Milan Kragujevic Posted May 31, 2019 Posted May 31, 2019 I'd like to do hardware-accelerated H.264 encoding on TX3 Mini. I compiled latest Armbian with kernel 5.1.0, however it is not working, when I try to use a h264_v4l2m2m encoder, I get this error: [h264_v4l2m2m @ 0xaaaae3bb2a20] driver 'meson-vdec' on card 'Amlogic Video Decoder' [h264_v4l2m2m @ 0xaaaae3bb2a20] Could not find a valid device [h264_v4l2m2m @ 0xaaaae3bb2a20] can't configure encoder On lsmod, I only see amlogic-vdec, not venc[oder]...
TonyMac32 Posted June 2, 2019 Posted June 2, 2019 Moved to TV box topic, most likely more of the people following this subforum have interest/info about the topic.
gcsuri Posted June 6, 2019 Posted June 6, 2019 On 5/31/2019 at 10:00 AM, Milan Kragujevic said: I'd like to do hardware-accelerated H.264 encoding on TX3 Mini. I compiled latest Armbian with kernel 5.1.0, however it is not working, when I try to use a h264_v4l2m2m encoder, I get this error: [h264_v4l2m2m @ 0xaaaae3bb2a20] driver 'meson-vdec' on card 'Amlogic Video Decoder' [h264_v4l2m2m @ 0xaaaae3bb2a20] Could not find a valid device [h264_v4l2m2m @ 0xaaaae3bb2a20] can't configure encoder On lsmod, I only see amlogic-vdec, not venc[oder]... Hi, the mainline kernel only supports hw decoding (yet). I hope it will change soon
martos Posted June 6, 2019 Posted June 6, 2019 No way to hardware encoding with aml chipset : the hack of hardware decoding use the V4L2 M2M and it use less cpu it don t use all the hardware decoding. ( i make lot of tests ). the autor of the hack have stopped To work on it. ( check with google ely, french guy, and v4l2 m2m you can find a vidéo with beautifull explain ) If nobody continue and work on the encoding the only way it to make in software. With my test only s912 can make some encoding but i wait the new s922 To make new tests of encoding h264 with an odroid n2 or the hardware tested by balbes150. Another hope is rockchip have a roadmap for the mpp ffmpeg plugin to hardware encode for this years ...
balbes150 Posted June 7, 2019 Posted June 7, 2019 8 hours ago, martos said: No way to hardware encoding with aml chipset : the hack of hardware decoding use the V4L2 M2M and it use less cpu it don t use all the hardware decoding. ( i make lot of tests ). the autor of the hack have stopped To work on it. ( check with google ely, french guy, and v4l2 m2m you can find a vidéo with beautifull explain ) If nobody continue and work on the encoding the only way it to make in software. He didn't stop the work. It now focuses on the more important decoding tasks that a much larger number of users need.
martos Posted June 9, 2019 Posted June 9, 2019 Perfect if "elyotna"continue and yes i see it : https://lkml.org/lkml/2019/6/6/535 and i understand the decoding is the most important at this time. And if amlogic help : "We have received a redistributable license from Amlogic and the firmwares have been merged in linux-firmware" So i continue to wait, because if decoding use the complete hardware , i have more cpu to encode ... Thank you for giving me hope ! my news read : https://patchwork.kernel.org/project/linux-amlogic/list/
martos Posted June 10, 2019 Posted June 10, 2019 If i read correctly ( http://linux-meson.com/doku.php ) , the S922x is a g12b, no yet implemeted ( i see some odroid guy dev work on it) but : v5.3 (work in progress) ... G12B: add support for the S922X SoC and G12B : Identical to GXL but with Quad Cortex-A73 + dual Cortex-A53 cores S922X: mostly pin compatible with S905X2 And if i read correctly , lot of similarity with S905X2, so it could be quick (https://patchwork.kernel.org/cover/10964079/ ) ... to come back with the subject, i wait the new kernel and i try to transcode with my amlogic ( i have s912, TX3 Mini ) and come back with result.
balbes150 Posted June 10, 2019 Posted June 10, 2019 3 hours ago, martos said: If i read correctly ( http://linux-meson.com/doku.php ) , the S922x is a g12b, no yet implemeted ( i see some odroid guy dev work on it) but : v5.3 (work in progress) Libreelec at S922 been working with the new kernel 5.1 and HW. https://yadi.sk/d/0MvYbltA8TqxUw and Armbian for s922 https://yadi.sk/d/YYmDbnNv4wLJaA
martos Posted July 13, 2019 Posted July 13, 2019 kernel request : https://www.phoronix.com/scan.php?page=news_item&px=Linux-5.3-Media-Updates - new Atmel microship ISC driver; - coda has gained support for mpeg2 and mpeg4; - cxusb gained support for analog TV;- rockchip staging driver was split into two separate staging drivers; - added a new staging driver for Allegro DVT video IP core;- added a new staging driver for Amlogic Meson video decoder; - lots of improvements and cleanups. Must wait to make more tests ...
