From the media script thread:
I'm using the 5.75 image which comes with the 4.4 kernel, updated everything with "apt update -y && apt upgrade -y && apt dist-upgrade -y" and I installed system, chromium and mpv. mpv works fine.. however; chromium states:
Flash Stage3D: Software only. Hardware acceleration disable
And others too. it's slow and can't load youtube videos at 480p.... what next?
EDIT: Yes, I ran the script and installed system, mpv and chromium. chromium under "chrome://gpu" states that it IS software only and not HW accelerated.....
Chromium is unusable right now. I'm having to use Firefox. :(
EDIT1: I ran the media-script .sh and it auto installed the default selection and I also ticked "streaming" which I know is Chromium...
EDIT2: I'm on the latest Chromium for Ubuntu bionic... 73.x
EDIT3: This is what Chromium says under "chrome://gpu":
Graphics Feature Status
Canvas: Software only, hardware acceleration unavailable
Flash: Software only. Hardware acceleration disabled
Flash Stage3D: Software only. Hardware acceleration disabled
Flash Stage3D Baseline profile: Software only. Hardware acceleration disabled
Compositing: Software only. Hardware acceleration disabled
Multiple Raster Threads: Force enabled
Native GpuMemoryBuffers: Software only. Hardware acceleration disabled
Out-of-process Rasterization: Disabled
Hardware Protected Video Decode: Disabled
Rasterization: Software only. Hardware acceleration disabled
Skia Renderer: Disabled
Surface Control: Disabled
Surface Synchronization: Enabled
Video Decode: Software only. Hardware acceleration disabled
Viz Service Display Compositor: Enabled
WebGL: Software only, hardware acceleration unavailable
WebGL2: Software only, hardware acceleration unavailable
Problems Detected
Native GpuMemoryBuffers have been disabled, either via about:flags or command line.
Disabled Features: native_gpu_memory_buffers
Skia renderer is not used by default.
Disabled Features: skia_renderer
What am I doing wrong?
es2_info:
root@rock64:/home/rock64/Desktop# es2_info
EGL_VERSION: 1.4 Linux-r7p0-00rel0
EGL_VENDOR: ARM
EGL_EXTENSIONS:
    EGL_KHR_image, EGL_KHR_image_base, EGL_KHR_image_pixmap,
    EGL_EXT_image_dma_buf_import, EGL_KHR_gl_texture_2D_image,
    EGL_KHR_gl_texture_cubemap_image, EGL_KHR_gl_renderbuffer_image,
    EGL_KHR_reusable_sync, EGL_KHR_fence_sync,
    EGL_KHR_swap_buffers_with_damage, EGL_EXT_swap_buffers_with_damage,
    EGL_KHR_lock_surface, EGL_KHR_lock_surface2,
    EGL_EXT_create_context_robustness, EGL_ANDROID_blob_cache,
    EGL_KHR_create_context, EGL_KHR_partial_update,
    EGL_KHR_create_context_no_error
EGL_CLIENT_APIS: OpenGL_ES
GL_VERSION: OpenGL ES 2.0
GL_RENDERER: Mali-450 MP
GL_EXTENSIONS:
    GL_OES_texture_npot, GL_OES_vertex_array_object,
    GL_OES_compressed_ETC1_RGB8_texture,
    GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_OES_standard_derivatives,
    GL_OES_EGL_image, GL_OES_depth24, GL_ARM_rgba8,
    GL_ARM_mali_shader_binary, GL_OES_depth_texture,
    GL_OES_packed_depth_stencil, GL_EXT_texture_format_BGRA8888,
    GL_OES_vertex_half_float, GL_EXT_blend_minmax, GL_OES_EGL_image_external,
    GL_OES_EGL_sync, GL_OES_rgb8_rgba8, GL_EXT_multisampled_render_to_texture,
    GL_EXT_discard_framebuffer, GL_OES_get_program_binary,
    GL_ARM_mali_program_binary, GL_EXT_shader_texture_lod, GL_EXT_robustness,
    GL_OES_depth_texture_cube_map, GL_KHR_debug,
    GL_ARM_shader_framebuffer_fetch,
    GL_ARM_shader_framebuffer_fetch_depth_stencil, GL_OES_mapbuffer,
    GL_KHR_no_error
Segmentation fault
and glxgears:
root@rock64:/home/rock64/Desktop# glxgears
libGL error: unable to load driver: rockchip_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: rockchip
Just to add to this:
but under es2_info:
GL_RENDERER: Mali-4
Help?!
