  2. I am getting a thermal zone failure message during boot, which has always happened with kernels after 6.6, at least as far as I know. Is this error actually harmful? HardWare:NanoPi NEO2 Armbian Version: Packages: Debian stable (bookworm) v25.2.3 for NanoPi Neo 2 running Armbian Linux 6.12.20-current-sunxi64 Support: DIY (community maintained) Kernel: Linux nanopineo2 6.12.20-current-sunxi64 #1 SMP Sat Mar 22 19:54:28 UTC 2025 aarch64 GNU/Linux dmesg output [ 7.018086] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 7.018125] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000) [ 7.018245] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 7.018258] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000) [ 7.018413] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator [ 7.018426] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000) [ 7.018552] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator [ 7.018564] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000) [ 7.019699] thermal thermal_zone0: binding cdev cpufreq-cpu0 to trip 3 failed: -22 [ 7.019785] thermal thermal_zone0: binding cdev cpufreq-cpu0 to trip 4 failed: -22 dmesg.txt
  3. Early May brought another round of steady advancements to the Armbian project, with progress in U-Boot updates, board enablement, firmware fixes, and notable improvements to Armbian’s growing catalog of self-hosted applications. Bootloader and Firmware Enhancements Several platforms saw significant U-Boot improvements. The Cherryba-M1 now benefits from an upgraded U-Boot and reorganized patch structure, thanks to Igor‘s work on upgrading Cherryba-M1 to latest u-boot and moving patch to new folder. Andy bumped U-Boot to v2025.04 for the Lubancat2, keeping the board current. The Radxa Rock 4 SE also migrated to this version, where Niklas refined its configuration and boot behavior. Meanwhile, the Khadas VIM3 received a broader bootloader overhaul led by Ricardo, introducing SD-first boot order, squashfs and fileenv support, and enhanced compatibility with Home Assistant OS in a comprehensive update to U-Boot for Khadas VIM3. Older configurations didn’t go unnoticed: Igor removed deprecated ATF tags for sun50iw9 / H61x, while Olaf pushed the sunxi64 platform to the latest LTS version of ATF. Expanding Device Support Armbian continues to grow its ecosystem. Rolf introduced official support for the Banana Pi M2+, making it easier for users to deploy on this compact board. On the RISC-V side, libiunc brought the kernel for the StarFive2 platform up to v6.6, ensuring ongoing support and compatibility. Installer Improvements and Runtime Fixes Improving install experience, Igor Velkov added Btrfs root subvolume support when installing to NVMe, paving the way for better snapshot and maintenance workflows. Igor also corrected missing Broadcom firmware for Raspberry Pi boards to fix wireless support and suppressed firmware warnings related to built-in Realtek USB network drivers, helping clean up logs and reduce confusion. Self-Hosted App Catalog Grows The list of installable apps during Armbian setup has expanded. Two powerful platforms are now just a selection away: Immich, a self-hosted photo and video backup system, was added with the introduction of Immich to configNG. NetBox, a leading infrastructure resource management solution, joined the roster in the addition of NetBox to Armbian configNG. Both are available via the configNG provisioning interface. Deprecations and Housekeeping Support for legacy distributions has now ended: Debian Bullseye and Ubuntu Focal and Jammy will no longer receive repository updates, as noted in the userspace status change to EOS. Elsewhere, dependency and CI maintenance continued. Automated tools like Dependabot bumped packages such as setuptools and GitHub actions for changed-files, while amazingfate restored support for the AIC8800 Wi-Fi driver by reverting a mistaken disable. Further Reading Explore the full range of updates in the official Armbian snapshot. The post Armbian Development Highlights – Early May 2025 first appeared on Armbian. View the full article
  5. I set the version in userpatches/lib.config , then executed this: ./compile.sh BOARD=orangepizero2 BRANCH=current kernel-config KERNEL_BTF=no KERNEL_GIT=full and when the kernel menu came up, just exited to shell. Is this the kernel source directory I can point the compiler script of the module ? /build/cache/sources/linux-kernel-worktree/6.12__sunxi64__arm64$ ls arch COPYING defconfig fs io_uring Kconfig LICENSES mm rust security usr block CREDITS Documentation include ipc kernel MAINTAINERS net samples sound virt certs crypto drivers init Kbuild lib Makefile README scripts tools
  6. this is what dmesg looks like dmesg.txt
  7. Hi, Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  8. if you want zfs on recent kernel you've to compile it manually, this worked on kernel 6.14.5 on Radxa Rock 5 ITX.
