balbes150 Posted April 27, 2020 Author Share Posted April 27, 2020 21 minutes ago, Alessandro Salgoni said: hi, if I give you the dtb.img file of my Beelink MxII Mini, is possible add the .dtb file at your release? Thanks No, I don't add binaries. I only accept DTS with the correct structure (not converted by the DTC utility). Link to comment Share on other sites More sharing options...
dsh Posted April 27, 2020 Share Posted April 27, 2020 (edited) Hi there. P281's vendor u-boot can recognize correct MAC address. Is there a way to pass that information to Kernel 5.x ? Edited April 27, 2020 by dsh typo Link to comment Share on other sites More sharing options...
balbes150 Posted April 27, 2020 Author Share Posted April 27, 2020 2 hours ago, dsh said: Hi there. P281's vendor u-boot can recognize correct MAC address. Is there a way to pass that information to Kernel 5.x ? mac= 1 Link to comment Share on other sites More sharing options...
Armin Posted April 27, 2020 Share Posted April 27, 2020 (edited) On 12/22/2019 at 2:35 PM, balbes150 said: Starting from version 19.11.4, armbian TV supports Tanix TX6 with Allwinner H6 processor, 3Gb RAM, USB 3.0, LAN 100Mb, mali T720. Given that Panfrost has added support for the mali T720 (which is used in this model), it is a promising enough model to use. There are already Libreelec and Armbian for this TV box model. + Eachlink H6 (Allwinner H6) Hurry up to buy these models before the sellers learned about this possibility and raised the price .... Hello, Is it this model ? https://fr.aliexpress.com/item/4000469743393.html Possible to boot (Armbian) on the eMMC ? Greetings Edited April 27, 2020 by Armin Link to comment Share on other sites More sharing options...
mormegil Posted April 28, 2020 Share Posted April 28, 2020 On 4/26/2020 at 8:29 PM, medmouncef said: Hello. I have a H96 Max X3 4GB 128GB like you. I installed the armbian - version you specified with FDT = / dtb / amlogic / meson-sm1-H96max-X3.dtb - and the rest of usual procedure, ... but neither embedded wifi nor bluetooth work. Can you please tell me what else do you do to make them work. Thank you. PS : I noticed that "unit xrdp.service could not be found", so we cannot activate it directly from armbian-config In "focal" version. It must be installed on command line. I was more worried about getting my gigabit lan working, which it did. Regarding wifi, I was surprised myself to find it working. Didn't really expect that nor do I need it actually. I tried the 5ghz wifi speed and it was really slow tbh. I didn't really do anything extra. Just copied my dtb file in and edited the uEnv.txt file. That's all. Here's my nmcli output if it's of any help. (wifi disabled from GUI) root@arm-64:~# nmcli eth0: connected to Wired connection 1 "eth0" ethernet (meson8b-dwmac), ...... wlan0: unavailable "Broadcom Wi-Fi" wifi (brcmfmac), ..... Link to comment Share on other sites More sharing options...
mrrobot Posted April 28, 2020 Share Posted April 28, 2020 On 4/27/2020 at 12:42 PM, mrrobot said: @balbes150 I've installed Armbian_20.05.3_Arm-64_bionic_current_5.7.0-rc2_desktop_20200425 for Mecool KIII pro on SDcard, but ETH and WIFI cannot work. already try meson-gxm-mecool-kiii-pro.dtb and meson-gxm-q200.dtb still didn't work. could you suggest about this issue ? Thanks. Hi @balbes150 Could you help to advise how to fix about this? Let me know what i'am supposed to do Thank you. Link to comment Share on other sites More sharing options...
balbes150 Posted April 28, 2020 Author Share Posted April 28, 2020 8 minutes ago, mrrobot said: Could you help to advise how to fix about this? Let me know what i'am supposed to do I don't have such hardware, I have no idea what's wrong with the parameters there. Link to comment Share on other sites More sharing options...
Didikdw Posted April 28, 2020 Share Posted April 28, 2020 Hello.. Is there avaible armbian 5.8.7 or above for s905x debian 9 stretch I need armbian with libqt4 for ibstall hyperion ambianlight Ihave instal with armbian ver 5.8.4 work but my wifi device cant active Sorry bad my english 🙏🙏 Link to comment Share on other sites More sharing options...
dbsharpe Posted April 28, 2020 Share Posted April 28, 2020 1 hour ago, Didikdw said: Hello.. Is there avaible armbian 5.8.7 or above for s905x debian 9 stretch I have the following images I can share but they are Ubuntu: Armbian_5.78_Aml-s905_Ubuntu_bionic_next_5.1.0-rc5-next-20190416-gde3c659c8-dirty_desktop.img.xz (no zram module) Armbian_5.86_Aml-s905_Ubuntu_bionic_default_5.1.0_desktop_20190514.img.xz Armbian_5.91_Aml-s905_Ubuntu_bionic_default_5.1.0_desktop_20190708_s905_s905x_s912.img.xz Armbian_5.94_Aml-g12_Ubuntu_bionic_default_5.2.1_desktop_20190821.img.xz Armbian_5.96_Aml-g12_Ubuntu_bionic_default_5.3.0-rc8_desktop_20190910_s905x2_s922.img.xz Armbian_5.96_Aml-g12_Ubuntu_disco_default_5.3.0-rc8_desktop_20190910_s905x2_s922.img.xz Link to comment Share on other sites More sharing options...
kalazino Posted April 28, 2020 Share Posted April 28, 2020 Hi everyone, I have a Beelink M18 (MX64). Which .dtb should i use? I managed to start the box using the meson-gxbb-vega-s95-pro.dtb file, but the Wifi doesn't work. Could anyone help me? Thanks so much Link to comment Share on other sites More sharing options...
SteeMan Posted April 28, 2020 Share Posted April 28, 2020 23 minutes ago, kalazino said: Which .dtb should i use? I managed to start the box using the meson-gxbb-vega-s95-pro.dtb file, but the Wifi doesn't work. The general rule around here is to try all of the dtb's and use the one that works best for you. I would also add, that you should not expect to have working wifi or bluetooth. If you can get the box to boot, have working ethernet, usb, and hdmi with sound you have what you should expect to work. Anything more is a bonus. Don't expect working wifi, bluetooth or gpu based accelerated graphics. I have four different boxes and none of them have any of these extras working. Link to comment Share on other sites More sharing options...