@TonyMac32 care to help?
Ok, so testing...
I selected; "system" and "opengl wrapper" and nothing else, let that install... I set it to use arm soc xorg....
I rebooted. then unticked "system" and didn't tick "opengl" and then I ticked streaming, and mpv... chromium still says that it's NOT hw acceled.
Here's Chromium's GPU settings:
Problems Detected
Version Information
Data exported2019-05-22T13:29:48.634Z
Chrome versionChrome/73.0.3683.86
Operating systemLinux 4.4.174-rockchip64
Software rendering list URLhttps://chromium.googlesource.com/chromium/src/+/f9b0bec6063ea50ce2b71f5b9abbae7beee319a6/gpu/config/software_rendering_list.json
Driver bug list URLhttps://chromium.googlesource.com/chromium/src/+/f9b0bec6063ea50ce2b71f5b9abbae7beee319a6/gpu/config/gpu_driver_bug_list.json
ANGLE commit idunknown hash
2D graphics backendSkia/73 636ee33902ddc27fd9683d250ceb23f65467488b-
Command Line/usr/lib/chromium-browser/chromium-browser --disable-low-res-tiling --num-raster-threads=4 --profiler-timing=0 --disable-composited-antialiasing --disk-cache-dir=/tmp/-cache --disk-cache-size=20M --no-sandbox --test-type --show-component-extension-options --ignore-gpu-blacklist --use-gl=egl --ppapi-flash-path=/opt/google/chrome/pepper/libpepflashplayer.so --ppapi-flash-version=30.0.0.113 --enable-pinch --flag-switches-begin --ignore-gpu-blacklist --flag-switches-end
Driver Information
Initialization time65
In-process GPUfalse
Passthrough Command Decoderfalse
Sandboxedfalse
GPU0VENDOR = 0x0000 [Google Inc.], DEVICE= 0x0000 [Google SwiftShader] *ACTIVE*
Optimusfalse
AMD switchablefalse
Driver vendor
Driver version4.1.0.5
Driver date
GPU CUDA compute capability major version0
Pixel shader version3.00
Vertex shader version3.00
Max. MSAA samples4
Machine model name
Machine model version
GL_VENDORGoogle Inc.
GL_RENDERERGoogle SwiftShader
GL_VERSIONOpenGL ES 3.0 SwiftShader 4.1.0.5
GL_EXTENSIONSGL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_framebuffer_object GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_texture_3D GL_OES_vertex_array_object GL_OES_vertex_half_float GL_EXT_blend_minmax GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_draw_buffers GL_EXT_instanced_arrays GL_EXT_occlusion_query_boolean GL_EXT_read_format_bgra GL_EXT_texture_compression_dxt1 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_rg GL_ARB_texture_rectangle GL_ANGLE_framebuffer_blit GL_ANGLE_framebuffer_multisample GL_ANGLE_instanced_arrays GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_texture_format_BGRA8888 GL_CHROMIUM_color_buffer_float_rgba GL_CHROMIUM_texture_filtering_hint GL_NV_depth_buffer_float2 GL_NV_fence GL_NV_framebuffer_blit GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil
Disabled Extensions
Disabled WebGL Extensions
Window system binding vendorGoogle Inc.
