I would always go RPi, as I have been burned going with a different board in the past. This may not be a fair reflection on the Orange Pi, as I can only speak for having purchased an Odroid C1+ many years ago. The C1+ was a very capable board, and definitely more capable than the RPi offering at the time. However, there just is no substitute for the support and community around the RPi. I now have 3, and even my original RPi 1 Model B+ is still supported by the RPi foundation, and still gets modern kernel and OS updates. This is a board running off just 512MB RAM, A 700 MHz single-core 32-bit processer and released over 11 years ago. No one could complain if they had dropped support long ago, but they didn't, and they still show no signs of dropping support any time soon. Hardkernel, on the other hand, pretty much dumped support for the Odroid C1+ as soon as it released, so it is stuck on a 3.x kernel and a uBoot from 2011. If it wasn't for the Armbian project this board just would not be useable, and even then, we are still stuck on a 15 year old uBoot solution. None of this may be important to you, and like I say, my experience is not likely a like-for-like comparison with the Orange Pi, but the long term support you get from the RPi foundation and the wider community around it is not even close to being matched by any other vendor, and (personally) I don't like supporting vendors who effectively manufacture e-waste.
@Shubham Singh To check if KVM is compiled into the kernel, use the following command: grep CONFIG_KVM /boot/config-$(uname -r) CONFIG_KVM=y CONFIG_KVM_MMIO=y CONFIG_KVM_VFIO=y CONFIG_KVM_GENERIC_DIRTYLOG_READ_PROTECT=y CONFIG_KVM_XFER_TO_GUEST_WORK=y You also need to ensure your CPU supports virtualization. Check with: egrep -c '(vmx|svm)' /proc/cpuinfo 0 A return value greater than 0 indicates virtualization support is present. CPU doesn't support virtualization. Check the official Radxa image. Using these commands. I doubt it works. I'm using the same kernel config and Board support package.
HI, I'm trying Mint forum. I am receiving this notification on every system startup. 19/11/2025,16:18:34 Problems during Cinnamon initialization Cinnamon started successfully, but it was not possible to load one or more applets, desklets or extensions. Check the system logs and the LookingGlass log for any issues in Cinnamon. You can disable all extension(s) in Cinnamon Settings to prevent this message from appearing repeatedly. Please contact the developer. and Looking Glass log error t=2025-11-19T03:20:50Z [menu@cinnamon.org]: Util.latinise is not a function [menu@cinnamon.org]: Failed to evaluate 'main' function on applet: menu@cinnamon.org/0 error t=2025-11-19T03:20:50Z [menu@cinnamon.org]: Applet menu@cinnamon.org: Could not create applet object.