bluetooth does not detect any devices on Banana Pi M2+
laibsch replied to laibsch's topic in Allwinner sunxi
hcitool does see something, but bluetoothctl still does not $ hcitool scan Scanning ... 41:BB:00:D0:D3:D8 Baseus Bowie WM02 -
Sorry I did not provide enough info. I am using Debian bookworm, completely updated as far as I know, and it looks like you might be using Ubuntu. Maybe I needed to use bookworm-backports as you suggested; it looks like a newer version there. I've actually found another way to do what I was trying to do with v4l2loopback and don't need it anymore, but thanks for looking at it. Here is some output that you asked for: _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.5.1 for Renegade running Armbian Linux 6.12.32-current-rockchip64 Packages: Debian stable (bookworm) IPv4: (LAN) 10.0.44.17, 192.168.4.254 (WAN) 107.77.207.5 Performance: Load: 50% Up time: 0 min Memory usage: 13% of 968M CPU temp: 36°C Usage of /: 13% of 30G Commands: Configuration : armbian-config Monitoring : htop Last login: Sat Jul 5 20:21:20 2025 from 10.0.44.1 pburt@gato:~$ cat /etc/debian_version 12.11 pburt@gato:~$ apt-cache policy v4l2loopback-dkms v4l2loopback-dkms: Installed: (none) Candidate: 0.12.7-2 Version table: 0.13.2-1~bpo12+1 100 100 http://deb.debian.org/debian bookworm-backports/main arm64 Packages 100 http://deb.debian.org/debian bookworm-backports/main armhf Packages 0.12.7-2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 500 http://deb.debian.org/debian bookworm/main armhf Packages pburt@gato:~$ sudo apt install v4l2loopback-dkms [sudo] password for pburt: Reading package lists... Done Building dependency tree... Done Reading state information... Done The following additional packages will be installed: dkms Suggested packages: menu Recommended packages: fakeroot The following NEW packages will be installed: dkms v4l2loopback-dkms 0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded. Need to get 86.0 kB of archives. After this operation, 308 kB of additional disk space will be used. Do you want to continue? [Y/n] Get:1 http://deb.debian.org/debian bookworm/main arm64 dkms all 3.0.10-8+deb12u1 [48.7 kB] Get:2 http://deb.debian.org/debian bookworm/main arm64 v4l2loopback-dkms all 0.12.7-2 [37.2 kB] Fetched 86.0 kB in 1s (119 kB/s) Selecting previously unselected package dkms. (Reading database ... 71668 files and directories currently installed.) Preparing to unpack .../dkms_3.0.10-8+deb12u1_all.deb ... Unpacking dkms (3.0.10-8+deb12u1) ... Selecting previously unselected package v4l2loopback-dkms. Preparing to unpack .../v4l2loopback-dkms_0.12.7-2_all.deb ... Unpacking v4l2loopback-dkms (0.12.7-2) ... Setting up dkms (3.0.10-8+deb12u1) ... Setting up v4l2loopback-dkms (0.12.7-2) ... Loading new v4l2loopback-0.12.7 DKMS files... Building for 6.12.32-current-rockchip64 Building initial module for 6.12.32-current-rockchip64 Error! Bad return status for module build on kernel: 6.12.32-current-rockchip64 (aarch64) Consult /var/lib/dkms/v4l2loopback/0.12.7/build/make.log for more information. dpkg: error processing package v4l2loopback-dkms (--configure): installed v4l2loopback-dkms package post-installation script subprocess returned error exit status 10 Errors were encountered while processing: v4l2loopback-dkms E: Sub-process /usr/bin/dpkg returned an error code (1) pburt@gato:~$ cat /var/lib/dkms/v4l2loopback/0.12.7/build/make.log DKMS make.log for v4l2loopback-0.12.7 for kernel 6.12.32-current-rockchip64 (aarch64) Sun Jul 6 06:20:57 PM CDT 2025 Building v4l2-loopback driver... make -C /lib/modules/6.12.32-current-rockchip64/build M=/var/lib/dkms/v4l2loopback/0.12.7/build modules make[1]: Entering directory '/usr/src/linux-headers-6.12.32-current-rockchip64' CC [M] /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.o /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.c: In function ‘vidioc_querycap’: /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.c:717:9: error: implicit declaration of function ‘strlcpy’; did you mean ‘strncpy’? [-Werror=implicit-function-declaration] 717 | strlcpy(cap->driver, "v4l2 loopback", sizeof(cap->driver)); | ^~~~~~~ | strncpy cc1: some warnings being treated as errors make[3]: *** [scripts/Makefile.build:229: /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.o] Error 1 make[2]: *** [/usr/src/linux-headers-6.12.32-current-rockchip64/Makefile:1945: /var/lib/dkms/v4l2loopback/0.12.7/build] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-6.12.32-current-rockchip64' make: *** [Makefile:43: v4l2loopback.ko] Error 2 pburt@gato:~$
I am having trouble with my SPI LCD, which uses driver panel-mipi-dbi It works great when I use a minimal Armbian image, but with a desktop image it doesn't work. This is because package "plymouth" does something in the ko loading order: it loads panel-mipi-dbi too early. Plymouth provides a graphical boot animation. The driver depends on a binary file /lib/firmware/panel-mipi-dbi-spi.bin (but the file name could change depending on the DTS) At boot time, I saw that the panel-mipi-dbi.ko is loaded BEFORE the EXT4 in the microSD is mounted... and the binary file is not in the initrd.img-version (checked with lsinitramfs) Is it possible to add something in /etc/initramfs-tools/ to include /lib/firmware/panel-mipi-dbi-spi.bin ? With my Raspberry Pi (Raspbian) I don't have this problem, because the panel-mipi-dbi driver is loaded AFTER EXT4-fs (and it also uses plymouth)
I believe you likely have an outdated version of the package. Here is the latest changelog entry for Ubuntu Noble. If you are using an older version, consider upgrading. If you are on bookworm you might want to consider the backports pocket. Or you can think about simply applying above patch locally. Next time, please provide relevant information and logs in your first post. Don't make us guess.
please give the output of "apt policy v4l2loopback-dkms" FWIW, installation worked just fine right now on my BPi M2+ $ sudo apt reinstall v4l2loopback-dkms Reading package lists... Done Building dependency tree... Done Reading state information... Done 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 5 not upgraded. Need to get 30.6 kB of archives. After this operation, 0 B of additional disk space will be used. Get:1 http://ports.ubuntu.com noble/universe armhf v4l2loopback-dkms all 0.12.7-2ubuntu5 [30.6 kB] Fetched 30.6 kB in 1s (20.8 kB/s) (Reading database ... 143046 files and directories currently installed.) Preparing to unpack .../v4l2loopback-dkms_0.12.7-2ubuntu5_all.deb ... Deleting module v4l2loopback-0.12.7 completely from the DKMS tree. Unpacking v4l2loopback-dkms (0.12.7-2ubuntu5) over (0.12.7-2ubuntu5) ... Setting up v4l2loopback-dkms (0.12.7-2ubuntu5) ... Loading new v4l2loopback-0.12.7 DKMS files... Building for 6.12.30-current-sunxi Building initial module for 6.12.30-current-sunxi Done. v4l2loopback.ko: Running module version sanity check. - Original module - No original module exists within this kernel - Installation - Installing to /lib/modules/6.12.30-current-sunxi/updates/dkms/ depmod....
Hi friends, I have good news, I found the Maskrom pin and managed to solve the problem with my MX10 box! By grounding the pin at boot time, it was able to boot from the sdcard and I used Multitools to burn a minimal Armbian image, after that it worked! My modified system, that uses the legacy kernel, only works the boot from sdcard, I tested it by burning the image and using the armbian-install command and it doesn't work! Even in maskrom mode the rkdeveloptool commands didn't work! These emcp memories are complicated, and this is 1.5Gb RAM and 8Gb of storage!
