Hi everyone, I have a Helios 4 running Armbian 5.68
I have set up Nextcloud, and everything is working. However, if the server is "cold" it takes several seconds for the page to load. If the server is "hot" then the page loads immediately. I'd like to know if there's anything I can do to keep the page loading at its fastest speed.
I'm confident that it's not due to the hard drive going into standby. I have used the command
sudo hdparm -S 0 /dev/sda
To disable the hard drive going into standby mode, and confirmed that the slow loading still occurs if the hard drive is active/idle with
sudo hdparm -C /dev/sda
Any suggestions?
Expand
What do you mean by that? Right after boot? Please provide logs with to see if anything is suspicious there:
armbianmonitor -u
  On 4/19/2019 at 5:55 AM, LogicalUnit said:
Sorry, by "cold" I meant that the server has been idle for a while.
Expand
OK, but we have to know what is doing when its idle. Perhaps you are using swap file and software you are trying to use gets swapped out?
Logs, logs, logs. Otherwise we are bling: armbianmonitor -u
Expand
Here is the link to my result: http://ix.io/1GPC
I'm wondering if Armbian has any kind of standby/sleep functionality that might slow it down when it has been idle.
Expand
No, but here we have a software layer that drastically changes Armbian's behavior. Perhaps Nextcloud adaptations are overlapping with Armbian defaults? One is obvious - log2ram and folder2ram.  Try with disabling our implementation which is much better and efficient. If that doesn't help, ask Nextcloud people what could be. I am not familiar with this app.
OK - may be a stupid idea, but did you test the same usage with another governor like performance in
/etc/default/cpufrequtils
Check also there the MIN_SPEED for 480000
because less could make problems in disk-activity-performance
Maybe you could also test with
armbianmonitor -m
the cpu-frequence when in idle and then when you do access your system
also take a look with cpufreq-info !?