[menu@cinnamon.org]: Error importing applet.js from menu@cinnamon.org error t=2025-11-19T03:20:51Z [menu@cinnamon.org]: Util.latinise is not a function [menu@cinnamon.org]: Failed to evaluate 'main' function on applet: menu@cinnamon.org/0 error t=2025-11-19T03:20:51Z [menu@cinnamon.org]: Applet menu@cinnamon.org: Could not create applet object. [menu@cinnamon.org]: Error importing applet.js from menu@cinnamon.org info t=2025-11-19T03:20:51Z AppletManager started in 15564 ms info t=2025-11-19T03:20:51Z Cinnamon took 15834 ms to start info t=2025-11-19T03:20:51Z Adding systray: blueman-tray (1x1px) info t=2025-11-19T03:20:51Z Adding systray: solaar (1x1px) info t=2025-11-19T03:20:51Z Adding systray: indicator-solaar (1x1px) info t=2025-11-19T03:20:51Z GPU offload supported: false Captured from my system: cury@orangepi5-plus:~$ inxi -Fxxxz System: Kernel: 6.1.115-vendor-rk35xx arch: aarch64 bits: 64 compiler: gcc v: 11.4.0 clocksource: arch_sys_counter Desktop: Cinnamon v: 6.4.10 wm: Muffin v: 6.4.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Armbian GNU/Linux 13 (trixie) Machine: Type: ARM System: Orange Pi 5 Plus details: N/A CPU: Info: 8-core model: N/A variant-1: cortex-a76 variant-2: cortex-a55 bits: 64 type: MCP smt: <unsupported> arch: ARMv8 rev: 0 cache: L1: 768 KiB L2: 2.5 MiB L3: 3 MiB Speed (MHz): avg: 1800 min/max: 408/1800:2256 cores: 1: 1800 2: 1800 3: 1800 4: 1800 5: 1800 6: 1800 7: 1800 8: 1800 bogomips: N/A Features: Use -f option to see features Graphics: Device-1: display-subsystem driver: rockchip_drm v: N/A bus-ID: N/A chip-ID: rockchip:display-subsystem class-ID: display-subsystem Device-2: rk3588-dw-hdmi driver: dwhdmi_rockchip v: N/A bus-ID: N/A chip-ID: rockchip:fde80000 class-ID: hdmi Device-3: rk3588-dw-hdmi driver: dwhdmi_rockchip v: N/A bus-ID: N/A chip-ID: rockchip:fdea0000 class-ID: hdmi Display: x11 server: X.Org v: 21.1.16 driver: X: loaded: modesetting unloaded: fbdev dri: rockchip gpu: rockchip_drm,dwhdmi_rockchip, dwhdmi_rockchip display-ID: :0 screens: 1 Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93") Monitor-1: HDMI-A-1 mapped: HDMI-1 model: LG (GoldStar) FHD serial: <filter> res: mode: 1920x1080 hz: 100 scale: 100% (1) dpi: 82 size: 597x336mm (23.5x13.23") diag: 685mm (27") modes: max: 1920x1080 min: 640x480 API: EGL v: 1.5 platforms: device: 0 drv: panthor device: 1 drv: rknpu device: 2 drv: rockchip device: 3 drv: swrast gbm: drv: panthor surfaceless: drv: panthor x11: drv: rockchip inactive: wayland API: OpenGL v: 4.5 compat-v: 3.1 vendor: mesa v: 25.0.7-2 glx-v: 1.4 direct-render: yes renderer: Mali-G610 (Panfrost) device-ID: ffffffff:ffffffff Info: Tools: api: eglinfo,glxinfo x11: xdriinfo, xdpyinfo, xprop, xrandr Audio: Device-1: hdmi driver: rk_hdmi_sound bus-ID: N/A chip-ID: rockchip:dp0-sound class-ID: dp0-sound Device-2: rk3588-dw-hdmi driver: dwhdmi_rockchip bus-ID: N/A chip-ID: rockchip:fde80000 class-ID: hdmi Device-3: rk3588-dw-hdmi driver: dwhdmi_rockchip bus-ID: N/A chip-ID: rockchip:fdea0000 class-ID: hdmi Device-4: hdmi driver: rk_hdmi_sound bus-ID: N/A chip-ID: rockchip:hdmi0-sound class-ID: hdmi0-sound Device-5: hdmi driver: rk_hdmi_sound bus-ID: N/A chip-ID: rockchip:hdmi1-sound class-ID: hdmi1-sound API: ALSA v: k6.1.115-vendor-rk35xx status: kernel-api Server-1: PulseAudio v: 17.0 status: active Network: Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: 1000 bus-ID: 0003:31:00.0 chip-ID: 10ec:8125 class-ID: 0200 IF: enP3p49s0 state: down mac: <filter> Device-2: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: 100000 bus-ID: 0004:41:00.0 chip-ID: 10ec:8125 class-ID: 0200 IF: enP3p49s0 state: