  2. After applying these settings, TomeRaider can be run perfectly now, Thank you !
  4. https://github.com/lanefu/fan-control-rock5b-poe
  5. No You can try to set env: export BOX64_PREFER_EMULATED=1
  6. Have you ever met the issue "lack of OpenAl32.dll". I try to run "isaac:rebirth" and come out cannot find "openAl32.dll", I got a copy of openAl32.dll from my windows laptop and put it into $WINEPREIX/windows/system32 or the game's executable file folder, cannot get the right result.
  7. What is happening with the board maintainer in general? I think they have been incommunicado pretty much since the first release and now is the time do do something (especially since the board has been "upgraded" now).
  8. You extract and copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file folder. So no need to change anything in $WINEPREFIX dir.
  9. Everytime you change you wine version, should the $WINEPREFIX dir such as ~/.wine/driver_c should be deleted and install DVXK dll again?
  10. Wrong serial console set in kernel parameter could be a reason for having not output afterwards, so the suggestion isnt completely off. Though no clue what might be correct here.
  11. No, because as mentioned, we need to wait until the bump to 6.18 is approved and merged. Then the work for more recent AW SoCs can be rebased on top of that.
  12. According to the schematic it seems like pwm is used for that. That would need to be enabled as device tree overlay. https://dl.radxa.com/accessories/25w-poe/radxa_25w_poe_plus_hat_v1.2_schematic.pdf Not sure if there is further/DIY programming necessary to make it work.
  13. This was fixed quite recently:https://github.com/armbian/build/pull/9039 Upgrading uboot package does not automatically rewrite the binaries. It just provides them for manual rewrite. So upgrading this package should not do any harm without actually writing the boot loader.
  14. Thanks to Nick Alilovic for the solution to this issue. You need to add "BOOTFS_TYPE=fat to the board config. If you are on Windows and using an image created by someone else, it's possible you may need to install a utility to show .ext partitions. The you can edit /boot/armbianEnv.txt or extlinux to config to point to a different dtb etc.
  15. I have an Radxa 5B+ that are powered through POE HAT. The problem is that POE HAT fan does not work at all. I have to identical machines, same issue on both of them. I have installed Armbian minimal Bookworm on both, on nvme ssd.
  16. I have Radxa 5B+ with 1TB nvme ssd. I installed Armbian minimal Bookworm on my nvme disk. IT starts without the SD card. Problem started few days ago when i run apt upgrade. After that, the machine don't start without SD card. I have tried to reinstall the machine several times, same happends. I also tried Armbian minimal Trixie, but there the machine don't start at all without SD card. So something have changed the last days. At the moment i have installed Bookworm again, and used the command "sudo apt-mark hold linux-u-boot-rock-5b-plus-vendor". Now the machine starts without SDcard, and i can use apt upgrade, but it is not a long term solution. Anyone have the same issue and a solution?
  17. Cool! Is it possible to build a test image? I tried to download this pull request locally and build it, but I can't find OrangePi 4A in the list of target boards. Any hints how to build it and test?
  18. Thank you so much! I will try it tonight!
  19. You're in luck. Major work has been done. https://github.com/armbian/build/pull/9049 Still needs testing Once this is merged 4A and other more recent Allwinner Soc related work can be rebased on top of that.
  20. That would be my best guess too. Check other PRs which add support for boards to get some clues how to achieve. If there are questions, feel free to state.
  21. (https://www.pcgamingwiki.com/wiki/Vampire_Survivors) Vampire_Survivors is a 64-bit / Direct3D 11.1 game. You may not be setting DXVK (stripped) properly. Set var environments as below: export WINEDLLOVERRIDES="d3d12,d3d12core,d3d11,dxgi,d3d10,d3d10_1,d3d10core,d3d9,d3d8,dinput8=n,b" Download the DXVK (stripped) here: https://github.com/khanh-it/dxvk/releases/tag/releases (You may want to try to know which version works best for this game) Extract and then copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file. If you're setting up the DXVK properly, you will see the output with something like the following:
  22. Hi @Nick A, I have an identical motherboard as shown on page 1. Ik316-emcp_v1.0 2021.06.01 I can boot from the SD card, but it doesn't detect the internal memory. The Wi-Fi isn't working either, but that's already explained in the topic. How can I tell if the EMCP is damaged? Or if it's not being identified correctly? I have a CH431A available if needed. I believe it's possible to access UART via CH431. Previous reports suggest that the internal memory worked on this model, but I'm not certain of that. However, I must inform you that I was unable to install the supposed ROM on this model using PhoenixTool or PhoenixCard, This could indicate a failure in the emcp in the storage block. Thank you in advance for your support. boot.log
  23. Well, two things. 1: The cpu clock changing on the fly was not the issue. That may just be an old issue with H3 series SOCs. 2: The XU4 likes running at 1.4ghz continually just fine. fwiw I'm using a newish 5v 4a power supply. It doesn't even get warm or spin up the fan while printing.
  24. hello, is there any armbian build i can try now?
  25. I just used wine-proton 10.0.3. While replace the wine to 11.0-rc1 to my previous proton environment, which is working fine on some games, such as VampireSuvivors, after installing Wine-mono, none game can be played. Comes out a dialog says that "Failed to initialize graphics, Make sure you have DirectX installed"
