  1. Yesterday
  2. Hello, can you please say, where i can find: Armbian_community_25.11.0-trunk.413_Aml-s9xx-box_plucky_edge_6.18.0-rc3.img thank you.
  3. Subject: X88MAX RK3328 - Cannot boot from SD/USB, need help installing Armbian Hello Armbian Community, I'm trying to install Armbian on my X88 RK3328 TV box but facing multiple issues. Need your expert help! Device Information: Model: X88MAX.p2.0.01.d4 SoC: Rockchip RK3328 Android Version: Android 9 (SDK 28) Board: Blue PCB (Hugsun design similar to T9) Storage: 4GB RAM + eMMC Buttons: Power button only (no visible reset button) What I've Tried: 1. SD Card Boot: Downloaded: Armbian_community_26.2.0-trunk.606_Rk3318-box_trixie_current_6.18.18_minimal.img.xz Downloaded: multitool_rk3318-3328.img Flashed to Netac SD card using BalenaEtcher (verified) SD card is detected in Android environment Problem: Box always boots Android, ignores SD card completely 2. USB Boot: Flashed Multitool to USB flash drive Problem: Same result - boots Android, ignores USB 3. Reset Button Method: Tried holding reset button (inside AV port) while powering on Problem: No change, still boots Android 4. Rooting Attempts: Tried KingRoot - stuck on "checking state" forever Device confirmed NOT ROOTED (Root Checker app) Problem: Cannot root to install from Android 5. Maskrom Mode: Have AndroidTool v2.38 ready Problem: PC shows "No Devices Found" when trying to enter Maskrom Current Status: ✅ SD card slot works (Android detects it) ✅ Multitool files accessible on SD card ✅ Have all necessary images downloaded ❌ Cannot boot from SD or USB ❌ Cannot root Android ❌ Cannot enter Maskrom mode My Goal: Install pure Armbian (not Android + Linux apps) for better performance and native Linux experience. Questions: Does anyone have X88 RK3328 working with Armbian? If yes, what method did you use? Is there a specific Armbian build for X88 boards? The generic Rk3318-box image doesn't boot. How to enter Maskrom mode on X88? PC shows "No Devices Found" - am I missing something? Can I convert Armbian .img to Rockchip firmware format for USB Burning Tool? Any X88-specific instructions or device tree files I should use? What I Have Ready: ✅ Armbian image (Rk3318-box minimal) ✅ Multitool image ✅ AndroidTool v2.38 ✅ USB-A to USB-A cable ✅ Willing to backup original Android first Any help or X88-specific guidance would be greatly appreciated! Thanks in advance! 🙏 Device: X88MAX.p2.0.01.d4 SoC: RK3328 (Chip Tag: 33 32 32 48, Flag: RK322H) Storage: Samsung eMMC 64GB FlashID: 45 4D 4D 43 20 Status: Successfully in LOADER mode via RKDevTool v2.86 Android: Backed up and ready Problem: - SD/USB boot ignored by bootloader - Android not rootable (KingRoot fails) - Need Armbian in Rockchip firmware format What I Have: - Device in LOADER mode ✓ - Full Android backup ✓ - RKDevTool v2.86 working ✓ - Armbian_community_26.2.0-trunk.606_Rk3318-box_trixie_current_6.18.18_minimal.img.xz What I Need: - parameter.txt for X88 RK3328 - Armbian partitions in Rockchip format - Or .update file for X88 Tag: @jock Anyone successfully flashed Armbian on X88 RK3328?
