jernej Posted June 16, 2016 Share Posted June 16, 2016 I started doing what you've said, I got some part done, but now I'm a bit lost about platform files searching for the legacy sys_config.h You should mark it as 386 platform, e.g. no special platform initialization. Also copy wifi power part from OPi2 dts. Link to comment Share on other sites More sharing options...
martinayotte Posted June 16, 2016 Share Posted June 16, 2016 Thanks for the clue ! Unfortunately, it was producing a module with 2 undefined symbols, extern_wifi_set_enable() and sdio_reinit(). Since it was originally set in the Legacy to use CONFIG_PLATFORM_ARM_SUN8I, I've look at CONFIG_PLATFORM_ARM_SUNxI instead, it is compile and load successfully, but no wlan0. So, I think now it is because the DTS isn't set at all for SDIO, I will have to go back studying that and fixing it ! Not a trivial task finally ... Link to comment Share on other sites More sharing options...
jernej Posted June 16, 2016 Share Posted June 16, 2016 Ah, sorry. I spoke to quickly. Actually, you shouldn't set any platform. Check this: https://github.com/jwrdegoede/rtl8189ES_linux/blob/master/MakefileAnyway, you don't need to do anything for sdio. Just be sure that you have enabled power this way: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/arch/arm/boot/dts/sun8i-h3-orangepi-2.dts?id=refs/tags/v4.7-rc3#n98 Link to comment Share on other sites More sharing options...
martinayotte Posted June 17, 2016 Share Posted June 17, 2016 I've been looking at that Makefile the whole day (those Makefile are so ugly with tons of ifdef), and unfortunately if no platform is defined, I'm end up with "not build target", so a platform seems to be required. Thank for the "wifi_pwrseq" hint, I will take a look a that tomorrow ... Link to comment Share on other sites More sharing options...
martinayotte Posted June 17, 2016 Share Posted June 17, 2016 I've added the "wifi_pwrseq" stuff, but "wlan0" doesn't show up. I think it still related to the "platform" config in Makefile. For now, I don't have much choice to throw the towel ... :-( Link to comment Share on other sites More sharing options...
jernej Posted June 17, 2016 Share Posted June 17, 2016 Why don't you just disable all platforms and when you get compile error, check how it was fixed in RTL8189ES sources. HAL part should be very similar. Link to comment Share on other sites More sharing options...
martinayotte Posted June 17, 2016 Share Posted June 17, 2016 I've tried without any platform, but the Makefile is choking by saying "No such file or directory"/"recipe for target 'modules' failed". I've diff-ed Hans version and current one, I didn't figure out where is the problem. (I must admit that I'm not a Makefile expert) I've ported all other changes in Hans version into current, it compile fine but only when a platform is defined. Link to comment Share on other sites More sharing options...
jernej Posted June 17, 2016 Share Posted June 17, 2016 Ok, I checked few things and this should work: 1. edit platform/platform_ops.c and remove lines from 34 to 39 so the function will just return 0. 2. deselect all platforms in Makefile 3. compile with: make KSRC=/lib/modules/$(uname -r)/build ARCH=arm 1 Link to comment Share on other sites More sharing options...
martinayotte Posted June 17, 2016 Share Posted June 17, 2016 Thanks a lot ! It is now compiled without any platform (I had to add CONFIG_LITTLE_ENDIAN in the EXTRA_CFLAGS) The modprobe succeeded, but still no wlan0 ... :-( Is there something else missing in the DTS apart from wifi_pwrseq ? Link to comment Share on other sites More sharing options...
jernej Posted June 17, 2016 Share Posted June 17, 2016 You didn't forgot to add pin configuration like here https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/arch/arm/boot/dts/sun8i-h3-orangepi-2.dts?id=refs/tags/v4.7-rc3#n160(line 160)? Can you show your dts? Link to comment Share on other sites More sharing options...
martinayotte Posted June 17, 2016 Share Posted June 17, 2016 Of course I did :-) Otherwise, it wouldn't compile ... https://gist.github.com/martinayotte/56287a608a93b5ad7cddcac67d704a4c (BTW, it appears in /proc/device-tree and looks okay, but I don't see anything in dmesg) Link to comment Share on other sites More sharing options...
jernej Posted June 17, 2016 Share Posted June 17, 2016 All seems good. How does your system behave? When I start board, I didn't even need to modprobe, because sdio interface has similar autoloading mechanism to USB. Maybe you can check if kernel even detected your wifi chip. This can be done over /sys interface, I'm just not sure how exactly. Maybe you can measure power pin with multimeter. Another attempt would be setting pin in u-boot just to be sure it's on... Link to comment Share on other sites More sharing options...
