Armbianmonitor:
Hello
In raspberry pi there is an option to add a boot splash screen, looking in this forum I havent found and instructions or if it is even possible.
I am not interested with u-boot splash screen but when the Linux start booting.
I am using 3.5" SPI LCD and I do see the boot logs when the Linux is loading.
So my question is if there is any guide of how to do that boot splash screen in Armbian or there is no way to do that?
You can use plymouth to create a splash boot.
I have done this on a Pine64-LTS board so maybe you need to alter some steps.
First step is to create a custom boot logo image for u-boot to show.
I am not really sure which file you need exactly but to be sure just
use the same image as boot logo and save the images in /boot
1 file named boot-desktop.png in /boot/boot-desktop.png
1 file named boot.bmp in /boot/boot.bmp
If you don't want to lose the original ones, back-up them first:
cp /boot/boot-desktop.png /boot/boot-desktop.png-orig
cp /boot/boot.bmp /boot/boot.bmp-orig
Next reboot you will notice you are having a nice new boot image, but you will
probably also notice that the kernel boot messages are written over this screen
and/or maybe also the init boot messages. Sadly this is due to the fact that u-boot
isn't compled with silent boot support. It would have been nice, because you
could then set a parameter to use it in silent or not. Now we first have to recompile
the u-boot with a patch to silence the boot messages. Use the default Armbian
build guide and before you start compiling you need to enable a u-boot patch.
You can try to enable the patch, but i tried it and it failed applying due to some
inconsistencies. I changed the patch so it now works. I don't know how i should
give this patch change to the correct maintainer, so i will place it here:
patch file located in -><armbian git clone dir>/20.02.2/build/patch/u-boot/u-boot-sunxi
File name -> remove-boot-messages-from-hdmi.patch.disabled
You should normally only have to remove the '.disabled' part to make use of this patch.
But since this version did not work i created a new file called:
containing:
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h
--- a/include/configs/sunxi-common.h
+++ b/include/configs/sunxi-common.h
@@ -438,12 +438,12 @@
 #ifdef CONFIG_VIDEO
 #define CONSOLE_STDOUT_SETTINGS \
-       "stdout=serial,vga\0" \
-       "stderr=serial,vga\0"
+       "stdout=serial\0" \
+       "stderr=serial\0"
 #elif CONFIG_DM_VIDEO
-       "stdout=serial,vidconsole\0" \
-       "stderr=serial,vidconsole\0"
+       "stderr=serial\0"
 #else
        "stdout=serial\0" \
*UPDATE* - Jan 27th 2022 - When using the new Armbian build trunk called 22.02.0
i again was not able to use this new patch, since the 'sunxi-common.h' file changed
too much. For those also trying to use this guide using Armbian 22.02.0 trunk please
try the following patch instead:
This removes all boot messages but leave logo. For Plymouth configuration proceed here:
https://forum.armbian.com/topic/10087-armbian-boot-splash-screen/?do=findComment&comment=96114
@@ -403,8 +403,8 @@
 #ifdef CONFIG_DM_VIDEO
+       "stderr=serial\0"
 #else
        "stdout=serial\0" \
After creating this file you can use the Armbian build guide to create a new 'release'.
Use the deb files in the output path located at:
<armbian git clone dir>/20.02.2/build/output/debs
The most important file is -> linux-u-boot-current-pine64so_20.05.0-trunk_arm64.deb
Keep in mind i am describing these steps for a Pine64-LTS, the idea stays the same...
Put the deb file on your unit and install the package with:
dpkg -i linux-u-boot-current-pine64so_20.05.0-trunk_arm64.deb
Once this is finished you also have to save this u-boot img to mmc/sdcard or whatever you are using.
You can do this with armbian-config. Start armbian-config and select menu item 'system' then 'install'
and then '5 Install/Update the bootloader on sD/eMMC' . Once finished you will have the new u-boot
on your system. To really make sure you are not getting any messages to your console make the
following changes to your armbianEnv.txt
verbosity=0
console=custom
consoleargs="console=ttyS0,115200 console=tty7"
#extraargs=vt.global_cursor_default=0 quiet splash fbcon=rotate:3 plymouth.ignore-serial-consoles
extraargs=vt.global_cursor_default=0 quiet splash plymouth.ignore-serial-consoles
stdout=serial
vt.global_cursor_default=0 makes sure you dont see any blinking cursor in the upper left corner
quiet makes sure you don't get extra kernel messages.
splash enables kernel splash logo.
fbcon=rotate:3 you don't need to and is only needed on LCD's or HDMI units that are rotated.
plymouth.ignore-serial-consoles makes sure plymouth ignores the /dev/ttyS0 console because else plymouth wont continue and
you wont get any video driver attached to plymouth.
stdout=serial makes sure the boot.scr does not do his own thing.