Window system binding version1.4 SwiftShader 4.1.0.5
Window system binding extensionsEGL_KHR_create_context EGL_KHR_get_all_proc_addresses EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_fence_sync EGL_KHR_image_base EGL_KHR_surfaceless_context EGL_ANGLE_iosurface_client_buffer EGL_ANDROID_framebuffer_target EGL_ANDROID_recordable
Window managerXfwm4
Compositing managerNo
Direct renderingYes
Reset notification strategy0x0000
GPU process crash count1
System visual ID0
RGBA visual ID0
Compositor Information
Tile Update ModeOne-copy
Partial RasterEnabled
GpuMemoryBuffers Status
R_8Software only
R_16Software only
RG_88Software only
BGR_565Software only
RGBA_4444Software only
RGBX_8888Software only
RGBA_8888Software only
BGRX_8888Software only
BGRX_1010102Software only
RGBX_1010102Software only
BGRA_8888Software only
RGBA_F16Software only
YVU_420Software only
YUV_420_BIPLANARSoftware only
UYVY_422Software only
Display(s) Information
InfoDisplay[1251532481599554] bounds=[0,0 1920x1080], workarea=[0,0 1920x1049], scale=1, external.
Color space information{primaries:INVALID, transfer:INVALID, matrix:INVALID, range:INVALID}
Bits per color component8
Bits per pixel24
Video Acceleration Information
Driver Information for Hardware GPU
In-process GPUfalse
Sandboxedfalse
Optimusfalse
AMD switchablefalse
Driver vendor
Driver date
Max. MSAA samples4
Machine model name
Disabled Extensions
Window managerXfwm4
Direct renderingYes
System visual ID0
RGBA visual ID0
Graphics Feature Status for Hardware GPU
Problems Detected for Hardware GPU
Log Messages
[42:42:0522/132937.648330:ERROR:gl_surface_egl.cc(957)] : eglInitialize Default failed with error EGL_BAD_ALLOC
[42:42:0522/132937.648465:ERROR:gl_initializer_x11.cc(154)] : GLSurfaceEGL::InitializeOneOff failed.
GpuProcessHostUIShim: The GPU process exited with code 1024.
Help?!?!!??!
I'm afraid I'm something of an electrician when it comes to Linux, I'm much more hardware oriented than software. This is something@JMCC works on, perhaps if he has time he can be of more use.
I also didn't update anything, I done all this on a fresh 5.75 image. ran the "media script" ticked system, selected arm soc and opengl wrapper. then rebooted and selected streaming and mpv.
Chromium refuses to get HW acceled....
It should work on a fresh Default image (4.4 kernel), just with default options selected. I haven't tested it in a while, let's see if I can find some time and check whether recent updates broke the script.
Hi. It's best when you run the script the first time not to choose any other things. You also do not need streaming for Chromium to have VPU acc.
There's a small bug in the script what makes it that you can't choose the different system choices(can't think of the names)
1 minute ago, thatchunkylad1989 said:
@JMCC and @NicoD so what should I tick on a fresh install?
Just try with the default options: click "Accept", "Yes" or "OK" every time, and let it run.
Only choose system. And no other options. Then glamour I think.
That installs the drivers for Chromium. Streaming is a 32-bit Chromium running in Docker. So that you don't need.
Please also tell your experiences with it. I've sometimes got Chromium crashing. I'm not sure if it's with all Rock64's.
