With dtc tool you can also get the dts (text) from the dtb (binary)
$ dtc -I dtb -O dts meson-g12b-ugoos-am6.dtb > meson-g12b-ugoos-am6.dts
And you get the device tree in a text file, see attachment.
I guess you need to get data from the X88 android dts files I uploaded in the last post and create a linux dts like the one in this attachment. I guess it won't be easy.
And then you can compile the dtb binary and try it
$ dtc -O dtb -o meson-g12b-X88king.dtb meson-g12b-X88king.dts
meson-g12b-ugoos-am6.dtsFetching info...
I think the dts extracted from the X88 King image is linked to the android kernel, so when you create the meson-g12b-X88king.dts file it has to be linked to the armbian kernel, I guess only kernel developers know how to do that.
I have gone dtb -> dts -> changed a few things -> dtb with some success, cpuspeed for eg, but in this case the usb subsystem doesn't fire up at all.
With meson-g12b-ugoos-am6.dtb I can get to the desktop, but without usb no keyboard and mouse. 1'll try looking for clues in the extracted dtb/dts.
There is reference to g12b_w400_a in the dtb, for odroid N2 perhaps?
  On 1/1/2020 at 1:25 PM, amirul said:
Expand
Having a look at the X88 dts files extracted from the android image, I think you need to add some new amlogic USB modules in the armbian kernel: amlogic-new-usb2-v2 and amlogic-new-usb3-v2
Expand
Thanks for the suggestion but that might just be beyond my capabilities :)
As far as I can tell from the android dts, these are the bits that look like they have reference to usb
	dwc3@ff500000 {
		compatible = "synopsys, dwc3";
		status = "okay";
		reg = <0xff500000 0x100000>;
		interrupts = <0x0 0x1e 0x4>;
		usb-phy = <0x2a 0x2b>;
		cpu-type = "gxl";
		clock-src = "usb3.0";
		clocks = <0x13 0x41>;
		clock-names = "dwc_general";
		phandle = <0xdd>;
	usb2phy@ffe09000 {
		compatible = "amlogic, amlogic-new-usb2-v2";
		status = "okay";
		reg = <0xffe09000 0x80 0xffd01008 0x100 0xff636000 0x2000 0xff63a000 0x2000>;
		pll-setting-1 = <0x9400414>;
		pll-setting-2 = <0x927e0000>;
		pll-setting-3 = <0xac5f69e5>;
		pll-setting-4 = <0xfe18>;
		pll-setting-5 = <0x8000fff>;
		pll-setting-6 = <0x78000>;
		pll-setting-7 = <0xe0004>;
		pll-setting-8 = <0xe000c>;
		portnum = <0x2>;
		phandle = <0x2a>;
	usb3phy@ffe09080 {
		compatible = "amlogic, amlogic-new-usb3-v2";
		status = "okay";
		reg = <0xffe09080 0x20>;
		phy-reg = <0xff646000>;
		phy-reg-size = <0x2000>;
		usb2-phy-reg = <0xffe09000>;
		usb2-phy-reg-size = <0x80>;
		interrupts = <0x0 0x10 0x4>;
		clocks = <0x13 0x18>;
		clock-names = "pcie_refpll";
		portnum = <0x0>;
		otg = <0x1>;
		phandle = <0x2b>;
	dwc2_a@ff400000 {
		compatible = "amlogic, dwc2";
		status = "okay";
		device_name = "dwc2_a";
		reg = <0xff400000 0x40000>;
		interrupts = <0x0 0x1f 0x4>;
		pl-periph-id = <0x0>;
		clock-src = "usb0";
		port-id = <0x0>;
		port-type = <0x2>;
		port-speed = <0x0>;
		port-config = <0x0>;
		port-dma = <0x0>;
		port-id-mode = <0x0>;
		usb-fifo = <0x2d8>;
		cpu-type = "v2";
		phy-reg-size = <0xa0>;
		phy-interface = <0x0>;
		clocks = <0x13 0x41 0x13 0x49>;
		clock-names = "usb_general", "usb1";
		controller-type = <0x3>;
		phandle = <0xde>;
How to translate to armbian dts is beyond me at the moment
	dwc3@ff500000 {
		status = "okay";
		cpu-type = "gxl";
		phandle = <0xdd>;
	usb2phy@ffe09000 {
		status = "okay";
		portnum = <0x2>;
		phandle = <0x2a>;
	usb3phy@ffe09080 {
		status = "okay";
		portnum = <0x0>;
		otg = <0x1>;
		phandle = <0x2b>;
	dwc2_a@ff400000 {
		status = "okay";
		clock-src = "usb0";
		port-id = <0x0>;
