use the images in this thread
I started down this path and realized that the patches are applied to downloaded linux kernel source. Normally, the kernel source is "cleaned" even if the build fails. I then found the sakura pi github page and the page has more recent commit than the Rock-s0, incorporates the kernel.dtsi while adhering the the u-boot requirements for rockpi's. U-boot for Rockpi. I'd like to base my build on the more up-to-date code. The easist way to do this is set CLEAN_LEVEL="" but I'm running into issues with the patches in GitHub: Sakura-Pi failing to apply. Essentially, I would iike to have the patches apply, not necessarily build and have the files generated by the patches remain. I have a large dtb file, extracted from Sovol's OEM firmware, that I would like to copy/paste into the generated *.dtb file, rename the *csc file and the defconfig file, and then generate a patch against clean source. Conceptually, this should work and I'm suprised it is this difficult to generate a new board for an existing family. Alternatively, a script could generate a file from a highlited portion of a patch and generate a file. Or is is possbile to run ./compile.sh a step at a time? It would be helpful in this setting, very instructive about the process and would narrow down build failures. Am I on the right path? Any step-by-step examples and or links to helpful scripts?
Hi, would this image work on x96q?
I have to be upfront: I'm not a developer. I'm an ops/observability engineer who knows how to use software to get things done. I know a bit of Go — not much — and I have no formal background in software design. What I do know is what I need, and what was missing. So I built it. Take the code with that in mind. The problem I run a Kobol Helios64 as my home NAS — a five-bay ARM board that's been sitting in a sweet spot between "serious hardware" and "abandoned by its software ecosystem." I tried the usual NAS UIs. They were either too heavy, too opinionated about owning the underlying OS, or simply unmaintained. None of them gave me a clean window into my ZFS pools without dragging in a container runtime, a Node.js server, or a Python daemon alongside them. I wanted something simple: observe and manage my storage from a browser, on a machine that stays close to a vanilla Armbian or FreeBSD install. No agents, no frameworks, no surprises. What I built dumpstore — a lightweight ZFS management UI written in Go. link: https://github.com/langerma/dumpstore It's a single compiled binary with a bunge of html/js/css/ansible playbooks. No database. No Node. No container runtime. Ansible handles writes (dataset creation, snapshots, user/group management, ACLs) Current features: Pool overview — health, usage, vdev tree, fragmentation Live I/O statistics per pool (SSE-pushed, no polling) S.M.A.R.T. data per disk — temperature, power-on hours, reallocated sectors Dataset browser — collapsible tree, compression, quota, mountpoint Dataset create / edit / delete Snapshot management — list, create (recursive), delete User & group management — create, edit, delete; system users protected ACL management — POSIX and NFSv4, recursive apply supported Prometheus /metrics endpoint (because of course) Runs on Linux (systemd) and FreeBSD (rc.d) Builds with make build && sudo make install — that's it What it is not: a full TrueNAS replacement. SMB/NFS share management, a file browser, and ZFS send/receive are on the roadmap — but I'm building deliberately, one thing at a time. Why Armbian specifically The Helios64 is the reason this exists. If you're running Armbian on a Helios64, an older ARM server, or any ZFS box where you care about what's actually installed — this was built for you. Feedback welcome Since I'm not a developer by trade, I'm sure there are things I've done in a way that makes experienced Go or software folks cringe. Issues, PRs, and honest feedback are very welcome. The code is small enough to be auditable — main.go plus a handful of internal packages. Markus Langer
Thank you very much. Unfortunately, Trixie won't start. BootROM - 1.73 Booting from MMC BootROM: Bad header at offset 00000200 … BootROM: Bad header at offset 02E00000 BootROM: Bad h Trying Uart
I need you to understand something very important: the manufacturer is infecting the boards with Java botnet software. All the software you should use is developed by the Armbian community. Welcome to the Armbian community! Now that you are a member, you must develop software that schedules the board's power-on. -
Which armhf version should I choose?