down mac: <filter> Device-3: wlan-platdata driver: wlan_platdata v: N/A bus-ID: N/A chip-ID: wlan-platdata:wireless-wlan class-ID: wireless-wlan IF-ID-1: dummy0 state: down mac: <filter> IF-ID-2: enP4p65s0 state: down mac: <filter> IF-ID-3: wlx90de807f1947 state: up mac: <filter> Bluetooth: Device-1: Realtek 802.11ac NIC driver: btusb,rtw_8822bu type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 bus-ID: 1-1.4:3 chip-ID: 0bda:b82c class-ID: e001 serial: <filter> Report: hciconfig ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes address: <filter> Drives: Local Storage: total: 1.04 TiB used: 107.07 GiB (10.0%) ID-1: /dev/nvme0n1 vendor: Reletech model: P600 M.2 PCIE3.0 1TB size: 953.87 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SN10660 temp: 39.9 C scheme: GPT ID-2: /dev/sda vendor: Kingston model: DataTraveler 3.0 size: 115.47 GiB type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 tech: N/A serial: <filter> fw-rev: 0000 scheme: MBR Partition: ID-1: / size: 576.47 GiB used: 12.63 GiB (2.2%) fs: ext4 dev: /dev/nvme0n1p1 ID-2: /var/log size: 46.8 MiB used: 7.4 MiB (15.9%) fs: ext4 dev: /dev/zram1 Swap: ID-1: swap-1 type: partition size: 19.14 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2 ID-2: swap-2 type: zram size: 7.79 GiB used: 0 KiB (0.0%) priority: 5 dev: /dev/zram0 Sensors: System Temperatures: cpu: 49.0 C mobo: N/A Fan Speeds (rpm): N/A Info: Memory: total: N/A available: 15.58 GiB used: 4.38 GiB (28.1%) Processes: 313 Power: uptime: 1h 17m states: freeze,mem suspend: deep wakeups: 0 Init: systemd v: 257 default: graphical Packages: pm: dpkg pkgs: 1548 Compilers: clang: 19.1.7 gcc: 14.2.0 Shell: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.38 cury@orangepi5-plus:~$
Yes, I removed that as well quite quickly. Now the printer is ready in 30s after power-on.
@djoness you need to Disable Armbian kernel/firmware upgrades using the armbian-config tool. System -> Updates -> UPD002 - Disable Armbian firmware upgrades -> Disable Armbian kernel/firmware upgrades X96Q has many different variations of the same box. Read the bottom of this thread. https://github.com/warpme/miniarch/issues/102 If you want a well supported box get a Transpeed 8K618-t.
This issues has had me sticking with the old BTT images for ages, then I found a different issue with those so was forced to come back to try again with Armbian. After going down many rabbit holes a friend said just install KlipperScreen earlier than you normally would when running up a Klipper install, that will pull in network manager. It was so simple for my use case I hadn't even considered it. Worked a treat, I could set up the wifi on the touchscreen and it survived reboots. I then found a slow down in the boot process because networkd was still waiting for a connection, a solution to that wasn't as hard to find I ran these two commands in the terminal and now it doesn't slow anything down during boot up. I have no idea if this is the correct way but I'll post it in case it helps anyone else following the same breadcrumbs I've been chasing. sudo systemctl disable systemd-networkd-wait-online.service sudo systemctl mask systemd-networkd-wait-online.service
