Subair Posted November 12, 2019 Posted November 12, 2019 I have complied R40 board ( not bpi v40) with Armbian kernel and the u-boot hangs and showing BOOT. I was using u-boot 2014-07 and boot0_sdcard.fex and boot_package.fex for bootloader.
JuanEsf Posted January 8, 2020 Posted January 8, 2020 Hi everyone. I have compiled sunxi-next u-boot and activated the SoC internal analog audio codec, now I am testing the mali node. Audio Working! Commit: https://github.com/juanesf/u-boot/commits/master 3
JuanEsf Posted January 10, 2020 Posted January 10, 2020 Hello again, here are the system logs before, after and during the u-boot compilation log-armbian-5.5.rc2-afterFetching info... log-armbian-5.5.rc2-beforeFetching info... log-armbian-5.5.rc2-compile_u-bootFetching info...
JuanEsf Posted January 17, 2020 Posted January 17, 2020 http://forum.banana-pi.org/t/enable-audio-and-mic-bpi-m2ultra-r40/10532/4?u=juanesf
Subair Posted February 10, 2020 Author Posted February 10, 2020 i was able to boot the board as it uses LDDR , i had to change the DRAM settings in menu config. i still have challenges to get eMMC, Ethernet working.
JuanEsf Posted June 17, 2020 Posted June 17, 2020 Hello, following the steps to add audio support to h3, v3s, a23 modified sun4i-codec to add support for r40, and if anyone else wants to try: Video curl -s https://raw.githubusercontent.com/juanesf/codec/master/compile-codec.sh | sudo bash /dev/stdin 1
Werner Posted June 18, 2020 Posted June 18, 2020 On 6/17/2020 at 5:51 AM, JuanEsf said: Hello, following the steps to add audio support to h3, v3s, a23 modified sun4i-codec to add support for r40, and if anyone else wants to try: Video curl -s https://raw.githubusercontent.com/juanesf/codec/master/compile-codec.sh | sudo bash /dev/stdin Expand If you could provide this as patches for Armbian to include into the building process it would be appreciated 1
guidol Posted June 18, 2020 Posted June 18, 2020 On 6/17/2020 at 5:51 AM, JuanEsf said: Hello, following the steps to add audio support to h3, v3s, a23 modified sun4i-codec to add support for r40, and if anyone else wants to try Expand I did try it on my BPI M2Berry. Compile went Ok after installing the kernel-headers, but after modprobe sun4i-codec I only got the following dmesgs: Quote [ 135.129196] sun4i_codec: loading out-of-tree module taints kernel. [ 135.129577] sun4i_codec: module verification failed: signature and/or required key missing - tainting kernel root@bpi-m2-berry(192.168.6.20):/lib/modules/5.6.16-sunxi/kernel/sound/soc/sunxi# ls -l total 200 -rw-r--r-- 1 root root 32493 Jun 10 13:17 ac100-codec.ko -rw-r--r-- 1 root root 50840 Jun 18 21:24 sun4i-codec.ko -rw-r--r-- 1 root root 23913 Jun 10 13:17 sun4i-i2s.ko -rw-r--r-- 1 root root 12881 Jun 10 13:17 sun4i-spdif.ko -rw-r--r-- 1 root root 5389 Jun 10 13:17 sun8i-adda-pr-regmap.ko -rw-r--r-- 1 root root 25924 Jun 18 21:24 sun8i-codec-analog.ko -rw-r--r-- 1 root root 40881 Jun 10 13:17 sun8i-codec.ko root@bpi-m2-berry(192.168.6.20):/lib/modules/5.6.16-sunxi/kernel/sound/soc/sunxi# uname -a Linux bpi-m2-berry 5.6.16-sunxi #20.05.3 SMP Wed Jun 10 12:17:59 CEST 2020 armv7l GNU/Linux root@bpi-m2-berry(192.168.6.20):~# lsmod|grep codec sun8i_codec_analog 24576 0 sun8i_adda_pr_regmap 16384 1 sun8i_codec_analog sun4i_codec 36864 0 snd_soc_hdmi_codec 20480 0 snd_soc_core 126976 3 sun4i_codec,sun8i_codec_analog,snd_soc_hdmi_codec snd_pcm 73728 4 sun4i_codec,snd_pcm_dmaengine,snd_soc_hdmi_codec,snd_soc_core snd 49152 4 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm root@bpi-m2-berry(192.168.6.20):~# aplay -l aplay: device_list:272: no soundcards found... Expand Is there a difference for the R40/V40 CPU? Because I think I have a "early" BPI M2Berry which hasnt the CPU which is normally on the board. But as I did read the are compatible and differ only in work-temperatures?