geraldog Posted April 29, 2020 Share Posted April 29, 2020 Hello again, balbes150! First off, a BIG thank you for your unvaluable work! The ARMBIAN project certainly deserves a donation! I'm here to report on the Armbian_20.05.3_Arm-64_bullseye_current_5.7.0-rc2_20200425.img. Let me tell you, I did not flash the image to a SD Card. Instead I only updated the kernel, within a live system that was previously running kernel 5.5.0-rc6. That's probably why sound did not work But there were a few other problems that I'd like to report. [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.7.0-rc2-arm-64 (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)), GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #20.05.3 SMP PREEMPT Sat Apr 25 13:17:40 MSK 2020 [ 0.000000] Machine model: Amlogic Meson GXM (S912) Q200 Development Board [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a3400000, size 256 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] On node 0 totalpages: 740096 [ 0.000000] DMA zone: 4032 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 248576 pages, LIFO batch:63 [ 0.000000] DMA32 zone: 7680 pages used for memmap [ 0.000000] DMA32 zone: 491520 pages, LIFO batch:63 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv0.2 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] percpu: Embedded 22 pages/cpu s51160 r8192 d30760 u90112 [ 0.000000] pcpu-alloc: s51160 r8192 d30760 u90112 alloc=22*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 728384 [ 0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=78:c2:c0:9a:ff:49 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB) [ 0.000000] Memory: 2530692K/2960384K available (16124K kernel code, 1514K rwdata, 6980K rodata, 3904K init, 944K bss, 167548K reserved, 262144K cma-reserved) [ 0.000000] random: get_random_u64 called from cache_random_seq_create+0x84/0x158 with crng_init=0 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000421] Console: colour dummy device 80x25 [ 0.000748] printk: console [tty0] enabled [ 0.000795] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.000817] pid_max: default: 32768 minimum: 301 [ 0.000974] LSM: Security Framework initializing [ 0.001037] SELinux: Initializing. [ 0.001171] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.001202] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.002884] rcu: Hierarchical SRCU implementation. [ 0.005587] EFI services will not be available. [ 0.006093] smp: Bringing up secondary CPUs ... [ 0.006638] Detected VIPT I-cache on CPU1 [ 0.006696] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.007292] Detected VIPT I-cache on CPU2 [ 0.007339] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.007875] Detected VIPT I-cache on CPU3 [ 0.007918] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.008514] Detected VIPT I-cache on CPU4 [ 0.008574] CPU4: Booted secondary processor 0x0000000100 [0x410fd034] [ 0.009163] Detected VIPT I-cache on CPU5 [ 0.009190] CPU5: Booted secondary processor 0x0000000101 [0x410fd034] [ 0.009722] Detected VIPT I-cache on CPU6 [ 0.009748] CPU6: Booted secondary processor 0x0000000102 [0x410fd034] [ 0.010271] Detected VIPT I-cache on CPU7 [ 0.010297] CPU7: Booted secondary processor 0x0000000103 [0x410fd034] [ 0.010387] smp: Brought up 1 node, 8 CPUs [ 0.010520] SMP: Total of 8 processors activated. [ 0.010533] CPU features: detected: 32-bit EL0 Support [ 0.010545] CPU features: detected: CRC32 instructions [ 0.024663] CPU: All CPU(s) started at EL2 [ 0.024735] alternatives: patching kernel code [ 0.026511] devtmpfs: initialized [ 0.033268] Registered cp15_barrier emulation handler [ 0.033308] Registered setend emulation handler [ 0.033326] KASLR disabled due to lack of seed [ 0.033729] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.033775] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.041984] xor: measuring software checksum speed [ 0.080080] 8regs : 1977.000 MB/sec [ 0.120113] 32regs : 2269.000 MB/sec [ 0.160149] arm64_neon: 1986.000 MB/sec [ 0.160162] xor: using function: 32regs (2269.000 MB/sec) [ 0.160230] pinctrl core: initialized pinctrl subsystem [ 0.161054] thermal_sys: Registered thermal governor 'step_wise' [ 0.161410] DMI not present or invalid. [ 0.162027] NET: Registered protocol family 16 [ 0.164099] DMA: preallocated 256 KiB pool for atomic allocations [ 0.164156] audit: initializing netlink subsys (disabled) [ 0.164410] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1 [ 0.165812] cpuidle: using governor ladder [ 0.165957] cpuidle: using governor menu [ 0.166319] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.166493] ASID allocator initialised with 65536 entries [ 0.167329] Serial: AMBA PL011 UART driver [ 0.184237] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.184266] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.184280] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.184293] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.189694] cryptd: max_cpu_qlen set to 1000 [ 0.264369] raid6: neonx8 gen() 1790 MB/s [ 0.332412] raid6: neonx8 xor() 1337 MB/s [ 0.400480] raid6: neonx4 gen() 1839 MB/s [ 0.468546] raid6: neonx4 xor() 1325 MB/s [ 0.536613] raid6: neonx2 gen() 1753 MB/s [ 0.604675] raid6: neonx2 xor() 1214 MB/s [ 0.672748] raid6: neonx1 gen() 1530 MB/s [ 0.740813] raid6: neonx1 xor() 1040 MB/s [ 0.808878] raid6: int64x8 gen() 1240 MB/s [ 0.876965] raid6: int64x8 xor() 652 MB/s [ 0.945011] raid6: int64x4 gen() 1391 MB/s [ 1.013063] raid6: int64x4 xor() 707 MB/s [ 1.081123] raid6: int64x2 gen() 1182 MB/s [ 1.149188] raid6: int64x2 xor() 624 MB/s [ 1.217246] raid6: int64x1 gen() 879 MB/s [ 1.285317] raid6: int64x1 xor() 457 MB/s [ 1.285330] raid6: using algorithm neonx4 gen() 1839 MB/s [ 1.285343] raid6: .... xor() 1325 MB/s, rmw enabled [ 1.285356] raid6: using neon recovery algorithm [ 1.285982] ACPI: Interpreter disabled. [ 1.287367] iommu: Default domain type: Translated [ 1.287715] vgaarb: loaded [ 1.288441] SCSI subsystem initialized [ 1.288639] libata version 3.00 loaded. [ 1.288907] usbcore: registered new interface driver usbfs [ 1.288964] usbcore: registered new interface driver hub [ 1.289055] usbcore: registered new device driver usb [ 1.289571] pps_core: LinuxPPS API ver. 1 registered [ 1.289586] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.289624] PTP clock support registered [ 1.289657] EDAC MC: Ver: 3.0.0 [ 1.290731] FPGA manager framework [ 1.290860] Advanced Linux Sound Architecture Driver Initialized. [ 1.291503] NetLabel: Initializing [ 1.291519] NetLabel: domain hash size = 128 [ 1.291530] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 1.291600] NetLabel: unlabeled traffic allowed by default [ 1.292185] clocksource: Switched to clocksource arch_sys_counter [ 1.292513] VFS: Disk quotas dquot_6.6.0 [ 1.292591] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.292737] FS-Cache: Loaded [ 1.293201] pnp: PnP ACPI: disabled [ 1.299761] NET: Registered protocol family 2 [ 1.300406] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 1.300489] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 1.300750] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 1.301225] TCP: Hash tables configured (established 32768 bind 32768) [ 1.301428] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.301536] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.301887] NET: Registered protocol family 1 [ 1.302364] RPC: Registered named UNIX socket transport module. [ 1.302384] RPC: Registered udp transport module. [ 1.302396] RPC: Registered tcp transport module. [ 1.302408] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.302427] NET: Registered protocol family 44 [ 1.302451] PCI: CLS 0 bytes, default 64 [ 1.302687] Trying to unpack rootfs image as initramfs... [ 1.850590] Freeing initrd memory: 10068K [ 