andrey.lobov replied to jock's topic in Rockchip CPU Boxes
Hi all, I have an RK3318 TV box (A95X R2_V20). The front panel controller is TM1628. I’m running Armbian 23.11.1 with kernel 6.19.0‑edge‑rockchip64. Problem: tm16xx is not enabled in this kernel (CONFIG_TM16XX_* not set), and there is no rk3318x-config in this image. I tried to locate tm16xx sources in current Armbian kernel trees and mainline, but the driver is missing, so I can’t build it from the local headers. I have active Docker projects (avito-bot) on this box and don’t want to reinstall the system, and previous two reinstalls ended with apt issues, so I’d prefer to avoid a fresh image. Question: Is there a known external tm16xx driver repo (or patch) that can be built as an out‑of‑tree module for RK3318? If yes, could you point me to the source and any required device‑tree overlay/pin mapping for TM1628? I already posted board photos and dtb above (my post is still unanswered), so please refer to that if needed. Thanks! - Today
Mirrors come and go. Check https://docs.armbian.com/Mirrors/#current-mirrors for an up to date list of active mirrors and its status.
Werner replied to ずっと一人's topic in Orange Pi 5 Plus
I don't know. I don't maintain this board. Perhaps the maintainer knows which is alexl83. I don't know if he has a forums account though. Try via Github -
Hi @Werner For your info, with kernel-6.19.5-edge-rockchip64 using dtb from kernel-7.0.0-rc5/rc6-edge-rockchip64, Headphone Jack audio/sound is available. Does this mean the device tree is not the culprit and it is related to the kernel? Have not tried not tried booting up kernel-6.18.10-current-rockchip64 with device tree from kernel-6.18.20-current-rockchip64. -
What happened to https://mirror.aarnet.edu.au/pub/armbian/ ? It's showing an empty directory. https://mirrors.lahansons.com/armbian/apt/ proxy via Cloudflare so may be a suitable alternative.
chaitan3 replied to XXXBold's topic in Orange Pi 5
I'm using Ubuntu 24.04 noble armbian distribution, the branch I used for ffmpeg is https://code.ffmpeg.org/Kwiboo/FFmpeg/src/branch/v4l2request-v3 The ffmpeg included in the distribution does not matter, but regardless it is version 6.1.1. The mpv is built against the locally compiled ffmpeg with libplacebo from https://code.videolan.org/videolan/libplacebo.git - Yesterday
@Mohammad Adel can find the wifi chip on the board? Also Ethernet.
After upgrade to 7.0.0-rc6-edge-sunxi64 wlan is shown in interfaces. Gigabit Ethernet does not work yet.
Just a quick update for those who are following this thread, looks like there was a pull request for U-Boot with this fix (2026-02-02): https://github.com/armbian/build/pull/9333 Waiting for the U-Boot update i guess (i'm using `linux-u-boot-odroidm1-edge/sid` currently).
X98H is booted Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_server.img.xz https://github.com/NickAlilovic/build
Thank you for being specific about the RKxxx+6.19+Noble information As I asked in the other thread, please also specify which ffpmeg and mpv sources you used. I hope I can make it work in opiz3 (H618) in a more recent Debian (I only could make it work in Bookworm). Do you see any difference in 8bit vs 10bit HEVC(H265)?
hello i try image "Armbian-unofficial_26.05.0-trunk_Orangepi-4a_trixie_edge_7.0.0-rc5.img" not detected emmc and wifi. ethernet crushed periodically
@Mohammad Adel There are differences like Ethernet and maybe WiFi. Lets see if the X98H boots first.
For context, he is talking about: https://code.ffmpeg.org/FFmpeg/FFmpeg/pulls/20847 There are many ffpmpeg options. Which ffmpeg did you use? https://code.ffmpeg.org/Kwiboo/FFmpeg/src/branch/v4l2request-v3 https://code.ffmpeg.org/Kwiboo/FFmpeg/src/branch/v4l2-request-n8.1 And which debian/ubuntu version did you use? Which ffmpeg is included in that distribution? -
I need a Linux system that runs on an x98h device Anything that does not work is not booted by the device
The x98h pro device is not the same as the x98h
Werner replied to Mohammad Adel's topic in Allwinner CPU Boxes
duplicate -
@m1zfs I am willing to test as i have an m1 odroid with 4GB ram. What do i need to do ? I tried your dkms package installed it and rebooted but system never turned up after reboot.