eselarm replied to Humboldt's topic in Software, Applications, Userspace
Maybe see https://wiki.postmarketos.org/wiki/Medion_Chromebook_S2015_(google-veyron-mighty) It is RK3288, so an Armbian Rockchip kernel might do something, but I have no clue about DeviceTree and/or bootloader. Alpine is quite different from Armbian/Debian but maybe with that bootloader+kernel+DTB and Armbian rootfs it might do something, but make sure you have seril debug cable. In general might need to find solder points on motherboard/PCB or some specific resistor value on OTG ID pin. -
Werner replied to Humboldt's topic in Software, Applications, Userspace
None of these images will most likely work. https://docs.armbian.com/User-Guide_FAQ/#why-no-universal-image -
Hello, I have a Medion Chromebook S2015 with a CPU (armv7 processor rev 1 (v7l)) and RAM (2062808 kB). So it's 32-bit. I want to install Linux on it. To do this, I need an armhf architecture. However, under armhf on ARMBIAN, I find (Inovato Quadra, Khadas Edge 2, Khadas VIM4, Mekotronics R58 4X4, Mekotronics R58 HD, Muse Pi Pro, NanoPC T6 LTS, NanoPi M5, Nanopi M6, Nanopi R3S / LTS, NanoPi R76S, Radxa Rock 5B Plus, Radxa Rock 5C and Radxa Rock 5T). What should I select? Are there still 32-bit versions available?
Try to build from this PR: https://github.com/armbian/build/pull/9381 - use CURRENT branch - enable additional DEBUT if it doesn't proceed - leave u-boot as is or try with most recent
The issue was that these variables in the kernel config were set to 10. Setting them to 12 allowed uart10 to initilaize. CONFIG_SERIAL_8250_NR_UARTS=12 CONFIG_SERIAL_8250_RUNTIME_UARTS=12
Hello everyone Just would like to start a discussion about the current state of video acceleration (decoding only, h.265/h.264/av1). The soc (rk3588) recently got mainline support for these features in 7.0: https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md Has anyone tested this on a OPI5 already, especially using Kodi? Does this work ootb there now? Regards, XXXBold
Hi! I have an OrangePi3 (not Zero!) running Armbian (H6), with a TFT ILI9486 display connected via the 26-pin header. The screen works fine, but the XPT2046 touch controller does not initialize. Here’s the situation: CS0 on PH5, DC on PD16, RESET on PD21. XPT2046 (CS1) on PL8, IRQ on PD24. I tried adding XPT2046 to the overlay with all parameters configured (ti,x/y-min/max, pressure, swap-xy, etc.). The overlay compiles successfully, but when loading the module it says: ads7846 spi0.1: probe with driver ads7846 failed with error -22 I also tried loading the ads7846 module with parameters via modprobe — all parameters are ignored because the driver only supports configuration via Device Tree. Here is my current overlay: /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h6"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&pio 7 3 0>; display: display@0 { compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; spi-max-frequency = <20000000>; txbuflen = <65536>; rotate = <90>; bgr = <0>; fps = <30>; buswidth = <8>; regwidth = <16>; height = <480>; width = <320>; dc-gpios = <&pio 3 16 0>; reset-gpios = <&pio 3 21 1>; debug = <3>; init = <0x10000b0 0x00 // Interface Mode Control 0x1000011 // Sleep Out 0x20000ff // Delay (255ms) 0x10000C0 0x0D 0x0D // Power Control 1 0x10000C1 0x43 // Power Control 2 0x10000C5 0x00 0x48 0x80 // VCOM Control 1 0x10000C7 0x00 // VCOM Control 2 0x1000036 0x28 // Memory Access Control (Rotação) 0x100003A 0x55 // Pixel Format Set (16bit) 0x10000B1 0xB0 0x11 // Frame Rate Control 0x10000F0 0x01 // Enable Extended Comand Set 0x10000F6 0x00 0x01 0x32 // SPI ilInterface Control 0x1000026 0x01 // Gamma Set 0x10000E0 0x0F 0x31 0x2B 0x0C 0x0E 0x08 0x4E 0xF1 0x37 0x07 0x10 0x03 0x0E 0x09 0x00 // Positive Gamma Correction 0x10000E1 0x00 0x0E 0x14 0x03 0x11 0x07 0x31 0xC1 0x48 0x08 0x0F 0x0C 0x31 0x36 0x0F // Negative Gamma Correction 0x10000B6 0x02 0x02 0x3B // Display Function Control 0x1000011 // Sleep Out 0x20000ff // Delay (255ms) 0x1000029>; // Display ON }; /* --- ADS7846 (XPT2046) --- */ ads7846: ads7846@1 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <1000000>; interrupt-parent = <&pio>; interrupts = <3 24 2>; pendown-gpio = <&pio 3 24 1>; cs-gpios = <&pio 11 8 0>; /* OPTIONS */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0xFFF>; ti,y-max = /bits/ 16 <0xFFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFF>; ti,x-plate-ohms = /bits/ 16 <400>; ti,swap-xy = <1>; }; }; }; }; Could anyone advise how to properly connect XPT2046 so that PD24 is used as IRQ? Is there a working example overlay for TFT ILI9486 + XPT2046 on OrangePi3 / H6? Or has anyone managed to use the touch controller via a module without overlay? Or is that simply impossible on this kernel? I would really appreciate any working examples or advice!