  9. No, unfortunately not. But there was an image, among many others that I tested that worked, but it had other problems, I don't remember anymore. And even if I want to recover it, I can't find it anymore. I spent a lot of time testing a lot of images, and then I just started putting in a folder the ones that ran well at boot and started without problems. I have a four or five, but all without working usb ports. However, since I only wanted to install the Pi-Hole on it, I found that I could access it via a computer via SSH. And since then everything has been much easier, even higher with the help of our friend CHATGPT!! And even then, the image that finally worked is where I installed the Pi-Hole. must have problems. From time to time it freezes. I see that I'll have to test others. If there is news, I will say so. And if you also have any news, please share it. Hug
  10. We just figured out we have dropped packing kernel sources at some point. Until we figure out how to re-enable that or if this makes sense, use build framework to add a custom module. It has the ability to do that. Allwinner kernel is heavily patched, version is not necessarily latest, quite distanced from mainline, while Amlogic, on the other hand, is closer, changed less.
  11. Welcome on board. This will be a huge difference, so be open for learning, have a lot of patience. https://docs.armbian.com/User-Guide_Board-Support-Rules/ One of the key challenges we face is that maintaining older hardware is both time-consuming and costly. With limited financial and community support, the resources we have are already stretched thin across the entire project. Our team is very small—currently, we have only one dedicated maintainer for the Allwinner software stack that is focused into latest 64bit Allwinner family (H6/H6xxx). Other projects often face similar constraints, often relying on a single contributor who can do anything. For example, in our collaboration with LibreELEC (LE), we benefit from some shared efforts, but both sides are still primarily driven by individual volunteers working on a best-effort basis. If priorities shift, progress can be delayed significantly—and unfortunately, Armbian doesn't have the capacity to pick up. I’m sharing this openly in the hope that it raises awareness. Personally, I would love to see continued support for legacy devices. But to make that happen, we need to ask: who is willing and able to invest weeks or months each year required to maintain these older platforms? What you can do? Try to understand how this works, connect with people that share your problem (all similar board owners with interest that it is maintained) - invest time to learn. Probably USB ports are just not enabled - check this: https://docs.armbian.com/User-Guide_Armbian-Config/System/#device-tree-overlays
  12. Yes correct the SSV6252p is hard to get it run because no support , the MSN8800D i think was a old chip from i-phone or a clone from something , support looks bad ( only some one match with google ) but its have nothimng to do with emmc support , maybe this board has nand or eMCP memmory and than also emmc not found ( Nand only in legacy image support , eMCP only with correct led-config sometimes) when you have exp in hot air soldering maybe swap the wifi this a best solution or use usb stick
