Do you try also toothpick (there is a recovery button behind headphone port) methode and SD-Card ? or USB boot , there are some box with lock bootloader
I'm trying to boot multitool, but my device is booting directly into android. I've flashed my sdcard using dd and balena, both works fine apparently, the box recognizes the sdcard (it shows on android file manager), but every time I reboot it, it only boots android... Does anyone have any clue of what should I do?
https://www.cnx-software.com/2025/10/25/35-orange-pi-4-pro-an-allwinner-a733-edge-ai-sbc-with-up-to-16gb-lpddr5-wifi-6/ https://www.cnx-software.com/2025/07/07/allwinner-a527-t527-and-a733-datasheets-user-manuals-and-linux-sdk-released/ http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/details/Orange-Pi-4-Pro.html Another Allwinner board dropped figuring out the wifi chip is always hard, seem to be https://www.taobao.com/list/item/931793873067.htm https://pine64.sfo3.cdn.digitaloceanspaces.com/doc/datasheet/oz64/AIC8800DC Datasheet v1.0.pdf as usual, it is uncertain if drivers and firmware is after all available. Ethernet according to CNX seemed to be YT8531CA Ethernet seemed to be same as that in OrangePi Zero 3 https://www.cnx-software.com/2023/07/03/orange-pi-zero-3-allwinner-h618-sbc-ships-with-up-to-4gb-ram/ WiFi is 'more critical' these days, if it is closed sourced and no firmware, then it is good as just a door stop. Then that thare are other stuff the figure out especially the : - DRAM controller, - and various DRAM timing and configuration aspects - many other low level specific stuff to even have u-boot to boot it up to the linux prompt. - then the other devices e.g. uart etc. - then HDMI - then gpu acceleration (or at least display video, not playing media yet) - then media - and finally NPU, don't seemed documented yet - many more known or unknown unknowns, audio etc
Hi all, I’m trying to get KlipperScreen running directly on the framebuffer on a BigTreeTech CB1 that’s using an Allwinner H616B chip. It’s running Armbian Bookworm (kernel 6.6.66-vendor-sunxi64, Dec 2024 build) on a Manta M8P V2.0 board with a TFT35-SPI display that shows up as fb_st7796s. The goal is to have KlipperScreen render directly to /dev/fb0 without needing a desktop or HDMI. The framebuffer itself seems fine as the screen shows the BigTreeTech logo on boot, and I can write to it manually, so the driver appears to be working correctly. KlipperScreen installs fine, the Python environment and dependencies are all in place, but when I launch it, I always get “Gtk couldn’t be initialized.” If I try running it under Xorg, it throws “xf86OpenConsole: Switching VT failed,” which seems to mean the kernel isn’t allowing virtual terminal switching. I’ve tried both framebuffer and Xorg modes, set SDL_VIDEODRIVER=fbcon and FBDEV=/dev/fb0, and even forced it to use SDL directly, but GTK still won’t start. Everything else works normally, it just refuses to render the GUI. Here’s the kicker: this exact setup worked perfectly on Armbian V2.3.4. KlipperScreen ran out of the box with no special tweaks, so something clearly changed in V3.0 and later builds that broke framebuffer support or GTK initialization. It feels like either framebuffer rendering got dropped, VT switching was removed, or GTK was built without fbdev support. So my main questions are: was framebuffer (fbdev) support intentionally removed from newer Armbian builds for the CB1? Is VT switching disabled by design in the H616 kernel? And is there any known way to run GTK or SDL apps directly on /dev/fb0 under the current Bookworm build? If it’s just a matter of rebuilding GTK or enabling a missing kernel flag, I’m happy to do that I just need to know where the problem actually lies.
