pkfox Posted November 24, 2019 Posted November 24, 2019 Hi all, I installed the desktop using armbian-config Install Browser and other but It still boots into a shell - what else do I need to do ?
Igor Posted November 24, 2019 Posted November 24, 2019 On 11/24/2019 at 4:24 PM, pkfox said: Hi all, I installed the desktop using armbian-config Install Browser and other but It still boots into a shell - what else do I need to do ? Expand Since you didn't tell us which build nor which hardware you are using ... nobody can help you. (logs with armbianmonitor -u) There used to be problems in some previous versions with this, so consider using latest build or at least upgrade there. Getting from this semi working image will be hard.
pkfox Posted November 24, 2019 Author Posted November 24, 2019 On 11/24/2019 at 4:51 PM, Igor said: Since you didn't tell us which build nor which hardware you are using ... nobody can help you. (logs with armbianmonitor -u) There used to be problems in some previous versions with this, so consider using latest build or at least upgrade there. Getting from this semi working image will be hard. Expand Hi Igor, I'm using a Nanopi M4 v1 and running Buster
NicoD Posted November 24, 2019 Posted November 24, 2019 On 11/24/2019 at 5:59 PM, pkfox said: Hi Igor, I'm using a Nanopi M4 v1 and running Buster Expand Are you sure it installed the desktop? Was internet connected? If not it'll just skip everything. You can try with startx and see if it boots into desktop. If so then probably there's a problem with the display manager. So try to install "sudo apt install lightdm". Also On 11/24/2019 at 4:51 PM, Igor said: (logs with armbianmonitor -u) Expand
pkfox Posted November 24, 2019 Author Posted November 24, 2019 It was definitely connected to the internet Nico - and apt install lightdm states that the latest is already installed
Igor Posted November 24, 2019 Posted November 24, 2019 Since you didn't provide the most important info armbianmonitor -u (to see relevant data), now for the 3rd time, you are only wasting our time. You use this free software on your own risk and support is our personal cost. After R&D ... In case you didn't update to this before installing it could be our bug. In any case, images from the download section are fixed. Installing desktop must work there. If not, bug will be accepted and fixed when we find time.
Igor Posted November 24, 2019 Posted November 24, 2019 On 11/24/2019 at 6:11 PM, pkfox said: and apt install lightdm states that the latest is already installed Expand Well, lightdm is installed in this process. You need to have one for easy operations. You can try uninstalling ... update ... try again.
pkfox Posted November 24, 2019 Author Posted November 24, 2019 On 11/24/2019 at 6:28 PM, Igor said: Well, lightdm is installed in this process. You need to have one for easy operations. You can try uninstalling ... update ... try again. Expand This is the output from startx X.Org X Server 1.20.4 X Protocol Version 11, Revision 0 Build Operating System: Linux 4.9.0-8-arm64 aarch64 Debian Current Operating System: Linux nanopim4 4.4.192-rk3399 #6 SMP Tue Oct 8 18:32:46 CEST 2019 aarch64 Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 rootwait coherent_pool=1m root=UUID=a219086b-aecd-44d5-80b7-8da3f490a03e rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=2d97cec0-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 Build Date: 05 March 2019 08:11:12PM xorg-server 2:1.20.4-1 (https://www.debian.org/support) Current version of pixman: 0.36.0 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.1.log", Time: Sun Nov 24 18:33:19 2019 (==) Using config directory: "/etc/X11/xorg.conf.d" (==) Using system config directory "/usr/share/X11/xorg.conf.d" gbm: failed to open any driver (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri) gbm: Last dlopen error: /usr/lib/dri/rockchip_dri.so: cannot open shared object file: No such file or directory failed to load driver: rockchip (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
