Hi all. For a new video I've made a list with my most used/useful terminal commands.
Please let me know what I've missed, or which commands you use most.
Useful Linux commands for Ubuntu/Debian
Update/Install
sudo apt update                               Update repolists
sudo apt upgrade                              Upgrade system/programs
sudo apt autoremove                           Remove obsolete programs
sudo apt install programName                  Install program
sudo apt remove programName                   Remove program
sudo aptitude install                         When having issue's with apt, aptitude can help to solve this
sudo apt update && sudo apt upgrade           Update and upgrade together/You can run multiple commands with &&
sudo dpkg -i packageName.deb                  Install .deb file
Root user
sudo passwd                                   Change root password
su                                            Super User/Enter root user
Debug/Monitor
dmesg                                         Shows debug messages
uname -a                                      Shows basic system information
env                                           Shows the environment information
htop                                          Hardware monitor
Switch terminal
ctrl + ALT + F4       (F1 - F6)                                    Open new terminal 4
ctrl + ALT + F1                                                    Go back to terminal 1
ctrl + ALT + F7                                                    Go back to desktop
Reboot/Shutdown
sudo reboot                                   Reboot
sudo shutdown now                             Shutdown
CPU Tools
cpufreq-set -g performance                    Set governor to performance
cpufreq-set -u 2Ghz                           Set max frequency for all cores
cpufreq-set -c 0-1 -u 1.8Ghz                  Set max frequency for specific cores
lscpu | grep MHz                              Show cpu frequency
taskset -c 3 programName                      Use a specific core for an application
Files/Directories
nano /home/fileToRemove.txt                   Create a txt file with Nano. You could use any other texteditor.
touch filename                                Create an empty file, no matter what kind
cat /home/fileToRemove.txt                    Shows the content of a file
cp /home/fileToRemove.txt /home/copy.txt      Copy file
find /home/ -iname "*.txt"                    Search files that end with .txt
comm /home/fileToRemove.txt /home/copy.txt    Compare files
rm /home/fileToRemove.txt                     Remove file
mv /home/copy.txt ~/Documents/                Move file
mkdir /home/directoryToGoTo/                  Create directory
cd /home/directoryToGoTo/                     Go to directory
ls                                            List directory
ls -l                                         Gives more information about every file/directory
ls -l filename.txt                            Gives file information
pwd                                           Show current working directory
cd ..                                         Go to the above directory
rmdir /home/directoryToGoTo/                  Remove directory
wget http://www.website.com/file.txt          Download file
Zip/Tar/GunZip
zip myzip file1 file2 file3                   Create zip file
unzip myzip.zip                               Unzip file
tar xvf filename.tar
gunzip filename_tar.gz
Mount drives/USB Devices
lsusb                                         List USB devices
lsblb                                         List attached drives
mount /mount/mountedDisk /dev/sda2            Mount drive
sudo chmod -R 777 /mount/mountedDisk          Give user read/write permissions
df -a                                         List all filesystems
Swap file/ZRam
sudo apt install zram-config                  Install zram script
sudo fallocate -l 8G /swapfile                Allocate 8GB for swapfile
sudo chmod 600 /swapfile                      Give the correct rights for the swapfile
sudo mkswap /swapfile                         Make it a swapfile
sudo swapon /swapfile                         Turn on the swapfile
sudo nano /etc/fstab                          Open fstab and add the line ...
  |_
       /swapfile swap swap defaults 0 0
Wifi
sudo nano /etc/network/interfaces
and write:
 auto wlan0
 iface wlan0 inet dhcp
                wpa-ssid {ssid}
                wpa-psk  {password}
				OR
nmcli device wifi rescan                                           Scan for available wifi networks
nmcli device wifi list                                             Show available wifi networks
nmcli device wifi connect SSID-Name password wireless-password	   Connect wifi
ip a                                                               Show ip
ifconfig
iwconfig
Change Keyboard Layout
sudo dpkg-reconfigure keyboard-configuration                       Set keyboard layout
Add display resolution
cvt 2560 1440 60                                                   Select the display resolution you want
# 2560x1440 59.96 Hz (CVT 3.69M9) hsync: 89.52 kHz; pclk: 312.25 MHz
Modeline "2560x1440_60.00"  312.25  2560 2752 3024 3488  1440 1443 1448 1493 -hsync +vsync
xrandr --newmode "2560x1440_60.00"  312.25  2560 2752 3024 3488  1440 1443 1448 1493 -hsync +vsync         Add resolution, everything after Modeline from cvt is copied after newmode
xrandr --addmode HDMI-1 2560x1440_60.00        Add the new resolution to your display
xrandr --newmode "2560x1440_60.00"  312.25  2560 2752 3024 3488  1440 1443 1448 1493 -hsync +vsync && xrandr --addmode HDMI-1 2560x1440_60.00
Others
reset                                                              Clear terminal
shift + page up                                                    Scroll up
shift + page down                                                  Scroll down
tab        Autocomplete
ctrl + c                                                           Quit for many programs
date                                                               Show date/time
cal        Show calender
Funny commands
sl        First need to install "sudo apt install sl", then try it out. It's great :)
sl -alF
cmatrix
fortune/fortune-mod
cowsay
figlet
toilet
ponysay
inxi
cat /dev/urandom
:(){ :|:& };:                                                     Endless loop (useful to test CPU maximized temperatures)
Armbian
sudo armbianmonitor -m
sudo armbian-config
change cpu settings
sudo nano /etc/default/cpufrequtils
Made by NicoD
Pimp your bash. To be fair I copied some from the link at the bottom:
A few commands are needed quite often and to reduce typing a little bit, voila:
To create the file  nano ~/.bash_aliases
# my personal Aliases list #
# to create the file  nano ~/.bash_aliases
# **** DIRECTORY LISTING in human-readable units ****
alias ll="ls -lhAF"
alias ..="cd .."
