  1. Yesterday
  2. After some experimentation, I realized that the full xfce images are working fine, likely because NetworkManager is built in. The minimal CLI images, even after switching to NetworkManager per the instructions here, never worked for me to retain Wifi after a reboot. I'm going through the process of removing the XFCE desktop from my install as CPU utilization in Klipper is very high otherwise.
  3. FWIW, I am running -edge kernel from armbian with respective dtb (linux-dtb-edge-rockchip64 package), and it's quite stable. vmlinuz-6.18.0-rc6-edge-rockchip64 dtb-6.18.0-rc6-edge-rockchip64 🤞
  4. For information: First reboot and crash same that before use rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp. 😞 Back to 6.12.58, rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and freeze to this setting Me and my brother have helios64 with 6.18.10 Kernel : RAID 10 / LVM / LUKS and crash always when "cryptsetup open..." start Crash when many I/O Crash when use Full CPUs With rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and Kernel 6.12.58 or 6.12.(XX below): Me, never crash but I reboot often and power off often for personal choice. My brother have uptime upper than 100 or 200 days with problem, freeze or crash Bye
  5. Hi everybody, I running Helios64 with kernel 6.12.58 since a long time and the prahal dtb file rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and my helios64 work well. Today, Armbian upgrade to 6.18.10 kernel. Is this update use the same change or patch like in rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp ? Is rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp work with 6..18.10 kernel ? Is I must to downgrade to 6.12.58 kernel with rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and freeze at this kernel version ? Thanks for answer.
  6. @naceur abdelkader Your post has nothing to do with Armbian. Please find a more appropriate site to ask your question. This site is for Armbian linux.
  7. Dear Sir/Madam, I am writing to request the official firmware for my Trenspeed H616 device. I accidentally installed an Orange Pi firmware, which caused my device to lose the Google Play Store and essential services. Device specifications: Board: T98_616_LP3_210222 Memory: 4GB RAM / 32GB storage Current version: Android 10 I would greatly appreciate it if you could provide a link to the official firmware or instructions for the correct update, ensuring that it includes Google Play Store and core services. Thank you very much for your assistance.
  8. sven-ola
    Download the RV2 image. It's basically the same plus DKMS (including headers) for building the bcmdhd wifi driver. You need to change the "fdt" line in /boot/extlinux/extlinux.conf for rv2->r2s (DTB file is there), e.g before uploading with mount -o offset=$(( 512 * 8192 )) Armbian-....img /mnt/
  9. maxsub
    @sven-ola The nightly is on 6.19 without headers, so I can't build any additional drivers. The nightly is working on the R2S with ethernet ports and no heating issues, no load average problems. How do I get a 6.18 build (Current)? Thanks.
  10. sven-ola
    PCIe is a rabbit hole for it's own. I have a Wifi card that cannot issue in-line-interrupts ("MSI") for some reason so the firmware upload fails, while working fine with same driver in my PC. I simply don't use it. ASPM quirks also seems not to be too uncommon, a simple grep quirk_disable_aspm drivers/pci/quirks.c|wc -l shows 21...
  11. sven-ola
    @maxsub with a recent kernel, temp and load should be fine. The exiting question is: all 4 Ethernet ports are working?
  12. sven-ola
    Schematics-wise no - at leasts I don't see a diff in the RV2_SCH.pdf. Electrical-wise probably - other traces, so maybe more or less crosstalk, better or worse gnd and such. From a software perspective: this is PCIE-B and C (while A is unused). That PCIe active state power management seems to be a source of endless pleasure, maybe the NVME vendors all have digested the wrong specs or so. Anyhow: if it works now, it's fine probably.
  13. My n2 works fine btw. https://paste.armbian.com/cocivagayi
  14. maxsub
    @sven-ola Nightly build fixed the load problem and heat problem on R2S: linux-image-current-spacemit/now 26.2.0-trunk.574 riscv64 [installed,local] Armbian Linux current kernel image 6.18.18-current-spacemit This is my current uname -r: 6.18.18-current-spacemit
  15. Setting pcie_aspm=off makes the drive work in the top slot albeit one order of magnitude slower than in the bottom slot. If I swap the kernel parameter with pcie_aspm.policy=performance, I've got a working drive and it's operating at normal speed. Thanks a bunch! Seeing that there are differences in behavior between the two M.2 slots, does that mean they're connected differently?
