stareintheair Posted July 7, 2019 Share Posted July 7, 2019 Hello, I'm setting up my Odroids with Ansible and managed to automated almost everything. I just got a HC1 and read on the download page that I should load optimized board configuration in armbian-config. Sadly, armbian-config seems to be an interactive only tool. Are there ways to automate armbian-config? The easiest way would be command line arguments. I also tried to understand what the DTB menu options actually do from the source code but was unsuccessful. My best idea now is to use expect, but that doesn't seem stable: #!/usr/bin/expect set timeout 10 spawn armbian-config sleep 5 # Enter System menu send "\n" sleep 5 # Enter DTB menu send "d\n" sleep 5 # Choose HC1 option send "h\n" sleep 5 # Cancel reboot send "c" Am I overlooking something? Any other ideas? Thanks and kind regards. 1 Link to comment Share on other sites More sharing options...
Igor Posted July 7, 2019 Share Posted July 7, 2019 43 minutes ago, stareintheair said: Sadly, armbian-config seems to be an interactive only tool. I would like to see all the needed feature implemented, but if I am pretty much alone doing this ... it will take months - years. Start changing the script towards this goal ... I am sure someone else also wants to have this feature, I will help as much as possible. For example, our build script reads and handles parameters: https://github.com/armbian/build/blob/master/compile.sh#L60 Link to comment Share on other sites More sharing options...
lanefu Posted July 8, 2019 Share Posted July 8, 2019 17 hours ago, stareintheair said: I'm setting up my Odroids with Ansible and managed to automated almost everything. I just got a HC1 and read on the download page that I should load optimized board configuration in armbian-config. Sadly, armbian-config seems to be an interactive only tool. Are there ways to automate armbian-config? The easiest way would be command line arguments. Ansible is the magic word... What steps specifically do you need to automate? ....to your point armbian config won't help... the device tree overlay step is updating /boot/armbianEnv.txt so lineinfile is your friend for that. Here's a few more breadcrumbs for armbianEnv.txt https://docs.armbian.com/User-Guide_Allwinner_overlays/#armbianenvtxt-entries-reference Link to comment Share on other sites More sharing options...
Igor Posted July 8, 2019 Share Posted July 8, 2019 3 hours ago, lanefu said: What steps specifically do you need to automate? Ideally any feature I would also wants to use it some time, but no time for RFC. Link to comment Share on other sites More sharing options...
jsilence Posted September 29, 2019 Share Posted September 29, 2019 On 7/8/2019 at 4:00 AM, lanefu said: What steps specifically do you need to automate? Dear lanefu, I am in the same boat. Would also like to fully automate the setup of my Odroid devices. Also I am not capable of programming to make armbian-config scriptable. Any progress on figuring out what System->DTB actually does, so that we can Ansiblify that step? Best, -jsl Link to comment Share on other sites More sharing options...
lanefu Posted October 7, 2019 Share Posted October 7, 2019 On 9/29/2019 at 8:49 AM, jsilence said: Dear lanefu, I am in the same boat. Would also like to fully automate the setup of my Odroid devices. Also I am not capable of programming to make armbian-config scriptable. Any progress on figuring out what System->DTB actually does, so that we can Ansiblify that step? Best, -jsl it literally modifies the file /boot/armbianEnv.txt and add and removes items to overlay= Spoiler lane@cranbone:~/GIT/lanesible$ cat /boot/armbianEnv.txt|fgrep overlays overlays=cir pwm https://docs.armbian.com/User-Guide_Allwinner_overlays/#armbianenvtxt-entries-reference Link to comment Share on other sites More sharing options...
