Hi Keith, I'm not too familiar with the in and outs of armbian-config. Just navigate around and see what's available. The kernel being Edge makes it easiest to install to a different device (i.e. if that's eMMC), so you're goo there. And remember, if you break the operating system, you can always start again with a clean install. So don't be afraid to experiment. It's how we learn. But I am very careful with the 16 MB SPI-NOR, and not to mess with that. I'm not sure if overwriting that with junk would brick the machine or not. Perhaps someone else who knows more about that can comment. But otherwise just follow your instincts as best you can and do what makes sense to you. Armbian-config is meant to be pretty straight-forward.
The kernel 6.17 release benefits from improvements in the graphics subsystem, hardware enablement, and more! See where Collabora's kernel team contributed to this release. View the full article
So I now got Edge 6.16.4 Kernel on my SD card, and I want to boot from either EMMC or SATA to take advantage of the extra speed. Arbian-config presents several options. Which option is generally recommended, from the 5 shown in Armbian-config?. For me, Option 3 (boot from EMMC, System on SATA, USB or NVMe) seems to be what I want, but I am interested to hear any recommendations or problems, since this is and Edge Kernel. Tanks, Keith
leave a link for other users like @John Taylor to continue your work, also @fedes_gl could give a hand -
I already said i cant and dont want to. Anyway, in the meantime, I tried to port to latest version of armbian and didn't managed to finish because of some issues with devicetree. I gave up because no time for the moment (and found nomore fun in debugging for something i dont need) Final goal was to port haos to it anyway. Armbian was only a step for me.
I know an expert in rk3528, his name is @fensoft we are depending on him finding a weekend to dedicate to the community https://github.com/ilyakurdyukov/rk3528-tvbox he will help us by taking this repository and including it in armbian with a wonderful pull request I would like to buy this board and join the fun that you have, but my country has literally started an embargo on all TV boxes -
Thanks for that , TallMan. You told me I needed 6.16.4 - and it took me a while to realise that I could probably find it using the Armbian-config. I thought I did pretty much as you describe, but it wouldn't boot, so I guess I did something wrong, (Probably picked up the faulty card mentioned above!). but didn't have time yesterday to try again - so thats for this evening. I'll get there eventually, I hope. At the moment I guess I'm still scared I'm going to do something irrepairable, because up til now I've always been a user, so not too adventurous yet. Keith
@fensoft please make this https://github.com/ilyakurdyukov/rk3528-tvbox as a pull request, you have the dq08 tvbox board, you're embedded in the community, you've tested everything, you seem like the perfect guy -
Radxa-cubie-a5e second Ethernet port not work after update
Samixa replied to Samixa's topic in Allwinner sunxi
Hi, I tested with the version 25.11.0-trunk.129 and the second network port worked with this. https://paste.armbian.com/hasewoloti -
Don't know what to tell you, it is running fine on my boxes and dmesg is clean. Also I cannot see what is your build version since the screenshot is missing the top line of the screen. 🤷♂️
This is internal development for our boards, unfortunately, there is no public repository for our kernel. The code is borrowed from reverse-engineered POCs h264 + * Based on https://github.com/jemk/cedrus + * Copyright (c) 2014-2015 Jens Kuske <jenskuske@gmail.com> jpeg + * Based on https://gitorious.org/recedro/jepoc + * Copyright (c) 2014 Manuel Braga <mul.braga@gmail.com>
Please tell me the source of this patch.