Unable to backup NVME to image on SD card using DD command
laibsch replied to compent's topic in Orange Pi 5
Are you trying to copy the rootfs of the system you are currently booted into? That won't work. You need to boot a separate installation, the filesystem you want to dd should not be mounted. You didn't really say what went wrong, by the way. -
https://github.com/alexl83 and https://github.com/chraac are listed as the maintainers for the Opi Z3
Okay, so I ran a little experiment to verify that it's not about mocp but rather something about the file or file system: $ cp -a /mnt/music/_INCOMING/Malukah\ -\ The\ Dragonborn\ Comes\ \(2017\)/01\ -\ Awake.flac 01.flac Segmentation fault The resulting file contains 9175040 Bytes instead of the expected 9593429, so is truncated. Consequently I also see the corresponding dmesg output parrots what I showed before. So it's about exfat, it appears. Prior to the upgrade did I move the file over to an ext4 partition as well (as I guessed it would be impossible with the 6.12.30-current-sunxi kernel). Copying that around, including _to_ the USB key doesn't seem to cause any issues. I'll see if I am able to figure out how to get the clusters of that particular file. Perhaps it becomes reproducible elsewhere with a (trimmed down) disk image? 2025-07-06_dmesg.txt
@Ryzer attached is the lightly redacted log (removed user and hostname; one mount point now shows as $HOME, because I simply used this instead of manual manipulations: gzip -ckd /var/log/armbian-hardware-monitor.log.1.gz|sed "s|$HOME|\$HOME|g; s|$USER|username|g; s|$(hostname)|host|g; s|$(hostname -s)|host|g" The log is with the older kernel booted, which didn't exhibit the issue. Going to try the other one now. Please note, the actual armbian-hardware-monitor.log was empty (i.e. had been logrotate'd). debsums gives: $ sudo debsums -cs /etc/issue /etc/issue.net /etc/os-release /usr/share/doc/base-files/changelog.gz debsums: missing file /etc/default/armbian-motd.dpkg-dist (from linux-bionic-root-next-cubietruck package) debsums: missing file /etc/default/armbian-ramlog.dpkg-dist (from linux-bionic-root-next-cubietruck package) debsums: missing file /etc/default/armbian-zram-config.dpkg-dist (from linux-bionic-root-next-cubietruck package) /etc/skel/.config/htop/htoprc debsums: missing file /etc/update-motd.d/99-armbian-point-to-faq (from linux-bionic-root-next-cubietruck package) Will remove linux-bionic-root-next-cubietruck then reboot. But as you can see from the reference to bionic, this system isn't exactly freshly installed :-D armbian-hardware-monitor.log.gz
My Banana Pi M2+ is running quite fine on noble but something is amiss with bluetooth. bluetoothctl never shows any devices even when scanning for them and there are plenty of devices within arm's length. I am hoping for your help in diagnosing and ultimately fixing the issue. Logs:
Right, judging by only one instance in the topwise a721 dts: [ 3.446799] sun4i-drm display-engine: No panel or bridge found... RGB output disabled I am inclined to think that is configuring the panel. This can be validated by checking ls /sys/devices/platform/display-engine/drm/card0 or looking for simple-panel in lsmod. I suspect it may be a pin-muxing issue where the pins are not being set. now what these are set depends on the lcd panel type which could be LVDS or a parallel panel. I believe it should be LVDS but just wanted to confirm. Now the A10's pin controller section within the dtsi does not map out as many function compared A20 dtsi, so within the topwise a721 dts under the pio node the display pins need to be declared and their function stated. Secondly attach the pin control handle to tcon0. For example: &pio { lvds0_pins: lvds0-pins@0 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9"; function = "lvds0" }; }; &tcon0 { pinctrl-names = "default"; pinctrl-0 = <&lvds0_pins>; }; -
A few days ago I had an issue with a successfully running Armbian installation running from the NVME of my Orange Pi 5 that suddenly developed an issue with nothing being shown on my TV. So after seemingly not being to identify the problem, I started again, wrote the image to an SD card and then moved the installation to the NVME drive using armbian-config utility. So now that I have a set-up that works again, I want to instigate a more belt and braces approach and create an image of the NVME installation using GZIP to compress the image file and decided to use the DD option from terminal. Having tried well over a hundred different combinations of commands, I am unable to get things to work. I either get errors of Not a directory, No such file or directory or Is a directory The output of lsblk is NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mtdblock0 31:0 0 16M 0 disk mmcblk1 179:0 0 59.5G 0 disk └─mmcblk1p1 179:1 0 59.5G 0 part zram0 252:0 0 3.9G 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk nvme0n1 259:0 0 238.5G 0 disk └─nvme0n1p1 259:1 0 238.5G 0 part /var/log.hdd So in order to create the copy of the NVME installation, that is only taking up 13gb of the 238Gb total, to the root of a 64Gb SD card, completely empty and formatted to EXT4 via gparted, using the information above, can anybody see where I am going wrong. A few typical examples of command structures that I have tried are: sudo dd if=/dev/nvme0n1 of=/dev/mmcblk1/armbian.gz conv=sync bs=64K | gzip --stdout > bs=4M status=progress dd if=/dev/nvme0n1 conv=sync bs=64K | gzip --stdout > of=/dev/mmcblk1/armbian.gz dd if=/dev/nvme0n1p1 conv=sync bs=64K | gzip --stdout > of=/dev/mmcblk1p1/armbian.gz bs=4M status=progress This is the general template that I initially followed from a website dd if=/dev/SOURCE conv=sync bs=64K | gzip --stdout > /path/to/file.gz I've researched the use of the DD command until I am cross eyed.