Try setenv kernel_addr_r 0x42000000 setenv fdt_addr_r 0x43000000 setenv ramdisk_addr_r 0x44000000 setenv bootm_low 0x40000000 setenv bootm_size 0x20000000 setenv bootm_mapsize 0x20000000 setenv fdt_high 0x5fffffff setenv initrd_high 0x5fffffff Some time boot some time not (( Begain crazy 😷
____ _ _ _ _ / ___| _| |__ (_) ___| |_ _ __ _ _ ___| | __ | | | | | | '_ \| |/ _ \ __| '__| | | |/ __| |/ / | |__| |_| | |_) | | __/ |_| | | |_| | (__| < \____\__,_|_.__/|_|\___|\__|_| \__,_|\___|_|\_\ Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 6.6.75-legacy-sunxi System load: 1.07 Up time: 1 min Memory usage: 4 % of 1978Mb IP: 192.168.1.96 CPU temp: 43°C Usage of /: 27% of 7.9G [ 268 updates to install: apt-get upgrade ] root@volumio:~# dmesg [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 6.6.75-legacy-sunxi (build@armbian) (arm-linux-gnue abihf-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu ) 2.42) #3 SMP PREEMPT Sat Feb 1 17:37:57 UTC 2025 [ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache [ 0.000000] OF: fdt: Machine model: Cubietech Cubietruck [ 0.000000] printk: debug: ignoring loglevel setting. [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 M iB [ 0.000000] OF: reserved mem: initialized node default-pool, compatible id sh ared-dma-pool [ 0.000000] OF: reserved mem: 0x4a000000..0x4fffffff (98304 KiB) map reusable default-pool [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000040000000-0x000000006fffffff] [ 0.000000] HighMem [mem 0x0000000070000000-0x00000000bdffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x00000000bdffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bdffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT [ 0.000000] percpu: Embedded 18 pages/cpu s43860 r8192 d21676 u73728 [ 0.000000] pcpu-alloc: s43860 r8192 d21676 u73728 alloc=18*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Kernel command line: console=ttyS0,115200 console=tty0 ignore_log level loglevel=8 \ root=/dev/mmcblk0p1 rootwait rootfstype=ext4 rw \ panic=10 consoleblank=0 net.ifnames=0 biosdevname=0 enforcing=0 \ clk_ignore_unused [ 0.000000] Unknown kernel command line parameters "\ \ \ biosdevname=0", wil l be passed to user space. [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, li near) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 514368 [ 0.000000] allocated 2064384 bytes of page_ext [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] Memory: 1926540K/2064384K available (8192K kernel code, 1367K rwd ata, 6396K rodata, 1024K init, 317K bss, 39540K reserved, 98304K cma-reserved, 1 277952K highmem) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] ftrace: allocating 36178 entries in 107 pages [ 0.000000] ftrace: allocated 106 pages with 4 groups [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 ji ffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 43980 46511097ns [ 0.000018] Switching to timer-based delay loop, resolution 41ns [ 0.000490] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_ idle_ns: 79635851949 ns [ 0.001502] Console: colour dummy device 80x30 [ 0.001528] printk: console [tty0] enabled [ 0.002602] Calibrating delay loop (skipped), value calculated using timer fr equency.. 48.00 BogoMIPS (lpj=24000) [ 0.002652] CPU: Testing write buffer coherency: ok [ 0.002736] pid_max: default: 32768 minimum: 301 [ 0.009780] LSM: initializing lsm=capability,bpf,integrity [ 0.013970] LSM support for eBPF active [ 0.016037] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linea r) [ 0.016084] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.026743] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.028723] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 r cu_task_cpu_ids=2. [ 0.029062] RCU Tasks Rude: Setting shift to 1 and lim to 1 rcu_task_cb_adjus t=1 rcu_task_cpu_ids=2. [ 0.029317] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adju st=1 rcu_task_cpu_ids=2. [ 0.029554] Setting up static identity map for 0x40100000 - 0x40100054 [ 0.029882] rcu: Hierarchical SRCU implementation. [ 0.029918] rcu: Max phase no-delay instances is 400. [ 0.031448] smp: Bringing up secondary CPUs ... [ 0.043079] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.043342] smp: Brought up 1 node, 2 CPUs [ 0.043416] SMP: Total of 2 processors activated (96.00 BogoMIPS). [ 