1.851791] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 2.077722] Initialise system trusted keyrings [ 2.077993] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 2.084793] zbud: loaded [ 2.086476] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.086822] FS-Cache: Netfs 'nfs' registered for caching [ 2.087579] NFS: Registering the id_resolver key type [ 2.087623] Key type id_resolver registered [ 2.087635] Key type id_legacy registered [ 2.087655] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 2.087670] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 2.089264] FS-Cache: Netfs 'cifs' registered for caching [ 2.089669] Key type cifs.spnego registered [ 2.089696] Key type cifs.idmap registered [ 2.089727] ntfs: driver 2.1.32 [Flags: R/W]. [ 2.090454] JFS: nTxBlock = 8192, nTxLock = 65536 [ 2.096322] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled [ 2.098455] ocfs2: Registered cluster interface o2cb [ 2.098736] OCFS2 User DLM kernel interface loaded [ 2.100992] gfs2: GFS2 installed [ 2.125775] NET: Registered protocol family 38 [ 2.125814] Key type asymmetric registered [ 2.125827] Asymmetric key parser 'x509' registered [ 2.125840] Asymmetric key parser 'pkcs8' registered [ 2.125908] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 2.126107] io scheduler mq-deadline registered [ 2.126124] io scheduler kyber registered [ 2.126366] io scheduler bfq registered [ 2.143966] soc soc0: Amlogic Meson GXM (S912) Revision 22:a (82:2) Detected [ 2.149032] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled [ 2.151263] Serial: AMBA driver [ 2.151708] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 12, base_baud = 1500000) is a meson_uart [ 2.151910] serial serial0: tty port ttyAML6 registered [ 2.152193] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 15, base_baud = 1500000) is a meson_uart [ 3.146468] printk: console [ttyAML0] enabled [ 3.167120] brd: module loaded [ 3.178895] loop: module loaded [ 3.184571] libphy: Fixed MDIO Bus: probed [ 3.185966] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found [ 3.189651] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found [ 3.195857] meson8b-dwmac c9410000.ethernet: PTP uses main clock [ 3.201699] meson8b-dwmac c9410000.ethernet: no reset control found [ 3.208536] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37 [ 3.214994] meson8b-dwmac c9410000.ethernet: DWMAC1000 [ 3.220152] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported [ 3.227567] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported [ 3.234983] meson8b-dwmac c9410000.ethernet: COE Type 2 [ 3.240158] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported [ 3.247144] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported [ 3.253559] meson8b-dwmac c9410000.ethernet: Normal descriptors [ 3.259393] meson8b-dwmac c9410000.ethernet: Ring mode enabled [ 3.265171] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 3.273598] libphy: stmmac: probed [ 3.278139] VFIO - User Level meta-driver version: 0.3 [ 3.284738] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.288042] ehci-pci: EHCI PCI platform driver [ 3.292515] ehci-platform: EHCI generic platform driver [ 3.297865] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.303747] ohci-pci: OHCI PCI platform driver [ 3.308203] ohci-platform: OHCI generic platform driver [ 3.314186] usbcore: registered new interface driver usb-storage [ 3.319521] mousedev: PS/2 mouse device common for all mice [ 3.325937] i2c /dev entries driver [ 3.332118] sdhci: Secure Digital Host Controller Interface driver [ 3.334360] sdhci: Copyright(c) Pierre Ossman [ 3.338677] Synopsys Designware Multimedia Card Interface Driver [ 3.346491] meson-gx-mmc d0072000.mmc: Got CD GPIO [ 3.377487] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq [ 3.404964] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.405945] ledtrig-cpu: registered to indicate activity on CPUs [ 3.411642] meson-sm: secure-monitor enabled [ 3.415751] gxl-crypto c883e000.crypto: will run requests pump with realtime priority [ 3.416211] mmc0: new high speed SDHC card at address 0001 [ 3.423173] gxl-crypto c883e000.crypto: will run requests pump with realtime priority [ 3.429196] mmcblk0: mmc0:0001 USD00 29.0 GiB [ 3.442721] mmcblk0: p1 p2 [ 3.452958] hid: raw HID events driver (C) Jiri Kosina [ 3.453255] usbcore: registered new interface driver usbhid [ 3.458023] usbhid: USB HID core driver [ 3.462780] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered [ 3.473915] no UART detected at 0x1 [ 3.479858] NET: Registered protocol family 17 [ 3.480201] Key type dns_resolver registered [ 3.483576] registered taskstats version 1 [ 3.486994] Loading compiled-in X.509 certificates [ 3.491921] zswap: loaded using pool lzo/zbud [ 3.496537] Key type ._fscrypt registered [ 3.500007] Key type .fscrypt registered [ 3.503893] Key type fscrypt-provisioning registered [ 3.510001] Btrfs loaded, crc32c=crc32c-generic [ 3.531759] mmc1: new HS200 MMC card at address 0001 [ 3.532634] mmcblk1: mmc1:0001 032GE4 29.1 GiB [ 3.535891] mmcblk1boot0: mmc1:0001 032GE4 partition 1 4.00 MiB [ 3.541814] mmcblk1boot1: mmc1:0001 032GE4 partition 2 4.00 MiB [ 3.543483] Key type encrypted registered [ 3.547589] mmcblk1rpmb: mmc1:0001 032GE4 partition 3 4.00 MiB, chardev (241:0) [ 3.573719] meson-drm d0100000.vpu: Queued 3 outputs on vpu [ 3.574119] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.608260] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) [ 3.613024] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver [ 3.621204] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops) [ 3.628331] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0 [ 3.710700] random: fast init done [ 3.744324] [drm] kms: can't enable cloning when we probably wanted to. [ 3.896314] meson-dw-hdmi c883a000.hdmi-tx: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 [ 3.896323] meson-dw-hdmi c883a000.hdmi-tx: colorspace: YCbCr 4:2:2 [ 3.896328] meson-dw-hdmi c883a000.hdmi-tx: scan mode: Underscan [ 3.896332] meson-dw-hdmi c883a000.hdmi-tx: colorimetry: ITU709 [ 3.896337] meson-dw-hdmi c883a000.hdmi-tx: picture aspect: 16:9 [ 3.896342] meson-dw-hdmi c883a000.hdmi-tx: active aspect: Same as Picture [ 3.896347] meson-dw-hdmi c883a000.hdmi-tx: itc: No Data [ 3.896352] meson-dw-hdmi c883a000.hdmi-tx: extended colorimetry: xvYCC 709 [ 3.896357] meson-dw-hdmi c883a000.hdmi-tx: quantization range: Default [ 3.896362] meson-dw-hdmi c883a000.hdmi-tx: nups: Unknown Non-uniform Scaling [ 3.896366] meson-dw-hdmi c883a000.hdmi-tx: video code: 16 [ 3.896371] meson-dw-hdmi c883a000.hdmi-tx: ycc quantization range: Limited [ 3.896376] meson-dw-hdmi c883a000.hdmi-tx: hdmi content type: Graphics [ 3.896380] meson-dw-hdmi c883a000.hdmi-tx: pixel repeat: 0 [ 3.896386] meson-dw-hdmi c883a000.hdmi-tx: bar top 0, bottom 0, left 0, right 0 [ 3.896410] meson-dw-hdmi c883a000.hdmi-tx: HDMI infoframe: Source Product Description (SPD), version 1, length 25 [ 3.896415] meson-dw-hdmi c883a000.hdmi-tx: vendor: DW [ 3.896419] meson-dw-hdmi c883a000.hdmi-tx: product: HDMI [ 3.896425] meson-dw-hdmi c883a000.hdmi-tx: source device information: PC General (0x9) [ 3.959135] Console: switching to colour frame buffer device 240x67 [ 4.125076] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device [ 4.132853] libphy: mdio_mux: probed [ 4.143492] libphy: mdio_mux: probed [ 4.196435] phy phy-d0078080.phy.3: unsupported PHY mode 5 [ 4.199640] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 4.201898] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 4.209618] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010 [ 4.218830] xhci-hcd xhci-hcd.0.auto: irq 34, io mem 0xc9000000 [ 4.225038] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07 [ 