		port-type = <0x2>;
		port-speed = <0x0>;
		port-dma = <0x0>;
		usb-fifo = <0x2d8>;
		cpu-type = "v2";
		phandle = <0xde>;
Expand
It seems that Odroid N2 also uses the same amlogic-new-usb2-v2 driver, and should be included in the kernel, as it appears in a coreelec log here:
https://discourse.coreelec.org/t/odroid-n2-test-builds/4560%3Fpage%3D89&ved=2ahUKEwj4n8b9z-rmAhXI0eAKHUL1Ce0QFjAAegQIBhAC&usg=AOvVaw1iva3UyWfsd1781fs0eTVh&cshid=1578164449966
Yesterday I ordered a X88 King for a good friend of mine who lives next door. He will just use kodi and very light gaming in Android, and he wanted a very fast box with good internal memory, and gigabit network, so he chose it amongst the rest of S922X devices we saw. No brainer, 80€ for this beast with 4Gb LPDDR4 and 128 Emmc is amazing.
I will be able to do armbian testing with it, I guess usb and Ethernet will get supported soon, I don't care much about wifi and BT atm. I have started to read some device trees tutorials to see if I can help with it.
And I'll keep my A95X F2 4/64 for now, instead of selling it and getting a new box. Maybe Ugoos AM6 will drop price in some moment and I'll get one, we'll see.
Expand
Awesome. I look forward to the results of your investigations :)
Expand
I have just ordered this one for me, a H96 Max X3, with a S905x3 and 4Gb/128Gb, for 42€ included shipping. 😁
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.es%2Fulk%2Fitm%2F274165708444
so I can test with more different socks.
I will probably also get a 25€ TX9S S912 2Gb/8Gb so I can test latest midgard support in panfrost that should be already working.
I also have a S905 that works great with coreelec.
Expand
Look forward to your results.
I already have Armbian running on TX9 Pro s912 3gb but probably TX9S is wildly different :)
Waiting for reviews to come in for the Orange Pi 4 rk3399 before putting in the order. Looks great on paper, performance and price
So you can modify g12b_s922x_odroid_n2.dts using the reg values in dtb_2 and rename it as g12b_s922x_x88king.dts, compile the dtb and try it in coreelec 9.2.1.
If this works, we will need to adapt the  odroid n2 armbian dts with the different reg values and maybe usb can work.
My box will take a couple of weeks for shipping. I think the H6 MAX X3 S905X3 will be here first.
I have a feeling it's a bit more complicated because in the armbian odroid n2 dtb are the following references to usb:
					bank@40 {
						reg = <0x0 0x40 0x0 0x4c 0x0 0xe8 0x0 0x18 0x0 0x120 0x0 0x18 0x0 0x2c0 0x0 0x40 0x0 0x340 0x0 0x1c>;
						reg-names = "gpio", "pull", "pull-enable", "mux", "ds";
						gpio-controller;
						#gpio-cells = <0x2>;
						gpio-ranges = <0xe 0x0 0x0 0x56>;
						phandle = <0x14>;
						usb-hub {
							gpio-hog;
							gpios = <0x14 0x0>;
							output-high;
							line-name = "usb-hub-reset";
			phy@36000 {
				compatible = "amlogic,g12a-usb2-phy";
				reg = <0x0 0x36000 0x0 0x2000>;
				clocks = <0x10>;
				clock-names = "xtal";
				resets = <0x8 0x30>;
				reset-names = "phy";
				#phy-cells = <0x0>;
				phy-supply = <0xb>;
				phandle = <0x31>;
			phy@3a000 {
				reg = <0x0 0x3a000 0x0 0x2000>;
				clocks = <0x10>;
				resets = <0x8 0x31>;
				#phy-cells = <0x0>;
				phy-supply = <0x11>;
				phandle = <0x32>;
			phy@46000 {
				compatible = "amlogic,g12a-usb3-pcie-phy";
				reg = <0x0 0x46000 0x0 0x2000>;
				clocks = <0x3 0xc9>;
				clock-names = "ref_clk";
				resets = <0x8 0xe>;
				assigned-clocks = <0x3 0xc9>;
				assigned-clock-rates = <0x5f5e100>;
				#phy-cells = <0x1>;
				phandle = <0x33>;