  4. Anyone using dedicated fan? Are they working? Mine won't spin.Tried swap polarity, still won't...
  5. Why you do this (on a normal modern Trixie kernel, actually even 1 year newer)? This is what I have (runs rockchip64 7.0-rc3 kernel): root@ranc:~# ls -al /sbin/iptables /etc/alternatives/iptables lrwxrwxrwx 1 root root 22 Nov 1 2023 /etc/alternatives/iptables -> /usr/sbin/iptables-nft lrwxrwxrwx 1 root root 26 Jan 16 2023 /sbin/iptables -> /etc/alternatives/iptables On other Aarch64 computer, it dates back to 2019 already, that is a standard Debian installation, always in-place upgraded since Buster or so. The Linux kernel does things natively as NetFilter, the iptables commands are mapped. Legacy is even older and I guess the old kernel API has been removed. But do research yourself if you want to know, at least 'man iptables-legacy'
  6. After the update/upgrade, all CPUs are now installed nproc 4 This didn't fix my Bluetooth (maybe it's some individual bug in my system?) but since Bluetooth works correctly in the new images for OrangePi 3 LTS, I'm marking this thread as resolved... I'll probably install the latest image soon, although it will be time-consuming. ........................... orangepi3-lts:~# dmesg | grep "CPU" [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.005157] smp: Bringing up secondary CPUs ... [ 0.007070] Detected VIPT I-cache on CPU1 [ 0.007260] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.009368] Detected VIPT I-cache on CPU2 [ 0.009541] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.011117] Detected VIPT I-cache on CPU3 [ 0.011261] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.011373] smp: Brought up 1 node, 4 CPUs [ 0.011398] CPU: All CPU(s) started at EL2 [ 0.011443] CPU features: detected: 32-bit EL0 Support [ 0.011449] CPU features: detected: 32-bit EL1 Support [ 0.011458] CPU features: detected: CRC32 instructions [ 0.011470] CPU features: detected: PMUv3 [ 0.260754] ledtrig-cpu: registered to indicate activity on CPUs [ 0.414642] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 0.457342] WARNING: CPU: 3 PID: 71 at drivers/iommu/iommu.c:612 __iommu_probe_device+0x1a8/0x4a0 [ 0.457375] CPU: 3 UID: 0 PID: 71 Comm: kworker/u16:4 Not tainted 6.18.19-current-sunxi64 #2 PREEMPT Ps. I don't know if I announced the CPU solution too early? Maybe there's a problem with the processor clock speed? .............. cat /etc/default/cpufrequtils ENABLE=false MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=performance root@orangepi3-lts:~# cpu Temperature: 40 °C CPU-0 Frequency: 1608 Mhz CPU-1 Frequency: 1608 Mhz CPU-2 Frequency: 1608 Mhz CPU-3 Frequency: 1608 Mhz root@orangepi3-lts:~# cat /etc/default/cpufrequtils ENABLE=false MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=performance root@orangepi3-lts:~# cat /etc/default/cpufrequtils ENABLE=false MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=performance root@orangepi3-lts:~# root@orangepi3-lts:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq 1608000 root@orangepi3-lts:~# cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor performance performance performance performance ............... shouldn't it be : 1810000 ... ?
  7. Anyone got the dedicated Fan header working correctly? It won't spin at all. Enabled the fanctrl overlay. changed pwm rate,the fan won't budge.. Tried stress the CPU but this only cause shutdown
  8. PanVK’s new framebuffer abstraction for Mali GPUs removes OpenGL-specific constraints, unlocking more flexible tiled rendering features in Vulkan. View the full article
