Lime2 default wheezy desktop does not compile
borsti67
Hi all,
some days ago I successfully built the image mentioned above (Build environment is Ubuntu 14.04/64 bit). The only remarkable issue was the ever-repeating "firstrun" script, which was easily solved with the method mentioned here: http://forum.armbian.com/index.php/topic/1100-post-install-scripts-on-every-reboot/#entry8509
(may be ALL of the scripts should be changed this way?)
But today, after checking out the actual "master", I see a lot of failed copy and sed commands until the debootstrap-ng script finally fails at Mali-libdri2.
The 1st occurrence of an error was during installation of "ramlog". I've inserted a breakpoint and looked into the image. "dpkg.log" reads
2016-05-13 07:45:53 startup archives install
2016-05-13 07:45:53 install ramlog:all <none> 2.0.0
2016-05-13 07:45:53 status half-installed ramlog:all 2.0.0
2016-05-13 07:45:53 status unpacked ramlog:all 2.0.0
I manually issued the dpkg -i with the following result:
dpkg -i /tmp/ramlog_2.0.0_all.deb
Selecting previously unselected package ramlog.
(Reading database ... 9890 files and directories currently installed.)
Unpacking ramlog (from /tmp/ramlog_2.0.0_all.deb) ...
dpkg: dependency problems prevent configuration of ramlog:
 ramlog depends on lsof; however:
  Package lsof is not installed.
 ramlog depends on rsync; however:
  Package rsync is not installed.
dpkg: error processing ramlog (--install):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
 ramlog
I have tried to deactivate the apt-cache by inserting the somewhat hidden command "NO_APT_CACHER=yes" in my compile.sh but this didn't help.
(There are more errors following this one, e.g. /etc/default/console-setup is missing as well as /etc/lirc/hardware.conf, /etc/lirc/lircd.conf, /etc/wicd/manager-settings.conf, /etc/default/nodm, /etc/X11/xorg.conf)
Some strange messages in-between, which I think I also saw earlier but as i haven't faced an issue with the image I ignored them:
[ o.k. ] Installing desktop [ XFCE ]
/bin/tar: A lone zero block at 70
/bin/bash: unzip: command not found
At the very end:
[ o.k. ] Adding support for Mali - acceleration [ sunxi ]
E: Unable to locate package mesa-utils-extra
E: Unable to locate package libdri2-1
E: Unable to locate package libdri2-dev
dpkg: dependency problems prevent configuration of libdri2-1:
 libdri2-1 depends on libdrm2 (>= 2.3.1); however:
  Package libdrm2 is not installed.
 libdri2-1 depends on libx11-6 (>= 2:1.4.99.1); however:
  Package libx11-6 is not installed.
 libdri2-1 depends on libxext6; however:
  Package libxext6 is not installed.
dpkg: error processing libdri2-1 (--install):
 libdri2-1
[ error ] Installation failed [ Mali - libdri2-1 ]
What should I do now?
ok, I started from scratch with only "compile.sh" in an empty directory.
Unfortunately it still doesn't work, but by chance I saw a message which is not recorded in the logs:
Get:595 http://httpredir.debian.org/debian/ wheezy/main wifi-radar all 2.0.s08+dfsg-1.1 [52.4 kB]
Failed to fetch http://httpredir.debian.org/debian/pool/main/w/weather-util/weather-util-data_2.0-1_all.deb  Hash Sum mismatch
Fetched 295 MB in 43s (6787 kB/s)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Free space:
tmpfs           2.5G  624M  1.9G  25% /home/qt/armb2/output/cache/sdcard
...could this be the reason? How can I possibly fix it?
Or is more data cached anywhere outside of the lib, sources and toolchains directories?
I have searched for "fail" and "error" in the available logs, but the only logged one is at the end, when Mail fails.
To enable "full" logging you have to add
PROGRESS_LOG_TO_FILE=yes
to compile.sh
As for your errors - httpredir.debian.org redirects you to one of many possible mirrors based on your IP, so it's entirely possible that you are getting unlucky with selected mirror. You can override this selection by setting DEBIAN_MIRROR in userpatches/lib.config, i.e.
DEBIAN_MIRROR="ftp.de.debian.org/debian/"
And just a small note - Wheezy is now considered a LTS release and it's recommended to use newer releases instead.
yes, I already found that switch after I tried to include another driver into the kernel (it didn't compile but anyway only "install.log" was in the debug folder - a compilation log was only saved when it was not needed: successfully compiled  B) ).
But I left in since then.
Thanks for the hint regarding the mirror, I will try that. It would explain why it sometimes works!
