@prahal - I tried a number of those images but none worked. With RoobiOS I see that all of the blue lights below the SATA ports (i.e. on the underside of the board) light up as blue for a couple of seconds, then they turn off and then they flash twice ... the screen comes on and after a couple of error messages the Installation GUI starts. With the images from the links you provided, I don't get the blue lights (although I do get a yellow network link light). hmmmm ... more head scratching ...
Wifi chip model?
... straightforward and smooth.
With linux 6.12 the optimizations in /etc/rc.local do not apply anymore since some configuration options have vanished. So if you like to have a stable 2.5Gbit/s network connection without timeouts, linux-6.6 is still recommended (bookworm and trixie). You can build it yourself using an Armbian snapshot (from Dec. 2024) or download a recent linux-6.6.100 from here.
Hi, i want to try the Gnome on Armbian with my Raspberry Setup. Pi5 with Touchdisplay2. The Display is working but without touch input. I looked through the /boot/firmware/config.txt and everything looks fine. I also tried to run Gnome on Xorg. Has someone a hint for me?
@Nick AHi,I bought another model of TV box (with the same CPU and eMCP chip model, but a different Wi-Fi chip), and it has the same issue. Could you help me figure out how to solve this? Thank you!
Which kernel mod needs to be loaded to get battrey support on cubietruck?
eselarm replied to pet's topic in Allwinner sunxi
Armbian is a stable OS, but we don't know about what SD-card, power-supply etc you use with your Cubitruck and/or NanoPi Neo+2 The decompression error can simply mean corrupt file due to something wrong with HW. Or something could have gone wrong during download of the files that you or the system decompress. Also note you use a kernel from beta repo (25.11.0-trunk.41). I you want better control, create/build an image formatted as Btrfs, not Ext4. Then you can check where it went wrong. I have several NanoPi-NEOs, all use Btrfs. 2 run 24/7, the others not all the time and usually just get sudden power cut, but they start fine next time. I do in-place upgrade them since years. If something would go wrong, typically as the error you show, I go back to a previous Btrfs snapshot or/and backup from NAS. That is simply what you could do / have done. Maybe something went wrong with that sunxi64 kernel build on the Armbian infrastructure side, that can happen every now and then as it is beta. So Also then, protect your devices again such issues. Also please don't post kernel upgrade errors in a topic about LiPo controller chip. OK for now, but annoying -
Thank you Nick, that worked! Not sure what the root cause is but will try to compare and see if I can find it. thanks again
pet replied to pet's topic in Allwinner sunxi
Your answers are pretty much appreciated, and i would like to thank you for all the good work for the last 15 years @armbian.com. But, i would like to have a system that is more stable than (the last more or less two years) armbian on cubie* or friendlyarm SBCs just right now. I do need a stable OS which is able to serve pihole or other base network stuff constantly. Something like dpkg-deb (subprocess): decompressing archive '/tmp/apt-dpkg-install-mzEu51/7-linux-image-current-sunxi64_25.11.0-trunk.41_arm64.deb' (size=38908852) member 'data.tar': lzma error: compressed data is corrupt dpkg-deb: error: <decompress> subprocess returned error exit status 2 dpkg: error processing archive /tmp/apt-dpkg-install-mzEu51/7-linux-image-current-sunxi64_25.11.0-trunk.41_arm64.deb (--unpack): cannot copy extracted data for './lib/modules/6.12.35-current-sunxi64/kernel/drivers/hwmon/w83781d.ko' to '/lib/modules/6.12.35-current-sunxi64/kernel/drivers/hwmon/w83781d.ko.dpkg-new': unexpected end of file or stream ...leading to a system that is not able to boot anymore (this is today's log of 'armbian-upgrade' on a NanoPI Neo+2) makes me think about asking you if i could provide some time to test your community builds and upgrades before they will be released to the public (-: Cheers - Yesterday
@zink try these images https://github.com/NickAlilovic/build/releases/tag/20250306