Hello, my Orange Pi 5 works well with the stock OS (1.22, Ubuntu Jammy, BSP kernel 6.1.99), using the SD as a boot device. It also works ok with Armbian Minimal-IoT / Debian 13 / 6.1: v25.8.2 for Orange Pi 5 running Armbian Linux 6.1.115-vendor-rk35xx But I prefer Ubuntu and wanted to try 6.12, so I downloaded 25.8.2 / Ubuntu Server / 6.12. Wrote to SD, hooked up the debug UART and powered on. The bootloader is fine, the kernel starts, but at a certain point it panics: [ OK ] Reached target sockets.target - Socket Units. Starting armbian-hardware-monitor.…ce - Armbian hardware monitoring... Starting armbian-hardware-optimize… - Armbian hardware optimization... Starting armbian-led-state.service - Armbian leds state... Starting armbian-resize-filesystem…vice - Armbian filesystem resize... armbian-hardware-monitor.service [ OK ] Finished armbian-hardware-monitor.…vice - Armbian hardware monitoring. [ OK ] Finished armbian-led-state.service - Armbian leds state. armbian-led-state.service [ OK ] Finished armbian-hardware-optimize…ce - Armbian hardware optimization. armbian-hardware-optimize.service [ OK ] Finished console-setup.service - Set console font and keymap. console-setup.service sys-kernel-debug-tracing.mount [ 158.363359] rockchip-pm-domain fd8d8000.power-management:power-controller: failed to get ack on domain 'gpu', val=0xa9fff [ 158.364324] SError Interrupt on CPU7, code 0x00000000be000411 -- SError [ 158.364327] CPU: 7 UID: 0 PID: 462 Comm: (udev-worker) Tainted: G M C 6.12.49-current-rockchip64 #1 [ 158.364332] Tainted: [M]=MACHINE_CHECK, [C]=CRAP [ 158.364333] Hardware name: Xunlong Orange Pi 5 (DT) [ 158.364334] pstate: 404000c9 (nZcv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 158.364336] pc : _raw_spin_lock_irqsave+0x38/0x8c [ 158.364342] lr : regmap_lock_spinlock+0x18/0x2c [ 158.364347] sp : ffff800083f03660 [ 158.364348] x29: ffff800083f03660 x28: 0000000000000000 x27: ffff800083f03c60 [ 158.364351] x26: 0000000000000000 x25: ffff710bf0c4c080 x24: ffff710bf0f64098 [ 158.364354] x23: 0000000000000000 x22: 0000000000000001 x21: 0000000000000000 [ 158.364356] x20: 000000000000000c x19: 0000000000000000 x18: ffffffffffffffff [ 158.364358] x17: 66203a72656c6c6f x16: 72746e6f632d7265 x15: 776f703a746e656d [ 158.364361] x14: 6567616e616d2d72 x13: 00000000000002ac x12: 00000000ffffffea [ 158.364363] x11: 0000000000000001 x10: 0000000000000001 x9 : ffffc80dcfdf9250 [ 158.364365] x8 : 000000000002ffe8 x7 : c0000000ffffdfff x6 : 00000000000affa8 [ 158.364368] x5 : ffffc80dce6c1b54 x4 : 0000000000000008 x3 : ffffc80dce6c15c8 [ 158.364370] x2 : 0000000000000001 x1 : 0000000000000000 x0 : ffff710bf0f65c00 [ 158.364373] Kernel panic - not syncing: Asynchronous SError Interrupt [ 158.364374] CPU: 7 UID: 0 PID: 462 Comm: (udev-worker) Tainted: G M C 6.12.49-current-rockchip64 #1 [ 158.364377] Tainted: [M]=MACHINE_CHECK, [C]=CRAP [ 158.364378] Hardware name: Xunlong Orange Pi 5 (DT) [ 158.364379] Call trace: [ 158.364380] dump_backtrace+0x94/0x114 [ 158.364383] show_stack+0x18/0x24 [ 158.364385] dump_stack_lvl+0x38/0x90 [ 158.364387] dump_stack+0x18/0x24 [ 158.364389] panic+0x39c/0x3f4 [ 158.364392] nmi_panic+0x40/0x8c [ 158.364394] arm64_serror_panic+0x70/0x80 [ 