  13. Broadcom brcmsmac(PCIe) and brcmfmac(SDIO/USB) drivers https://wireless.docs.kernel.org/en/latest/en/users/drivers/brcm80211.html Broadcom brcmfmac driver Support for both 32 and 64 bit Linux kernels Firmware installation Current For SDIO driver you need to copy the nvram for your system and place it in /lib/firmware/brcm. The nvram file name depends on the chip you have. The kernel log will tell you the exact file name. For the USB driver no nvram file is strictly needed: in fact, the driver only loads the firmware blob and does not look for an nvram text file. However, the nvram parameters are still required and they are already part of the firmware blob. This is a TRX file which contains the nvram parameters as a sequence of zero-terminated plain text strings, appended at the end of the last section. For an example of how to modify/add nvram parameters for USB devices, see this post: https://elimo.io/2-4ghz-coexistence-reverse-engineering-broadcom-chips-to-enable-packet-traffic-arbitration/ The firmware files are located in the linux-firmware repository and can be copied as is to /lib/firmware/brcm. SDIO chip on older kernels (before 3.13) In kernel priors to v3.13 the SDIO driver used generic firmware names. Below are the instruction Use the nvram file installed in your system and copy it to /lib/firmware/brcm/brcmfmac-sdio.txt The firmware can be found in the linux-firmware repository. For 4329: cp brcm/brcmfmac4329.bin /lib/firmware/brcm/brcmfmac-sdio.bin For 4330: cp brcm/brcmfmac4330.bin /lib/firmware/brcm/brcmfmac-sdio.bin Alternatively, when not available the Android version can be used as well: git clone https://android.googlesource.com/platform/hardware/broadcom/wlan firmware files: bcmdhd/firmware/bcm4329/fw_bcm4329.bin bcmdhd/firmware/bcm4330/fw_bcm4330_b2.bin NVRAM from EFI Some new devices are storing the nvram which is needed in addition to the firmware by the driver in an EFI variable and the Windows driver can access it (this file should be optional in the case of PCIe devices). Currently brcmfmac does not support this automatically. First mount the efi vars into sysfs: mount -t efivarfs none /sys/firmware/efi/efivars The content of the nvram is in this file: /sys/firmware/efi/efivars/nvram-74b00bd9-805a-4d61-b51f-43268123d113 Copy this file where brcmfmac expects the nvram, for example: cat /sys/firmware/efi/efivars/nvram-74b00bd9-805a-4d61-b51f-43268123d113 > /lib/firmware/brcm/brcmfmac43241b4-sdio.txt
  14. Yesterday
  15. Hello. I have a z8pro TV box, installed an image from x98 but WiFi sv6256 doesn't work, no sound. Specifications: System: Android TV 12.0 Processor: Alwinner H618 Graphics processor: Mali-G31 RAM: 4GB Built-in storage: 32GB Connectors: HDMI 2.1, USB 2.0, USB 2.0, LAN 100Mbit, S/PDIF, AV, MicroSD Auto frame rate: Yes Network interfaces: Wi-Fi 2.4/5GHz, Bluetooth, LAN 100Mbit Maybe someone has already assembled an arbian assembly for this board? Please share.
  16. Hi, I need linux kernel source to compile a custom module. The one I downloaded from kernel.org did not work, got module format error, indicating the kernel is different. i did not have this problem compiling the same module for Armbian lepotato (amlogic) Where do I get the kernel source for my Orangepi Zero 2? Linux orangepizero2 6.12.20-current-sunxi64 #1 SMP Sat Mar 22 19:54:28 UTC 2025 aarch64 GNU/Linux linux-headers-current-sunxi64/bookworm,now 25.2.3 arm64 [installed] Armbian Linux current headers 6.12.20-current-sunxi64 linux-image-current-sunxi64/bookworm,now 25.2.3 arm64 [installed] Armbian Linux current kernel image 6.12.20-current-sunxi64
  17. Hi! I'm trying to make it work too! How should I name your DTS file from April 3? And then, after copying it, should I run the armbian-add-overlay command and reboot? That's it? I don't need to change Armbian Env? Thanks for your help!
  18. Hi, Pilinha. I am having the same problem. How did you get to get the keyboard working?
  19. Start with a minimal image: no X11, no desktop sudo systemctl list-units --type=service --all Find those services you don't need, and "sudo systemctl disable <service>" Is buildroot a nice experience like armbian?