4.232848] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.239997] usb usb1: Product: xHCI Host Controller [ 4.244830] usb usb1: Manufacturer: Linux 5.7.0-rc2-arm-64 xhci-hcd [ 4.251035] usb usb1: SerialNumber: xhci-hcd.0.auto [ 4.256461] hub 1-0:1.0: USB hub found [ 4.259589] hub 1-0:1.0: 3 ports detected [ 4.263941] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 4.268996] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 4.276578] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 4.283535] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 4.292194] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07 [ 4.300965] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.308713] usb usb2: Product: xHCI Host Controller [ 4.314896] usb usb2: Manufacturer: Linux 5.7.0-rc2-arm-64 xhci-hcd [ 4.321722] usb usb2: SerialNumber: xhci-hcd.0.auto [ 4.328462] hub 2-0:1.0: USB hub found [ 4.334705] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19) [ 4.344893] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq [ 4.378053] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware [ 4.406053] printk: console [netcon0] enabled [ 4.411704] mmc2: queuing unknown CIS tuple 0x01 (3 bytes) [ 4.418843] netconsole: network logging started [ 4.432544] ALSA device list: [ 4.435809] mmc2: queuing unknown CIS tuple 0x1a (5 bytes) [ 4.438730] No soundcards found. [ 4.449333] mmc2: queuing unknown CIS tuple 0x1b (8 bytes) [ 4.457857] mmc2: queuing unknown CIS tuple 0x14 (0 bytes) [ 4.459469] Freeing unused kernel memory: 3904K [ 4.467090] mmc2: queuing unknown CIS tuple 0x80 (1 bytes) [ 4.469869] Run /init as init process [ 4.475705] mmc2: queuing unknown CIS tuple 0x81 (1 bytes) [ 4.481362] with arguments: [ 4.481367] /init [ 4.487173] with environment: [ 4.487177] HOME=/ [ 4.487180] TERM=linux [ 4.487183] mac=78:c2:c0:9a:ff:49 [ 4.487269] mmc2: queuing unknown CIS tuple 0x82 (1 bytes) [ 4.493195] mmc2: new high speed SDIO card at address 0001 [ 4.596295] usb 1-2: new high-speed USB device number 2 using xhci-hcd [ 4.636611] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.17 [ 4.652966] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.662823] usb 1-2: Product: 4-Port USB 2.0 Hub [ 4.668658] usb 1-2: Manufacturer: Generic [ 4.732550] hub 1-2:1.0: USB hub found [ 4.739971] hub 1-2:1.0: 4 ports detected [ 4.889200] input: adc-keys as /devices/platform/adc-keys/input/input0 [ 4.897308] input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input1 [ 4.928311] usb 1-3: new high-speed USB device number 3 using xhci-hcd [ 4.954063] usb 1-3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36 [ 4.964902] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.972996] usb 1-3: Product: USB2.0 Hub [ 5.021967] hub 1-3:1.0: USB hub found [ 5.033057] hub 1-3:1.0: 4 ports detected [ 5.100617] usb 1-2.1: new high-speed USB device number 4 using xhci-hcd [ 5.198010] usb 1-2.1: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.17 [ 5.216277] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.230093] usb 1-2.1: Product: 4-Port USB 2.0 Hub [ 5.242133] usb 1-2.1: Manufacturer: Generic [ 5.310088] hub 1-2.1:1.0: USB hub found [ 5.331033] hub 1-2.1:1.0: 4 ports detected [ 5.464612] usb 1-2.3: new low-speed USB device number 5 using xhci-hcd [ 5.629150] usb 1-2.3: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 [ 5.647642] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 5.658354] usb 1-2.3: Product: USB OPTICAL MOUSE [ 5.708598] usb 1-2.1.1: new high-speed USB device number 6 using xhci-hcd [ 5.782823] input: USB OPTICAL MOUSE as /devices/platform/soc/soc:usb@c9000000/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2.3/1-2.3:1.0/0003:275D:0BA6.0001/input/input2 [ 5.850024] usb 1-2.1.1: New USB device found, idVendor=1058, idProduct=25fb, bcdDevice=30.04 [ 5.857528] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-2.3/input0 [ 5.864867] usb 1-2.1.1: New USB device strings: Mfr=2, Product=3, SerialNumber=1 [ 5.886433] usb 1-2.1.1: Product: easystore 25FB [ 5.893154] usb 1-2.1.1: Manufacturer: Western Digital [ 5.899855] usb 1-2.1.1: SerialNumber: 3753475858355243 [ 5.908524] usb-storage 1-2.1.1:1.0: USB Mass Storage device detected [ 5.914848] scsi host0: usb-storage 1-2.1.1:1.0 [ 5.984361] usb 1-2.4: new low-speed USB device number 7 using xhci-hcd [ 6.111265] usb 1-2.4: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.02 [ 6.136209] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 6.147865] usb 1-2.4: Product: USB Keyboard [ 6.157809] usb 1-2.4: Manufacturer: Logitech [ 6.184526] usb 1-2.1.2: new high-speed USB device number 8 using xhci-hcd [ 6.285455] input: Logitech USB Keyboard as /devices/platform/soc/soc:usb@c9000000/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.0/0003:046D:C31C.0002/input/input3 [ 6.286367] usb 1-2.1.2: New USB device found, idVendor=1058, idProduct=10b8, bcdDevice=10.12 [ 6.374641] usb 1-2.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=5 [ 6.382031] usb 1-2.1.2: Product: Elements 10B8 [ 6.387003] usb 1-2.1.2: Manufacturer: Western Digital [ 6.391958] usb 1-2.1.2: SerialNumber: 575846314139353530465A4C [ 6.399994] usb-storage 1-2.1.2:1.0: USB Mass Storage device detected [ 6.430191] scsi host1: usb-storage 1-2.1.2:1.0 [ 6.430907] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-2.4/input0 [ 6.463573] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/soc:usb@c9000000/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.1/0003:046D:C31C.0003/input/input4 [ 6.516475] usb 1-2.1.3: new high-speed USB device number 9 using xhci-hcd [ 6.544879] input: Logitech USB Keyboard System Control as /devices/platform/soc/soc:usb@c9000000/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.1/0003:046D:C31C.0003/input/input5 [ 6.614970] hid-generic 0003:046D:C31C.0003: input,hiddev0,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-2.4/input1 [ 6.616386] usb 1-2.1.3: New USB device found, idVendor=0480, idProduct=0900, bcdDevice= 3.15 [ 6.712226] cpufreq: __target_index: Failed to change cpu frequency: -5 [ 6.717993] usb 1-2.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 6.804202] cpufreq: __target_index: Failed to change cpu frequency: -5 [ 6.818843] usb 1-2.1.3: Product: External USB 3.0 [ 6.904239] cpufreq: __target_index: Failed to change cpu frequency: -5 [ 6.918342] usb 1-2.1.3: Manufacturer: TOSHIBA [ 7.024206] cpufreq: __target_index: Failed to change cpu frequency: -5 [ 7.039981] usb 1-2.1.3: SerialNumber: 20180913010213F [ 7.128233] cpufreq: __target_index: Failed to change cpu frequency: -5 [ 7.148546] scsi 0:0:0:0: Direct-Access WD easystore 25FB 3004 PQ: 0 ANSI: 6 [ 7.148715] usb-storage 1-2.1.3:1.0: USB Mass Storage device detected [ 7.149045] scsi host2: usb-storage 1-2.1.3:1.0 [ 7.171793] usbcore: registered new interface driver uas [ 7.179272] scsi 0:0:0:1: Enclosure WD SES Device 3004 PQ: 0 ANSI: 6 [ 7.202851] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 7.204285] sd 0:0:0:0: [sda] Spinning up disk... [ 7.210889] sd 0:0:0:1: Attached scsi generic sg1 type 13 [ 7.456345] ------------[ cut here ]------------ [ 7.475373] WARNING: CPU: 0 PID: 297 at kernel/time/hrtimer.c:928 hrtimer_forward+0x8c/0xc8 [ 7.480256] thermal thermal_zone0: failed to read out thermal zone (-62) [ 7.495958] Modules linked in: uas gpio_keys_polled adc_keys [ 7.495991] CPU: 0 PID: 297 Comm: kworker/0:2 Not tainted 5.7.0-rc2-arm-64 #20.05.3 [ 7.553110] Hardware name: Amlogic Meson GXM (S912) Q200 Development Board (DT) [ 7.573175] Workqueue: events dbs_work_handler [ 7.591515] pstate: 20000085 (nzCv daIf -PAN -UAO) [ 7.609772] pc : hrtimer_forward+0x8c/0xc8 [ 7.627947] lr : txdone_hrtimer+0xf4/0x118 [ 7.645999] sp : ffff800010003e20 [ 7.663928] x29: ffff800010003e20 x28: ffff0000b797e200 [ 7.681481] x27: ffff800011df5bc0 x26: 0000000000000000 [ 7.698541] x25: 