martinayotte Posted June 17, 2016 Share Posted June 17, 2016 I got the idea to try it out also on my previous build of 2 week ago, the Armbian_5.12_Orangepih3_Debian_jessie_4.6.0.raw, (the current one was Armbian_5.14_Orangepilite_Debian_jessie_4.6.2.raw), but without much success there too. On both, the 8189fs is never loaded (I have to do a modprobe to get it), and doing "dmesg | grep -i sdio" doesn't show anything while doing it with a Legacy build reveal several lines, samething with "mmc1" or "wifi". On your side, which kind of board and kernel are you using ? EDIT : wait a minute, the DTS doesn't have any "mmc1", I will add it and keep you posted ... Link to comment Share on other sites More sharing options...
jernej Posted June 17, 2016 Share Posted June 17, 2016 Last time I tested this was with 4.6.0-rc1 on OPi2. You can take a look also here: http://moinejf.free.fr/opi2/8189es.patchMost interesting part would be platform file... Link to comment Share on other sites More sharing options...
martinayotte Posted June 17, 2016 Share Posted June 17, 2016 Got it for 4.6.0, it was the missing "mmc1" in the DTS : [ 5.586907] mmc1: new high speed SDIO card at address 0001 and : [ 12.613221] ######platform_wifi_power_on: [ 13.583977] 29 81 03 CC 00 00 50 00 00 00 04 CC 0A 0C 00 00 [ 13.589991] FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 13.595831] FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF But, unfortunately, for the 4.6.2, even if I get the same stuff above in dmesg, it still not loading the driver and make the "wlan0" appearing. I will try to figure out, but at least, it is a BIG step toward !!! Thanks, Jernej for all your help !!! (and thanks to provide me the link from JFMoine for his patch, it can help even if I got it, and I've been in touch with Jef a month ago for other issues.) Link to comment Share on other sites More sharing options...
jernej Posted June 17, 2016 Share Posted June 17, 2016 You're welcome. I'm really interested what's left to be fixed... /offtopic Do you know anything about the state of his display engine driver? Link to comment Share on other sites More sharing options...
martinayotte Posted June 18, 2016 Share Posted June 18, 2016 For the 4.6.2 left to be fixed, me too ! Hoping it is not some regression ... Armbian 5.15 will be out soon, I will check that too, because in fact the main thing I'm aware between my 4.6.0 and 4.6.2 was that previous was generic for all H3 and newer is specific for H3-Lite. For Jef's display engine ? I don't know ... Patches take sometime months before getting merged ... I was in touch with him for other reason, I'm not using his display engine since all my boards are headless. He is a nice friendly guy, so don't hesitate to contact him, he has done an update few days ago on his page : http://moinejf.free.fr/opi2/index.html Link to comment Share on other sites More sharing options...
jernej Posted June 18, 2016 Share Posted June 18, 2016 Can you post full dmesg? Link to comment Share on other sites More sharing options...
martinayotte Posted June 18, 2016 Share Posted June 18, 2016 For the 4.6.2 dmesg, you can see that it has the SDIO transaction shown, but wlan0 doesn't appear. We can see in the 4.6.0 a line with "######platform_wifi_power_on:", but this line isn't present in the 4.6.2. I will continue investigate today, but I have some other tasks too... EDIT : About the "######platform_wifi_power_on:", it seems that it was some kind of randomness. Today, I've rebooted, and got it printed, and the "wlan0" appeared and worked. So, maybe yesterday, there was a ghost around ... ;-) Issue closed ! lite-462-dmesg.zip lite-460-dmesg.zip Link to comment Share on other sites More sharing options...
jernej Posted June 18, 2016 Share Posted June 18, 2016 Great to hear! Is driver autoloaded or not? Link to comment Share on other sites More sharing options...
martinayotte Posted June 18, 2016 Share Posted June 18, 2016 Yes, it is autoloaded, but yesterday too. The difference with yesterday is that "######platform_wifi_power_on:" wasn't appearing. I will do reboot 10 times to confirm robustness ... Link to comment Share on other sites More sharing options...
martinayotte Posted June 18, 2016 Share Posted June 18, 2016 Robustness still there today ! (no clues about yesterday) Small unrelated note : The MAC is set randomly each times, so I get different IP from DHCP. 1 Link to comment Share on other sites More sharing options...
