ghanjiboy Posted June 11, 2019 Posted June 11, 2019 Hi there, can someone comment on usually how long it takes to build an image? I know there are several factors at play - but what are some times people have gotten in making an SD card image with a clean build. Just trying to set expectations - I am on a quad core 1.5GZ machine with 8 gigs of ram on SSD. Thanks
lanefu Posted June 11, 2019 Posted June 11, 2019 starting fresh without cache.. probably an hourish for that setup..... once you have toolchain and rootfs cache... more like 15 minutes
guidol Posted June 11, 2019 Posted June 11, 2019 2 hours ago, lanefu said: starting fresh without cache.. probably an hourish for that setup..... once you have toolchain and rootfs cache... more like 15 minutes got these times with a Core2Duo 2.4GHz, 8GB Ram but with a normal 7200rpm HDD Image for a - to the cache - new device around 60-75 minutes. for a device in cache around 15-25 minutes.
ghanjiboy Posted June 12, 2019 Author Posted June 12, 2019 Thanks, I guess my machine isnt as fast as I thought ;( clean build took about 4 hours, I modified the /etc/network/interfaces file and rebuilt and that took about an hour.
renedis Posted June 19, 2019 Posted June 19, 2019 It feels like it takes forever.. +- 40 min on a Intel i5 6500 with 16GB memory.. Memory is not really important, it's CPU intensive.
Igor Posted June 19, 2019 Posted June 19, 2019 Building CLI image on 28x Xeon 2G/128GB/NvME with kernel and u-boot recompilation: [ o.k. ] Done building [ /home/igorp/build/output/images/Armbian_5.89_Lime2_Debian_buster_next_4.19.50.img ] [ o.k. ] Runtime [ 13 min ]
GeraltOfTrivia Posted June 19, 2019 Posted June 19, 2019 Around 30mins iirc on an i7-4710MQ (4C/8T) 16GB RAM, SSD for a CLI image. Sometimes it takes an insane amount of time to download the toolchains and rootfs when you run the script for the first time, keep that in mind.
Igor Posted June 19, 2019 Posted June 19, 2019 1 hour ago, GeraltOfTrivia said: Sometimes it takes an insane amount of time to download the toolchains and rootfs when you run the script for the first time, keep that in mind. USE_TORRENT="yes" might help in both cases. I always get maxed out download speed.
GeraltOfTrivia Posted June 19, 2019 Posted June 19, 2019 Just now, Igor said: USE_TORRENT="yes" might help in both cases. I always get maxed out download speed. Thanks for the tip, I'll keep that in mind, it will definitely come in handy sooner or later.
Igor Posted June 19, 2019 Posted June 19, 2019 2 minutes ago, GeraltOfTrivia said: Thanks for the tip, I'll keep that in mind, it will definitely come in handy sooner or later. You are welcome. In case you have some storage and spare bandwidth:
ghanjiboy Posted June 22, 2019 Author Posted June 22, 2019 Hi, so in the last 2 days or so, whenever I try to build for the nanopi m4, I get a new prompt for what looks like kernel config items. Even though I am choosing to use default kernel config. So I thought it was my issue somehow, I got rid of the vagrant image and completely re-downloaded everything, once the compressing if the linux kernel finishes, I get the prompts and I am certainly not sure what options to pick. Is there any guidance you can provide? Thanks.
Igor Posted June 22, 2019 Posted June 22, 2019 52 minutes ago, ghanjiboy said: Hi, so in the last 2 days or so, whenever I try to build for the nanopi m4, I get a new prompt for what looks like kernel config items. Even though I am choosing to use default kernel config. So I thought it was my issue somehow, I got rid of the vagrant image and completely re-downloaded everything, once the compressing if the linux kernel finishes, I get the prompts and I am certainly not sure what options to pick. Is there any guidance you can provide? Upstream sources were severely changed and I am fixing patches for the past two days ... wait or help.
ghanjiboy Posted June 22, 2019 Author Posted June 22, 2019 No worries Igor, I wasn't sure if it was I that was doing something wrong. I wish I could help, this is clearly meant for smarter people - good luck and Thank you for all of your efforts.