0.043444] CPU: All CPU(s) started in HYP mode. [ 0.043464] CPU: Virtualization extensions available. [ 0.045123] devtmpfs: initialized [ 0.061526] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4 [ 0.062156] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 1911260446275000 ns [ 0.062265] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.072993] pinctrl core: initialized pinctrl subsystem [ 0.076756] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.078880] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.080266] audit: initializing netlink subsys (disabled) [ 0.080872] audit: type=2000 audit(0.069:1): state=initialized audit_enabled= 0 res=1 [ 0.081641] thermal_sys: Registered thermal governor 'fair_share' [ 0.081659] thermal_sys: Registered thermal governor 'bang_bang' [ 0.081692] thermal_sys: Registered thermal governor 'step_wise' [ 0.081716] thermal_sys: Registered thermal governor 'user_space' [ 0.081739] thermal_sys: Registered thermal governor 'power_allocator' [ 0.081913] cpuidle: using governor ladder [ 0.081992] cpuidle: using governor menu [ 0.082269] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.082314] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.092957] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.093153] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.093313] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.093479] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.093624] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.093771] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.094207] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-contro ller@1c0d000 [ 0.094421] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-contro ller@1c0c000 [ 0.094895] /soc/interrupt-controller@1c81000: Fixed dependency cycle(s) with /soc/interrupt-controller@1c81000 [ 0.095139] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.095359] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.095590] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.095805] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.095937] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0d000 [ 0.096067] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0c000 [ 0.096175] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /display-frontend@1e20000 [ 0.096280] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /display-frontend@1e00000 [ 0.096417] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0d000 [ 0.096534] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0c000 [ 0.096638] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /display-frontend@1e20000 [ 0.096742] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /display-frontend@1e00000 [ 0.097863] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.098061] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.098219] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.098629] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.098782] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.098930] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.101800] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.102148] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.102463] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-contro ller@1c0d000 [ 0.102766] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-contro ller@1c0c000 [ 0.106363] /soc/pinctrl@1c20800: Fixed dependency cycle(s) with /soc/pinctrl @1c20800/clk-out-a-pin [ 0.112205] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.112375] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.112818] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.112934] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.113451] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.113665] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.113839] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.114046] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.114212] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0d000 [ 0.114370] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0c000 [ 0.114620] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /display-frontend@1e20000 [ 0.114781] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /display-frontend@1e00000 [ 