jernej Posted June 18, 2016 Share Posted June 18, 2016 This is known. Set module parameter for that. You can use same way as Igor did for 3.4. Link to comment Share on other sites More sharing options...
martinayotte Posted June 18, 2016 Share Posted June 18, 2016 Is that related to this post ? http://forum.armbian.com/index.php/topic/1193-orange-pi-plus-2e-now-available/#entry9732 I can't find the new mecanism, I will have to reboot with my 3.4.112 to figure it out. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted June 18, 2016 Share Posted June 18, 2016 I can't find the new mecanism, I will have to reboot with my 3.4.112 to figure it out. This? Link to comment Share on other sites More sharing options...
martinayotte Posted June 18, 2016 Share Posted June 18, 2016 Yes ! Thanks a lot, @zador ! I'm seeing in the history that it was added a day after I built my Armbian_5.12_Orangepih3_Debian_jessie_4.6.0.raw. But even if were there, since the lsmod wouldn't report 8189fs presence, it wouldn't have created the 8189fs.conf file ... ;-) Link to comment Share on other sites More sharing options...
lanefu Posted July 5, 2016 Share Posted July 5, 2016 Ok, for the THS, adding back the 1008000 entry is a kind of ugly workaround : during boot FREQ switch is crashing, but at least it continue to boot completely. I presume that real fix would not be adding it, but change the value at the origin of that 1008000, which is probably in u-boot, but this is outside of my knowledge. @Tkaiser, the patches you mentioned, and even Megi's change doesn't seem to be part of the Armbian build process. Maybe patches are not applied for some reason. @jernej, I started doing what you've said, I got some part done, but now I'm a bit lost about platform files searching for the legacy sys_config.h I did some poking with my Opi One because I was having the same problem.. u-boot does have a default for 1008000 for the h3 devices.. most of the DTS files end up just including the Orange Pi PC DTS file I made a dinky u-boot patch and it works now, but there's other thermal stuff missing.. i get fun errors and only 1 cpu core in /proc/cpuinfo Naturally--I barely know what i'm doing diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index de6e9c8..4dd59a8 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -23,3 +23,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB_EHCI_HCD=y +##lj Clock freq defaults are 10080000 inherited from OPI PC default, kernel DTS doesn't have that speed, trying valid ones from kernel dts +CONFIG_SYS_CLK_FREQ=1200000000 +#CONFIG_SYS_CLK_FREQ=816000000 +#CLK_DIVIDER_ALLOW_ZERO=y ## didn't make my error go away Link to comment Share on other sites More sharing options...
martinayotte Posted July 5, 2016 Share Posted July 5, 2016 For the 1 core in /proc/cpuinfo, I've just figured out now (I didn't noticed before) that all my newer kernels (4.6.2) on orangepilite/orangepipcplus/orangepiplus2e have only 1 core while older ones 4.6.0+ on orangpipc/orangepione have 4 core. So, maybe a bug introduced recently somehow ... EDIT : Oh ! looking at the root DTS, there wasn't any of this clock stuff defined in 4.6.0+, and in the 4.6.2 it is defined but only for cpu0. So, I wonder if only duplicating it for cpu1/cpu2/cpu3 will do the job. 1 Link to comment Share on other sites More sharing options...
jernej Posted July 5, 2016 Share Posted July 5, 2016 For the 1 core in /proc/cpuinfo, I've just figured out now (I didn't noticed before) that all my newer kernels (4.6.2) on orangepilite/orangepipcplus/orangepiplus2e have only 1 core while older ones 4.6.0+ on orangpipc/orangepione have 4 core. So, maybe a bug introduced recently somehow ... EDIT : Oh ! looking at the root DTS, there wasn't any of this clock stuff defined in 4.6.0+, and in the 4.6.2 it is defined but only for cpu0. So, I wonder if only duplicating it for cpu1/cpu2/cpu3 will do the job. Not sure if this would help. On H3 U-Boot is actually responsible for bringing up all cores through PSCI interface. 1 Link to comment Share on other sites More sharing options...
martinayotte Posted July 5, 2016 Share Posted July 5, 2016 Do you mean that it is some kind of regression bug introduced recently in u-boot ? EDIT : searching quickly, I've only find #define CONFIG_ARMV7_PSCI_NR_CPUS 4 in u-boot/v2016.05/u-boot.cfg. Link to comment Share on other sites More sharing options...