JuanEsf Posted June 18, 2020 Posted June 18, 2020 what happens is this is just the module, for them to work you need to add the codec node to sun8i-r40.dts and sun8i-r40-bananapi-m2-ultra.dts, just give me a few hours to fix some details and give you details how to compile u-boot with changes
JuanEsf Posted June 18, 2020 Posted June 18, 2020 Compile Codec for R40/V40: curl -s https://raw.githubusercontent.com/juanesf/codec/master/compile-codec.sh | sudo bash /dev/stdin Compile u-boot for R40 emmc (M2-Ultra): curl -s https://raw.githubusercontent.com/juanesf/u-boot/audio-codec/compile_u-boot_r40_emmc.sh | sudo bash /dev/stdin Compile u-boot for R40 sd (M2-Ultra): curl -s https://raw.githubusercontent.com/juanesf/u-boot/audio-codec/compile_u-boot_r40_sd.sh | sudo bash /dev/stdin Compile u-boot for V40 emmc (M2-Berry): curl -s https://raw.githubusercontent.com/juanesf/u-boot/audio-codec/compile_u-boot_v40_emmc.sh | sudo bash /dev/stdin Compile u-boot for V40 sd (M2-Berry) curl -s https://raw.githubusercontent.com/juanesf/u-boot/audio-codec/compile_u-boot_v40_sd.sh | sudo bash /dev/stdin it only remains to add two lines to /etc/rc.local before exit 0: modprobe sun8i-codec-analog modprobe sun4i-codec sudo nano /etc/rc.local #!/bin/sh -e # # rc.local # # This script is executed at the end of each multiuser runlevel. # Make sure that the script will "" on success or any other # value on error. # # In order to enable or disable this script just change the execution # bits. # # By default this script does nothing. modprobe sun8i-codec-analog modprobe sun4i-codec exit 0
guidol Posted June 18, 2020 Posted June 18, 2020 Quote https://raw.githubusercontent.com/juanesf/u-boot/audio-codec/compile_u-boot_v40_sd.sh Expand gives me a 404 - not found Or do you need more time - because you wrote "just give me a few hours to fix some details"? Here is no audio-codec directory:https://github.com/juanesf/u-boot Do you got the part to ad to the .dts/.dtb? I did such a ad job also for my NanoPi A64 or NanoPi Neo PCM5102A-I2S Soundboard
JuanEsf Posted June 18, 2020 Posted June 18, 2020 it was only a problem with the name of the extension that has already been corrected
JuanEsf Posted June 25, 2020 Posted June 25, 2020 A volunteer. What can I test and confirm if it works correctly?
guidol Posted June 25, 2020 Posted June 25, 2020 On 6/25/2020 at 2:35 AM, JuanEsf said: A volunteer. What can I test and confirm if it works correctly? Expand should I test it with my M2Berry now? With which kernel version should it work?
JuanEsf Posted June 25, 2020 Posted June 25, 2020 yes, you can test in m2-berry, and it should work at least from kernel 5.4.x
guidol Posted June 25, 2020 Posted June 25, 2020 I tested curl -s https://raw.githubusercontent.com/juanesf/u-boot/audio-codec/compile_u-boot_v40_sd.sh | sudo bash /dev/stdin but at the end of the script I did get BINMAN u-boot-sunxi-with-spl.bin CFGCHK u-boot.cfg \033[36m make boot.scr.\033[0m mkimage: Can't stat /tmp/u-boot/r40_boot.cmd: No such file or directory \033[36m copying binary u-boot sd.\033[0m 461+1 records in 461+1 records out 472571 bytes (473 kB, 461 KiB) copied, 0.00600794 s, 78.7 MB/s \033[36m copying new dtb sd.\033[0m \033[36m Please reboot Now.\033[0m root@bananapim2berry:~# ls /tmp/u-boot/ api config.mk Kbuild System.map u-boot.img arch configs Kconfig test u-boot.lds board disk lib tools u-boot.map boot.scr doc Licenses u-boot u-boot-nodtb.bin build drivers MAINTAINERS u-boot.bin u-boot.srec cmd dts Makefile u-boot.cfg u-boot-sunxi-with-spl.bin common env net u-boot.cfg.configs u-boot.sym compile_u-boot_r40_emmc.sh examples post u-boot.dtb compile_u-boot_r40_sd.sh fs README u-boot-dtb.bin compile_u-boot_v40_emmc.sh image.map scripts u-boot-dtb.img compile_u-boot_v40_sd.sh include spl u-boot.dtb.out After reboot root@bananapim2berry:~# aplay -l aplay: device_list:272: no soundcards found...
JuanEsf Posted June 25, 2020 Posted June 25, 2020 you must run two commands one to compile u-boot with the codec node, the other is to compile and copy the new codec with r40/v40 support. and finally it remains to load the modules, there are two ways one is to load it manually: sudo modprobe sun8i-codec-analog sudo modprobe sun4i-codec and the second way is to add the two previous commands in /etc/rc.local which loads the modules automatically. first try the manual commands, if after loading manually the sound card appears you should modify rc.local so that it loads automatically