update to edge kernel rolling release 6.16.x
The Tall Man replied to Dantes's topic in NanoPi R6S/R6C
Btw, about things turning orange... I had that experience some time ago before I got into Armbian. I did a clean install of Debian Bookworm. Then I tried installing the vendor GPU drivers and packages from the Orange PI company. Their drivers and packages were so horribly hacked / designed that various programs that needed certain SoC features needed to be custom modified to work with those specific vendor drivers. So all versions of those programs needed be held and were non-upgradable if I wanted continued GPU and video acceleration support. Anyway the main GPU driver package, when I installed it myself (instead of whatever secret sorcery their installation did), it turned things orange. Fortunately now, pure Trixie works out of the box on my board (from the Debian installer .iso), except that the kernel needs to be upgraded from their 6.12 to 6.16.3 from trixie-backports. Armbian's edge kernel on an otherwise pure Trixie is even better than Debian's, because it's customized for Rockchip. If you've been doing things like I was trying to before, things have much improved and now simple is better and it works. Also things tend to get really mangled up when upgrading over time - especially major LTS upgrades. Why not try a fresh install of a 25.8.1 Armbian image? -
Fix: run armbian-install, then selected “Install/Update the bootloader on SD card (/dev/mmcblk0)”
I have a different board (Orange PI 5 Plus). My experience with the edge is that it works great in Wayland and terribly in X. Also KDE Plasma Wayland is different than Gnome Wayland (and Plasma is buggy in Trixie). So you could try all three combinations and see if one works better than the others. You tried both the stable edge and the rolling edge ...with the same results? -
And it did not work out, no sound in the edge 6.16 kernel. I did find : https://lkml.org/lkml/diff/2025/8/7/872/1 to enable HDMI-audio, which is most likely the reason. However the edge also has some graphics distortion (orange glow), so I'm not gaining a lot by applying that patch. Ill let everyone know
U-Boot 2024.01-armbian-2024.01-S866c-Pbc32-Ha9af-V80bb-Bda0a-R448a (Nov 25 2024 - 14:01:12 -0500) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: Transpeed 8K618-T DRAM: 4 GiB Core: 61 devices, 22 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4022000: 1 Loading Environment from FAT... MMC: no card present ** Bad device specification mmc 0 ** In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: apply fix for AC300 ephy bb version bug ... using AC300 emac1 ephy default config ... eth0: ethernet@5030000 starting USB... Bus usb@5101000: sun4i_usb_phy phy@5100400: External vbus detected, not enabling our own vbus USB EHCI 1.00 Bus usb@5101400: USB OHCI 1.0 Bus usb@5200000: USB EHCI 1.00 Bus usb@5200400: USB OHCI 1.0 scanning bus usb@5101000 for devices... 1 USB Device(s) found scanning bus usb@5101400 for devices... 1 USB Device(s) found scanning bus usb@5200000 for devices... 1 USB Device(s) found scanning bus usb@5200400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop MMC: no card present switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... MMC: no card present No EFI system partition No EFI system partition Failed to persist EFI variables BootOrder not defined EFI boot manager: Cannot load any image Device 0: unknown device ethernet@5030000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! missing environment variable: pxeuuid Retrieving file: pxelinux.cfg/01-02-00-41-2d-68-a7 ethernet@5030000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Retrieving file: pxelinux.cfg/00000000 ethernet@5030000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Retrieving file: pxelinux.cfg/0000000 what can i do ? and how to do? 3ks
Describe what you did before to make it work. Show the DTS, the wiring you connected and the linux version that worked. If you used spidev before, I don't have experience in that. I only have experience with these drivers: panel-mipi-dbi-spi, ili9431 and adafrui-xy... The threads I showed you require you to stop using spidev, since the Linux kernel will communicate directly to the LCD, without a user program. Using both will just make them interfere with each other. If the LCD remains white and doesn't even flicker, and you made it work in an older kernel, then keep that wiring. If the /dev/fb0 exists, it means that linux has taken one SPI output port for display, but you need to make sure that: * and SPI parameters in the DTS are correct, * the gpio to handle the command/data, reset parameters are pointing to valid orange pi pins which are not used by anything else * the high/low polarity of those gpio * the wiring is correct, * the initialization bytes are correct
Hmm... i dont think thats in there anymore due to some spring cleaning, all i have is: armbian-add-overlay armbian-install armbian-upgrade So I navigated to : https://github.com/armbian/configng/blob/main/tools/repository/armbian-config.sources Where I found: https://github.armbian.com/configng/ So I did: echo "deb [signed-by=/usr/share/keyrings/armbian.gpg] https://github.armbian.com/configng stable main" | sudo tee /etc/apt/sources.list.d/armbian-development.list > /dev/null sudo apt update sudo apt -y install armbian-config Lets hope it works out I totally understand, this problem will solve itself in what looks to be Linux 6.18 coming December.