  20. TL:DR Orange Pi Plus 2e USB ports are not working on newer images (LE and Armbian). Full story: Hi. I am Catota and I am new here. I am mainly a windows user with very little experience with linux. My brother recently discovered an old forgotten Orange Pi Plus 2e and gave it to me as I was looking for a media player. It has a functional Armbian 20.02.1 installed in its internal memory, but my brother does not know the passwords for either the normal user or root anymore. I installed the latest Armbian from the SD slot and it booted just fine, but the USB ports (used for keyboard and mouse) do not seem to be working. I installed the latest LE from the SD slot and it booted just fine, but the USB ports do not seem to be working. I booted from internal memory into the old Armbian and all USB ports are working fine (but i lack permissions to upgrade or install anything because I do know any passwords). I installed the oldest Armbian (21.02) and LE (10.04) I could find, but the USB ports do not seem to be working. Does anybody know if there is something very obvious that I am missing? Thanks.
  21. i have the DQ08 and the lan cable is not working anymore. It was in the past but now it only works through Wifi. How is this even possible? Anyone an idea? or how to fix this. The option is not even in the menu anymore even when the LAN cable is plugged in
  22. I have an IoT project that uses an SPI LCD (480x320), showing 1 full screen application on top of X11, which starts automatically, almost in kiosk mode. Is it worth a lot trying to switch to Wayland? I have 2 roadblocks, which I am trying to drill through: * tkinter app re-write in pyqt * starting from a minimal armbian image, and install the bare minimum to have wayland and start the app Solid advantage: * Future proofing the product I have these preconceived advantages: * less resources needed: my application is fine with an OrangePi Zero 3 with 1 GB RAM, I don't want to upgrade RAM * faster startup (now I need to wait 1 minute from power-on to app ready to use, reducing it to 30 seconds would be nice) I know that I can't expect these advantages, since I use SPI instead of HDMI or DSI: * 30 FPS * No frame tearing But really, my main objective is faster startup: will Wayland help me with that? (without having disadvantageous side effects)
  23. Found a handful of working mxq boards in the trash, the unique ones are labed R329Q_v8.1, MXQ_RK3229_EMPC_V4.1 and B00-RK28A-REV76. What are they actually? Almost all of them have an ssv6256p. Can someone confirm me it's actually impossible to use the wifi with this chip? I tried and tried and couldn't get it to work. There's one board with a chip called MSN8800D I would try to get wifi with it but multitool says the emmc storage was not found. Did the chip fry, even though it's a 8Gb/8GB one? If it fried the board shouldn't work at all because the ram would fry too, no? It's Samsung KMQ7X000SA-B315
  24. glad i stumbled on this - had the same problem and i spent the weekend reconfiguring my nas and turning off all updates for now. Igor you have done great work over the years and absolutely understand the difficulty. I wish I knew programming and could assist. However the helios4 has had a great run, its def time for an upgrade.
  25. I am including the Tanix tx6s and Vontar h618 complete android firmware for wifi/bluetooth. I previously tried using some of the files with no success but found the complete firmware save to a usb drive. I think android is using different file names to what is usually expected to work. hopefully its useful to get Bluetooth working in armbian. Tanix Tx6s Wifi/BT: SP6330-X0 Clock: 26.0 MHz Tanix tx6s android firmware also includes fdt (dtb) file Vontar H618 Wifi/BT: HK6334Q Clock: 37.4 MHz Vontar H618 android firmware I no longer have working android to boot into. If someone can copy the android fdt (dtb) file from their vontar h618 box and upload it. i would be very grateful. here is how you can do it , i did this for tanix tx6s get android fdt (dtb) think this is the android path to the file /sys/firmware/fdt
  26. @dale murata is armbian firmware, samsung is from vontar android firmware, if you open .hcd with text editor you see text of murata or samsung, I just use that as reference for each file.
  27. Try some of these images. https://github.com/armbian/os/releases/tag/25.5.0-trunk.507 And please post here what doesn't work with the download link to the image.