For my project I need full graphics support (eventually I will also have to switch to another kernel branch as mentioned here http://linux-sunxi.org/Optimizing_system_performance#Advanced_topic:_Using_more_recent_Mali_drivers - as far as I can see currently R3P0 is used while R3P2 could get more out of it).
Some of the toolchains I will have to install are only maintained within Wheezy :( - I don't know if everything will work with Jessie. For compiling Armbian I also need the (former) LTS Ubuntu instead of Xenial, I fear many things will break here if that's going to be changed...
But probably I'll give it a try after having everything else up and running. ;)
Now let's have some quiet holidays, I hope you have 'em, too!
Hi to All,
I have also get errors trying to build the image after today's scrips updates.
The process stopped by error:
[ o.k. ] Building deb [ sunxi-tools ]
[ o.k. ] ... downloading sources [ sunxi-tools ]
[ o.k. ] ... downloading sources [ temper ]
[ o.k. ] ... downloading sources [ BT utils ]
[ o.k. ] ... compiling [ sunxitools ]
[ error ] Not built [ tools ]
[ error ] ERROR in function unmount_on_exit [ debootstrap-ng.sh:522 ]
[ error ] debootstrap-ng was interrupted
[ o.k. ] Process terminated
and debug logs where fail:
root@chr-vm-yocto:/data/armbian-cust/output/debug# cat tools-build.log
cc -g -O0 -Wall -Wextra  -std=c99 -D_POSIX_C_SOURCE=200112L -D_BSD_SOURCE -D_DEFAULT_SOURCE -Iinclude/  -o sunxi-fexc fexc.c script.c script_uboot.c script_bin.c script_fex.c
cc -g -O0 -Wall -Wextra  -std=c99 -D_POSIX_C_SOURCE=200112L -D_BSD_SOURCE -D_DEFAULT_SOURCE -Iinclude/  -o sunxi-bootinfo bootinfo.c
cc -g -O0 -Wall -Wextra  -std=c99 -D_POSIX_C_SOURCE=200112L -D_BSD_SOURCE -D_DEFAULT_SOURCE -Iinclude/ `pkg-config --cflags libusb-1.0`  -o sunxi-fel fel.c progress.c  `pkg-config --libs libusb-1.0`
cc -g -O0 -Wall -Wextra  -std=c99 -D_POSIX_C_SOURCE=200112L -D_BSD_SOURCE -D_DEFAULT_SOURCE -Iinclude/ -c -o nand-part-main.o nand-part-main.c
cc -g -O0 -Wall -Wextra  -std=c99 -D_POSIX_C_SOURCE=200112L -D_BSD_SOURCE -D_DEFAULT_SOURCE -Iinclude/  -o sunxi-pio pio.c
Package libusb-1.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `libusb-1.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libusb-1.0' found
fel.c:18:20: fatal error: libusb.h: No such file or directory
 #include <libusb.h>
compilation terminated.
cc -g -O0 -Wall -Wextra  -std=c99 -D_POSIX_C_SOURCE=200112L -D_BSD_SOURCE -D_DEFAULT_SOURCE -Iinclude/ -c -o nand-part-a10.o nand-part.c -D A10
cc -g -O0 -Wall -Wextra  -std=c99 -D_POSIX_C_SOURCE=200112L -D_BSD_SOURCE -D_DEFAULT_SOURCE -Iinclude/ -c -o nand-part-a20.o nand-part.c -D A20
Makefile:105: recipe for target 'sunxi-fel' failed
make: *** [sunxi-fel] Error 1
make: *** Waiting for unfinished jobs....
cc  -o sunxi-nand-part nand-part-main.o nand-part-a10.o nand-part-a20.o
I try to remove all output staff and rebuild all but the result is the same.
Next I try to remove sources for sunxi-tools and the result is the same.
And finally I have start from scratch and the result is the same.
Where is the problem?
Best regards
Chris
Thanks Igor and Zador,
I found the problem.
I overwrite PACKAGE_LIST_ADDITIONAL in lib.config because of need to add some additional packages.
Unfortunately, this way is not clean and brings the problems when the package staff is changed in main code base.
Is it possible to add an empty PACKAGE_LIST_USERS for using by the users to customize the package staff?
Of course it is semi solution because the user may need to remove some of the packages used by default in Armbian.
Are there any suggestions how to proceed in such a cases?
Best regards
Chris
You always can append packages instead of replacing whole list, i.e.
