  2. How do I go about doing that ? It more looks like its to do with the `.github` repo tag contents itself ? But if its not is there a 101 or HOWTO on this please ?
  3. I tried this in a raspberry pi with graphic services stopped. Labwc exits normally I tried it in a virtualbox x86, with Debian trixie netinstall (barebones+labwc+seatd). Labwc exits normally. I think other armbian users (probably non allwinner) have used labwc, but they never complained about Labwc crashes. YES. I will try it with a true intel system.
  4. From the screenshot you included I can determine the following: 1) This is a repurposed TV Box type device since it is running the rk3318-box build. (Note Armbian does not support TV Boxes, these are all community supported) 2) You are running a build from May of 2022 (over three years old) 3) As it says: No end-user support: built from trunk (which means this isn't any sort of official armbian build) For support you really need to go to the company that you bought this from
  5. great, keep us posted and be sure to invite Danubio to post here directly, too!
  6. @Werner https://paste.armbian.de/wikedaqena I have ordered a couple of 3.3/5v UART USB adapters. I used to have an old 5V old. Thanks !
  7. You would also need to rollback all the patches that armbian applies to the point in time that Armbian built with that particular kernel version. And likely all the outside repositories that Armbian pulls in that have source code for the various drivers and other code that is also built into the kernel.
  8. What is the brand name and model of your "server home assistant"?
  9. with userpatches/config-test.conf ``` EXPERT="yes" DEST_LANG="en_GB.UTF-8" BOARD="bananapim7" BRANCH="current" KERNEL_VERSION_LEVEL="6.12" KERNELSWITCHOBJ="tag:6.12.22" KERNELBRANCH="tag:6.12.22" ``` I am getting the following ``` [🌱] Producing new & caching [ GIT_INFO_KERNEL ] [🌱] Fetching SHA1 of 'tag' 'refs/heads/6.12.22^{}' [ https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git ] [🌱] SHA1 of tag refs/heads/6.12.22^{} [ '' ] [🌱] Failed to fetch SHA1 of 'tag' 'refs/heads/6.12.22^{}' [ https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git ] [🌱] Fetching SHA1 of 'tag' 'refs/heads/6.12.22' [ https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git ] [🌱] SHA1 of tag refs/heads/6.12.22 [ '' ] [🌱] Failed to fetch SHA1 of 'tag' 'refs/heads/6.12.22' [ https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git ] [🌱] Fetching SHA1 of 'tag' '6.12.22^{}' [ https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git ] [🌱] SHA1 of tag 6.12.22^{} [ '' ] [🌱] Failed to fetch SHA1 of 'tag' '6.12.22^{}' [ https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git ] [🌱] Fetching SHA1 of 'tag' '6.12.22' [ https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git ] [🌱] SHA1 of tag 6.12.22 [ '' ] [🌱] Failed to fetch SHA1 of 'tag' '6.12.22' [ https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git ] [💥] error! [ Failed to fetch SHA1 of 'https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git' 'tag' '6.12.22' - make sure it's correct ] ```
  10. I see you already went upstream which is probably the best place to discuss this. OTOH, you identified that this might be GPU driver issue which would likely require us to patch the kernel. May I ask if you got this running on regular Intel-hardware? Might be best to iron out some bugs there before moving on to the arm-challenge. I'd be happy to test this for you, but my SBC is headless, so I guess I am out?
  11. I don't think 6.16 has rockchip64 support. The rockchip64 support seems to be in current 6.12.y. I really needed to get 6.12.22 building again but am getting problems getting it to build. How do I build the kernel of my choice ? I thought I could just create a `userpataches/config-test.conf` but thats does not seem to be working with `./compile.sh test EXPERT="yes" Can someone please give me a working example of how to build a particular kernel please, because what I was using no longer seems to work.
  12. Today
  13. Sorry for the late reply. I had some spare time and I've installed bookworm 25.5.1 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St. 20:38:51 1296 MHz 0.41 7% 0% 2% 0% 3% 0% 58.1 °C 0/7 20:38:56 480 MHz 0.38 0% 0% 0% 0% 0% 0% 54.4 °C 0/7 20:39:01 480 MHz 0.35 1% 0% 0% 0% 0% 0% 59.8 °C 0/7 20:39:06 480 MHz 0.32 0% 0% 0% 0% 0% 0% 54.8 °C 0/7 20:39:11 480 MHz 0.29 0% 0% 0% 0% 0% 0% 56.4 °C 0/7 20:39:16 480 MHz 0.27 0% 0% 0% 0% 0% 0% 55.5 °C 0/7 20:39:21 480 MHz 0.25 0% 0% 0% 0% 0% 0% 57.6 °C 0/7 20:39:27 480 MHz 0.23 0% 0% 0% 0% 0% 0% 56.2 °C 0/7 20:39:32 480 MHz 0.21 0% 0% 0% 0% 0% 0% 54.2 °C 0/7 20:39:37 480 MHz 0.19 0% 0% 0% 0% 0% 0% 56.1 °C 0/7 20:39:42 480 MHz 0.18 0% 0% 0% 0% 0% 0% 54.1 °C 0/7 20:39:47 480 MHz 0.16 0% 0% 0% 0% 0% 0% 58.0 °C 0/7 20:39:52 480 MHz 0.15 0% 0% 0% 0% 0% 0% 57.0 °C 0/7^C Actually you had some difference in temp between bookworm and bullseye
  14. Werner
    Hiii
    Hi, moved to off-topic since nothing in particular is covered.
  15. petersonn
    Hiii
    Hii this is my first post
  16. Never mind, I found this old image with built-in desktop environment and I was able to upgrade it to current. https://users.armbian.com/jock/web/rk322x/armbian/beta/Armbian-unofficial_24.11.0-trunk_Rk322x-box_noble_current_6.6.56_xfce_desktop.img.xz
  17. The display was working fine on 6.12, but has now stopped. I have tried the other kernels, the vendor has issues with passwords as well for some strange reason its not recognising the set password. I am going to look into the kernel, and kernel patches if I can work out what I am doing, but Armbian with its three fixed kernel versions is a nightmare and always has been. I have had exactly the same issue with BananaPi-M3. The fact Armbian will not build old versions is stupid. I can select older kernels using armbian-config and these work. If armbian/build would allow the user to select the same kernel images as armbian-config can this would go some way to solving this issue.
  18. Having non-working hw is kind of expected with current kernel. Support for rk3588 is basic at most in this version and will not receive further enhancements in that matter. Security fixes only. If you need stuff working Try edge or vendor. Bleeding edge. May work, may not. https://debug.armbian.de
  19. not working on latest 6.12.y kernel 6.12.39-current-rockchip64 either.
  20. Open a terminal, type the command in question, provide us the output.
  21. If boot from USB works, you don't need to install anything, just do 1st login config as described here: https://docs.armbian.com/User-Guide_Getting-Started/#first-login If boot from USB is not supported by this hardware (I don't recall if it works on N2+ or not), you need to start with SD card, conduct previous steps following by https://docs.armbian.com/User-Guide_Getting-Started/#installation
  22. How does this work ?
  23. If it isn't in armbian-config you can follow any upstream tutorial for Ubuntu or Debian to install a DE
  24. Please see https://github.com/armbian/community/issues/39
  25. Hello. How can I install a desktop environment? I've successfully installed Armbian on a rk322x tv box, but the option to install a desktop environment is missing from armbian-config utility. Thanks!