Igor Posted November 24, 2019 Posted November 24, 2019 On 11/24/2019 at 6:35 PM, pkfox said: X.Org X Server 1.20.4 Expand I don't know what you break but here are X.org logs from a clean server image + armbian-config desktop install. Logs with our tool: http://ix.io/22Lr Reveal hidden contents [ 2026.436] X.Org X Server 1.20.4 X Protocol Version 11, Revision 0 [ 2026.436] Build Operating System: Linux 4.9.0-8-arm64 aarch64 Debian [ 2026.436] Current Operating System: Linux nanopim4 4.4.192-rk3399 #3 SMP Sun Nov 24 19:35:29 CET 2019 aarch64 [ 2026.436] Kernel command line: root=UUID=bd2f546a-352e-4a9a-817e-40f3596b2d19 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=d29c695e-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 2026.436] Build Date: 05 March 2019 08:11:12PM [ 2026.436] xorg-server 2:1.20.4-1 (https://www.debian.org/support) [ 2026.436] Current version of pixman: 0.36.0 [ 2026.436] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 2026.436] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 2026.437] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Nov 24 19:20:28 2019 [ 2026.438] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 2026.438] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 2026.448] (==) No Layout section. Using the first Screen section. [ 2026.448] (==) No screen section available. Using defaults. [ 2026.448] (**) |-->Screen "Default Screen Section" (0) [ 2026.448] (**) | |-->Monitor "<default monitor>" [ 2026.451] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 2026.451] (**) Option "BlankTime" "0" [ 2026.451] (**) Option "StandbyTime" "0" [ 2026.451] (**) Option "SuspendTime" "0" [ 2026.451] (**) Option "OffTime" "0" [ 2026.451] (==) Automatically adding devices [ 2026.451] (==) Automatically enabling devices [ 2026.451] (==) Automatically adding GPU devices [ 2026.451] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 2026.451] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 2026.452] Entry deleted from font path. [ 2026.452] (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins [ 2026.452] (==) ModulePath set to "/usr/lib/xorg/modules" [ 2026.452] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 2026.452] (II) Loader magic: 0x558da39e08 [ 2026.452] (II) Module ABI versions: [ 2026.452] X.Org ANSI C Emulation: 0.4 [ 2026.452] X.Org Video Driver: 24.0 [ 2026.452] X.Org XInput driver : 24.1 [ 2026.452] X.Org Server Extension : 10.0 [ 2026.456] (++) using VT number 7 [ 2026.457] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 2026.459] (II) xfree86: Adding drm device (/dev/dri/card0) [ 2026.471] (II) no primary bus or device found [ 2026.471] falling back to /sys/devices/platform/display-subsystem/drm/card0 [ 2026.471] (II) LoadModule: "glx" [ 2026.471] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 2026.476] (II) Module glx: vendor="X.Org Foundation" [ 2026.476] compiled for 1.20.4, module version = 1.0.0 [ 2026.476] ABI class: X.Org Server Extension, version 10.0 [ 2026.476] (==) Matched modesetting as autoconfigured driver 0 [ 2026.476] (==) Matched fbdev as autoconfigured driver 1 [ 2026.476] (==) Assigned the driver to the xf86ConfigLayout [ 2026.476] (II) LoadModule: "modesetting" [ 2026.476] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 2026.477] (II) Module modesetting: vendor="X.Org Foundation" [ 2026.477] compiled for 1.20.4, module version = 1.20.4 [ 2026.477] Module class: X.Org Video Driver [ 2026.477] ABI class: X.Org Video Driver, version 24.0 [ 2026.477] (II) LoadModule: "fbdev" [ 2026.477] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 2026.477] (II) Module fbdev: vendor="X.Org Foundation" [ 2026.477] compiled for 1.20.0, module version = 0.5.0 [ 2026.477] Module class: X.Org Video Driver [ 2026.477] ABI class: X.Org Video