  16. maxsub
    > apt search linux-headers linux-headers-6.19.6+deb14+1-common/testing 6.19.6-2 all Common header files for Linux 6.19.6+deb14+1 linux-headers-6.19.6+deb14+1-riscv64/testing 6.19.6-2 riscv64 Header files for Linux 6.19.6+deb14+1-riscv64 linux-headers-riscv64/testing 6.19.6-2 riscv64 Header files for Linux riscv64 configuration (meta-package) > uname -r 6.18.18-current-spacemit
  17. maxsub
    I installed 6.18.18-current-spacemit from the nightly but can't find the headers package to build the GPU support. The repo has 6.19.x headers but no 6.18.x headers.
  18. FT232R, CH340 or CP2104 are known to work nicely. Search for any usb uart adapter built around one of these. Don't get CP2102 because if you ever get a rockchip board it would be useless.
  19. If you'd like to get the LEDs working with armbian, you can run these commands (or one of the other ones if you want different indications): run modprobe ledtrig-netdev to check if it's loading the driver properly. If not, add the file /etc/modules-load.d/ledtrig.conf add just this line: ledtrig-netdev Then, create /etc/tmpfiles.d/leds.conf and add this: w /sys/class/leds/green:lan/trigger - - - - netdev w /sys/class/leds/green:lan/device_name - - - - eth0 w /sys/class/leds/green:lan/link - - - - 1 w /sys/class/leds/green:lan/tx - - - - 1 w /sys/class/leds/green:lan/rx - - - - 1 w /sys/class/leds/green:wan/trigger - - - - netdev w /sys/class/leds/green:wan/device_name - - - - eth1 w /sys/class/leds/green:wan/link - - - - 1 w /sys/class/leds/green:wan/tx - - - - 1 w /sys/class/leds/green:wan/rx - - - - 1 w /sys/class/leds/red:power/trigger - - - - activity Note that "red:power" is actually the "green:sys" LED. I don't see a way to control the red power led (which is fine, the green:sys is what want to control anyway). I also use NetworkManager and set my ethernet names to eth0 and eth1 instead of the default names... Here's all the choices available for "triggers": none usb-gadget usb-host kbd-scrolllock kbd-numlock kbd-capslock kbd-kanalock kbd-shiftlock kbd-altgrlock kbd-ctrllock kbd-altlock kbd-shiftllock kbd-shiftrlock kbd-ctrlllock kbd-ctrlrlock disk-activity disk-read disk-write mtd nand-disk heartbeat cpu cpu0 cpu1 cpu2 cpu3 cpu4 cpu5 activity default-on panic usbport mmc1 rfkill-any rfkill-none r8169-0-100:00:link r8169-0-100:00:10Mbps r8169-0-100:00:100Mbps r8169-0-100:00:1Gbps stmmac-0:01:link stmmac-0:01:10Mbps stmmac-0:01:100Mbps stmmac-0:01:1Gbps netdev "activity" is also a good one for red:power if you prefer that to "heartbeat"
  20. I changed the devicedesc, but game still shows same error. And the launcher shows it is another name. (Nvdia Geforce 6800).Ps: must go bed for now XD.
  21. Not sure its related, but on the MusePi Pro I was getting odd happenings with the PCIe. Adding this to the command line resolved it my case: nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off
  22. sven-ola
    @Curvy Android I don't see meaningful differences in the kernels init msgs for top and bottom PCIe slots - besides that "Buffer I/O error" that leads to the non-working NVME. Besides that, the "faulty power saving mode" line looks familar. I have trouble with my Samsung NVME with that power saving blurb as well. Can you retry with NVME in the top slot and an additional pcie_aspm=off added to your booting SD card in the /boot/extlinux/extlinux.conf file behind append kernel params?
  23. I can see it has already set: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum Mali-G610 MC4
  24. I found that if I use umu-run(protonge), the launcher will crash, but if i use wine staging (with dxvk), the launcher start is no problem but the game got a error.
  25. I found "https://www.naeu.playblackdesert.com/en-US/Forum/Qna/Detail?_questionNo=1122&_answerSortType=0" have same problem, but I have no idea about find the device ID.
