  2. @billymore Maybe this will help. https://groups.google.com/g/linux-sunxi/c/OrktE3duFDA
  4. Hello Nick, Thanks for your reply. I tried to do this with a basic USB A to C cable, with an adapter on the USB-C part to have a USB male. The TX1 started (LED lit up) but no detection of the TX1 as USB device on my machine I'm using a Macbook M1 with Debian Linux VM to detect this. And the TX1 is never detected as USB OTG.
  5. Hello, I'm stuck as well. I tried to boot on different version of Armbian made for H313 (X96Q) but without success (burning image on USB drive, booting with AV FEL button pressed during boot). LED remains RED and no booting. I tried miniarch. I tried to enter fel mode via USB and Debian virtual Machine witout succcess (the TX1 does not appear as USB peripheral during my USB FEL attempts).
  6. This is required to use Armbian on the amlogic TV boxes. Enabling multiboot is one of the steps on the install instructions.
  7. Thank you OP, I used HeliOS64 for a long time until it started to get disconnected after few hours of use that that was annoying. And so I stopped using it. I have just started using Claude-code. I am missing a remote backup solution. Claude-code gave me encouragement to revive it. I got directed to https://www.armbian.com/helios64/ to download, the only issue I found was that initially my 2.5Gbe worked and then after reboot stopped. Cloud code help me get that fixed. Below is what got it working again: # Step 1: Enable 2.5GbE (then reboot) echo "overlays=rk3399-pcie-gen2" | sudo tee -a /boot/armbianEnv.txt sudo reboot # Step 2: Install driver & Tailscale sudo apt update && sudo apt install -y build-essential dkms git linux-headers-current-rockchip64 cd /usr/src && sudo git clone https://github.com/awesometic/realtek-r8125-dkms.git r8125-9.013.02 cd r8125-9.013.02 && sudo ./dkms-install.sh Best of luck
  8. Yes running on gnome-wayland session. jfl@orangepi5-plus:~$ apt list labwc Listing... Done labwc/noble 0.7.1-1build1 arm64
  9. @billymore https://linux-sunxi.org/Tanix_TX1 Use a toothpick or any other non-conductive stick to push the button inside the A/V connector when powering up the box. Connect a USB-A/USB-A cable to the only USB port and a host PC. https://www.slashinit.com/posts/boot-uboot-orange-pi-zero-2-using-usb-mode/ https://linux-sunxi.org/FEL/USBBoot
  10. Board: ODroid C4 Image: Armbian_26.2.1_Odroidc4_noble_current_6.18.8_xfce_desktop.img.xz Tested OK: - Installation to SD card - Boot to desktop, login - OpenGL / Panfrost - USB 2.0 - Ethernet Not tested: - Audio via HDMI (Though alsamixer reports there's stuff there) If anything, the serial console seems rather quiet. But attached ... minicom.cap
  11. I have two boards I can test. ODroid C4 and NanoPi M4v2. I'll pull down the C4 build and give it a go. I don't see a build for the M4v2? (EDIT - Doesn't look like the Github action failed)
  12. I don't use multiboot. I test also to put the sd-card on the SD-Card of box and with armbian images (both - xfce bookworm or the last version Xfce of the armbian site) don't work. I test images separately, I erase the SD-Card and then try the other version image, One by One. With the steps that I already mention above. I think that I can write documents on the device and system if that boot apps like Office should work I think but I only can test it if the system armbian boot. Thanks.
  13. You don't need to decompile.this as the original source dts is available in the Linux git source code.
  14. Have you used Armbian on other amlogic TV Boxes? I would never recommend using an amlogic TV Box as a mini pc. The graphical performance is poor. See the FAQ for TV boxes pined in this forum.
  15. Why are you using USB? Does the box not have an SD card slot? Also what method are you using to enable multiboot?
  16. I decompile the dtb [meson-sm1-sei610.dtb] to dts any idea if I can edit some option on it ? meson-sm1-sei610.txt
  17. Yesterday
  18. @Nick A Thank you for your excellent work! I managed to compile it myself and shared it with someone who has the same board (IK316-EMCP_V1.0). 1. Changed kernel preemption mode from full preemption to voluntary preemption. 2. Added MediaTek Wi-Fi drivers (MT7601U etc). 3. Embedded kernel headers. https://github.com/cdhigh/armbian_build/releases/tag/v20250306
  19. Hello, I'm also interested in finding an image and getting feedback on Tanix TX1 QHZIW_H313_TX1_EMCP_V2.0. I bought this cheap box on Temu for 15 USD (2GB/16GB) I tried with USB drive and BalenaEtcher several images, without success (trying to boot on it, with tootpick on button) : ๐Ÿ”ด Armbian-unofficial_26.02.0-trunk_X96q-v1-3_bookworm_current_6.12.64_minimal.img.xz ๐Ÿ”ด Armbian-unofficial_24.11.0-trunk_X96q_bookworm_current_6.6.44_mate_desktop.img.xz ๐Ÿ”ด Armbian-unofficial_26.02.0-trunk_X96q-v5-1_bookworm_current_6.12.64_cinnamon_desktop.img.xz Based on my other experiences, this box, although close to x96q, is different. With X96Q, you just have to use SD card and boot was succesful. However, here, nothing is working. Looking for other's experience and advice.
