eyatsko Posted April 27, 2019 Posted April 27, 2019 Armbianmonitor: http://ix.io/1Hlf Hello! How to enable 1-Wire Dallas? I tried this: vi /boot/armbianEnv.txt ----------------------------------------------------- overlays=w1-gpio param_w1_pin=PA10 param_w1_pin_int_pullup=1 ----------------------------------------------------- Then I saw /sys/bus/w1/devices 00-400000000000 -> ../../../devices/w1_bus_master1/00-400000000000/ 00-800000000000 -> ../../../devices/w1_bus_master1/00-800000000000/ w1_bus_master1 -> ../../../devices/w1_bus_master1/ But there was not data. I tried this: vi /etc/modules ----------------------------------------------------- g_serial w1-sunxi w1-gpio w1-therm ----------------------------------------------------- ..and I even saw this: lsmod | grep w1 w1_therm 16384 0 w1_gpio 16384 0 wire 28672 2 w1_gpio,w1_therm But with no effect. May you help to understand what's wrong? Kind regards, Ellad
martinayotte Posted April 27, 2019 Posted April 27, 2019 4 hours ago, eyatsko said: vi /etc/modules ----------------------------------------------------- g_serial w1-sunxi w1-gpio w1-therm Don't load modules via /etc/modules, it is short-circuit the DT loader, the overlay will take care of loading with proper pin settings. 4 hours ago, eyatsko said: 00-400000000000 -> ../../../devices/w1_bus_master1/00-400000000000/ Usually, getting such strange device number is either using the wrong pin or not having a strong enough pullup, maybe try to use external 4K7 pullup instead of "param_w1_pin_int_pullup=1"
eyatsko Posted May 2, 2019 Author Posted May 2, 2019 Hello Martin! First of all, I'd like to thank you! You were absolutely right about 4K7. But now I have another problem: may you explain why 2 certain Thermometers of 6 disaplears sometimes, and I should reboot by power cycle my Orange board. Sometimes they come back accidentally. Two certain Dallas-es. Are they broken? And is there way to reset 1-Wire by CLI in Armbian? Kind regards, Ellad
martinayotte Posted May 2, 2019 Posted May 2, 2019 8 minutes ago, eyatsko said: why 2 certain Thermometers of 6 disaplears sometimes Are they always the same 2 ones ? You can try to lower even more the pullup, maybe to 3K3 ...
vlad59 Posted May 2, 2019 Posted May 2, 2019 @eyatsko What is the total cable length for your 6 sensors ? Do you use CAT5 / CAT6 ? 5 or 6 years ago, I tried to add 4 sensors in each of my first floor rooms (in the ceiling) -> 4 * 4 = 16 DS18B20 but it was way too much cable length (even with cat5) to have a consistent sensor read. I often had only 8 or 9 sensor available (and sometimes to whole bus disappeared). I tried lowering the pullup, it helped. I tried replacing my only pullup with 3 (and even 4) 15k (distributed along the cable) : it also helped but it was never perfect. Finally I ended up with 4 buses of 4 sensors using 4 pins and it was flawless. Less interesting for you but now I have a single ESP8266 for each room with a some i2c sensors (SI7021, ...). All my DS18B20 were donated or binned. Hope this helps
eyatsko Posted May 2, 2019 Author Posted May 2, 2019 Hello friends! The length of the whole line is approximately 60 cm. I use 6 sensors at all. When they all are online, they are read perfect. OrangePI --6cm-- (4K7) --15cm-- [ba81] --8cm-- [4035] --9cm-- [c554] --10cm-- [5c11] --9cm-- [bbff] --9cm-- [55d9] all are present OrangePI --6cm-- (4k7) --15cm-- [ ] --8cm-- [4035] --9cm-- [ ] --10cm-- [5c11] --9cm-- [bbff] --9cm-- [55d9] two are abscent This always repeats. 6, then 4. then 6, then again 4, again 6. Do you think 3K3 will correct the situation? Kind regards, Ellad
vlad59 Posted May 2, 2019 Posted May 2, 2019 60cm should be very safe, it should not hurt to try 3K3.
vlad59 Posted May 2, 2019 Posted May 2, 2019 For the record my cable length was over 70m (meters not centimeters)
eyatsko Posted May 2, 2019 Author Posted May 2, 2019 It seems I got it... :-( I soldered with flux. I washed it no clean and it shortened Dallas pins. Simply, isn't it.. Kind regards, Ellad
