guidol Posted October 31, 2019 Posted October 31, 2019 I dont know if it real (but for me it feels like) that updating packaged (fetching/reading the list) takes much longer than on stretch or a bionic version. (also on buster creating locales via armbian-config - I use de,gb and us - does take longer to generate) While do a apt update I did see that buster do get package/content lists will come for armhf and aarm64 - is that OK or to much? Get:8 http://cdn-fastly.deb.debian.org/debian buster/main arm64 Packages [7728 kB] Get:9 https://apt.armbian.com buster/main armhf Packages [69.6 kB] Get:10 https://apt.armbian.com buster/main arm64 Packages [67.4 kB] Get:11 https://apt.armbian.com buster/main armhf Contents (deb) [2728 kB] Get:12 http://cdn-fastly.deb.debian.org/debian buster/main armhf Packages [7690 kB] Get:13 http://cdn-fastly.deb.debian.org/debian buster/main armhf Contents (deb) [35.2 MB] Get:14 https://apt.armbian.com buster/main arm64 Contents (deb) [2742 kB] Get:15 https://apt.armbian.com buster/buster-utils arm64 Packages [3459 B] Get:16 https://apt.armbian.com buster/buster-utils armhf Packages [3749 B] Get:17 https://apt.armbian.com buster/buster-utils arm64 Contents (deb) [572 B] Get:18 https://apt.armbian.com buster/buster-utils armhf Contents (deb) [572 B] Get:19 https://apt.armbian.com buster/buster-desktop arm64 Packages [403 B] Get:20 https://apt.armbian.com buster/buster-desktop armhf Packages [1531 B] Get:21 https://apt.armbian.com buster/buster-desktop arm64 Contents (deb) [60 B] Get:22 https://apt.armbian.com buster/buster-desktop armhf Contents (deb) [213 B] Get:23 http://cdn-fastly.deb.debian.org/debian buster/main arm64 Contents (deb) [35.3 MB]
guidol Posted November 1, 2019 Author Posted November 1, 2019 I checked with dpkg -l the count of packages for arm64, armhf and all on a NanoPi Neo2 (H5 64Bit) and a NanoPi Neo (H3 32Bit) and got no armhf packages on the NanoPi Neo2 NanoPi Neo2 H5 CPU - 64Bit - 4*Cortex-A53 # ============================================================================================= root@npi-neo2-22(192.168.6.22):~# dpkg -l|grep arm64|wc -l 441 root@npi-neo2-22(192.168.6.22):~# dpkg -l|grep armhf|wc -l 0 root@npi-neo2-22(192.168.6.22):~# dpkg -l|grep all|wc -l 92 root@npi-neo2-22(192.168.6.22):~# dpkg --print-foreign-architectures armhf # ============================================================================================= and no arm64 packages on NanoPi Neo, NanoPi Neo H3 CPU - 32Bit - 4*Cortex-A7 # ============================================================================================= root@npi-neo(192.168.6.25):~# dpkg -l|grep armhf|wc -l 432 root@npi-neo(192.168.6.25):~# dpkg -l|grep arm64|wc -l 0 root@npi-neo(192.168.6.25):~# dpkg -l|grep all|wc -l 89 # ============================================================================================= but on the NanoPi Neo2 is armhf configured as foreign-architecture: root@npi-neo2-22(192.168.6.22):~# dpkg --print-foreign-architectures armhf The Neo hasnt an additional foreign-architecture: root@npi-neo(192.168.6.25):~# dpkg --print-foreign-architectures root@npi-neo(192.168.6.25):~# So I did according to the following pages https://askubuntu.com/questions/978677/why-is-my-ubuntu-trying-to-fetch-aarch64-packages-on-x86-64-systemhttps://askubuntu.com/questions/66875/how-to-disable-multiarch-support remove the armhf from my NanoPi Neo2: sudo dpkg --remove-architecture armhf Now the NanoPi Neo2 only collects arm64 package-lists (or also "all"?) @Igor Do you think that will cause any trouble? I can re-add with: dpkg --add-architecture armhf or is it better to change it in /etc/apt/sources.list like (sample from https://wiki.debian.org/Multiarch/HOWTO): deb [arch=armel,armhf] http://ports.ubuntu.com/ubuntu-ports quantal main universe Note: There is a bug in apt versions >=0.9.7 and <0.9.7.2 which means that putting 'arch=armel,armhf' on one line didn't work - you needed two separate entries.
sfx2000 Posted November 13, 2019 Posted November 13, 2019 On 10/31/2019 at 5:44 AM, guidol said: I dont know if it real (but for me it feels like) that updating packaged (fetching/reading the list) takes much longer than on stretch or a bionic version. (also on buster creating locales via armbian-config - I use de,gb and us - does take longer to generate) In my experience - debian-stable is a bit slower to pull in upstream on stable vs Ubuntu, even on Ubuntu-LTS builds. debian is good on patching security issues.
Igor Posted November 13, 2019 Posted November 13, 2019 On 11/1/2019 at 10:49 AM, guidol said: Do you think that will cause any trouble? It shouldn't.