  9. Hi, i have amlogic s805 tv box from mxq, how do i run armbian onecloud? bc none of this helped me.
  10. Hi, Here what I do 1°) Flash the minimal - IOT image (trixie) for Odroid N2+ on my EMMc 2°) setup Root password and user 3°) Set up locale 4°) use armbian-config to switch on kernel 6.19.0 5°) Reboot - After Reboot I can see this : v26.2.1 for Odroid N2 running Armbian Linux 6.19.0-edge-meson64 6°) use armbian-config to add linux header 7°) reboot 8°) use these commands: # grep -r "iptables" /lib/modules/. grep: /lib/modules/./6.19.0-edge-meson64/kernel/net/ipv4/netfilter/ipt_rpfilter.ko : fichiers binaires correspondent grep: /lib/modules/./6.19.0-edge-meson64/kernel/net/bridge/br_netfilter.ko : fichiers binaires correspondent # grep -r "ip_tables" /lib/modules/. -- nothing # find /lib/modules/ -name ip* lot of filkes but no ip_tables.ko 9°) use armbian-upgrade 10°) reboot 11°) retry commands grep et find: same result 12°) Try to launch # iptables -L command not found 13°) Install iptables # apt install -y iptables # iptables -v iptables v1.8.11 (nftables): no command specified # iptables -L Chain INPUT (policy ACCEPT) target prot opt source destination Chain FORWARD (policy ACCEPT) target prot opt source destination Chain OUTPUT (policy ACCEPT) target prot opt source destination # update-alternatives --set iptables /usr/sbin/iptables-legacy update-alternatives: utilisation de « /usr/sbin/iptables-legacy » pour fournir « /usr/sbin/iptables » (iptables) en mode manuel # update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy update-alternatives: utilisation de « /usr/sbin/ip6tables-legacy » pour fournir « /usr/sbin/ip6tables » (ip6tables) en mode manuel # iptables -L modprobe: FATAL: Module ip_tables not found in directory /lib/modules/6.19.0-edge-meson64 iptables v1.8.11 (legacy): can't initialize iptables table `filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded. 14°) Reboot 15°) Try # iptables -L modprobe: FATAL: Module ip_tables not found in directory /lib/modules/6.19.0-edge-meson64 iptables v1.8.11 (legacy): can't initialize iptables table `filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded. Do I made something wrong ? Thanks
  11. I installed the patch files with "Pb143" in the name on Friday, but unfortunately there was no improvement. Here are the logs: https://paste.armbian.com/dovedafali Can you tell me if I can test something with this? If so, what exactly do I need to do?
  12. Did you perhaps upgrade kernel and forgot to reboot?
  13. Thanks for your answer. I very sorry to ask you one more things please. How can I check if module is present. In modules files in "/lib/modules/6.18.10-current-meson64" ? I tried to do this : # cd /lib/modules/6.18.10-current-meson64 # grep -r "iptables" . Answer grep: ./net/ipv4/netfilter/ipt_rpfilter.ko : fichiers binaires correspondent grep: ./net/bridge/br_netfilter.ko : fichiers binaires correspondent I not an expert PS : I'am on Minimal / IOT version. Maybe it's the reason ? Thanks
  14. logs are incomplete. dmesg is missing completely which would be the most relevant. moved to staging
  15. https://github.com/armbian/build/blob/b8eab09ef561f2d03956098d26351d323a3b2d7b/config/kernel/linux-meson64-current.config#L355 Check your /lib/modules directory if it is present. It should be.
  16. Why would you use an image for the Zero 3 for the 5B? You cannot simply shove an image for a random board into yours and assume it works...
  17. This is latest edge version 6.18. Should be easily reproducible on your end, effects all rock 5B+ boards and this board is a platinum supported board.
  18. Hi all, Over the past few months working on the A7Z, I’ve successfully ported a number of BSP drivers to Linux 6.18. The code is available here: https://github.com/alexcaoys/allwinner-bsp/tree/linux-6.18.y It’s currently tested on 6.18.19 and should, in theory, work with newer 6.18.y releases. I’ve tried to reuse as much upstream (mainline) drivers as possible, and have also upstreamed support for PCK600 and ET7304 used on the A7Z. Hopefully this helps accelerate ongoing mainline efforts. Feedback, issues, and PRs are very welcome. I may also look into creating branches for Linux 7.x in the future.
  19. Hello. It seems there is an issue with iptables in the 6.18.10-current-meson64 kernel. I can't start Docker because of this. ``` ~# iptables -L modprobe: FATAL: Module ip_tables not found in directory /lib/modules/6.18.10-current-meson64 iptables v1.8.11 (legacy): can't initialize iptables table `filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded. ``` As I run a docker version 28.X.X, it does not support nftable. (Cannot upgrade at the moment). What can I do to solve the problem ? Thanks
  20. Last week
  21. Sorry I'm not able to find the sub category for M4V2 so I chose R4S instead. But please keep in mind that this is a bug report for NanoPi M4V2. So my box has been running well for 5 years without any issue, through multiple system upgrade from armbian buster to trixie. However after I upgrade the kernel from 6.12.58 to 6.18.10 just a couple of days ago, the system started to have some weird behavior. The main symptom is that I'll lose the network connection from the box once it starts up, and it could happen after just a few minutes, or a couple of hours. I have to power cycle the box to get it back online as I don't have any peripherals, and soon I will lose the connection again. Other symptoms I've observed so far: - Once I lost the connection and powered cycle the box, the timestamp in the log looks confusing. Somehow the system clock paused at the moment when system froze. When it boots up, there could be a large gap between the NTP server and it will have to sync up, and I don't even seem to be able to find any logs before this reboot - The line `fdtfile=rockchip/rk3399-nanopi-m4v2.dtb` in `/boot/armbianEnv.txt` looks to be missing, so I added it back but it didn't fix the issue Eventually I downgraded to 6.12.58 with armbian-config, by timing the time window between the bootup and system freeze. After that the issue seems to be gone. Please find the results for `armbianmonitor -u` at https://paste.armbian.com/werujijedo For those who has the same model as mine, please think twice before upgrading. Do backup your data if you'd like to take the risk.