0000000000000001 x24: 0000000000000001 [ 7.715240] x23: ffff0000a28233e8 x22: 00000000000000f8 [ 7.731571] x21: ffff0000a28233b8 x20: ffff0000a28232c0 [ 7.747768] x19: 00000000000f4240 x18: ffff0000a300a700 [ 7.763946] x17: 0000000000000000 x16: 00000000ffffffff [ 7.780106] x15: 0000012bcbb37c94 x14: 00000000000003b8 [ 7.796145] x13: 00000000000003b3 x12: 0000000000000000 [ 7.812045] x11: 0000000000000000 x10: 0000000000000040 [ 7.827770] x9 : ffff800012b277e8 x8 : ffff800012b277e0 [ 7.843367] x7 : 0000000000001816 x6 : 000000002aa76f82 [ 7.858885] x5 : 00ffffffffffffff x4 : 00000001bc2e6915 [ 7.874298] x3 : 0000000000000001 x2 : 00000000000f4240 [ 7.889732] x1 : 00000001bc2e812b x0 : ffff0000a28233e8 [ 7.905071] Call trace: [ 7.919864] hrtimer_forward+0x8c/0xc8 [ 7.934244] __hrtimer_run_queues+0x11c/0x1b0 [ 7.948562] hrtimer_interrupt+0xe8/0x248 [ 7.962791] arch_timer_handler_phys+0x30/0x40 [ 7.977061] handle_percpu_devid_irq+0x84/0x148 [ 7.991308] generic_handle_irq+0x30/0x48 [ 8.005450] __handle_domain_irq+0x64/0xc0 [ 8.019515] gic_handle_irq+0x54/0xa8 [ 8.033228] el1_irq+0xcc/0x180 [ 8.046420] __msecs_to_jiffies+0x0/0x28 [ 8.059118] scpi_send_message+0x178/0x298 [ 8.071305] scpi_dvfs_set_idx+0x44/0x68 [ 8.082937] scpi_dvfs_set_rate+0x6c/0x80 [ 8.094147] clk_change_rate+0x14c/0x2a0 [ 8.105163] clk_core_set_rate_nolock+0x1c4/0x1f0 [ 8.116086] clk_set_rate+0x38/0xa8 [ 8.126816] scpi_cpufreq_set_target+0x48/0xb0 [ 8.137497] __cpufreq_driver_target+0x2c4/0x680 [ 8.148067] od_dbs_update+0xbc/0x1a0 [ 8.158511] dbs_work_handler+0x40/0x78 [ 8.168844] process_one_work+0x1e8/0x360 [ 8.179062] worker_thread+0x44/0x490 [ 8.189149] kthread+0x150/0x158 [ 8.199032] ret_from_fork+0x10/0x1c [ 8.208745] ---[ end trace 08915fc8ec85b3ec ]--- [ 8.221934] scsi 1:0:0:0: Direct-Access WD Elements 10B8 1012 PQ: 0 ANSI: 6 [ 8.223146] scsi 2:0:0:0: Direct-Access TOSHIBA External USB 3.0 5438 PQ: 0 ANSI: 6 [ 8.224584] . [ 8.245723] sd 2:0:0:0: Attached scsi generic sg2 type 0 [ 8.247326] sd 2:0:0:0: [sdb] 3907029164 512-byte logical blocks: (2.00 TB/1.82 TiB) [ 8.251162] sd 1:0:0:0: [sdc] 2930210816 512-byte logical blocks: (1.50 TB/1.36 TiB) [ 8.251389] sd 1:0:0:0: Attached scsi generic sg3 type 0 [ 8.253518] sd 2:0:0:0: [sdb] Write Protect is off [ 8.260667] sd 1:0:0:0: [sdc] Write Protect is off [ 8.267922] sd 2:0:0:0: [sdb] Mode Sense: 23 00 00 00 [ 8.273197] sd 1:0:0:0: [sdc] Mode Sense: 47 00 10 08 [ 8.278396] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 8.283059] sd 1:0:0:0: [sdc] No Caching mode page found [ 8.296921] sd 1:0:0:0: [sdc] Assuming drive cache: write through [ 8.557091] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback [ 9.248431] . [ 9.620514] systemd[1]: System time before build time, advancing clock. [ 9.922245] NET: Registered protocol family 10 [ 10.006730] Segment Routing with IPv6 [ 10.081739] systemd[1]: systemd 245.5-1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid) [ 10.110986] systemd[1]: Detected architecture arm64. [ 10.179046] systemd[1]: Set hostname to <arm>. [ 10.272276] . [ 10.928248] sdb: sdb1 [ 10.947085] sd 2:0:0:0: [sdb] Attached SCSI disk [ 10.993302] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly. [ 11.296484] . [ 11.303876] random: systemd: uninitialized urandom read (16 bytes read) [ 11.319381] systemd[1]: Created slice system-getty.slice. [ 11.330329] random: systemd: uninitialized urandom read (16 bytes read) [ 11.338330] systemd[1]: Created slice system-modprobe.slice. [ 11.349781] random: systemd: uninitialized urandom read (16 bytes read) [ 11.357982] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 11.372871] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 11.386813] systemd[1]: Created slice User and Session Slice. [ 11.399519] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 11.414308] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 11.428792] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 11.441101] systemd[1]: Reached target Local Encrypted Volumes. [ 11.454365] systemd[1]: Reached target Remote File Systems. [ 11.467307] systemd[1]: Reached target Slices. [ 11.480147] systemd[1]: Reached target Swap. [ 11.492924] systemd[1]: Reached target System Time Set. [ 11.506718] systemd[1]: Listening on Syslog Socket. [ 11.520759] systemd[1]: Listening on fsck to fsckd communication Socket. [ 11.535483] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 11.550811] systemd[1]: Listening on Journal Audit Socket. [ 11.564931] systemd[1]: Listening on Journal Socket (/dev/log). [ 11.579428] systemd[1]: Listening on Journal Socket. [ 11.593756] systemd[1]: Listening on udev Control Socket. [ 11.607597] systemd[1]: Listening on udev Kernel Socket. [ 11.627199] systemd[1]: Mounting Huge Pages File System... [ 11.644032] systemd[1]: Mounting POSIX Message Queue File System... [ 11.661503] systemd[1]: Mounting Kernel Debug File System... [ 11.673842] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 11.689180] systemd[1]: Starting Restore / save the current clock... [ 11.708693] systemd[1]: Starting Set the console keyboard layout... [ 11.726174] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 11.741859] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped. [ 11.755011] systemd[1]: Started Nameserver information manager. [ 11.768794] systemd[1]: Reached target Network (Pre). [ 11.799621] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 11.810067] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 11.825120] systemd[1]: Starting Journal Service... [ 11.851214] systemd[1]: Starting Load Kernel Modules... [ 11.871266] systemd[1]: Starting Remount Root and Kernel File Systems... [ 11.889131] systemd[1]: Starting udev Coldplug all Devices... [ 11.907412] systemd[1]: Mounted Huge Pages File System. [ 11.914257] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro [ 11.930928] systemd[1]: Mounted POSIX Message Queue File System. [ 11.943722] systemd[1]: Mounted Kernel Debug File System. [ 11.957764] systemd[1]: Finished Restore / save the current clock. [ 11.972279] systemd[1]: Finished Create list of static device nodes for the current kernel. [ 11.991724] systemd[1]: Finished Load Kernel Modules. [ 12.007029] systemd[1]: Finished Remount Root and Kernel File Systems. [ 12.021889] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 12.035406] systemd[1]: Mounting Kernel Configuration File System... [ 12.058038] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 12.068102] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 12.084837] systemd[1]: Starting Load/Save Random Seed... [ 12.101806] systemd[1]: Starting Apply Kernel Variables... [ 12.119072] systemd[1]: Starting Create System Users... [ 12.139200] systemd[1]: Mounted Kernel Configuration File System. [ 12.180125] systemd[1]: Finished Set the console keyboard layout. [ 12.225047] systemd[1]: Finished Apply Kernel Variables. [ 12.240975] systemd[1]: Finished Create System Users. [ 12.258195] systemd[1]: Starting Create Static Device Nodes in /dev... [ 12.320227] . [ 12.334106] systemd[1]: Finished udev Coldplug all Devices. [ 12.354205] systemd[1]: Finished Create Static Device Nodes in /dev. [ 12.367478] systemd[1]: Reached target Local File Systems (Pre). [ 12.385830] systemd[1]: Mounting /tmp... [ 12.403220] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 12.421368] systemd[1]: Starting udev Kernel Device Manager... [ 12.437437] systemd[1]: Mounted /tmp. [ 12.452126] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 12.731457] systemd[1]: Started udev Kernel Device Manager. [ 12.953218] systemd[1]: Started Journal Service. [ 13.127163] debugfs: Directory 'c1105400.audio-controller' with parent 'GX-HDMI-SPDIF' already present! [ 13.138907] debugfs: Directory 'c1105400.audio-controller' with parent 'GX-HDMI-SPDIF' already