  2. An update. I suspect that the issue (or at least 1 issue) is a regression in the handling of MMC (SD card driver in the kernel). I suspect this is a regression as this issue did not hit me on earlier builds. I set up a netconsole, and received the following stack trace: [ 216.236507] I/O error, dev mmcblk0, sector 849688 op 0x0:(READ) flags 0x84700 phys_seg 1 prio class 2 [ 216.524566] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:353: I/O error 10 writing to inode 131108 starting block 323201) [ 216.534718] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:353: I/O error 10 writing to inode 131109 starting block 323202) [ 216.544920] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:353: I/O error 10 writing to inode 131110 starting block 323203) [ 216.560591] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:353: I/O error 10 writing to inode 131111 starting block 323204) [ 216.575914] EXT4-fs (mmcblk0p2): failed to convert unwritten extents to written extents -- potential data loss! (inode 131108, error -5) [ 216.587187] Buffer I/O error on device mmcblk0p2, logical block 270977 [ 216.601434] EXT4-fs (mmcblk0p2): failed to convert unwritten extents to written extents -- potential data loss! (inode 131109, error -5) [ 216.601564] ------------[ cut here ]------------ [ 216.608348] Buffer I/O error on device mmcblk0p2, logical block 270978 [ 216.608383] WARNING: CPU: 0 PID: 129 at drivers/mmc/host/meson-mx-sdio.c:446 meson_mx_mmc_irq_thread+0x168/0x174 [ 216.608467] EXT4-fs (mmcblk0p2): failed to convert unwritten extents to written extents -- potential data loss! (inode 131110, error -5) [ 216.608485] Buffer I/O error on device mmcblk0p2, logical block 270979 [ 216.612894] Modules linked in: rpcsec_gss_krb5 [ 216.619667] EXT4-fs (mmcblk0p2): failed to convert unwritten extents to written extents -- potential data loss! (inode 131111, error -5) [ 216.629626] auth_rpcgss [ 216.629674] Buffer I/O error on device mmcblk0p2, logical block 270980 [ 216.629700] zram [ 216.632164] Aborting journal on device mmcblk0p2-8. [ 216.641941] zsmalloc [ 216.642033] JBD2: I/O error when updating journal superblock for mmcblk0p2-8. [ 216.648457] binfmt_misc [ 216.676718] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1639: inode #598: comm dpkg-reconfigur: reading directory lblock 0 [ 216.680959] evdev [ 216.681075] EXT4-fs (mmcblk0p2): I/O error while writing superblock [ 216.683223] snd_soc_meson_aiu snd_soc_meson_gx_sound_card snd_soc_hdmi_codec snd_soc_meson_card_utils snd_soc_meson_codec_glue snd_soc_core snd_pcm meson_ir snd_timer rc_core [ 216.683268] EXT4-fs (mmcblk0p2): Remounting filesystem read-only [ 216.683278] thermal_generic_adc snd meson_saradc soundcore cfg80211 rfkill efi_pstore pstore netconsole [ 216.744185] CPU: 0 UID: 0 PID: 129 Comm: irq/35-c1108c20 Not tainted 6.12.47-current-meson #3 [ 216.744207] Hardware name: Amlogic Meson platform [ 216.744212] Call trace: [ 216.744225] unwind_backtrace from show_stack+0x10/0x14 [ 216.744259] show_stack from dump_stack_lvl+0x50/0x64 [ 216.744275] dump_stack_lvl from __warn+0x80/0x11c [ 216.744294] __warn from warn_slowpath_fmt+0x17c/0x188 [ 216.744311] warn_slowpath_fmt from meson_mx_mmc_irq_thread+0x168/0x174 [ 216.744337] meson_mx_mmc_irq_thread from irq_thread_fn+0x1c/0x7c [ 216.744364] irq_thread_fn from irq_thread+0x134/0x224 [ 216.744378] irq_thread from kthread+0xe0/0xfc [ 216.744396] kthread from ret_from_fork+0x14/0x28 [ 216.744411] Exception stack(0xf1075fb0 to 0xf1075ff8) [ 216.744420] 5fa0: 00000000 00000000 00000000 00000000 [ 216.744428] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.744435] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 216.744458] ---[ end trace 0000000000000000 ]--- [ 217.163204] mmc0: new high speed SDHC card at address 0002 [ 217.163907] mmcblk0: mmc0:0002 Which suggests the SD card was connected and disconnected. I have already ruled out faulty SD card (happens on any SD card I use, as well as a thorough stress test on the current card prior to use). Further research tells me "The Amlogic Meson8b (S805) SoC’s MMC controller has known quirks." I switched to USB rootfs (external HDD), and I still get the same failure, but as it is just the boot partition being unmounted and remounted the system remains up. Ideally I would propose a patch to fix this, but I am not a kernel developer, and the changes between 3.10 and 6.12 are huge (as to be expected) so identifying what is required and where is non-trivial for me. For now, I am sticking with rootfs on USB as my interim fix, but I am going to keep netconsole up and monitor over the next couple of weeks to see if we hit another issue (when I tested this in the past, I was also getting failures with rootfs on an external USB stick, so I am not convinced I am completely out of the woods yet).