  22. mar 22 2026 build. system seems to boot up, lights on, fans on at boot but no hdmi output
  23. Pami, I have not personally found any LLM capable of generating working DTS files no matter what. It seems to be too niche for the LLM to understand. This DTS could potentially be a good starting ground for the pi, replacing "bcm2835" which refers to the pi zero 1, with "bcm2710" which refers to the pi zero 2. The github repository I linked is a good guide to getting the red displays working for a voron printer using panel-mipi driver, and I referenced it to create the DTS I use for the rock pi 4b. Also, try lowering the SPI speed to 20, 16, or 10 MHz, then raise it when you verify it works. I was frustrating myself for weeks thinking my DTS was broken, when it was fine the entire time, just my SPI speed was too high. robertoj: I appreciate your help, but I believe the issue I have with the red display (I have the same one as pami sent) is a combination of SPI commands being sent at the wrong interval (at the end of the clock cycle instead of in line), as well as insufficient SPI speed - where the display freezes above 24 MHz, and shows extreme visual tearing below it. At RGB666, its too much data for a measly 20MHz SPI rate, and the board does not support any other RGB modes in SPI. Since the TE pin is not exposed on the board, I cannot sync the SPI writes to the display. At least, that is my theory. I've given up on using an SPI display, and instead transitioned to an RGB Parallel display, which uses one gpio pin per color bit. Note that, at least in the display datasheet I received, the display actually does have the pins needed to drive it over DPI RGB Parallel. You can drive the board in 16, 18, or 24 bit mode over DPI RGB Parallel. These pins are not exposed on the board, but you could use an FPC breakout board to interface with these pins, and drive the display in DPI RGB parallel instead (accounting for the backlight voltage needed). The advantage of using RGB Parallel is it natively uses the GPU (RGB Parallel is the same technology as VGA) and has very fast refresh rate. For anyone here in future, any DPI hats that exist, like the adafruit kippah or othermod dpi topper, do not have the correct pinout to interface with this specific ili9486/8, but if you were to rearrange the pins on either the HATS or with an intermediary FPC PCB, then they would work plug and play.
  24. Hello, i tried "Armbian_community_26.2.0-trunk.606_Radxa-cubie-a5e_trixie_edge_6.19.8_minimal.img" and wlan didn't work, i think the device tree is broken Radxa-cubie-a5e kernel 6.19.x as a quick fix, I copy the kernel 6.18.x "sun55i-a527-cubie-a5e.dtb" file to the /boot/dtb/allwinner directory to get wlan working.
  25. maxsub
    @sven-ola there are 3 ways to boot the R2S: 1. Press the boot button before applying power. White USB port connected to a PC. Apply power. It goes into fastboot mode like an android. Theoretically this should let you flash the on-board eMMC. I can successfully put it in fastboot mode but the flashing has not worked. 2. Boot from eMMC 3. Boot from USB. The eMMC has two boot partitions that are fixed size and one large main partition. My project uses the u-boot environment but also does a few minor things. It prioritizes USB if it finds a bootable medium there. It also safely flashes the boot blocks on the eMMC and then the main blocks. It adds some safety checks before flashing. Nothing else.
  26. hi, I installed in usb the last version and boot. something wrong happen here, only left these two upgrades, I tried again with backup-img and falied to boot again