158.364396] do_serror+0x3c/0x78 [ 158.364398] el1h_64_error_handler+0x30/0x48 [ 158.364401] el1h_64_error+0x64/0x68 [ 158.364402] _raw_spin_lock_irqsave+0x38/0x8c [ 158.364404] regmap_lock_spinlock+0x18/0x2c [ 158.364407] regmap_write+0x3c/0x78 [ 158.364409] rockchip_pd_power+0xf8/0x5e8 [ 158.364414] rockchip_pd_power_on+0x14/0x20 [ 158.364417] _genpd_power_on+0x94/0x188 [ 158.364418] genpd_power_on.part.0+0xa4/0x1ac [ 158.364421] __genpd_dev_pm_attach+0x144/0x2dc [ 158.364423] genpd_dev_pm_attach+0x60/0x70 [ 158.364425] dev_pm_domain_attach+0x20/0x34 [ 158.364429] platform_probe+0x50/0xdc [ 158.364431] really_probe+0xc0/0x38c [ 158.364434] __driver_probe_device+0x7c/0x15c [ 158.364437] driver_probe_device+0x40/0x114 [ 158.364440] __driver_attach+0xf4/0x1fc [ 158.364443] bus_for_each_dev+0x74/0xd4 [ 158.364445] driver_attach+0x24/0x30 [ 158.364448] bus_add_driver+0x110/0x234 [ 158.364451] driver_register+0x60/0x128 [ 158.364453] __platform_driver_register+0x24/0x30 [ 158.364455] panthor_init+0x64/0x1000 [panthor] [ 158.364467] do_one_initcall+0x44/0x2a8 [ 158.364470] do_init_module+0x58/0x20c [ 158.364472] load_module+0x1e4c/0x1f3c [ 158.364474] init_module_from_file+0x84/0xc4 [ 158.364476] __arm64_sys_finit_module+0x1f4/0x2f0 [ 158.364478] invoke_syscall+0x48/0x110 [ 158.364481] el0_svc_common.constprop.0+0xc8/0xe8 [ 158.364484] do_el0_svc+0x20/0x2c [ 158.364487] el0_svc+0x30/0xfc [ 158.364488] el0t_64_sync_handler+0x13c/0x158 [ 158.364491] el0t_64_sync+0x190/0x194 [ 158.364492] SMP: stopping secondary CPUs [ 158.364557] Kernel Offset: 0x480d4dc00000 from 0xffff800080000000 [ 158.364558] PHYS_OFFSET: 0xffff8ef600000000 [ 158.364559] CPU features: 0x1c,00000017,00280928,4200720b [ 158.364561] Memory Limit: none [ 158.393407] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]--- Power brick is a solid 5V/4A and as I said works OK with the stock OS (7zip benchmark and all) and Armbian Minimal Any suggestion? Thanks a lot Fernando
Did you do Update All after removing knotes? If you were running wayland you will probably need to use Ctrl-Alt-F3 as wayland uses F1 and there is an (unusable) X server on F2 for xwayland. Then, after logging in sudo apt update sudo apt full-upgrade If that's not enough try sudo apt install task-kde-desktop
Hey @Nick A, first of all, thanks for providing us with the build, I flashed and tried the image, But I could not see kvm enabled in the system. Is this expected? some example outputs: ~$ ls -l /dev/kvm ls: cannot access '/dev/kvm': No such file or directory ~$ sudo dmesg | grep -i kvm [ 0.184039] kvm [1]: HYP mode not available also no output on lscpu | grep Virtualization
"This DRAM setup is currently not supported."
Nick A replied to qwerty keyboard's topic in Allwinner CPU Boxes
An apt error related to ntpdate typically indicates a time synchronization issue, as apt relies on accurate system time for validating package release files. https://www.google.com/search?sca_esv=55588fd05011d482&rlz=1CDGOYI_enCA922CA922&hl=en-US&sxsrf=AE3TifMjcn14YNfEQNUHV48vtdb2hNOADw:1763573317647&q=How+to+fix+apt+error+around+ntpdate&sa=X&ved=2ahUKEwiLzojJ3v6QAxUbEFkFHatLG24Q1QJ6BAgQEAE&biw=390&bih=665&dpr=3 -
@Marvin-03 this trixie img boot on Orange pi 4A?!