  4. AFBC support has been merged to PanVK and will be available in the Mesa 25.3 release! This new enablement reduces memory bandwidth and boosts performance. View the full article
  5. Hi, I’m new to the forum and just wanted to take a moment to appreciate the incredible work Armbian has done for the community. I have been tinkering around with Radxa rock 5 ITX SBC and Armbian. I flashed UEFI EDK2 for Radxa rock 5 ITX  v1.1 from EDK2 porting to RK3588 initiative. While I can install ARM64 version of Ubuntu and Debian, none of them had support for H/W transcoding. So I decided to build an Armbian which used vendor kernel and had `uefi-edk2-3588` extension. Full build report is linked in this Armbian paste ./compile.sh \ BOARD=rock-5-itx \ RELEASE=trixie \ BRANCH=vendor \ BUILD_MINIMAL=yes \ BUILD_DESKTOP=no \ KERNEL_CONFIGURE=no \ NETWORKING_STACK=systemd-networkd \ EXPERT=yes \ CLEAN_LEVEL=extras \ ENABLE_EXTENSIONS=mesa-vpu,uefi-edk2-rk3588 \ KERNEL_BTF=yes \ SHARE_LOG=yes \ CONSOLE_AUTOLOGIN=no \ build I flashed the resulting image to a usb stick and booted system off it. This is when I had encountered problems. armbian-upgrade complained about a readonly system root@rock-5-itx:~# armbian-upgrade Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 http://security.debian.org trixie-security InRelease Hit:4 http://deb.debian.org/debian trixie-backports InRelease Hit:5 https://github.armbian.com/configng stable InRelease Ign:6 http://mirror.twds.com.tw/armbian-apt trixie InRelease Err:7 http://mirror.twds.com.tw/armbian-apt trixie Release Could not open file /var/lib/apt/lists/partial/apt.armbian.com_dists_trixie_Release - open (30: Read-only file system) [IP: 103.147.22.36 80] Warning: chown to _apt:root of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chown to _apt:root of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chmod 0755 of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: Not using locking for read only lock file /var/lib/apt/lists/lock Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.foxhPQ - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.ZQLLDs - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.k64ifr - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.kWgd4F - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.pSkidL - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.PoF76X - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/deb.debian.org_debian_dists_trixie_InRelease - PrepareFiles (30: Read-only file system) Warning: chown to _apt:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chmod 0600 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/deb.debian.org_debian_dists_trixie-updates_InRelease - PrepareFiles (30: Read-only file system) Warning: chown to root:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chmod 0644 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chown to _apt:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chmod 0600 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/security.debian.org_dists_trixie-security_InRelease - PrepareFiles (30: Read-only file system) Warning: chown to root:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chmod 0644 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chown to _apt:root of file /var/lib/apt/lists/security.debian.org_dists_trixie-security_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chmod 0600 of file /var/lib/apt/lists/security.debian.org_dists_trixie-security_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chown to root:root of file /var/lib/apt/lists/security.debian.org_dists_trixie-security_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chmod 0644 of file /var/lib/apt/lists/security.debian.org_dists_trixie-security_InRelease failed - 201::URIDone (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/deb.debian.org_debian_dists_trixie-backports_InRelease - PrepareFiles (30: Read-only file system) Warning: chown to _apt:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chmod 0600 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/github.armbian.com_configng_dists_stable_InRelease - PrepareFiles (30: Read-only file system) Warning: chown to root:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chmod 0644 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chown to _apt:root of file /var/lib/apt/lists/github.armbian.com_configng_dists_stable_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chmod 0600 of file /var/lib/apt/lists/github.armbian.com_configng_dists_stable_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chown to root:root of file /var/lib/apt/lists/github.armbian.com_configng_dists_stable_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chmod 0644 of file /var/lib/apt/lists/github.armbian.com_configng_dists_stable_InRelease failed - 201::URIDone (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/apt.armbian.com_dists_trixie_InRelease - PrepareFiles (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/apt.armbian.com_dists_trixie_Release - PrepareFiles (30: Read-only file system) Error: The repository 'http://apt.armbian.com trixie Release' no longer has a Release file. Notice: Updating from such a repository can't be done securely, and is therefore disabled by default. Notice: See apt-secure(8) manpage for repository creation and user configuration details. Warning: Problem unlinking the file /var/lib/apt/lists/github.armbian.com_configng_dists_stable_main_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_main_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_contrib_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_non-free_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_non-free-firmware_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_contrib_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_main_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_non-free-firmware_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_non-free_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_contrib_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_non-free_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_non-free-firmware_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_non-free_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_non-free-firmware_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_non-free_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_contrib_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_main_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_non-free_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_main_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_non-free-firmware_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_contrib_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_non-free-firmware_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_non-free_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_contrib_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Not using locking for read only lock file /var/lib/dpkg/lock-frontend Warning: Not using locking for read only lock file /var/lib/dpkg/lock Error: Archives directory /var/cache/apt/archives/partial is missing. - Acquire (2: No such file or directory) Warning: chown to _apt:root of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chown to _apt:root of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chmod 0755 of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: Not using locking for read only lock file /var/lib/apt/lists/lock Warning: Not using locking for read only lock file /var/lib/dpkg/lock-frontend Warning: Not using locking for read only lock file /var/lib/dpkg/lock Error: Archives directory /var/cache/apt/archives/partial is missing. - Acquire (2: No such file or directory) armbian-install only shows /dev/ but lsblk and blkid can see all drives. I am sorry for the long post.