Note you can provide more diagnostics with armbianmonitor -u and then pasting the link to the report here. Maybe something could have gone wrong in the unpacking process or linger system components causing issue? Just trying to rule out all other possibilities before putting it down to regression. I haven't encountered this on my system or aware of anyone else having the same problem. That's not of course to say their could be a problem.
Tried to check the integrity: $ sudo fsck.exfat -n -v /dev/sdb1 exfatprogs version : 1.2.9 label: MUSIC sector size: 512.00 B cluster size: 256.00 KB volume size: 2.26 GB /dev/sdb1: clean. directories 2083, files 32997 So it's fine. Just built exfatprogs from main just now (52b816e). For good measure I'll boot up a Windows and retry a file system repair there to see if any errors show up. Curious, I just noticed the volume size appears to be wrong in the above output: /dev/sdb1 501G 390G 111G 78% /mnt/...
Hi folks, I'll give these a try. Sorry for the brief silence. I'll perform an integrity check. I did. I used --follow and had it run in another Tmux window. The excerpt above was retrieved this way. There's about a minute and a half of (no) dmesg output prior to the output at 90829. Will do. Hasn't that been pretty much proven by downgrading just the kernel and friends? And it'd be quite hard to test a clean image, but if the other methods fail to narrow it down, I'll do it. Have to see if I can find one. This system has run for a long time, but debsums should typically be enough to tell if something is amiss, no? So rather than a clean image I'd suggest to attempt another upgrade to see whether that helps, no? I have not. It's a good point, though. However, it'd still be a regression, no? Again, the older kernel simply reads everything and the music plays fine. These are good points. I'll try with cat or so and perhaps mpv as well. If it's indeed an exfat issue there is no relation to the song or mocp. Will report back with some more information.
Would it be easy to port Armbian on the Pipo M6 Pro and integrate additional device drivers to provide support for the touchscreen, the front and back camera and the sound? https://www.geekbuying.com/item/Pipo-M6Pro-GPS-Android-4-2-RK3188-Quad-Core-1-6GHz-Tablet-PC-9-7-inch-Retina-Capacitive-Touch-Screen-2048-1536-2GB-16GB-319264.html Is this something feasible in the first place? Anybody out there who want to help me on this project?
dear Comose your are in the wrong topic this is not about rk3528 , please look at armbian forum for right please of rk3528 hallo Comose du bist hier am falschen ort , dies hier ist über rk322x board und nicht rk3528 , biite schaue in den anderen Bereichen nach rk35xx (Rk3518 / Rk3528)
I can do that but it does not provide any useful information on the subject in my opinion. Is there a way to downgrade to 25.8.0-trunk.313? According to this post, it might be useful to set the kernel option nvme_core.default_ps_max_latency_us resp. the DT overlay parameter pciex1_gen=3. How can the kernel (cmdline) option be set in Armbian? Regarding the DT overlay parameter pciex1_gen, should I follow this part of the documentation?
So, there is nothing more we can do here I think. Wait for rockchip to correct upstream.
