_lock_irqsave+0x38/0x8c [ 158.364404] regmap_lock_spinlock+0x18/0x2c [ 158.364407] regmap_write+0x3c/0x78 [ 158.364409] rockchip_pd_power+0xf8/0x5e8 [ 158.364414] rockchip_pd_power_on+0x14/0x20 [ 158.364417] _genpd_power_on+0x94/0x188 [ 158.364418] genpd_power_on.part.0+0xa4/0x1ac [ 158.364421] __genpd_dev_pm_attach+0x144/0x2dc [ 158.364423] genpd_dev_pm_attach+0x60/0x70 [ 158.364425] dev_pm_domain_attach+0x20/0x34 [ 158.364429] platform_probe+0x50/0xdc [ 158.364431] really_probe+0xc0/0x38c [ 158.364434] __driver_probe_device+0x7c/0x15c [ 158.364437] driver_probe_device+0x40/0x114 [ 158.364440] __driver_attach+0xf4/0x1fc [ 158.364443] bus_for_each_dev+0x74/0xd4 [ 158.364445] driver_attach+0x24/0x30 [ 158.364448] bus_add_driver+0x110/0x234 [ 158.364451] driver_register+0x60/0x128 [ 158.364453] __platform_driver_register+0x24/0x30 [ 158.364455] panthor_init+0x64/0x1000 [panthor] [ 158.364467] do_one_initcall+0x44/0x2a8 [ 158.364470] do_init_module+0x58/0x20c [ 158.364472] load_module+0x1e4c/0x1f3c [ 158.364474] init_module_from_file+0x84/0xc4 [ 158.364476] __arm64_sys_finit_module+0x1f4/0x2f0 [ 158.364478] invoke_syscall+0x48/0x110 [ 158.364481] el0_svc_common.constprop.0+0xc8/0xe8 [ 158.364484] do_el0_svc+0x20/0x2c [ 158.364487] el0_svc+0x30/0xfc [ 158.364488] el0t_64_sync_handler+0x13c/0x158 [ 158.364491] el0t_64_sync+0x190/0x194 [ 158.364492] SMP: stopping secondary CPUs [ 158.364557] Kernel Offset: 0x480d4dc00000 from 0xffff800080000000 [ 158.364558] PHYS_OFFSET: 0xffff8ef600000000 [ 158.364559] CPU features: 0x1c,00000017,00280928,4200720b [ 158.364561] Memory Limit: none [ 158.393407] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]--- Power brick is a solid 5V/4A and as I said works OK with the stock OS (7zip benchmark and all) and Armbian Minimal Any suggestion? Thanks a lot Fernando
  25. Did you do Update All after removing knotes? If you were running wayland you will probably need to use Ctrl-Alt-F3 as wayland uses F1 and there is an (unusable) X server on F2 for xwayland. Then, after logging in sudo apt update sudo apt full-upgrade If that's not enough try sudo apt install task-kde-desktop
  26. Can you copy those dtbo's to /boot/user-overlays (maybe they will need renaming) Then activate them in armbianEnv.txt? https://docs.armbian.com/User-Guide_Armbian_overlays/
  27. Hey @Nick A, first of all, thanks for providing us with the build, I flashed and tried the image, But I could not see kvm enabled in the system. Is this expected? some example outputs: ~$ ls -l /dev/kvm ls: cannot access '/dev/kvm': No such file or directory ~$ sudo dmesg | grep -i kvm [ 0.184039] kvm [1]: HYP mode not available also no output on lscpu | grep Virtualization
  28. An apt error related to ntpdate typically indicates a time synchronization issue, as apt relies on accurate system time for validating package release files. https://www.google.com/search?sca_esv=55588fd05011d482&rlz=1CDGOYI_enCA922CA922&hl=en-US&sxsrf=AE3TifMjcn14YNfEQNUHV48vtdb2hNOADw:1763573317647&q=How+to+fix+apt+error+around+ntpdate&sa=X&ved=2ahUKEwiLzojJ3v6QAxUbEFkFHatLG24Q1QJ6BAgQEAE&biw=390&bih=665&dpr=3