0.115342] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.115574] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.115751] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.115959] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.116126] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0d000 [ 0.116343] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0c000 [ 0.116526] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /display-frontend@1e20000 [ 0.116718] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /display-frontend@1e00000 [ 0.119975] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /hdmi-connector [ 0.120269] /hdmi-connector: Fixed dependency cycle(s) with /soc/hdmi@1c16000 [ 0.129394] iommu: Default domain type: Translated [ 0.129462] iommu: DMA domain TLB invalidation policy: strict mode [ 0.130088] SCSI subsystem initialized [ 0.130771] libata version 3.00 loaded. [ 0.131174] usbcore: registered new interface driver usbfs [ 0.131290] usbcore: registered new interface driver hub [ 0.131387] usbcore: registered new device driver usb [ 0.131986] pps_core: LinuxPPS API ver. 1 registered [ 0.132031] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it> [ 0.132088] PTP clock support registered [ 0.133187] Advanced Linux Sound Architecture Driver Initialized. [ 0.135931] clocksource: Switched to clocksource arch_sys_counter [ 0.145715] VFS: Disk quotas dquot_6.6.0 [ 0.145819] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.163052] NET: Registered PF_INET protocol family [ 0.163574] IP idents hash table entries: 16384 (order: 5, 131072 bytes, line ar) [ 0.167109] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear) [ 0.167208] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.167260] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 0.167403] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear ) [ 0.167858] TCP: Hash tables configured (established 8192 bind 8192) [ 0.168145] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.168325] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.169413] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.170260] armv7-pmu pmu: hw perfevents: no interrupt-affinity property, gue ssing. [ 0.173064] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counter s available [ 0.179385] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 0.179585] zbud: loaded [ 0.385775] Key type asymmetric registered [ 0.386307] bounce: pool size: 64 pages [ 0.387002] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 48) [ 0.387472] io scheduler mq-deadline registered [ 0.387522] io scheduler kyber registered [ 0.388291] io scheduler bfq registered [ 0.511597] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.519421] misc dump reg init [ 0.526431] brd: module loaded [ 0.541243] loop: module loaded [ 0.548773] sunxi-rtc 1c20d00.rtc: registered as rtc0 [ 0.548877] sunxi-rtc 1c20d00.rtc: setting system clock to 2026-03-04T11:25:5 1 UTC (1772623551) [ 0.549293] i2c_dev: i2c /dev entries driver [ 0.552776] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, now ayout=0) [ 0.555515] ledtrig-cpu: registered to indicate activity on CPUs [ 0.556282] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 6370868154 ns [ 0.646743] NET: Registered PF_PACKET protocol family [ 0.646889] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 0.647545] Key type dns_resolver registered [ 0.647892] Registering SWP/SWPB emulation handler [ 0.662404] registered taskstats version 1 [ 0.678238] Key type .fscrypt registered [ 0.678308] Key type fscrypt-provisioning registered [ 0.684163] Key type encrypted registered [ 0.713816] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pi not found, using dum my regulator [ 0.714574] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.718035] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 0.720063] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dum my regulator [ 0.721774] printk: console [ttyS0] disabled [ 0.742858] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 69, base_baud = 15 00000) is a U6_16550A [ 0.743044] printk: console [ttyS0] enabled [ 2.190471] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 70, base_baud = 15 00000) is a U6_16550A [ 2.200103] serial serial0: tty port ttyS2 registered [ 2.206440] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dum