@JMCC according to Chromium (NOT streaming/32) normal chromium is accelerated:
Canvas: Hardware accelerated
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Hardware Protected Video Decode: Hardware accelerated
Skia Deferred Display List: Disabled
Viz Service Display Compositor: Disabled
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
Driver Bug Workarounds
clear_uniforms_before_first_program_use
disable_discard_framebuffer
disable_framebuffer_cmaa
disable_gl_rgb_format
scalarize_vec_and_mat_constructor_args
disabled_extension_GL_KHR_blend_equation_advanced
disabled_extension_GL_KHR_blend_equation_advanced_coherent
Problems Detected
Clear uniforms before first program use on all platforms: 124764, 349137
Applied Workarounds: clear_uniforms_before_first_program_use
Always rewrite vec/mat constructors to be consistent: 398694
Applied Workarounds: scalarize_vec_and_mat_constructor_args
Mali-4xx does not support GL_RGB format: 449150
Applied Workarounds: disable_gl_rgb_format
Discard Framebuffer breaks WebGL on Mali-4xx Linux: 485814
Applied Workarounds: disable_discard_framebuffer
Use GL_INTEL_framebuffer_CMAA on ChromeOS: 535198
Applied Workarounds: disable_framebuffer_cmaa
Disable KHR_blend_equation_advanced until cc shaders are updated: 661715
Applied Workarounds: disable(GL_KHR_blend_equation_advanced), disable(GL_KHR_blend_equation_advanced_coherent)
Viz service display compositor is not enabled by default.
Disabled Features: viz_display_compositor
Skia deferred display list is not used by default.
Disabled Features: skia_deferred_display_list
Version Information
Data exported2019-05-22T13:47:24.410Z
Chrome versionChrome/71.0.3578.98
Software rendering list URLhttps://chromium.googlesource.com/chromium/src/+/15234034d19b85dcd9a03b164ae89d04145d8368/gpu/config/software_rendering_list.json
Driver bug list URLhttps://chromium.googlesource.com/chromium/src/+/15234034d19b85dcd9a03b164ae89d04145d8368/gpu/config/gpu_driver_bug_list.json
2D graphics backendSkia/71 7469a9341afab19271b8ef07af5c16a0f2c4ccc1-
Command Line/usr/lib/chromium-browser/chromium-browser --disable-low-res-tiling --num-raster-threads=4 --profiler-timing=0 --disable-composited-antialiasing --disk-cache-dir=/tmp/rock64-cache --disk-cache-size=313287475 --no-sandbox --test-type --show-component-extension-options --ignore-gpu-blacklist --use-gl=egl --enable-pinch --flag-switches-begin --flag-switches-end
Driver Information
Initialization time214
In-process GPUfalse
Sandboxedfalse
GPU0VENDOR = 0x0000 [ARM], DEVICE= 0x0000 [Mali-450 MP] *ACTIVE*
Optimusfalse
AMD switchablefalse
Driver vendor
Driver version
Driver date
Pixel shader version1.00
Vertex shader version1.00
Max. MSAA samples4
Machine model name
GL_VENDORARM
GL_RENDERERMali-450 MP
GL_VERSIONOpenGL ES 2.0
GL_EXTENSIONSGL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer GL_KHR_no_error
Disabled ExtensionsGL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent
Window system binding vendorARM
Window system binding version1.4 Linux-r7p0-00rel0
Window system binding extensionsEGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_EXT_image_dma_buf_import EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_swap_buffers_with_damage EGL_EXT_swap_buffers_with_damage EGL_KHR_lock_surface EGL_KHR_lock_surface2 EGL_EXT_create_context_robustness EGL_ANDROID_blob_cache EGL_KHR_create_context EGL_KHR_partial_update EGL_KHR_create_context_no_error
Window managerXfwm4
XDG_CURRENT_DESKTOPXFCE
Direct renderingYes
Reset notification strategy0x8252
GPU process crash count0
System visual ID0
RGBA visual ID0
R_8Software only
R_16Software only
RG_88Software only
Bits per pixel24
Log Messages
[3167:3167:0522/134711.949307:ERROR:gl_surface_egl.cc(336)] : eglChooseConfig failed with error EGL_BAD_ATTRIBUTE
[3167:3167:0522/134712.030858:ERROR:gl_surface_egl.cc(336)] : eglChooseConfig failed with error EGL_BAD_ATTRIBUTE
[3167:3167:0522/134712.033195:ERROR:sandbox_linux.cc(364)] : InitializeSandbox() called with multiple threads in process gpu-process.
Then everything is fine. 32 bit (streaming version) is not working well, it is just an experiment. That's why it is disabled by default.