present! [ 13.151164] gx-sound-card sound: snd-soc-dummy-dai <-> I2S FIFO mapping ok [ 13.155821] systemd-journald[474]: Received client request to flush runtime journal. [ 13.171577] gx-sound-card sound: snd-soc-dummy-dai <-> SPDIF FIFO mapping ok [ 13.181880] gx-sound-card sound: multicodec <-> I2S Encoder mapping ok [ 13.190480] gx-sound-card sound: dit-hifi <-> SPDIF Encoder mapping ok [ 13.199069] gx-sound-card sound: i2s-hifi <-> CODEC CTRL HDMI OUT mapping ok [ 13.208125] gx-sound-card sound: t9015-hifi <-> ACODEC CTRL ACODEC OUT mapping ok [ 13.208986] Registered IR keymap rc-empty [ 13.217644] gx-sound-card sound: ASoC: no DMI vendor name! [ 13.225253] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0 [ 13.242559] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter [ 13.253970] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input6 [ 13.254783] panfrost d00c0000.gpu: clock rate = 666666666 [ 13.264790] meson-ir c8100580.ir: receiver initialized [ 13.271877] panfrost d00c0000.gpu: supply mali not found, using dummy regulator [ 13.288791] panfrost d00c0000.gpu: mali-t820 id 0x820 major 0x1 minor 0x0 status 0x0 [ 13.289501] mc: Linux media interface: v0.10 [ 13.298380] panfrost d00c0000.gpu: features: 00000000,101e76ff, issues: 00000000,24040400 [ 13.298392] panfrost d00c0000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7 [ 13.298397] panfrost d00c0000.gpu: shader_present=0x7 l2_present=0x1 [ 13.299405] panfrost d00c0000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 [ 13.303819] panfrost d00c0000.gpu: GPU Fault 0x00000088 (SHAREABILITY_FAULT) at 0x0000000100000010 [ 13.303828] panfrost d00c0000.gpu: There were multiple GPU faults - some have not been reported [ 13.314007] Unable to handle kernel NULL pointer dereference at virtual address 00000000000000f5 [ 13.325864] sdc: sdc1 [ 13.333744] Mem abort info: [ 13.333751] ESR = 0x96000004 [ 13.333763] EC = 0x25: DABT (current EL), IL = 32 bits [ 13.344196] . [ 13.354778] sd 1:0:0:0: [sdc] Attached SCSI disk [ 13.363354] SET = 0, FnV = 0 [ 13.363358] EA = 0, S1PTW = 0 [ 13.363360] Data abort info: [ 13.363362] ISV = 0, ISS = 0x00000004 [ 13.363364] CM = 0, WnR = 0 [ 13.363371] user pgtable: 4k pages, 48-bit VAs, pgdp=00000000a1627000 [ 13.363379] [00000000000000f5] pgd=0000000000000000 [ 13.466958] Internal error: Oops: 96000004 [#1] PREEMPT SMP [ 13.469474] videodev: Linux video capture interface: v2.00 [ 13.471948] Modules linked in: videodev(+) ecdh_generic mc ecc panfrost(+) crct10dif_ce(+) rfkill meson_ir rc_core ao_cec snd_soc_spdif_tx snd_soc_simple_amplifier gpu_sched meson_rng dw_hdmi_cec display_connector ip_tables x_tables ipv6 nf_defrag_ipv6 uas gpio_keys_polled adc_keys [ 13.508697] CPU: 0 PID: 509 Comm: systemd-udevd Tainted: G W 5.7.0-rc2-arm-64 #20.05.3 [ 13.517830] Hardware name: Amlogic Meson GXM (S912) Q200 Development Board (DT) [ 13.525079] pstate: 60000005 (nZCv daif -PAN -UAO) [ 13.530521] pc : dev_pm_opp_put_regulators+0x14/0xb0 [ 13.535961] lr : panfrost_devfreq_init+0x8c/0x1e0 [panfrost] [ 13.541357] sp : ffff80001056b8b0 [ 13.546650] x29: ffff80001056b8b0 x28: 00000000000001ce [ 13.551932] x27: ffff800012b297d0 x26: ffff80000a1cf750 [ 13.557164] x25: ffff80000a1cf580 x24: 0000000000000039 [ 13.562370] x23: ffff80000a1cf1d8 x22: ffff800012b11908 [ 13.567557] x21: ffff0000a08b9880 x20: ffffffffffffffed [ 13.572688] x19: ffff0000a325e410 x18: 0000000000000010 [ 13.577885] x17: 0000000000000000 x16: 0000000000000000 [ 13.583148] x15: 0000000000aaaaaa x14: 0720072007200720 [ 13.588408] x13: 0000000000000001 x12: 0000000000000008 [ 13.593669] x11: 0000000000000007 x10: 0101010101010101 [ 13.598930] x9 : fffffffffffffffd x8 : 7f7f7f7f7f7f7f7f [ 13.604191] x7 : fefefeff646c606d x6 : 00000000000000ff [ 13.609453] x5 : ffff0000a1448000 x4 : ffff0000a19ea880 [ 13.614714] x3 : ffff800012bf9d10 x2 : 0000000000000000 [ 13.619976] x1 : 0000000000000000 x0 : ffffffffffffffed [ 13.625236] Call trace: [ 13.629890] dev_pm_opp_put_regulators+0x14/0xb0 [ 13.634542] panfrost_devfreq_init+0x8c/0x1e0 [panfrost] [ 13.639214] panfrost_probe+0x108/0x1b8 [panfrost] [ 13.643894] platform_drv_probe+0x54/0xa8 [ 13.648554] really_probe+0xdc/0x440 [ 13.653168] driver_probe_device+0xe0/0x138 [ 13.657755] device_driver_attach+0x74/0x80 [ 13.662320] __driver_attach+0xa4/0x170 [ 13.666813] bus_for_each_dev+0x74/0xc8 [ 13.671251] driver_attach+0x24/0x30 [ 13.675601] bus_add_driver+0x19c/0x238 [ 13.679874] driver_register+0x64/0x120 [ 13.684134] __platform_driver_register+0x48/0x58 [ 13.688390] panfrost_driver_init+0x24/0x1000 [panfrost] [ 13.692672] do_one_initcall+0x74/0x1c0 [ 13.696856] do_init_module+0x54/0x210 [ 13.700962] load_module+0x1ca8/0x2010 [ 13.705023] __do_sys_finit_module+0xb4/0x118 [ 13.708204] thermal thermal_zone0: failed to read out thermal zone (-110) [ 13.709016] __arm64_sys_finit_module+0x20/0x30 [ 13.720310] el0_svc_common.constprop.3+0x9c/0x1d8 [ 13.725054] do_el0_svc+0x24/0x90 [ 13.728924] el0_sync_handler+0x150/0x2c0 [ 13.732736] el0_sync+0x158/0x180 [ 13.736540] Code: a9bd7bfd 910003fd a90153f3 aa0003f4 (f9408400) [ 13.741611] ---[ end trace 08915fc8ec85b3ed ]--- [ 13.793737] [drm] kms: can't enable cloning when we probably wanted to. [ 13.874083] Bluetooth: Core ver 2.22 [ 13.878280] Bluetooth: Starting self testing [ 13.899374] Bluetooth: ECDH test passed in 16670 usecs [ 13.906525] Bluetooth: SMP test passed in 2779 usecs [ 13.910765] Bluetooth: Finished self testing [ 13.915089] NET: Registered protocol family 31 [ 13.919281] Bluetooth: HCI device and connection manager initialized [ 13.924924] Bluetooth: HCI socket layer initialized [ 13.929804] Bluetooth: L2CAP socket layer initialized [ 13.934804] Bluetooth: SCO socket layer initialized [ 13.980234] random: crng init done [ 13.985625] random: 7 urandom warning(s) missed due to ratelimiting [ 14.258037] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 14.299013] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 14.368234] . [ 14.494406] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid [ 14.603949] Bluetooth: HCI UART driver ver 2.3 [ 14.609010] Bluetooth: HCI UART protocol H4 registered [ 14.613989] Bluetooth: HCI UART protocol BCSP registered [ 14.619229] Bluetooth: HCI UART protocol LL registered [ 14.624318] Bluetooth: HCI UART protocol ATH3K registered [ 14.624458] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 14.624784] Bluetooth: HCI UART protocol Intel registered [ 14.625018] Bluetooth: HCI UART protocol Broadcom registered [ 14.625060] Bluetooth: HCI UART protocol QCA registered [ 14.625063] Bluetooth: HCI UART protocol AG6XX registered [ 14.625104] Bluetooth: HCI UART protocol Marvell registered [ 14.625404] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator [ 14.625501] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator [ 14.643033] systemd-journald[474]: File /var/log/journal/957bec6bcd604faba980975d73790c61/system.journal corrupted or uncleanly shut down, renaming and replacing. [ 14.658379] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. [ 14.867363] Bluetooth: hci0: BCM: failed to write update baudrate (-56) [ 14.874490] Bluetooth: hci0: Failed to set baudrate [ 14.889369] ath10k_sdio mmc2:0001:1: Failed to find firmware-N.bin (N between 2 and 6) from ath10k/QCA9377/hw1.0: -2 [ 14.902060] ath10k_sdio mmc2:0001:1: could not fetch firmware files (-2) [ 14.955053] mmc2: queuing unknown CIS tuple 0x01 (3 bytes) [ 14.969955] mmc2: queuing unknown CIS tuple 0x1a (5 bytes) [ 14.978985] mmc2: queuing unknown CIS tuple 0x1b (8 bytes) [ 14.984534] mmc2: queuing unknown CIS tuple 0x14 (0 bytes) [ 14.990666] ath10k_sdio mmc2:0001:1: could not probe fw (-2) [ 15.059878] Bluetooth: hci0: BCM: Read verbose config info failed (-56) [ 15.392262] ..ready [ 