  6. perhaps someone who's more knowledgeable could update the script to work on newer versions than buster, like bookworm or trixie?
  7. @remolaan "...Hey i have a SDMC DV8040 stb ,SoC-Amlogic S805X,CPU-Quad-core 1.2 GHz,GPU-ARM Mali-450,RAM-1GB,Storage-8GB it currently runs custom made android 9..." Please @remolaan, could you send me a working download link for the custom Android 9 system you made?
  8. Hello. I have an old "Ott Amlogic S805 rlt8188 (wifi) 1GB/8GB" so Android 4.4.2 is fully outdated (It is no longer supported by Google, so it is unusable.) Is there an Armbian release that can be installed on "this fossil" 🙂 ?
  9. You can add APA to your system and as one of the benefits get a managed GPG key so you should not run into this issue again in the future.
  10. Armbian 25.8.1 Noble XFCE (mainline Kernel: 6.16.6-edge-rockchip64) + PanVk - mesa 23.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.7 (https://ryanfortner.github.io/box64-debs/) + wine-10.15-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.15) + DXVK-stripped v2.7.1 ~60fps@720p Hades
  11. Hello @Ian Coelho, have you ever got any solution? I got the same issue
  12. As long as you keep the discussion about this at their place... ophub is (ab)using the name Armbian without permission and they do not contribute to the core development process. Rather they trick users into thinking they get support here and therefore (ab)using our resources.
  13. zero2w != zero2 moved
  14. Hi All First post here. Have been using Rpi Zero 2W for a couple of years in various installations and other then speed been happy with it. So got an Orange Pi Zero 2 W in an attempt to use it as a plug in replacement for the Rpi. Installed Armbian and other than a booting issue, it all works. The first obstacle is the i2c, it is obvious that is nowhere near as easy as a Rpi to set up. I have read many posts and get more confused as the days go on. So, the question: Is there a step by step instruction on how to enable I2C. I am connecting 2 x ADS1115 A2D converters, one at &H48 and the 2nd at &H49. When I use i2cdetect -l i2c-0 i2c DesignWare HDMI i2c-1 i2c mv64xxx_i2c Adapter i2c-2 i2c ditto When I use i2cdetect -y 0 &h30 and &h50 show up When I use i2cdetect -y 1 I get UU on &h36 In software, I can do a fd = i2c_open("/dev/i2c-0") or use i2c-1 rc = i2cselect (fd,&h48,0) BUT, I cannot write or read to the device.(obviously because it does not exist according to i2cdetect ) My armbianEnv.txt has overlays=i2c3 changed from i2c0 after reading some posts. dtparam i2c_arm=on In armbian-config /system/kernel/booto001/ I have ticked i2c0-pi and for 2 and 3 as well. So after all that I have no idea how to proceed. Regards EDIT: kern.log has repeated entries as follows: mv64xxx_i2c 5002000 Error applying settings reverse things back
  15. I have the tinkerboard rk3288, where do I find the mpv-legacy
  16. Yesterday
  17. Yeah, I wasn't asking for diagnostics, I realise that this issue could be for a myriad of reasons, just I was sure (before) that it was hardware related, now I'm not so sure. FWIW, it has just happened again less than an hour after boot, so I'm going to pull the card and chroot in to analyse. (I'm a software developer, so am well aware of the 'it don't go, what's wrong?' approach to tech support 😉) Interestingly, I was still logged in on an ssh shell, and I realised there was an issue when it was telling me that `cat` was an unknown command (clearly not!). I logged out, and now got the dreaded "Connection reset by 192.168.1.44 port 22". I also ran a full badblocks pass (4 real passes) on the SD card prior to imaging just to 100% make sure the card is fine. My main concern is that it will not have flushed logs to disk after the issue, so I suspect I will find nothing. ____ Edit: It looks like Armbian has rsync on a schedule to hold logs in RAM and perhaps periodically copy back to HDD. so unfortunately I have no useful info here. Going to look into the Armbian docs and see if I can get it to log directly to disk whilst I test. ______________ Another edit: I managed to disable ramlog, but unfortunately nothing of note has been written to the log files. I have tried connecting a monitor via HDMI, but am getting no output. I am sure this is fixable, but not sure how much I'm prepared to fiddle around with a box that just wants to lock up after some undetermined amount of time. I'm going to install the official Ubuntu 18.04 image (urrrgh) and leave it running for a long while. If that displays the same symptoms, then I can safely say this board is e-waste. If it does not, then I will come back to it and try to get myself an output.
