sunshinetime Posted December 2, 2019 Share Posted December 2, 2019 Armbianmonitor: http://ix.io/23nK hi all, I've been running into an issue where the kernel starts throwing error messages (https://pastebin.com/bmPJPeq0), the board becomes very slow and the cpu load goes to 11 and stays there. This seems to happen when I change the CPU freq using armbian-config to anything lower than 528MHz. Any ideas how I could resolve this? Link to comment Share on other sites More sharing options...
Igor Posted December 2, 2019 Share Posted December 2, 2019 1 hour ago, sunshinetime said: I've been running into an issue where the kernel starts throwing error messages For start, upgrade to latest kernel + update u-boot and then try to reproduce this problem. Link to comment Share on other sites More sharing options...
sunshinetime Posted December 8, 2019 Author Share Posted December 8, 2019 Hi Igor, Thanks for your suggestions. I've tried to update the kernel as suggested in the page you linked to but I get an error: "Test install failed. Can't change firmware" The contents of /tmp/switch_kernel.log are this: linux-image-current-sunxi=19.11.3 linux-dtb-current-sunxi=19.11.3 linux-u-boot-olinuxino-a20-current Any suggestions on how to continue from there? Link to comment Share on other sites More sharing options...
Igor Posted December 8, 2019 Share Posted December 8, 2019 8 hours ago, sunshinetime said: Any suggestions on how to continue from there? Strange. Do you have network connection at the time you were trying to upgrade? You just also try to make a fresh build on a separate SD card to see if that works. Link to comment Share on other sites More sharing options...
pi-rat Posted December 20, 2019 Share Posted December 20, 2019 I am getting the same error saying "Test install failed. Can't change firmware" when I try to upgrade to kernel 5.3.9 and the file /tmp/switch_kernel.log contains just one line: linux-image-current-sunxi=19.11.3 linux-dtb-current-sunxi=19.11.3 linux-u-boot-bananapi-current Link to comment Share on other sites More sharing options...