my regulator [ 2.215289] sun7i-dwmac 1c50000.ethernet: IRQ eth_wake_irq not found [ 2.221756] sun7i-dwmac 1c50000.ethernet: IRQ eth_lpi not found [ 2.227972] sun7i-dwmac 1c50000.ethernet: PTP uses main clock [ 2.233811] sun7i-dwmac 1c50000.ethernet: no regulator found [ 2.240030] sun7i-dwmac 1c50000.ethernet: Version ID not available [ 2.246298] sun7i-dwmac 1c50000.ethernet: DWMAC1000 [ 2.251303] sun7i-dwmac 1c50000.ethernet: No HW DMA feature register supporte d [ 2.258560] sun7i-dwmac 1c50000.ethernet: TX Checksum insertion supported [ 2.265382] sun7i-dwmac 1c50000.ethernet: Normal descriptors [ 2.271074] sun7i-dwmac 1c50000.ethernet: Ring mode enabled [ 2.285888] axp20x-i2c 0-0034: AXP20x variant AXP209 found [ 2.301538] axp20x-adc axp20x-adc: DMA mask not set [ 2.309646] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set [ 2.343988] axp20x-ac-power-supply axp20x-ac-power-supply: DMA mask not set [ 2.368270] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set [ 2.400304] axp20x-i2c 0-0034: Backup (RTC) battery charging is enabled [ 2.407207] axp20x-i2c 0-0034: AXP20X driver loaded [ 2.421282] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dum my regulator [ 2.421327] sun4i-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dum my regulator [ 2.439280] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 2.449782] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regul ator [ 2.457675] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regula tor [ 2.473211] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB [ 2.497373] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP _PMP [ 2.505148] ahci-sunxi 1c18000.sata: forcing PORTS_IMPL to 0x1 [ 2.511826] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0 x1 impl platform mode [ 2.516771] mmc0: host does not support reading read-only switch, assuming wr ite-enable [ 2.522958] ahci-sunxi 1c18000.sata: flags: ncq sntf pm led clo only pio slum part ccc [ 2.531265] mmc0: new high speed SDXC card at address 0001 [ 2.545012] mmcblk0: mmc0:0001 SD64G 58.3 GiB [ 2.545108] scsi host0: ahci-sunxi [ 2.553673] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x1 00 irq 117 [ 2.554656] mmcblk0: p1 [ 2.565669] of_cfs_init [ 2.568521] ehci-platform 1c14000.usb: EHCI Host Controller [ 2.569221] ehci-platform 1c1c000.usb: EHCI Host Controller [ 2.576047] ehci-platform 1c14000.usb: new USB bus registered, assigned bus n umber 1 [ 2.580186] of_cfs_init: OK [ 2.589719] ohci-platform 1c14400.usb: Generic Platform OHCI controller [ 2.590587] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus n umber 2 [ 2.597388] ohci-platform 1c14400.usb: new USB bus registered, assigned bus n umber 3 [ 2.605964] ohci-platform 1c1c400.usb: Generic Platform OHCI controller [ 2.616244] clk: Not disabling unused clocks [ 2.619590] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus n umber 4 [ 2.624097] ALSA device list: [ 2.635425] ohci-platform 1c14400.usb: irq 120, io mem 0x01c14400 [ 2.635844] No soundcards found. [ 2.645447] ehci-platform 1c1c000.usb: irq 119, io mem 0x01c1c000 [ 2.651878] ohci-platform 1c1c400.usb: irq 121, io mem 0x01c1c400 [ 2.652025] ehci-platform 1c14000.usb: irq 118, io mem 0x01c14000 [ 2.664949] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 [ 2.672005] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00 [ 2.672295] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 6.06 [ 2.686636] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 2.694325] usb usb2: Product: EHCI Host Controller [ 2.699996] usb usb2: Manufacturer: Linux 6.6.75-legacy-sunxi ehci_hcd [ 2.706612] usb usb2: SerialNumber: 1c1c000.usb [ 2.712373] hub 2-0:1.0: USB hub found [ 2.716296] hub 2-0:1.0: 1 port detected [ 2.725231] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 6.06 [ 2.733744] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 2.741893] usb usb1: Product: EHCI Host Controller [ 2.747011] usb usb1: Manufacturer: Linux 6.6.75-legacy-sunxi ehci_hcd [ 2.753619] usb usb1: SerialNumber: 1c14000.usb [ 2.759304] hub 1-0:1.0: USB hub found [ 2.763177] hub 1-0:1.0: 1 port detected [ 2.768445] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bc dDevice= 6.06 [ 2.776948] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 2.784266] usb usb3: Product: Generic Platform OHCI controller [ 2.790393] usb usb3: Manufacturer: Linux 6.6.75-legacy-sunxi ohci_hcd [ 2.796980] usb usb3: SerialNumber: 1c14400.usb [ 2.802726] hub 3-0:1.0: USB hub found [ 2.806603] hub 3-0:1.0: 1 port detected [ 2.811697] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bc dDevice= 6.06 [ 2.820337] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 2.827653] usb usb4: Product: Generic Platform OHCI controller [ 2.833617] usb usb4: Manufacturer: Linux 6.6.75-legacy-sunxi ohci_hcd [ 2.840187] usb usb4: SerialNumber: 1c1c400.usb [ 2.845882] hub 4-0:1.0: USB hub found [ 2.849887] hub 4-0:1.0: 1 port detected [ 2.892640] ata1: SATA link down (SStatus 0 SControl 300) [ 2.924430] EXT4-fs (mmcblk0p1): mounted filesystem c15c8d11-cd4f-41fd-8824-d 41975865a75 r/w with writeback data mode. Quota mode: none. [ 2.937083] VFS: Mounted root (ext4 filesystem) on device 179:1. [ 2.953517] devtmpfs: mounted [ 2.967451] Freeing unused kernel image (initmem) memory: 1024K [ 2.974522] Run /sbin/init as init process [ 2.979713] with arguments: [ 2.982749] /sbin/init [ 2.985523] \ [ 2.987479] \ [ 2.989432] \ [ 2.991384] with environment: [ 2.994549] HOME=/ [ 2.996957] TERM=linux [ 2.999727] biosdevname=0 [ 3.299015] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 3.505775] usb 3-1: New USB device found, idVendor=08bb, idProduct=2902, bcd Device= 1.00 [ 3.514061] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.521234] usb 3-1: Product: USB PnP Sound Device [ 3.526057] usb 3-1: Manufacturer: C-Media Electronics Inc. [ 3.640964] random: crng init done [ 3.673470] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SEL INUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 3.687637] systemd[1]: Detected architecture 'arm'. [ 3.777382] systemd[1]: Failed to insert module 'ipv6' [ 3.788482] systemd[1]: Set hostname to <volumio>. [ 4.378960] systemd[1]: [/lib/systemd/system/mpd.service:17] Unknown lvalue ' ControlGroup' in section 'Service' [ 4.389248] systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue ' ControlGroupAttribute' in section 'Service' [ 4.538794] systemd[1]: Cannot add dependency job for unit display-manager.se rvice, ignoring: Unit display-manager.service failed to load: No such file or di rectory. [ 4.557766] systemd[1]: Expecting device dev-ttyS0.device... [ 4.564783] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 4.573012] systemd[1]: Started Forward Password Requests to Wall Directory W atch. [ 4.788778] fuse: init (API version 7.39) [ 5.301085] systemd-udevd[123]: starting version 215 [ 5.965330] sunxi-mmc 1c12000.mmc: allocated mmc-pwrseq [ 6.007107] sunxi-mmc 1c12000.mmc: initialized, max. request size: 16384 KB [ 6.034560] mmc1: Failed to initialize a non-removable card [ 6.275234] sun4i-ss 1c15000.crypto-engine: no reset control found [ 6.297699] sun4i-ss 1c15000.crypto-engine: Die ID 0 [ 6.416262] sun5i-a13-gpadc-iio: Failed to locate of_node [id: 0] [ 6.581124] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-00 34/axp20x-pek/input/input0 [ 6.853889] usbcore: registered new interface driver snd-usb-audio [ 6.941105] EXT4-fs (mmcblk0p1): re-mounted c15c8d11-cd4f-41fd-8824-d41975865 a75 r/w. Quota mode: none. [ 7.321837] systemd-journald[120]: Received request to flush runtime journal from PID 1 [ 11.038800] sun7i-dwmac 1c50000.ethernet eth0: Register MEM_TYPE_PAGE_POOL Rx Q-0 [ 11.049999] sun7i-dwmac 1c50000.ethernet eth0: PHY [stmmac-0:01] driver [Gene ric PHY] (irq=POLL) [ 11.058959] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support fou nd [ 11.066361] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabl ed [ 11.073748] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters ava ilable [ 11.081476] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW [ 11.089606] sun7i-dwmac 1c50000.ethernet eth0: configuring for phy/rgmii-id l ink mode [ 15.213705] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx root@volumio:~#
I try # Keep U-Boot relocations and early kernel mapping in a safe low window setenv bootm_low 0x40000000 setenv bootm_size 0x20000000 setenv bootm_mapsize 0x20000000 # Also cap where DTB/initrd may be copied setenv fdt_high 0x5fffffff setenv initrd_high 0x5fffffff but dont help * (