Driver, version 24.0 [ 2026.477] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 2026.477] (II) FBDEV: driver for framebuffer: fbdev [ 2026.554] (II) modeset(0): using drv /dev/dri/card0 [ 2026.554] (WW) Falling back to old probe method for fbdev [ 2026.554] (II) Loading sub module "fbdevhw" [ 2026.554] (II) LoadModule: "fbdevhw" [ 2026.554] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 2026.554] (II) Module fbdevhw: vendor="X.Org Foundation" [ 2026.554] compiled for 1.20.4, module version = 0.0.2 [ 2026.554] ABI class: X.Org Video Driver, version 24.0 [ 2026.554] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 2026.555] (II) modeset(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 2026.555] (==) modeset(0): Depth 24, (==) framebuffer bpp 32 [ 2026.555] (==) modeset(0): RGB weight 888 [ 2026.555] (==) modeset(0): Default visual is TrueColor [ 2026.555] (II) Loading sub module "glamoregl" [ 2026.555] (II) LoadModule: "glamoregl" [ 2026.555] (II) Loading /usr/lib/xorg/modules/libglamoregl.so [ 2026.564] (II) Module glamoregl: vendor="X.Org Foundation" [ 2026.565] compiled for 1.20.4, module version = 1.0.1 [ 2026.565] ABI class: X.Org ANSI C Emulation, version 0.4 [ 2026.727] (II) modeset(0): Refusing to try glamor on llvmpipe [ 2026.729] (EE) modeset(0): glamor initialization failed [ 2026.729] (II) modeset(0): ShadowFB: preferred NO, enabled NO [ 2026.881] (II) modeset(0): Output HDMI-1 has no monitor section [ 2027.099] (II) modeset(0): EDID for output HDMI-1 [ 2027.099] (II) modeset(0): Manufacturer: AVX Model: 4 Serial#: 0 [ 2027.099] (II) modeset(0): Year: 2014 Week: 40 [ 2027.099] (II) modeset(0): EDID Version: 1.3 [ 2027.099] (II) modeset(0): Digital Display Input [ 2027.099] (II) modeset(0): Max Image Size [cm]: horiz.: 53 vert.: 30 [ 2027.099] (II) modeset(0): Gamma: 2.20 [ 2027.099] (II) modeset(0): No DPMS capabilities specified [ 2027.099] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2 [ 2027.099] (II) modeset(0): First detailed timing is preferred mode [ 2027.099] (II) modeset(0): redX: 0.625 redY: 0.340 greenX: 0.280 greenY: 0.595 [ 2027.099] (II) modeset(0): blueX: 0.155 blueY: 0.070 whiteX: 0.283 whiteY: 0.298 [ 2027.099] (II) modeset(0): Supported established timings: [ 2027.099] (II) modeset(0): 640x480@60Hz [ 2027.099] (II) modeset(0): 800x600@60Hz [ 2027.099] (II) modeset(0): 1024x768@60Hz [ 2027.099] (II) modeset(0): Manufacturer's mask: 0 [ 2027.099] (II) modeset(0): Supported detailed timing: [ 2027.099] (II) modeset(0): clock: 148.5 MHz Image Size: 16 x 9 mm [ 2027.099] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 2027.099] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 2027.099] (II) modeset(0): Monitor name: AVT GC510 [ 2027.099] (II) modeset(0): Ranges: V min: 24 V max: 61 Hz, H min: 15 H max: 68 kHz, PixClock max 175 MHz [ 2027.099] (II) modeset(0): 2nd GTF parameters: f: 64 kHz c: 16 m: 8224 k 32 j 16 [ 2027.099] (II) modeset(0): Supported detailed timing: [ 2027.099] (II) modeset(0): clock: 148.5 MHz Image Size: 708 x 398 mm [ 2027.099] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 2027.099] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 2027.099] (II) modeset(0): Supported detailed timing: [ 2027.099] (II) modeset(0): clock: 74.2 MHz Image Size: 160 x 90 mm [ 2027.099] (II) modeset(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0 [ 2027.099] (II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0 [ 2027.099] (II) modeset(0): Number of EDID sections to follow: 1 [ 2027.100] (II) modeset(0): EDID (in hex): [ 2027.100] (II) modeset(0): 00ffffffffffff0006d8040000000000 [ 2027.100] (II) modeset(0): 2818010380351e781a0dc9a057479827 [ 2027.100] (II) modeset(0): 12484c21080001000100010001000101 [ 2027.100] (II) modeset(0): 010101010101023a801871382d40582c [ 2027.100] (II) modeset(0): 450010090000001e0000001000000000 [ 2027.100] (II) modeset(0): 00000000000000000000000000fc0041 [ 