Once you made all these changes you can do a reboot and notice that you will see a splash screen followed by a long
silence black screen and then the login prompt (or desktop if you are using desktop image).
You can now install plymouth to also show splash screen (takeover) from the point where u-boot left.
apt-get install plymouth
apt-get install plymouth-themes
Now you can try a default theme, for example spinner:
plymouth-set-default-theme spinner
To make really sure the initrd also starts plymouth i ran an extra initrd update:
update-initramfs -u
Ok, now you should be done. Reboot the system and enjoy the splash boot and loader.
  • Igor pinned this topic
Hello.
I have Orange PI with Armbian. I need to replace load logs by splashscreen.
As i understand, first of all i need to activate splashscreen in uboot loader.
i did next:
press Space before loading kernel.
usb start
load usb 0:1 92000000 logo.bmp
bmp d 92000000 - displays my picture on screen
cp.b 92000000 41F80000 3656856
setenv splashimage 41F80000
saveenv
and here i have error that emmc0 is unreachable.
my Armbian is on emmc and it is emmc1. emmc0 - microSD.
what i need to do to save to my emmc?
then i need to remove logs output (in uboot and armbian), how can i do it?
Hi Gogoer,
I did recompiled u-boot myself also the kernel for the Gentoo distribution, but i did
not yet do anything with the emmc unit (on my Pine64-LTS) so i do not know
exactly how u-boot knows which device to read and wirte environment data from/to.
I expect this to be hardcoded in the u-boot bootloader when first time creating it
with the make config command (during recompile of u-boot). I expect some
config settings indicating the environment device. But u-boot has made some
major changes during the last year, so it could also be possible that there
is some sort of autodetect possible.
I don't have any experience with the Orange Pi, but i would expect Armbian to work
in the same way. Can't you just boot up your system first, then edit the arnbianenv.txt
in the /boot directory, use armbian-config to update emmc u-boot and after that
follow the recompile steps i post earlier?
  • Igor unpinned this topic
hi Patrick Peters.
i trying to change my boot splash screen like your answer! but i think your command is old:
i think this command is not working right now because i install any plymouth like this:
sudo apt install plymouth-*
and after that i can not see any command like: plymouth-set-default-theme spinner in my terminal!
Edited by EmadDeve20
 trying to change my bootsplash screen like this url but not this is wotking in my armbian!
how can i change my bootsplash screen in armbian? my compony need to show logo in startup device!
i working in orangepi pluse 2e.
Hi EmadDeve20,
Sorry for the late reply. Did you try to find/execute the commands as 'root' user? because you should
have done that or else you won't be able to find/execute them. For instance:'plymouth-set-default-theme'
is located in the '/usr/sbin' directory which is not added as a standard search path for normal users by
default.
You can try to elevate yourself to 'root' user by executing the command: 'su -' on the prompt. If your
system does not allow this, you should type sudo in front of each command i stated in my earlier
posting.
 Jan 29th 2022
It works for me.
index e840e963..6b15462c 100644
@@ -418,8 +418,8 @@ extern int soft_i2c_gpio_scl;
+    "stderr=serial\0"
 #else
     "stdout=serial\0" \
On 4/8/2019 at 7:45 PM, Igor said:
Each hardware has their own special handling. It won't be simple if you want to have boot splash all the way from power-on to desktop ...
One generic way, but with limitations: https://github.com/armbian/build/blob/second/scripts/bootsplash
@Igor I can see its moved to https://github.com/armbian/build/tree/master/packages/blobs/splash
I changed the pngs and run the `bootsplash-packer` to create a file trying to recreate as per boot.cmd the bootsplash.armbian but file is too small compared to orginal.
Basically I d like to make the bootsplash just black and have only the spinner.
Any tips are welcome
Tx in advance
containing:
 #ifdef CONFIG_VIDEO
+       "stderr=serial\0"
+       "stderr=serial\0"
 #else
        "stdout=serial\0" \
@@ -403,8 +403,8 @@
+       "stderr=serial\0"
 #else
        "stdout=serial\0" \
verbosity=0
console=custom
stdout=serial
update-initramfs -u
I have tested similar steps for TInkeBoard. u-boot file is working nice after installation with the quiet or splash etc
I used the default patch within the build folder
My goal was to hide most things
Just need to hide the login without the use of the splash
Tx for sharing your steps.
Tx in advance
Ive tested below with success
Added the newly created 1K file (with just black pngs), renamed original to .BAK (for example), added 669 permission as the original and  after running the `sudo update-initramfs -u` next reboot was all black until my custom splashvideo.
Little effort and trial gave me the desired result
Hi@Igor Could I have your expertise please?
For the bootsplash-packer what would be the command  to use new bmp files to create a new bootsplash.armbian file
as mentioned above the "cd /build/packages/blobs/splash/ && ./bootsplash-packer bootsplash.armbian" or is it the bmp file specs?