Hello djmuted. I'm a german beginner. I have a Box Labeld Greva 8k Android 13 4G DDR3 / 64G emmc and CPU RK3528 from Amazon.de. She have an WiFi Chip EA6521QT . You have Compile it for 32bit Cpu RK322x . I need compile this driver for 64bit . It this possible? I have no idea how to compile it. Can you show me a way how I can compile it? I have Flashed armbian from this Site : https://github.com/fensoft/dq08-haos/blob/master/README.md and running HAOS & Gnome for Touchscreen . Works perfekt without Wifi. The power consumption 2.5W ( for Home Assistent Server Wonderfull) the Version is 5.10.160-legacy-rk3528-tvbox. Thanks
maybe this bug at Rockchip/mpp is relative : https://github.com/rockchip-linux/mpp/issues/855
Hi The rights seems to be ok : gart@orangepi5:~$ ls -la /dev/dma_heap total 0 drwxr-xr-x 2 root root 100 Jan 1 1970 . drwxr-xr-x 20 root root 3940 Jul 4 19:49 .. crw-rw---- 1 root video 251, 2 Jul 4 19:48 cma crw-rw---- 1 root video 251, 0 Jul 4 19:48 system crw-rw-rw- 1 root video 251, 1 Jul 4 19:48 system-uncached my user is in the video group gart@orangepi5:~$ sudo cat /etc/group | grep video video:x:44:gart There should not be any issue If I launch ffmpeg encoding with sudo, it does'nt work neither I still have this kind of messages in syslog : 2025-07-06T15:32:19.769702+02:00 orangepi5 kernel: rk_vcodec: mpp_collect_msgs:1622: session 1 process cmd 401 ret -22 2025-07-06T15:32:19.769706+02:00 orangepi5 kernel: rk_vcodec: mpp_dev_ioctl:1732: collect msgs failed -22 2025-07-06T15:32:19.769708+02:00 orangepi5 kernel: rk_vcodec: mpp_task_attach_fd:1841: can't import dma-buf 275 2025-07-06T15:32:19.769711+02:00 orangepi5 kernel: rk_vcodec: mpp_translate_reg_address:1897: reg[ 0]: 0x00000113 fd 275 failed 2025-07-06T15:32:19.769713+02:00 orangepi5 kernel: rk_vcodec: mpp_task_dump_mem_region:2084: --- dump task 0 mem region --- 2025-07-06T15:32:19.769716+02:00 orangepi5 kernel: mpp_rkvenc2 fdbd0000.rkvenc-core: no memory region mapped 2025-07-06T15:32:19.769718+02:00 orangepi5 kernel: rk_vcodec: mpp_process_task_default:589: alloc_task failed. 2025-07-06T15:32:19.769721+02:00 orangepi5 kernel: rkvenc2_wait_result:2340: session 00000000b0422e29 pending list is empty! 2025-07-06T15:32:19.769724+02:00 orangepi5 kernel: rk_vcodec: mpp_msgs_wait:1693: session 1 wait result ret -5 2025-07-06T15:32:19.768265+02:00 orangepi5 mpp[3723]: message repeated 2 times: [ mpp_serivce: mpp_service_ioc_attach_fd failed ret -1 errno 22 Invalid argument] 2025-07-06T15:32:19.785062+02:00 orangepi5 mpp[3723]: mpp_serivce: mpp_service_ioc_attach_fd failed ret -1 errno 22 Invalid argument 2025-07-06T15:32:19.786302+02:00 orangepi5 kernel: rk_vcodec: mpp_process_request:1434: can not import fd 143 2025-07-06T15:32:19.786319+02:00 orangepi5 kernel: rk_vcodec: mpp_collect_msgs:1622: session 1 process cmd 401 ret -22 2025-07-06T15:32:19.786321+02:00 orangepi5 kernel: rk_vcodec: mpp_dev_ioctl:1732: collect msgs failed -22 2025-07-06T15:32:19.786322+02:00 orangepi5 kernel: rk_vcodec: mpp_task_attach_fd:1841: can't import dma-buf 274 2025-07-06T15:32:19.786323+02:00 orangepi5 kernel: rk_vcodec: mpp_translate_reg_address:1897: reg[ 0]: 0x00000112 fd 274 failed 2025-07-06T15:32:19.786324+02:00 orangepi5 kernel: rk_vcodec: mpp_task_dump_mem_region:2084: --- dump task 0 mem region --- 2025-07-06T15:32:19.786324+02:00 orangepi5 kernel: mpp_rkvenc2 fdbd0000.rkvenc-core: no memory region mapped 2025-07-06T15:32:19.786325+02:00 orangepi5 kernel: rk_vcodec: mpp_process_task_default:589: alloc_task failed. 2025-07-06T15:32:19.786327+02:00 orangepi5 kernel: rkvenc2_wait_result:2340: session 00000000b0422e29 pending list is empty! I lauch a simple file encoding from an AV1 file to x265 : sudo ffmpeg -i file1.AV1.mkv -c:v hevc_rkmpp -c:a copy ~/Downloads/file1.x265.mkv The result is a file that has a correct size, but is unreadable, black screen.
Since U-Boot v2025.04 works very well on Orange Pi Zero v3 and has a shorter boot process time, if there was a possibility to switch to U-Boot v2504 for Orange Pi Zero V1, I would be grateful, as would probably other users of this SBC Regards