		usb@ffe09000 {
			status = "okay";
			compatible = "amlogic,meson-g12a-usb-ctrl";
			reg = <0x0 0xffe09000 0x0 0xa0>;
			#address-cells = <0x2>;
			#size-cells = <0x2>;
			ranges;
			clocks = <0x3 0x2f>;
			resets = <0x8 0x22>;
			dr_mode = "otg";
			phys = <0x31 0x32 0x33 0x4>;
			phy-names = "usb2-phy0", "usb2-phy1", "usb3-phy0";
			vbus-supply = <0x34>;
			usb@ff400000 {
				compatible = "amlogic,meson-g12a-usb", "snps,dwc2";
				reg = <0x0 0xff400000 0x0 0x40000>;
				clocks = <0x3 0x37>;
				clock-names = "ddr";
				phys = <0x32>;
				phy-names = "usb2-phy";
				dr_mode = "peripheral";
				g-rx-fifo-size = <0xc0>;
				g-np-tx-fifo-size = <0x80>;
				g-tx-fifo-size = <0x80 0x80 0x10 0x10 0x10>;
			usb@ff500000 {
				compatible = "snps,dwc3";
				reg = <0x0 0xff500000 0x0 0x100000>;
				dr_mode = "host";
				snps,dis_u2_susphy_quirk;
				snps,quirk-frame-length-adjustment;
	regulator-usb_pwr_en {
		compatible = "regulator-fixed";
		regulator-name = "USB_PWR_EN";
		regulator-min-microvolt = <0x4c4b40>;
		regulator-max-microvolt = <0x4c4b40>;
		vin-supply = <0xb>;
		gpio = <0x14 0x16 0x0>;
		enable-active-high;
		phandle = <0x34>;
  On 1/5/2020 at 3:06 PM, amirul said:
Could be the difference in kernel version, android is kernel 4.9 while armbian is kernel 5.5?
Expand
Yes, I think so.
But first I would try in coreelec 9.2.1 that has nearly identical dts. And if it works there we know that in armbian will work as well, just need to find the right dts settings, but kernel modules should be the same and are installed in armbian kernel, as in odroid n2 they work.
It seems that running coreelec will alter the tv box and would require full firmware recovery in order to run armbian afterwards.
Expand
I think this is only if you install it in the emmc, I have tried it in at least 2 boxes (S905, S905X2) with no problems at all, when you remove the microsd/usb it boots to android. And after this armbian worked, only had to use the toothstick again.
Anyway you can always restore the original firmware easily with USB tool or microsd recovery.
  On 1/5/2020 at 7:58 PM, balbes150 said:
If you like problems, you can try ....
Expand
Problems why? Well, in worst case scenario he just needs to recover factory firmware, right?
I haven't had problems in 2 different devices without restoring them I can boot armbian from USB again, after coreelec from microsd.
Expand
I see, now ethernet is not working in armbian in my S905, and it was working before running coreelec. Anyway, in this case we are trying to get usb working in the X88 King, there is no support at all at the moment, so armbian is not very useful until we get it working. Only for a headless server.
Expand
Not even headless because I believe ethernet is not working either on the X88
@amirul - one thing you might try is to boot an 4.9 bsp kernel based linux image (from the odroid n2 or khadas vim3) with the dtb from the box and see how far you get and if usb is working there ... this would at least be some basic check if usb is working in any setup ...
Expand
I've tried Armbian_5.87_Odroid-n2_Ubuntu_bionic_default_4.9.177_desktop_20190529, does not boot :(
there is no uEnv.ini to fiddle with
I guess what would work is an Armbian_19.11.4_Arm-64 spin with a 4.9 kernel :)
for testing you might start with the native odroid and khadas images to see if something works at all without having to invest too much effort and if that is the case you might look into building armbian with it ...
Expand
Pardon the ignorance, but where do I get a native odroid image?