16.518097] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16). [ 16.532160] sd 0:0:0:0: [sda] 15628052480 512-byte logical blocks: (8.00 TB/7.28 TiB) [ 16.540970] sd 0:0:0:0: [sda] 4096-byte physical blocks [ 16.548199] sd 0:0:0:0: [sda] Write Protect is off [ 16.554747] sd 0:0:0:0: [sda] Mode Sense: 47 00 10 08 [ 16.561698] sd 0:0:0:0: [sda] No Caching mode page found [ 16.568094] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 16.649429] systemd-journald[474]: Failed to read journal file /var/log/journal/957bec6bcd604faba980975d73790c61/user-1000.journal for rotation, trying to move it out of the way: Device or resource busy [ 16.705711] meson8b-dwmac c9410000.ethernet eth0: PHY [0.2009087f:00] driver [RTL8211F Gigabit Ethernet] (irq=36) [ 16.728956] zram: Added device: zram0 [ 16.737412] zram: Added device: zram1 [ 16.738204] zram: Added device: zram2 [ 16.744449] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found [ 16.768527] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW [ 16.777031] zram1: detected capacity change from 0 to 1073741824 [ 16.784761] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rgmii link mode [ 16.881198] Adding 1048572k swap on /dev/zram1. Priority:5 extents:1 across:1048572k SSFS [ 17.076508] zram0: detected capacity change from 0 to 52428800 [ 17.283175] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard [ 17.292381] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) [ 18.140065] sda: sda1 [ 18.157381] sd 0:0:0:0: [sda] Attached SCSI disk [ 18.388725] meson8b-dwmac c9410000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 18.409021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 22.473638] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 22.478162] Bluetooth: BNEP filters: protocol multicast [ 22.483161] Bluetooth: BNEP socket layer initialized [ 31.590407] fuse: init (API version 7.31) You can see I got a kernel trace (luckily no panic!) but that had already happened with the old kernel. Maybe my processor on the H96 Pro+ is a little flaky? Could be a hardware issue. The second time I booted the kernel I didn't got the trace. But what in fact happened is that the CPU temp was running HIGH. Usually it idles at 63 C, a bit high but normal as these boxes don't have active ventilation. It was idling at 70 C with the new Kernel! Also, I noticed the new kernel comes with Panfrost. The graphics was horrible on this particular box with Panfrost! Very illegible!! I tried a Youtube 1080p video though and it didn't seem to stutter as much as with the old kernel, so maybe we'll see good things as Panfrost develops. Those were the two issues I noticed, balbes150. A third (minor) one is that systemd was unable to reboot, it stuck there and wouldn't reboot as normal so I had to manually disconnect power. So there it is! Feel free to ask me for more information! Link to comment Share on other sites More sharing options...
geraldog Posted April 29, 2020 Share Posted April 29, 2020 Also I just finished running that ultimate errand! Trying to activate wireless and bluetooth for these boxes! Mine is a H96 Pro+ like I mentioned. 3G/32GB S912 I recompiled balbes150 "s905" kernel from github, actually version 5.7.0-rc1 Setting: # CONFIG_STANDALONE is not set # CONFIG_PREVENT_FIRMWARE_BUILD is not set CONFIG_FW_LOADER=y CONFIG_EXTRA_FIRMWARE="ath10k/QCA9377/hw1.0/board.bin ath10k/QCA9377/hw1.0/board-2.bin ath10k/QCA9377/hw1.0/firmware-6.bin" CONFIG_EXTRA_FIRMWARE_DIR="/lib/firmware" I got these files from a nonfree package of RPi I didn't try firmware-5.bin though, maybe that would work? Still got: ath10k_sdio mmc2:0001:1: Failed to find firmware-N.bin (N between 2 and 6) from ath10k/QCA9377/hw1.0: -2 ath10k_sdio mmc2:0001:1: could not fetch firmware files (-2) Link to comment Share on other sites More sharing options...
Jamboa Posted April 29, 2020 Share Posted April 29, 2020 @balbes150 I have deleted by mistake the Stretch version image about this armbian release. Is there any change to get the newest one back to the MEGA site? At least I don't find OLD folder from there anymore and I really have some use for your awesome work but just the Stretch one. Edit. just found the info that you have deleted the old folder (11-28-2019, 03:23) Link to comment Share on other sites More sharing options...
SteeMan Posted April 29, 2020 Share Posted April 29, 2020 @balbes150 I just wanted to report that with your latest builds that sound via hdmi works for all of my boxes: TX3 mini (s905w); H96 Max X2 (s905x2); and TX3 X3 (s905x3) I also wanted to report that I think there may be an issue with the sound not working after copying an install to emmc. I wasn't testing sound at the time I did a reinstall into emmc, so I'm not sure it is a problem, but I am pretty sure it was working before the move to emmc and not after. Also, as others have reported I am seeing hangs on reboot with the latest test builds. Link to comment Share on other sites More sharing options...
geraldog Posted April 30, 2020 Share Posted April 30, 2020 I can now confirm WIFI working on Armbian running on my H96 Pro+ 3G/32GB with kernel 5.7.0-rc1 pulled from balbes150 git repository!!! I had to recompile the kernel with those options as I stated earlier, the trick was to include both firmware-5.bin and firnware-sdio-5.bin from here: https://github.com/erstrom/ath10k-firmware/tree/master/QCA9377/hw1.0/untested It still complains about not finding the board sdio revision, but it's working! [ 11.724917] ath10k_sdio mmc2:0001:1: qca9377 hw1.1 sdio target 0x05020001 chip_id 0x00000000 sub 0000:0000 [ 11.741825] ath10k_sdio mmc2:0001:1: kconfig debug 0 debugfs 0 tracing 0 dfs 0 testmode 0 [ 11.742212] ath10k_sdio mmc2:0001:1: firmware ver WLAN.TF.1.1.1-00061-QCATFSWPZ-1 api 5 features ignore-otp crc32 7746e551 [ 11.911249] ath10k_sdio mmc2:0001:1: failed to fetch board data for bus=sdio,vendor=0271,device=0701,subsystem-vendor=0000,subsystem-device=0000 from ath10k/QCA9377/hw1.0/board-2.bin [ 11.911275] ath10k_sdio mmc2:0001:1: board_file api 1 bmi_id N/A crc32 544289f7 [ 13.132544] ath10k_sdio mmc2:0001:1: htt-ver 3.32 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1 The problem with this new kernel, besides all the problems with HIGH TEMP, illegible graphics and inability to reboot is that I got now sound $ dmesg | grep sound [ 2.930837] No soundcards found. [ 33.761309] platform sound: deferred probe pending But certainly high hopes y'all! I'll try bluetooth next as per this thread: https://www.mail-archive.com/search?l=ath10k@lists.infradead.org&q=subject:"QCA9377"&o=newest&f=1 Link to comment Share on other sites More sharing options...
balbes150 Posted April 30, 2020 Author Share Posted April 30, 2020 6 hours ago, SteeMan said: I also wanted to report that I think there may be an issue with the sound not working after copying an install to emmc. I wasn't testing sound at the time I did a reinstall into emmc, so I'm not sure it is a problem, but I am pretty sure it was working before the move to emmc and not after. Sound requires several elements (kernel , scripts, settings, etc.). All these elements are present only in the latest images. If you update only the kernel (without adding other necessary elements) in older versions, the sound will not work. 6 hours ago, SteeMan said: Also, as others have reported I am seeing hangs on reboot with the latest test builds. Yes, I know, this only shows up on some AML chips. 3 hours ago, geraldog said: I had to recompile the kernel with those options Compiling the kernel with a direct reference to files is a bad practice, it may be suitable for personal use, but it is not suitable for mass use. May need to correct the IDs to correctly identify the desired firmware (or rename firmware them). Link to comment Share on other sites More sharing options...