2027.100] (II) modeset(0): 56542047433531300a202020000000fd [ 2027.100] (II) modeset(0): 00183d0f4411020020202020202001c9 [ 2027.100] (II) modeset(0): 020322714f90059f1404931112151602 [ 2027.100] (II) modeset(0): 03060701230907018301000065030c00 [ 2027.100] (II) modeset(0): 1000023a801871382d40582c4500c48e [ 2027.100] (II) modeset(0): 2100001e011d007251d01e206e285500 [ 2027.100] (II) modeset(0): a05a0000001e00000000000000000000 [ 2027.100] (II) modeset(0): 00000000000000000000000000000000 [ 2027.100] (II) modeset(0): 00000000000000000000000000000000 [ 2027.100] (II) modeset(0): 00000000000000000000000000000067 [ 2027.100] (II) modeset(0): Printing probed modes for output HDMI-1 [ 2027.100] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 2027.100] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 2027.100] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e) [ 2027.101] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e) [ 2027.101] (II) modeset(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e) [ 2027.101] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e) [ 2027.101] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 2027.101] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 2027.101] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 2027.101] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 2027.101] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 2027.101] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 2027.101] (II) modeset(0): Modeline "720x576i"x50.0 13.50 720 732 795 864 576 580 586 625 interlace -hsync -vsync (15.6 kHz e) [ 2027.101] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 2027.101] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 2027.101] (II) modeset(0): Modeline "720x480i"x60.0 13.51 720 739 801 858 480 488 494 525 interlace -hsync -vsync (15.8 kHz e) [ 2027.101] (II) modeset(0): Modeline "720x480i"x59.9 13.50 720 739 801 858 480 488 494 525 interlace -hsync -vsync (15.7 kHz e) [ 2027.101] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 2027.101] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 2027.101] (II) modeset(0): Output HDMI-1 connected [ 2027.101] (II) modeset(0): Using exact sizes for initial modes [ 2027.101] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0 [ 2027.101] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0) [ 2027.101] (==) modeset(0): DPI set to (96, 96) [ 2027.101] (II) Loading sub module "fb" [ 2027.101] (II) LoadModule: "fb" [ 2027.101] (II) Loading /usr/lib/xorg/modules/libfb.so [ 2027.102] (II) Module fb: vendor="X.Org Foundation" [ 2027.102] compiled for 1.20.4, module version = 1.0.0 [ 2027.102] ABI class: X.Org ANSI C Emulation, version 0.4 [ 2027.102] (II) UnloadModule: "fbdev" [ 2027.102] (II) Unloading fbdev [ 2027.102] (II) UnloadSubModule: "fbdevhw" [ 2027.103] (II) Unloading fbdevhw [ 2027.113] (==) modeset(0): Backing store enabled [ 2027.113] (==) modeset(0): Silken mouse enabled [ 2027.114] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc. [ 2027.114] (==) modeset(0): DPMS enabled [ 2027.114] (II) Initializing extension Generic Event Extension [ 2027.114] (II) Initializing extension SHAPE [ 2027.115] (II) Initializing extension MIT-SHM [ 2027.115] (II) Initializing extension XInputExtension [ 2027.116] (II) Initializing extension XTEST [ 2027.117] (II) Initializing extension BIG-REQUESTS [ 2027.117] (II) Initializing extension SYNC [ 2027.118] (II) Initializing extension XKEYBOARD [ 2027.118] (II) Initializing extension XC-MISC [ 2027.119] (II) Initializing extension SECURITY [ 2027.119] (II) Initializing extension XFIXES [ 2027.120] (II) Initializing extension RENDER [ 2027.120] (II) Initializing extension RANDR [ 2027.121] (II) Initializing extension COMPOSITE [ 2027.122] (II) Initializing extension DAMAGE [ 2027.122] (II) Initializing extension MIT-SCREEN-SAVER [ 2027.123] (II) Initializing extension DOUBLE-BUFFER [ 