@laibsch, this is the Radxa Custom Debian OS that is shipped on the emmc. @justanothernoobCould be I did not have this issue because my board was delivered with an empty emmc (no RoobiOS installed). Though i doubt it. Do you have the serial console full output? Also is it a typo or is the error really about `/dev/mount/mmcblk0p1` not `/dev/mmcblk0p1`. Mind `/dev/mmcblk0p1` is the emmc partition while you should be booting from the SD card. I tet installed Note also that 25.2.2 linux (current) images area lacking most devices support, while vendor 25.2 has an issue with PCIe SATA detection. THe vendor PCIe detection is fixed in latest 25.08 vendor. But that does not explain your current issue... Can you try https://fi.mirror.armbian.de/incoming/prahal/rock-5-itx/archive/ vendor images dated after 16th of August (the ones before did not have the fix for PCIe SATA detection)? Like https://fi.mirror.armbian.de/incoming/prahal/rock-5-itx/archive/Armbian_25.8.1_Rock-5-itx_noble_vendor_6.1.115_xfce_desktop.img.xz
Try to upload the old and new driver to an AI with you overlay included. Here it gives some suggestions for what you can try. The power sequence seems to be changed with the new driver and it might be too fast for your display. It suggests to put some parameters in the overlay to delay some parts, with higher chance with the first 3: Under "dsi0_panel: panel@0 {" prepare-delay-ms = <120>; reset-delay-ms = <50>; init-delay-ms = <150>; enable-delay-ms = <50>; disable-delay-ms = <50>; unprepare-delay-ms = <120>;
BPI-R4 fails to build, missing bl2 firmware
tabrisnet replied to tabrisnet's topic in Other families
https://github.com/armbian/build/pull/8517 appears to fix my SFP problems. -
Ryzer replied to schunckt's topic in Allwinner sunxi
@schunckt Yes, I should have clarified that drm-copy is an argument is for MPV, which according to the guide mentioned above should allow the frame-buffer to be accessed directly. It is worth noting that mpv makes use of ffmpeg under the hood. Tried with ffplay once but did not have much luck with it. last I checked VLC is not supported other than the legacy vaapi. Please see: https://linux-sunxi.org/Sunxi-Cedrus You can use the sample media from linaro: https://samplemedia.linaro.org/ Just to check are you using the ffmpeg-v4l2-request? -
multiple system error messages after latest kernel update
bhouseski replied to bhouseski's topic in Radxa Rock 5B
v25.8.1 for Rock 5B Plus running Armbian Linux 6.1.115-vendor-rk35xx -
schunckt replied to schunckt's topic in Allwinner sunxi
@Ryzer There is no "ffmpeg -hwaccel drm-copy" option. Looks like this is mpv only, which - as said - doen't work with framebuffer. glxgears also can't work because i have no OpenGL. But in general that's a good hint. I'll create some small videos with different resolutions and compressions and measure the fps. Maybe that helps to nail down the issue. btw. I've not yet tested VLC. Need to figure out if this is a ffmpeg issue or something else inside the kernel, i.e. v4l2request related ... @robertoj Trying another image doesn't make much sense for me for several other reasons. T. -
Helios64 - Armbian 23.08 Bookworm issues (solved)
For information, fancontrol, deamon or service systemd crash but work just with run fancontrol from shell in root. Seen to be a privileges problem like systemd log... i look this soon and post here my workaround -
That's exactly what I did. I wrote a replacement for the .not_logged_in_yet file in my customize-image.sh with pre-set parameters, just like I create /root/provisioning.sh. I was just wondering if there were any other ways to do this.
Thanks @laibsch and @royk. For now, we’ve managed to get things working by running the latest vendor kernel, but using panel-simple.c from version 6.1.43. This workaround isn’t ideal, and we’ll try to investigate the root cause once we have more time. As for the log message "Expected bpc in {6,8} but got: 0", it doesn’t appear when using 6.1.43, even though the relevant source code is identical in that part.
Hi, Today i upgrade to Armbian Trixie my Helios64 with upgrade from bookworn to trixie, not clean install All seen to be Okok only with use of rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp file inside of original rk3399-kobol-helios64.dtb Only problems for moment are: - fancontrol not seen to work lm75 module... service crash... i will investigate soon if i have the time. - apt show warning with SHA1 checksum or anything i can't investigate for the moment