The Tyr prototype has now progressed from basic GPU job execution to running GNOME, Weston, and full-screen 3D games like SuperTuxKart, demonstrating a functional, high-performance Rust driver that matches C-driver performance! View the full article
qwerty keyboard replied to qwerty keyboard's topic in Allwinner CPU Boxes
Oh, btw your branch throws an APT error around "ntpdate" not having an installation candidate or something. I'm pretty sure there's other issues, but I'm out of the house at this very moment. I would've brought this up on your github project page, but there's no "Issues" tab. -
That's nice, I don't have this new board BOM, be free to add the variant, I think board variants are included using a .dtso file for armbian i think we cannot include tirth party drivers, but any changes to .dts could be included into a .dtso file that's a way to enable this variant into mainline armbian -
Good evening everyone. I acquired another X96Q TV Box with the same Armbian-H313 processor, but this time with revision V4.0. I flashed an SD card with the following image: Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img.xz Surprisingly, the box booted correctly with this version. However, when I tried to install my server, the system prompted me to perform an update. I ran the following command: sudo apt update && sudo apt upgrade After rebooting, the box remained stuck on the red LEDE. Luckily, I hadn't installed it in the internal memory. Here is a photo of the two cases: Here is a photo of the motherboards of both cases: Here is a photo of the X96Q-Armbian-H313 V4.0 boot screen: Here is a photo of the X96Q-Armbian-H313 V4.1 boot screen: Here is the X96Q-Armbian-H313 V4.0 report file: X96Q-Armbian-H313 V4.0.txt Here is the X96Q-Armbian-H313 V4.1 report file: X96Q-Armbian-H313 V4.1.txt Question: Could the difference between version V4.0 and V4.1 of X96Q explain the incompatibility during installation? And how can this be resolved? I would like to use them as servers. Is there any risk if I reinstall, but this time directly to the case's internal memory? Thank you in advancur help.
maka replied to Hqnicolas's topic in Rockchip CPU Boxes
I see this on your dts: ethernet-phy@1 { compatible = "ethernet-phy-id7b74.4411", "ethernet-phy-ieee802.3-c22"; But I think should be: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x1>; And try to use the generic driver for ethernet. -
I made a typing error: Please use the the correct emmc block instead the parition: Extract the DTB file with: dd if=/dev/mmcblk1 of=rk3528-<TV_BOX_NAME>.dtb skip=<START_ADDR> count=<SIZE> bs=1
So I rebuilt the image, applied a patch to integrate the tpm into the dts during the build and it works. I still need to figure out how to make overlays work with GRUB in case we need them. Thank you for your support
Since you're using UEFI, you can use Grub to boot. Grub has a Devcetree command. There's also a post here on how to integrate overlays:
Hello, Thank you for your answers. I decided to recompile the whole image with the correct configuration to be sure I did not mess up anything when updating my kernel (following this https://github.com/armbian/build/commit/54c896e0298a441338cd7d29f312ca590304f120 , using BRANCH=vendor RELEASE=noble) I was able to get the boot logs (see attached file). It seems since I'm using UEFI it completely bypasses the U-Boot applying the overlays ( i can see EFI stub: Using DTB from configuration table inside the logs but no Applying device tree overlay...) . I'll try to recompile the image while integrating my overlay directly into it to see if it works. boot.logs
You are likely hitting genuine bugs and/or the situation of missing packages. I do not use Cinnamon, so I cannot comment much. Try to see if there is anything relevant in the logs. Check ~/.xsession* files for hints, too. Maybe try a different DE first, set up it to be working and then work on your preferred choice after that. Have a look at APA which is trying to improve the experience of Armbian as an OS, maybe it can help you. Good luck, amigo!
@Igor, supposedly, these images do not boot. Maybe you have a chance to verify on your end.
http://debug.armbian.de
most likely a bunch of packages that shouldn't have been removed were removed alongside, the joys of GUI package management 1) don't be afraid of the command line 2) see if /var/log/dpkg.log gives any hints what is missing What desktop system were you using before? Try to get it back installed. PS: In your current situation, you can reach a log-in console and command line with Ctrl-Alt-F1 PPS: Reinstalling from scratch might be faster.