Hi! Have some problem with Cubietrack Sometime boot some time not Kernel setenv fdtfile sun7i-a20-cubietruck.dtb # safe low addresses setenv kernel_addr_r 0x42000000 setenv fdt_addr_r 0x43000000 setenv ramdisk_addr_r 0x44000000 # limit relocations setenv fdt_high 0x47f00000 setenv initrd_high 0x47f00000 mmc dev 0 mmc rescan setenv bootargs "console=ttyS0,115200 console=tty0 ignore_loglevel loglevel=8 \ root=/dev/mmcblk0p1 rootwait rootfstype=ext4 rw \ panic=10 consoleblank=0 net.ifnames=0 biosdevname=0 enforcing=0 \ nosmp mem=1024M clk_ignore_unused" echo ">> Boot device: mmc 0:1 ext4" if ext4load mmc 0:1 ${kernel_addr_r} /boot/zImage; then echo ">> Kernel loaded" else echo "### ERROR: /boot/zImage not found" reset fi if ext4load mmc 0:1 ${fdt_addr_r} /boot/dtb/${fdtfile}; then echo ">> DTB loaded" else echo "### ERROR: dtb not found" reset fi setenv initrd_arg "-" if ext4load mmc 0:1 ${ramdisk_addr_r} /boot/uInitrd; then setenv initrd_arg ${ramdisk_addr_r} fi bootz ${kernel_addr_r} ${initrd_arg} ${fdt_addr_r} root@volumio:~# cd /boot root@volumio:/boot# ls -all total 35200 drwxr-xr-x 7 root root 4096 Mar 4 11:44 . drwxr-xr-x 23 root root 4096 Mar 4 09:17 .. drwxr-xr-x 2 root root 4096 Feb 28 2016 bin -rw-r--r-- 1 root root 966 Mar 4 12:04 boot.cmd -rw-r--r-- 1 root root 1038 Mar 4 12:04 boot.scr -rw-r--r-- 1 root root 101188 Jan 22 2017 config-4.4.44 -rw-r--r-- 1 root root 101262 Apr 24 2016 config-4.4.8 -rw-r--r-- 1 root root 133815 Mar 21 2019 config-5.0.2-sunxi -rw-r--r-- 1 root root 159559 Mar 1 17:03 config-6.6.75-legacy-sunxi drwxr-xr-x 2 root root 4096 Mar 4 09:16 dtb drwxr-xr-x 3 root root 12288 Sep 12 2019 dtb-5.0.2-sunxi drwxr-xr-x 3 root root 12288 Feb 7 18:41 dtb-6.6.75-legacy-sunxi drwxr-xr-x 2 root root 4096 Feb 28 2016 dtb.old -rw-r--r-- 1 root root 0 Mar 3 17:32 .next lrwxrwxrwx 1 root root 24 Mar 3 16:54 script.bin -> /boot/bin/cubietruck.bin -rw------- 1 root root 1464739 Jan 22 2017 System.map-4.4.44 -rw------- 1 root root 1460350 Apr 24 2016 System.map-4.4.8 -rw-r--r-- 1 root root 2376380 Mar 21 2019 System.map-5.0.2-sunxi -rw-r--r-- 1 root root 2957247 Mar 1 17:03 System.map-6.6.75-legacy-sunxi -rw------- 1 root root 3384008 Jan 22 2017 vmlinuz-4.4.44 -rw------- 1 root root 3367664 Apr 24 2016 vmlinuz-4.4.8 -rwxr-xr-x 1 root root 4810496 Mar 21 2019 vmlinuz-5.0.2-sunxi -rw-r--r-- 1 root root 7824568 Mar 1 17:03 vmlinuz-6.6.75-legacy-sunxi -rw-r--r-- 1 root root 7824568 Mar 4 09:16 zImage root@volumio:/boot# uname -a Linux volumio 6.6.75-legacy-sunxi #3 SMP PREEMPT Sat Feb 1 17:37:57 UTC 2025 armv7l GNU/Linux root@volumio:/boot#
hi. Please tell me, I installed the image and bootloader on the emmc (armbian) on the radxa 5t and now I can't install another one because the board doesn't want to start from the CD card. what should I do? Im try this but doesnt work https://docs.radxa.com/en/rock5/rock5t/low-level-dev/maskrom/erase
Ý Nguyễn replied to Hqnicolas's topic in Rockchip CPU Boxes
I'm having trouble figuring out how to install a timer switch on the RK3566 board, or if there's any software from the manufacturer that can help with scheduling the power on/off times for the motherboard. -
@robertojHi, friend! How are you? How's your health? Do you have any news on the release of the Orange Pi Zero3 and ili9488 screen setup guide?
Does this mean that the latest version on which OMV7 can be installed is the following? https://fi.mirror.armbian.de/oldarchive/helios4/archive/Armbian_25.8.1_Helios4_bookworm_current_6.6.101_minimal.img.xz
thnx. it seems latest working vendor kernel for 3566 is 6.1.115. i already tried rk35xx, with bigtreetech_cb2.dtb but it stops at u-boot (in uart console) using orangepi-3b it boots, but gives errors in dmesg. when i try to add fdtfile bigtreetech_cb2.dtb, it stops boot .... 47274496 bytes read in 3902 ms (11.6 MiB/s) Failed to load '/boot/dtb/rockchip/rk3566-bigtreetech-cb2.dtb' libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' ..... but when i boot btt_cb2 as orangepi3b board, it boots and even shows mpp venc/dec/npu/whatever modules properly loaded. not checked yet if it works really maybe need to make some hybrid dtb from btt_cb2 and orange3b ========= btw, could You share what You do for 35xx board change? when i tried to change family rockchip64 to 35xx, it comiled, but not copied bigtreeetech_cb2.dtb to boot , and not boots ewven if i copy it by myself there