2027.123] (II) Initializing extension RECORD [ 2027.123] (II) Initializing extension DPMS [ 2027.124] (II) Initializing extension Present [ 2027.124] (II) Initializing extension DRI3 [ 2027.124] (II) Initializing extension X-Resource [ 2027.125] (II) Initializing extension XVideo [ 2027.125] (II) Initializing extension XVideo-MotionCompensation [ 2027.125] (II) Initializing extension SELinux [ 2027.126] (II) SELinux: Disabled on system [ 2027.126] (II) Initializing extension GLX [ 2027.126] (II) AIGLX: Screen 0 is not DRI2 capable [ 2027.142] (II) IGLX: Loaded and initialized swrast [ 2027.142] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 2027.142] (II) Initializing extension XFree86-VidModeExtension [ 2027.143] (II) Initializing extension XFree86-DGA [ 2027.143] (II) Initializing extension XFree86-DRI [ 2027.143] (II) Initializing extension DRI2 [ 2027.145] (II) modeset(0): Damage tracking initialized [ 2027.145] (II) modeset(0): Setting screen physical size to 508 x 285 [ 2027.321] (II) config/udev: Adding input device adc-keys (/dev/input/event1) [ 2027.321] (**) adc-keys: Applying InputClass "libinput keyboard catchall" [ 2027.321] (II) LoadModule: "libinput" [ 2027.321] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 2027.337] (II) Module libinput: vendor="X.Org Foundation" [ 2027.337] compiled for 1.20.4, module version = 0.28.2 [ 2027.337] Module class: X.Org XInput Driver [ 2027.337] ABI class: X.Org XInput driver, version 24.1 [ 2027.337] (II) Using input driver 'libinput' for 'adc-keys' [ 2027.337] (**) adc-keys: always reports core events [ 2027.337] (**) Option "Device" "/dev/input/event1" [ 2027.337] (**) Option "_source" "server/udev" [ 2027.343] (II) event1 - adc-keys: is tagged by udev as: Keyboard [ 2027.343] (II) event1 - adc-keys: device is a keyboard [ 2027.343] (II) event1 - adc-keys: device removed [ 2027.408] (**) Option "config_info" "udev:/sys/devices/platform/adc-keys/input/input1/event1" [ 2027.408] (II) XINPUT: Adding extended input device "adc-keys" (type: KEYBOARD, id 6) [ 2027.411] (II) event1 - adc-keys: is tagged by udev as: Keyboard [ 2027.411] (II) event1 - adc-keys: device is a keyboard [ 2027.415] (II) config/udev: Adding input device Typec_Headphone (/dev/input/event0) [ 2027.415] (II) No input driver specified, ignoring this device. [ 2027.415] (II) This device may have been added with another device file. [ 2027.416] (II) config/udev: Adding input device gpio-keys (/dev/input/event2) [ 2027.416] (**) gpio-keys: Applying InputClass "libinput keyboard catchall" [ 2027.416] (II) Using input driver 'libinput' for 'gpio-keys' [ 2027.417] (**) gpio-keys: always reports core events [ 2027.417] (**) Option "Device" "/dev/input/event2" [ 2027.417] (**) Option "_source" "server/udev" [ 2027.419] (II) event2 - gpio-keys: is tagged by udev as: Keyboard [ 2027.419] (II) event2 - gpio-keys: device is a keyboard [ 2027.419] (II) event2 - gpio-keys: device removed [ 2027.444] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input2/event2" [ 2027.444] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 7) [ 2027.447] (II) event2 - gpio-keys: is tagged by udev as: Keyboard [ 2027.447] (II) event2 - gpio-keys: device is a keyboard [ 2027.451] (II) config/udev: Adding input device Genius NetScroll+Mini Traveler (/dev/input/event5) [ 2027.451] (**) Genius NetScroll+Mini Traveler: Applying InputClass "libinput pointer catchall" [ 2027.451] (II) Using input driver 'libinput' for 'Genius NetScroll+Mini Traveler' [ 2027.451] (**) Genius NetScroll+Mini Traveler: always reports core events [ 2027.451] (**) Option "Device" "/dev/input/event5" [ 2027.451] (**) Option "_source" "server/udev" [ 2027.458] (II) event5 - Genius NetScroll+Mini Traveler: is tagged by udev as: Mouse [ 2027.458] (II) event5 - Genius NetScroll+Mini Traveler: device is a pointer [ 2027.459] (II) event5 - Genius NetScroll+Mini Traveler: device removed [ 2027.512] (**) Option "config_info" "udev:/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.8.auto/usb3/3-1/3-1.2/3-1.2.1/3-1.2.1.2/3-1.2.1.2:1.0/0003:0458:0036.0003/input/input5/event5" [ 2027.512] (II) XINPUT: Adding extended input device "Genius NetScroll+Mini Traveler" (type: MOUSE, id 8) [ 2027.513] (**) Option "AccelerationScheme" "none" [ 2027.513] (**) Genius NetScroll+Mini Traveler: (accel) selected scheme none/0 [ 2027.513] (**) Genius NetScroll+Mini Traveler: (accel) acceleration factor: 2.000 [ 2027.513] (**) Genius NetScroll+Mini Traveler: (accel) acceleration threshold: 4 [ 2027.520] (II) event5 - Genius NetScroll+Mini Traveler: is tagged by udev as: Mouse [ 2027.520] (II) event5 - Genius NetScroll+Mini Traveler: device is a pointer [ 2027.524] (II) config/udev: Adding input device SONiX USB Device (/dev/input/event3) [ 2027.524] (**) SONiX USB Device: Applying InputClass "libinput keyboard catchall" [ 2027.524] (II) Using input driver 'libinput' for 'SONiX USB Device' [ 2027.524] (**) SONiX USB Device: always reports core events [ 2027.524] (**) Option "Device" "/dev/input/event3" [ 2027.524] (**) Option "_source" "server/udev" [ 2027.530] (II) event3 - SONiX USB Device: is tagged by udev as: Keyboard [ 2027.530] (II) event3 - SONiX USB Device: device is a keyboard [ 2027.531] (II) event3 - SONiX USB Device: device removed [ 2027.552] (**) Option "config_info" "udev:/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.8.auto/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2:1.0/0003:0C45:7403.0001/input/input3/event3" [ 2027.552] (II) XINPUT: Adding extended input device "SONiX USB Device" (type: KEYBOARD, id 9) [ 2027.559] (II) event3 - SONiX USB Device: is tagged by udev as: Keyboard [ 2027.559] (II) event3 - SONiX USB Device: device is a keyboard [ 2027.563] (II) config/udev: Adding input device SONiX USB Device (/dev/input/event4) [ 2027.563] (**) SONiX USB Device: Applying InputClass "libinput pointer catchall" [ 2027.563] (**) SONiX USB Device: Applying InputClass "libinput keyboard catchall" [ 2027.563] (II) Using input driver 'libinput' for 'SONiX USB Device' [ 2027.563] (**) SONiX USB Device: always reports core events [ 2027.563] (**) Option "Device" "/dev/input/event4" [ 2027.563] (**) Option "_source" "server/udev" [ 2027.569] (II) event4 - SONiX USB Device: is tagged by udev as: Keyboard Mouse [ 2027.570] (II) event4 - SONiX USB Device: device is a pointer [ 2027.570] (II) event4 - SONiX USB Device: device is a keyboard [ 2027.570] (II) event4 - SONiX USB Device: device removed [ 2027.592] (II) libinput: SONiX USB Device: needs a virtual subdevice [ 2027.593] (**) Option "config_info" "udev:/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.8.auto/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2:1.1/0003:0C45:7403.0002/input/input4/event4" [ 2027.593] (II) XINPUT: Adding extended input device "SONiX USB Device" (type: MOUSE, id 10) [ 2027.593] (**) Option "AccelerationScheme" "none" [ 2027.593] (**) SONiX USB Device: (accel) selected scheme none/0 [ 2027.593] (**) SONiX USB Device: (accel) acceleration factor: 2.000 [ 2027.593] (**) SONiX USB Device: (accel) acceleration threshold: 4 [ 2027.599] (II) event4 - SONiX USB Device: is tagged by udev as: Keyboard Mouse [ 2027.600] (II) event4 - SONiX USB Device: device is a pointer [ 2027.600] (II) event4 - SONiX USB Device: device is a keyboard [ 2027.614] (**) SONiX USB Device: Applying InputClass "libinput pointer catchall" [ 2027.614] (**) SONiX USB Device: Applying InputClass "libinput keyboard catchall" [ 2027.614] (II) Using input driver 'libinput' for 'SONiX USB Device' [ 2027.614] (**) SONiX USB Device: always reports core events [ 2027.614] (**) Option "Device" "/dev/input/event4" [ 2027.614] (**) Option "_source" "_driver/libinput" [ 2027.614] (II) libinput: SONiX USB Device: is a virtual subdevice [ 2027.614] (**) Option "config_info" "udev:/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.8.auto/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2:1.1/0003:0C45:7403.0002/input/input4/event4" [ 2027.614] (II) XINPUT: Adding extended input device "SONiX USB Device" (type: KEYBOARD, id 11) [ 2028.615] (II) modeset(0): EDID vendor "AVX", prod id 4 [ 2028.616] (II) modeset(0): Using EDID range info for horizontal sync [ 2028.616] (II) modeset(0): Using EDID range info for vertical refresh [ 2028.616] (II) modeset(0): Printing DDC gathered Modelines: [ 2028.616] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 2028.616] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 2028.616] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e) [ 2028.616] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 2028.616] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e) [ 2028.616] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 2028.616] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 2028.616] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e) [ 2028.616] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 2028.616] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e) [ 2028.616] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 2028.616] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 2028.616] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 2028.616] (II) modeset(0): Modeline "256x160"x60.0 2.55 256 232 256 256 160 161 164 166 -hsync +vsync (10.0 kHz e) [ 2032.402] (II) modeset(0): EDID vendor "AVX", prod id 4 [ 2032.402] (II) modeset(0): Using hsync ranges from config file [ 2032.402] (II) modeset(0): Using vrefresh ranges from config file [ 2032.402] (II) modeset(0): Printing DDC gathered Modelines: [ 2032.402] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 2032.402] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 2032.402] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e) [ 2032.402] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 2032.402] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e) [ 2032.402] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 2032.402] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 2032.402] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e) [ 2032.402] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 2032.402] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e) [ 2032.402] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 2032.402] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 2032.403] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 2032.403] (II) modeset(0): Modeline "256x160"x60.0 2.55 256 232 256 256 160 161 164 166 -hsync +vsync (10.0 kHz e) [ 2032.453] (II) modeset(0): EDID vendor "AVX", prod id 4 [ 2032.453] (II) modeset(0): Using hsync ranges from config file [ 2032.453] (II) modeset(0): Using vrefresh ranges from config file [ 2032.453] (II) modeset(0): Printing DDC gathered Modelines: [ 2032.453] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 2032.453] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 2032.453] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e) [ 2032.453] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 2032.453] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e) [ 2032.453] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 2032.453] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 2032.453] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e) [ 2032.453] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 2032.453] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e) [ 2032.453] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 2032.453] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 2032.453] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 2032.453] (II) modeset(0): Modeline "256x160"x60.0 2.55 256 232 256 256 160 161 164 166 -hsync +vsync (10.0 kHz e) [ 2032.459] (II) modeset(0): Disabling kernel dirty updates, not required.