KickPi K2B not booting up: DRAM setup not supported
chuanzz replied to chuanzz's topic in KickPi K2B
I’ve sent the URL and details here, hoping they can take a look -
https://paste.armbian.com/raw/hohumivife -
I’ve spent way too much time on this, my back is killing me. I’d rather just buy a more common development board. My project didn’t require me to dig into all this u-boot and DTS stuff. So, fuck you KickPi. Here are all the DTS files I extracted from https://github.com/pyavitz/debian-image-builder and the official Linux SDK. Hopefully someone else can finish this job. dts.zip -
c0rnelius replied to chuanzz's topic in KickPi K2B
Here is everything I have been able to piece together from the web. Maybe something in there would be helpful? https://github.com/pyavitz/binary/releases/download/060420/KICKPI.zip -
Post a dmesg and sudo gpioinfo https://paste.armbian.com/ -
I recently noticed my ODroid XU4 was reporting weird temperature readings: cat /sys/class/thermal/thermal_zone0/temp -22000 Is this a software issue or maybe hardware failing? Also, I would like to upgrade, is there another board I could just transfer my EMMC to and be up and running? Thanks
@Jeeva Kandasamy correct
Looks like the same thing REV 1.1 uses. My guess would be the GPIO or PINCTRL may be different on the REV2. The problem is the schematic only shows 1.0 / 1.1 You could try shooting them an email in an attempt to obtain the v2 schematic? Without it, you would just be guessing. -
Still no network. I checked the official SDK, it uses the following hardware: Wired network: Allwinner GMAC driver + external PHY; Wireless network: AIC8800 series WiFi module driver; Bluetooth: AIC8800 Bluetooth Low Energy driver; USB network: RTL8152 USB to Ethernet driver. Does this have any impact? -
Nice. -
The parameters I’m using were extracted from the official Linux SDK using GPT. At least the DRAM parameters are functional. Debian can boot and log in normally, but there’s no wired network or WiFi/Bluetooth. I’m currently investigating why this is happening. -
I was just about to post a binary with something similar. So does the above work for you? I was gonna try this: CONFIG_DRAM_SUNXI_DX_ODT=0x03030303 CONFIG_DRAM_SUNXI_DX_DRI=0x0e0e0e0e CONFIG_DRAM_SUNXI_CA_DRI=0x1f12 CONFIG_DRAM_SUNXI_TPR0=0xc0001002 CONFIG_DRAM_SUNXI_TPR10=0x2f1107 CONFIG_DRAM_SUNXI_TPR11=0xddddcccc CONFIG_DRAM_SUNXI_TPR12=0xeddc7665 CONFIG_MACH_SUN50I_H616=y CONFIG_SUNXI_DRAM_H616_DDR3_1333=y CONFIG_DRAM_CLK=648 -
I used ur project https://github.com/pyavitz/debian-image-builder changed this file "patches\uboot\v2025.07\sun50i-h618\002-Add-board-KickPi-K2B.patch" +CONFIG_OF_UPSTREAM=y +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="allwinner/sun50i-h618-kickpi-k2b" +CONFIG_SPL=y +CONFIG_DRAM_SUNXI_DX_ODT=0x03030303 +CONFIG_DRAM_SUNXI_DX_DRI=0x0e0e0e0e +CONFIG_DRAM_SUNXI_CA_DRI=0x1f12 +CONFIG_DRAM_SUNXI_ODT_EN=0x0 +CONFIG_DRAM_SUNXI_TPR0=0xc0001002 +CONFIG_DRAM_SUNXI_TPR1=0x30fb +CONFIG_DRAM_SUNXI_TPR2=0x0000 +CONFIG_DRAM_SUNXI_TPR6=0x33808080 +CONFIG_DRAM_SUNXI_TPR10=0x2f1107 +CONFIG_DRAM_SUNXI_TPR11=0xddddcccc +CONFIG_DRAM_SUNXI_TPR12=0xeddc7665 +CONFIG_DRAM_SUNXI_TPR13=0x40 +CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_DDR3_1333=y +CONFIG_DRAM_CLK=648 +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_R_I2C_ENABLE=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_SYS_I2C_SLAVE=0x7f +CONFIG_SYS_I2C_SPEED=400000 +CONFIG_SUN8I_EMAC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_PHY_REALTEK=y +CONFIG_RTL8211F_PHY_FORCE_EEE_RXC_ON=y +CONFIG_RGMII=y +CONFIG_RMII=y +CONFIG_AXP313_POWER=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_MUSB_GADGET=y and maked a u-boot the debian was starting I was testing it -
verbosity was 7 already But no more log -
Change the loglevel to 7 in the armbianEnv file and if anything comes up after Starting kernel ... post it. -
Armbian with preinstalled OpenMediaVault (OMV)
usual user replied to Igor's topic in Software, Applications, Userspace
Out of curiosity, does it work if you drop my firmware build in place? dd bs=512 seek=1 conv=notrunc,fsync if=u-boot-meson.bin of=/dev/${entire-device-to-be-used} u-boot-meson.bin.tgz -
roastmeat replied to Igor's topic in Software, Applications, Userspace
This is my first time running Armbian on the odroid HC4, For some reason, I can boot without any drives (uSD card), and sometimes with one drive but never with two. Like no display on the monitor or can't ssh into the system. Anyone else getting something like this? I've wiped the 4 onboard memory locations so that it can boot from SD card (which it does without any drives) -
Hey @Adrienne, Github thread talks about two to three ways to so solve the issue. Did you apply the one that removes the symlinks ?
A phandle is a magical number assigned during DTB assembly, whose value is irrelevant as long as it references the same node with the phandle property. The magic value can change when the structure changes because it is assigned arbitrarily; for example, by inserting an additional node.