  18. @torz77 Without logs and diagnostic information it's hard to tell what is going on because what you're saying is the equivalent of "it doesn't work" Nonetheless I had the same symptoms when my SDcard was dying (bad sectors here and there). The kernel and network layer was loaded in to memory OK, so pings would work, but ssh calls upon extra binaries and files from the SD card and I was getting I/O errors, hence would result in SSH dying which is the connection refused the client sees. I had to connect mine to a display for the duration of a diagnostic session but thankfully it was easily reproducible so the error glared out. A replacement SD card got me there.
  19. I wonder if that is related to the issue I've been having. Not long after I posted my last message, I hit an issue where the Odroid would stop allowing me to SSH in (connection refused) but would still respond to pings. I tried with many different SD Cards (and USB Hard disks) and the issue would not go away. Could happen after a few hours or a week or so. In the end I just took the device out of service, as I assumed that it was just dying. My Odroid is headless, so can't connect to console to see any potential error messages. I can't remember how far I dug into logs, but I am sure I must have. I have now re-imaged it again, with latest Armbian Stable on Trixie, and will monitor it for further issues. I still suspect the device is dying, but your message has given me hope that it is not. I would be interested to know if anyone else is experiencing similar symptoms. v25.11 rolling for Odroid C1 running Armbian Linux 6.12.47-current-meson Packages: Debian stable (trixie) Support: DIY (custom image)
  20. @Rodrigo Campos @kazekami_him I think @nitrolack and @afiftyp had the same Transpeed M98-8k board. It booted fine with my transpeed image. (other than wifi) They didn't have a board that had secure boot. Check if your board is the same. Maybe you could try my older images. It could be the newer u-boot and patches broke the ram detection? Maybe your board is using a different ram?
  21. Hi and Thank @jock That's what I thought. I used ledconf-3 because that's the configuration you made specifically for my MX10 box. I ran a memtest, which went smoothly. The system is working, and I was able to compile rockchip mpp without any problems. The system is running Bookworm. Would it be better to update to Trixie or revert to a previous version? What do you think? I think the problem comes either from rk3318-box.dtb or from the overlays. Thanks again. 🤜🤛
  22. Hi @kazekami_him, Thanks for your information, but I have no idea in how to use this content for test it. Maybe @Nick A Could understand what this guy did and how to bring it to his port and help us to detect the correct ram amount.
  23. @jock well thanks but I already figured that part out 😊 my problem right now is that i can't find a single distro that works with my box . almost every one (even multitool) goes to a black screen and freezes excatly after 60 seconds . the best thing i could find was a android rom that have the same problem but in excatly 30 minute after booting up ! i did this stupid thing that did not backed up my original rom before writing to internal emcp flash 🤦‍♂️ if i can find any version that doesn't have this problem , i know how to merge armbian rootfs with it ! thank you again !
  24. Have you tried your python script with your Linux PC? If it happens again, you can tell that the problem is within the ESP32 program. I generally prefer having the most complex system (Armbian) poll the simplest device (ESP32), instead of the ESP32 interrupting the Armbian system. I found it more stable that way. Stay with wifi, and use the ESP32 serial port just for debugging. Program the ESP32 print an acknowledgement of data requests, and an alarm if it gets stuck in an unexpected state. I have also found ESP32 circuit or micro python very stable for serial port communications.
  25. I do not have any other monitor available but I did order a UART to usb device, and I have identified with a multimeter the uart pads, which are next to the SD card slot. I will keep this feed updated!
  26. Hello! You should really look to the board name in rk3318-config rather than relying to led-conf numbering; also your dmesg is showing a very bad error which is probably due to an unstable system rather than a bug
  27. rk322x armbian images never used the offset of 8192 sectors, only the multitool has such offset to increase compatibility with stock images