Kernel 6.1 is Vendor. Kernel 6.12 is Current / Mainline Kernel 6.16 is Edge. It's simple to change to edge. Just run armbian-config (it's available in the menu, or just type it in the command line using sudo). In armbian-config, as you make the selections, you'll find that you keep pressing ENTER until you get to the long list of kernels. Then scroll down to the latest Edge, which as of I last looked was 6.16.4. It may also say Armbian 25.8.1.
Hi, maybe someone will find this patch useful. It adds JPEG and H264 encoding to the main Cedrus driver. Both encoders use a stable stateful API, so they can be used with any multimedia software, such as gstreamer, ffmpeg, etc. gst-launch-1.0 videotestsrc pattern=smpte ! video/x-raw,width=1920,height=1080 ! v4l2h264enc ! h264parse ! matroskamux ! filesink location=test_h264.mkv gst-launch-1.0 videotestsrc ! v4l2jpegenc ! matroskamux ! filesink location=test_mjpeg.mkv I tested it on T113 (jpeg) and A40 (jpeg, h264) processors and I think it should work with H3 as well. It doesn't work with 64-bit processors like H616/T507 because their encoders have been updated, and as far as I know, they haven't been reverse-engineered yet. linux-6.12.28-cedrus-enc.patch
Ok, I foud some time to make additional tests. Here is what I found. It fully boots with 'x96q-lpddr3' SD card image if you swap dtb to one of the two: h618-linganpi-3h h618-orngepi2w However in both cases internal Ethernet does not work. I can use USB to ETH converter. Do you see any way to make internal ETH working in this board? In original Android dmesg there is a message about gmac: [ 28.389711] sunxi-gmac gmac1 eth0: eth0: Type(6) PHY ID 00441400 at 0 IRQ poll (gmac1-0:00) Does it sound like a solution?
quoting JPL: Did you see any announcement by the github's owner, about what we can expect from her/his source code? Looking at the content of the file, it seems like we need to download the code from: https://github.com/philipl/mpv#branch=v4l2request or https://github.com/philipl/mpv/tree/v4l2request And include this build-time configuration -Dv4l2request='enabled' I have posted instructions to build MPV on Sept 26 in this thread
Thanks for your comments. I did not touch the regulator@40 values at all - only the opp frequencies in line with suggestions from @prahal and some cache settings. cpufreq sampling_rates were changed to about 40000 (depending on the cluster) for kernels 6.6 by a script in /etc/rc.local. The script does not apply anymore in linux 6.12. Instead of disabling the A72 cluster altogether, reducing the burden on the CPUs during data transfers helps to substantially reduce crashes and avoids triggering the watchdog timer. P.S.: I bought a Rock-5B in October 2022 and I finally migrated everything to it.
TallMan - Thanks for the recommendations. I thought I would try them, and use it as a learning experience for Armbian - I made a hash of it, I think, and sorry, I need some help again. First I looked for kernel 6.16.4 online, and found at least two, with different SHA checksums. Then it occurred to me that perhaps they were listed in Armbios-config, so after reading about it in the documentation, I booted it and eventually found a list of kernels available, so I selected Vendor 6.16.4 and tried to install it. Somewhere I went wrong, but don't know where - the process seemed to be running fine, and something (?) seemed to be installed. Eventually it needed a reboot - but once again I had a brick. I didn't get as far as installing the OS on EMMC or SSD. I reflashed the SD card with vendor kernel 6.1 as previously, to start again from scratch, but am not confident about trying the update again - hence the need for one or two pointers. Sorry about this - your help would be appreciated. Keith