PACKAGE_LIST_ADDITIONAL="$PACKAGE_LIST_ADDITIONAL package1 package2"
also you can remove them using bash variable substitution syntax, but it's more tricky.
Thanks Zador,
I have already tried it but your suggestion has additional pair of quotation marks and will probably work so will report after testing.
You are right about possibility to remove the packages by syntax substitution especially is the changes are more than a single package.
Best regards
Chris
Hi Igor and Zador,
I have removed the sources and set the mirror as Zador proposed but still no luck...
The script seemingly runs fine, rolling back the screen and checking the logs shows no errors until here:
Free space:
tmpfs           2.5G  342M  2.2G  14% /home/qt/armb2/output/cache/sdcard
[ o.k. ] Ending debootstrap process and preparing cache [ wheezy ]
wheezy-ng-armhf.538...610.tgz:  218MB [ 176MB/s] [=====================================================================================================] 103%
[ o.k. ] Applying distribution specific tweaks for [ wheezy ]
sed: can't read /home/qt/armb2/output/cache/sdcard/etc/default/ramlog: No such file or directory
sed: can't read /home/qt/armb2/output/cache/sdcard/etc/default/console-setup: No such file or directory
[ o.k. ] Installing packages [ linux-image-sun7i ]
[ o.k. ] Installing u-boot [ linux-u-boot-lime2 ]
[ o.k. ] Installing headers [ linux-headers-sun7i ]
[ o.k. ] Installing firmware [ linux-firmware-image-sun7i ]
sed: can't read /home/qt/armb2/output/cache/sdcard/etc/lirc/hardware.conf: No such file or directory
cp: cannot create regular file ‘/home/qt/armb2/output/cache/sdcard/etc/lirc/lircd.conf’: No such file or directory
...followed by the same errors as mentioned in my 1st post, finally failing at the Mali acceleration.
Please delete rootfs cache, add
to compile.sh, run build process again and post output/debug/debootstrap.log on pastebin, Github Gist or similar service.
This
Free space:
is rather low, even for Wheezy, so something wasn't installed properly.
hmm, is it possible that caching leads to some of these issues?
At work I was unable to create an image (neither wheezy nor jessie) regardless of removing the caches.
At home  - where I formerly created working images - I only switched from wheezy to jessie but forgot to remove the caches and the same errors came. Then I deleted all caches and now it compiled again...
Will check it tomorrow @work again and supply logs. Thanks for your patience!
Hi,
it seems my VM got corrupted somehow... I have created a new one, since then the compilation succeeds. I have no clue what happened there. :(
In the meantime I have managed to update most of my stuff to Jessie, looks quite good but the processor load using h.264 is still much higher compared to an "original" Olimex image.
For the moment I have 3 more annotations/questions:
  1. formerly I have set the host name in lib.config. Now I noticed after the 1st login the machine is called "lime2" again? Looks like there is a bootscript now which changes it (but the other code seems still to be included?)... I would prefer if any automated change to the hostname would be done ONLY when it's not set manually.
  2. I need to install a lot of packages with apt-get. As I understand, repositories are cached (at least partially?) on the host machine. How do I make use of this, add mine to $PACKAGE_LIST?
  3. when I try to compile a project using c++ and OCAML in chroot, I see fails with a core dump. Seemingly qemu has some serious problems as this doesn't happen when running "live". Does anybody know how to circumvent this? Compiling on the A20 is no fun. :angry:
Firstrun script will be reworked in the future probably
Yes, this should work unless you have too many packages, in which case you'll have to set FORCE_USE_RAMDISK=no to prevent overfilling tmpfs mount.
Can you post exact error message here? And full steps (changes to customize-image.sh) to try to reproduce the crash?
Hello Zador,
In fact this already happened. :D
hm, this is a rather complex one. I did a lot of changes to lib.config and customize_image.sh as well as an additional "external" script.
Do you know the Paparazzi project? http://wiki.paparazziuav.org/wiki/Main_Page
I was able to install dependencies, create and install the .debs for ivy and install modules with OPAM (this also is obviously not using all processor power :( ).
The final step would be to call "make" in the paparazzi folder.
I have manually mounted the image and fired chroot:
/opt/paparazzi# make
qemu: uncaught target signal 11 (Segmentation fault) - core dumped
Segmentation fault (core dumped)
Building Paparazzi version v5.8.1_stable-none-g
The script continues for a while but either errors out somewhen or just does nothing anymore so I have to kill it with ^C.
Unfortuantely there is no more output, and a google search wasn't helpful.
I think I can paste the necessary changes here but be aware that a compilation (with cached data!) takes over an hour here. ;)