alias ...="cd ../../../"
alias back="cd $OLDPWD"
alias lsmount="mount |column -t"
# * Disk Space Usage in human-readable units,  including filesystem type *
alias dfh="df -Tha --total"
alias df="df -h --exclude=squashfs"
# * ALL files in a directory listed,  according their size *
alias du="du -ach | sort -h"
# * listing process table in detail *
alias psa="ps auxf"
alias dmesg="dmesg --human"
# * How to really CLEAR the terminal *
alias clr='printf "\033c"'
alias h="history"
# reload bash config
alias reload="source ~/.bashrc"
Now execute  . ~/.bashrc  in your terminal (there should be a space between the . and ~/.bashrc )
https://pastebin.com/kzPjE8y4    |   http://smlr.us/
Here's the first video.
Update/Upgrade/Install software.
Change passwords/enter root account.
Some debug tools.
How to switch terminals, and how to reboot and shutdown the system.
Looks good! Only thing missing for my linux noobs is a simple tar overview for extracting and creating archives and a simple grep overview
Can I win the hat this time please?
Expand
Thank you. That's indeed missing. I'll add it for the next video.
Expand
I still haven't found a hat sponsor. Sorry :)
AFAIK i really use often commands with systemctl and pure ip. Both are very useful. Especially "ip"for all problems with net.
systemD is worth to learn about
Ciao
As having to get along with old alcatel and debian
I come along with this script for DHCP is crap.
ip link set dev enp4s0 down
ip addr del 169.254.7.102/16 dev enp4s0
ip addr add dev enp4s0 local 10.0.1.1/24 broadcast 10.0.0.31
ip link set dev enp4s0 up
For the other netcard I have to add
ip route add default dev enp4s6 src 10.0.0.7 via 10.0.0.138
now everthing works fine here. Never use alcatel!
sudo reboot Reboot                      try  systemctl reboot
sudo shutdown now Shutdown   try  systemctl poweroff
systemctl restart gpm often needed with debian
   - " -       start, stop, ....  program instead of /etc/init.d/program startm restart, stop
journalctl -b -p err Bootmeldungen, dazu nur die Fehlermeldungen wasaschaßis,
            weil da haddascho gestiefelt    --since-yesterday
journalctl --since=2012-10-15 --until="2011-10-16 23:59:59"
journalctl -u httpd --since=00:00 --until=9:30
journalctl /dev/sdc
journalctl /usr/sbin/vpnc
journalctl -o verbose -n
journalctl -xe
journalctl -b > /0/jounalctl-ge4-ox.txt journalctl -b > /7/journalctl_gd3_.txt
systemctl status tahoe-lafs.service
systemctl -t service
systemd-cgls | less?
systemctl -a
systemctl list-unit-files  | less
systemctl -r
systemctl --failed
systemctl --now
systemctl --message=ciao --halt
systemctl poweroff  never --force
systemctl start sshd
systemctl status /dev/sda = systemctl status dev-sda.device
systemctl status /home = systemctl status home.mount
systemctl stop sshd@*.service
systemctl kill crond.service
systemctl stop sshd
systemctl kill crond.service better than  killall -9 or kill
systemctl enable example1
systemctl disable example1
systemctl disable ntpd.service   '
systemctl stop ntpd.service
systemctl link /path/to/foo.service
systemctl status networking.service
systemctl list-units
'systemctl status bluetooth.service' and 'journalctl -xn'
ln -s /dev/null /etc/systemd/system/ntpd.service
systemctl daemon-reload
BUT
systemd-analyze plot > /tmp/plot.svg  fascinating!
Ciao
Expand
Well I looked at  https://linuxjourney.com/ carefully but by lack of all systemD commands it might be a little bit outdated, Routing is not worth to be mentioned as IPv6 never ist mentioned