  20. Hello Orima, Thank you for asking. I am doing well. I've been mainly distracted by an online drawing class. I will try to make a complete written guide in the weekend. It will be a new project in my github, and I will make a new thread here.
  21. i had to do it on my own, no worries but it surprised me about it.
  22. I put extra dtb files that I download on /boot/amlogic . For example I find that devmfc uses meson-sm1-ac2xx-generic.dtb on /boot/dtb/amlogic. So I copy it to Armbian boot partition on dtb/amlogic/meson-sm1-ac2xx-generic.dtb Then I edit extlinux/extlinux.conf label Armbian_community kernel /Image initrd /uInitrd fdt /dtb/amlogic/meson-sm1-ac2xx-generic.dtb append root=UUID=7dc5c0a3-acfc-4d51-a066-6c14d983a9de rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles I also test with other dtb files ad of course with the stock (default) image of Armbian just when donwload it, I use balenaetcher to write image on sd-card put it on a usb with sd-card reader and boot the tvbox, but doesn't work at all. The u-boot that I use is the u-boot-s905x3 that I copy to a directory and rename as u-boot.ext and then copy It to /boot. I oly try to run Armbian Systems from here โ†’ https://www.armbian.com/amlogic-s9xx-tv-box/ And I find devmfc when I search on google for " Debain s905x tv boxes" โ†’ thiss ystem works perfect, I only need to put on sd-card and put the sd-card on the usb with the sd-card reader and Tv Box shows HKSERIES and then go enter on the system devmfc. But I want some graphical friendly image to test the performance of tvbox as mini pc and because this I try to install xfce version of armbian. Thanks.
  23. Please explain in more detail what you mean by these statements. "put dtb file" - there is no dtb file to put, just test the ones that are in the build and I would start with meson-sm1-sei610.dtb (which is the reference board for the s905x3 cpu). And what u-boot-* are you using? Also have you run any other linux distribution on this box other than an official Armbian build downloaded from this site?
  24. I'm been trying to install Armbian on this TV.BOX console. I already test bookworm xfce image of Armbian as like the last XFCE image โ†’ Armbian_community_26.2.0-trunk.357_Aml-s9xx-box_noble_current_6.18.7_xfce_desktop I als test minimal images ad they don't work. The spces of console are : Processor (CPU)Amlogic S905X3 Quad-core ARM Cortex-A55, up to 1.91GHz Graphics (GPU)Mali-G31 MP2 RAM4GB DDR3 Storage (ROM)32GB eMMC Video OutputHDMI, supports up to 8K@24fps (Android system) and 1080p (EmuELEC system) Connectivity2.4G/5G Dual-band Wi-Fi, 10/1000M Ethernet LAN, Bluetooth 4.0 Ports1x USB 3.0, 4x USB 2.0, HDMI, Ethernet, DCIN (Power), TF card slot, AV output I test to boot the stock images just after download them and the boot shows the HK1Series and then goes to internal android system (tvbox) so failed. When I do the steps to put dtb file, edit extlinux.conf and rename properly u-bott to u-boot.ext (I search and test test many dtb files as like meson-sm1-hk1box-vontar-x3.dtb, meson-sm1-h96max-x3.dtb, sm1_s905x3_4g_1gbit.dtb, sm1_s905x3_4g.dtb as like others that I download on web when I search info about install armbian on s905x tv boxes). I also try to see if I can edit a .dts file and then convert to .dtb qhen I did It doesn't work. So none of steps above works. But I find one image system that works called devmfc that has only a minimal image similar to a server image only with tty text. https://github.com/devmfc/debian-on-amlogic/releases I inspect the .image of this system, and I find that if I copy the boot.scr, boot.script and cfgload to the /boot partiton of the armbian systems and boot the Sper Console it goes to a pink screen and then after a minute just reboot or goes to hkseries system. So I think if I can edit boot.scr, bootscript and cfgload maybe I can put the right data to force boot the real kernel of armbian. Maybe then armbian works. I use Linux and try to open those files with text editor but doesn't work. Anyone knows How I can edit this files ? Any user can boot armbian on this console TvBox ? Thanks.
  25. This recipe does not work for me. Could you please explain in more detail which exact Armbian image you are using and what exactly needs to be done to get the sound working?
  26. JFL, can you check the Ubuntu gnome is running under wayland? ($ echo $XDG_SESSION_TYPE) Can you check the labwc availability in Ubuntu Noble? ($ apt list labwc) I never tested H265... I am glad it is working
  27. maxsub
    I have been testing the R2S extensively. The 1GbE is very stable, but the 2.5GbE drops frequently. I do not have debug logs yet but it is something I need to analyze. I also have a wireless AP running on the R2S. Performance is poor: 1GbE WAN connection, but I am getting only 20Mbps throughput but it is stable.
  28. @robertojGood afternoon. How are you? How is your health? Excuse me, but have you made any progress on writing the manual?
ร—
ร—