geraldog Posted April 30, 2020 Share Posted April 30, 2020 6 hours ago, balbes150 said: Sound requires several elements (kernel , scripts, settings, etc.). All these elements are present only in the latest images. If you update only the kernel (without adding other necessary elements) in older versions, the sound will not work. Yes, I know, this only shows up on some AML chips. Compiling the kernel with a direct reference to files is a bad practice, it may be suitable for personal use, but it is not suitable for mass use. May need to correct the IDs to correctly identify the desired firmware (or rename firmware them). Thanks and much respect to you my friend! Would you care to explain how to get sound working again after a kernel upgrade? Also, like I said, there is something seriously wrong with Panfrost. I know this comes from upstream and there's likely little you can do to solve it, but could it be that the overheating I'm experiencing in the new Kernel could be related to Panfrost? Also, I got WiFi working like I said with your new kernel, and I'd like to help other people have this benefit too. What is the correct way to add foreign firmware to the kernel? Link to comment Share on other sites More sharing options...
Povl H. Pedersen Posted April 30, 2020 Share Posted April 30, 2020 I am also on H96 Max, with the custom DTB from this thread. apt upgrade today also killed my box. ANd for some reason my SD card also had 2 blank partitions. Did not figure that out before after I had soldered UART wires onto the board. Anybody knows what package destroyed things ? We need to get the maintainer to fix it to stop bricking devices. Currently in the process of burning new SD Link to comment Share on other sites More sharing options...
geraldog Posted April 30, 2020 Share Posted April 30, 2020 1 minute ago, Povl H. Pedersen said: I am also on H96 Max, with the custom DTB from this thread. apt upgrade today also killed my box. ANd for some reason my SD card also had 2 blank partitions. Did not figure that out before after I had soldered UART wires onto the board. Anybody knows what package destroyed things ? We need to get the maintainer to fix it to stop bricking devices. Currently in the process of burning new SD Hi Povl, did you hold kernel upgrades with dpkg? Link to comment Share on other sites More sharing options...
balbes150 Posted April 30, 2020 Author Share Posted April 30, 2020 46 minutes ago, Povl H. Pedersen said: Anybody knows what package destroyed things ? We need to get the maintainer to fix it to stop bricking devices. If you use non-standard elements, no one will repair it for you. Moreover, the TV box s905x3 chip is not supported in this thread at all. Link to comment Share on other sites More sharing options...
geraldog Posted April 30, 2020 Share Posted April 30, 2020 1 minute ago, balbes150 said: If you use non-standard elements, no one will repair it for you. Perhaps it would be wise to state in the guide that you need to tell dpkg to hold kernel updates if you want to use apt update/upgrade Link to comment Share on other sites More sharing options...
geraldog Posted April 30, 2020 Share Posted April 30, 2020 @balbes150 I'm recompiling your kernel to see if I can get Bluetooth working on boards that use QCA9377 It should be a simple DTB update + compiling firmware into the kernel Link to comment Share on other sites More sharing options...
balbes150 Posted April 30, 2020 Author Share Posted April 30, 2020 3 minutes ago, geraldog said: Perhaps it would be wise to state in the guide that you need to tell dpkg to hold kernel updates if you want to use apt update/upgrade Can you also suggest that the developers have provided and described all imaginable and unimaginable situations that users will make with their devices ? Link to comment Share on other sites More sharing options...
geraldog Posted April 30, 2020 Share Posted April 30, 2020 1 minute ago, balbes150 said: Can you also suggest that the developers have provided and described all imaginable and unimaginable situations that users will make with their devices ? Wonderful quote. Will add to my fortune database! Link to comment Share on other sites More sharing options...
Povl H. Pedersen Posted April 30, 2020 Share Posted April 30, 2020 1 hour ago, balbes150 said: If you use non-standard elements, no one will repair it for you. Moreover, the TV box s905x3 chip is not supported in this thread at all. It is supported by this distro, and thanks for that. eMMC install works, and there is even an install-aml-sxxx script. What is recommended chipset for good performance if I want something else ? The issue is, that /boot/dtb was renamed to /dtb.old and since my dtb was not in, it would not boot. Booting from SD also was not good before I pointed uEnv on card to a standard dtb which I could use to boot. Seems like SD boot switched to eMMC Link to comment Share on other sites More sharing options...
geraldog Posted April 30, 2020 Share Posted April 30, 2020 On 4/18/2020 at 11:50 PM, lazydino said: I am trying to see if I can turn my X3-Plus ( S905X3 ) can run Armbian_20.05.2_Arm-64_bionic_current_5.7.0-rc1_desktop_20200418.img as a digital music computer for MIDI application. I tried meson-sm1-sei610.dtb, the sound is working but 'aconnect -l' shows reggie@arm-64:~$ aconnect -l ALSA lib seq_hw.c:466:(snd_seq_hw_open) open /dev/snd/seq failed: No such file or directory can't open sequencer How to fix it? Thanks for the hard work. Try to recompile the kernel with CONFIG_SND_VIRMIDI=m If you need help please ask! Link to comment Share on other sites More sharing options...
geraldog Posted April 30, 2020 Share Posted April 30, 2020 On 4/16/2020 at 12:35 PM, malloc32 said: Hello, I have installed the lastest image posible at today (Armbian_20.05.2_Arm-64_bionic_current_5.7.0-rc1_desktop_20200416) (meson-gxm-q200.dtb) in a H96 Pro Plus 3GB/32GB (S912). It works very well (I use ethernet, I don't know if wifi works), but if I executed glxinfo: Extended renderer info (GLX_MESA_query_renderer): Vendor: VMware, Inc. (0xffffffff) Device: llvmpipe (LLVM 9.0, 128 bits) (0xffffffff) Version: 19.2.8 Accelerated: no Video memory: 2741MB Unified memory: no Preferred profile: core (0x1) Max core profile version: 3.3 Max compat profile version: 3.1 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.0 Is this normal? Accelerated: no Is graphics driver (GPU Mali 820) installed? I have read about "Panfrost". Is posible install Panfrost? How? Thank you very much. Panfrost support still sucks at this point But it's moving fast! Link to comment Share on other sites More sharing options...
Povl H. Pedersen Posted April 30, 2020 Share Posted April 30, 2020 Just checked dpkg log, no kernel upgrade, but linux-image-current-arm-64 is the one at fault. It owns /boot/dtb Now, how do I upgrade everything ? Is there an easy way ? I run almost nothing but HomeAssistant, so I can of course create a HA backup, and read back in on a new system. That is trivial. But I do not necessarily know all the other stuff I set up. I know for sure I do have an outgoing VPN connection to my cloud server that is reverse proxy to my Home Assistant. I do plan to run DHCP/DNS on it, and my USB weather station, and other things for my home automation. Possible even video surveillance - Playing with motion detectors covering camera FoV, so I do not need a constant stream inflow. So we need a way to upgrade. One reason I picked 905x3 is that it performs well for the price according to: https://androidpctv.com/comparative-amlogic-s905x3/ Way better than H6 and RK3328. I am not looking at $100+ devices, then we are close to Intel land, and I would end up in the $250-300 range because I would got for a 8250u or better then. So I am looking at sub $50 boxes for best price/performance/watt. Link to comment Share on other sites More sharing options...
SteeMan Posted April 30, 2020 Share Posted April 30, 2020 6 minutes ago, Povl H. Pedersen said: Just checked dpkg log, no kernel upgrade, but linux-image-current-arm-64 is the one at fault. It owns /boot/dtb As I mentioned in your other post. You just need to put your custom dtb in a location outside the /boot/dtb directory. The easiest place is to put it directly in /boot and then change the uEnv.txt file to look for it there (i.e. FDT=/meson-sm1-custom.dtb instead of FDT=/dtb/amlogic/meson-sm1-custom.dtb). This will protect your custom dtb from future upgrades. Link to comment Share on other sites More sharing options...
