dolphs Posted December 11, 2019 Posted December 11, 2019 While 5.4.y is not in ( sunxi64_common.inc ) current yet, at this time of writing I like to explore " KERNELBRANCH="branch:orange-pi-5.5" ". Except for just updating to this branch, I noticed it is just too early as megous github branch is not prepared yet for 5.5-RC1. I am curious to see if any of these have been applied already and what new fun stuff needs to be considered in the kernel .config
Igor Posted December 11, 2019 Posted December 11, 2019 If you like to explore, just do it. If something doesn't work or if patches are not applying well - which is expected - dig in and fix them.
Werner Posted December 11, 2019 Posted December 11, 2019 https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/diff/?id=v5.5-rc1&id2=v5.4&dt=2 Check this for changes compared to 5.4 Examples for things you can find: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?id=2fabf6dd77014f19d45fc71c01f1b073c03df255 https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?id=46b257b1852fccdc4edaf4bbc6fdb59be0b94f0d
dolphs Posted December 16, 2019 Author Posted December 16, 2019 First attempt (5.5-rc2), thanks to @megi who added rc2 to the 5.5-branch This build resulted in compile errors at once, which was to be expected. Just reporting here in case DEV will be switched to 5.5 this month. The log attached holds "duplicate_label" as "well duplicate_node_names"-errors. compilation.log
Igor Posted December 16, 2019 Posted December 16, 2019 3 hours ago, dolphs said: Just reporting here in case DEV will be switched to 5.5 this month. It will 100% not unless you will do the job of adjusting and clearing patches.
Werner Posted December 18, 2019 Posted December 18, 2019 On 12/16/2019 at 9:55 AM, dolphs said: compilation.log 2.97 kB · 7 downloads Probably some patches are new obsolete since their content has been merged into mainline. Though they getting applied anyways which results in duplicate note errors. Same procedure as every time when a new kernel is released. Try to find the unneeded patches and disable them.
martinayotte Posted December 27, 2019 Posted December 27, 2019 I've committed the sunxi-dev switch to 5.5.y ! The only patches that I didn't took time to fix, so I've disabled them, are : 0128-drm-bridge-extract-some-Analogix-I2C-DP-common-code.patch-disabled 0130-drm-bridge-Add-Analogix-anx6345-support.patch-disabled v3-1-2-si2168-Set-TS-clock-mode-and-frequency.patch-disabled v3-2-2-dvbsky-Add-support-for-MyGica-T230C-v2.patch-disabled But I will try again later ... 1
Werner Posted December 28, 2019 Posted December 28, 2019 aufs5-standalone.patch fails to apply to the sources and therefore the build fails obviously. I will retry without AuFS. Edit: Yep, works.
guidol Posted December 28, 2019 Posted December 28, 2019 17 hours ago, martinayotte said: I've committed the sunxi-dev switch to 5.5.y ! "only" sunxi-dev or also sunxi64-dev?
martinayotte Posted December 28, 2019 Posted December 28, 2019 8 minutes ago, guidol said: only" sunxi-dev or also sunxi64-dev? Both ! I still have to test some boards but 75% of my garden is now on 5.5.0-rc2 ... 1
guidol Posted December 28, 2019 Posted December 28, 2019 2 hours ago, martinayotte said: Both ! I still have to test some boards but 75% of my garden is now on 5.5.0-rc2 ... My sunxi64-dev SBCs (3x NPI Neo2 + NPi A64) does startup fine: Neo2: Welcome to Armbian Buster with Linux 5.5.0-rc2-sunxi64 package bsp-kernel[19.11.5] u-boot[19.11.5] dtb[19.11.5] firmware[19.11.5] config[19.11.5] branch[dev] A64: Welcome to Debian Buster with Armbian Linux 5.5.0-rc2-sunxi64 package bsp-kernel[19.11.5] u-boot[19.11.5] dtb[19.11.3] firmware[19.11.5] config[19.11.5] branch[dev] Thanks Now I could start to compile for sunxi-dev
Igor Posted December 28, 2019 Posted December 28, 2019 8 hours ago, Werner said: aufs5-standalone.patch fails to apply to the sources and therefore the build fails obviously. Its expected to fail. It would be probably best to add AUFS="no" here:https://github.com/armbian/build/blob/master/config/sources/families/include/sunxi64_common.inc#L30 or even to https://github.com/armbian/build/blob/master/config/sources/arm64.conf under if $BRANCH = dev
Werner Posted December 29, 2019 Posted December 29, 2019 13 hours ago, Igor said: Its expected to fail. Of course I did not expect everything works out of the box. Though I wanted to mention it anyways ;).
guidol Posted December 29, 2019 Posted December 29, 2019 33 minutes ago, Werner said: Of course I did not expect everything works out of the box. Though I wanted to mention it anyways ;). I did compile with ./compile.sh EXPERT=yes WIREGUARD=no AUFS=no BUILD_KSRC=no and it did also work for for my non-64Bit-sunxi SBCs OPi Zero, OPi One and my BPi M2 Berry At this time I have no need for WireGuard. 1
Igor Posted December 29, 2019 Posted December 29, 2019 1 hour ago, Werner said: Though I wanted to mention it anyways ;). Yes, I know. Thanks! I only proposed to by default disable advanced features such as AUFS, WG, BUILD_KSRC perhaps even WIFI on DEV branches since they - in many cases - fail to build, build longer and its unnecessary trouble in development / testing stage.
martinayotte Posted December 29, 2019 Posted December 29, 2019 On 12/28/2019 at 6:01 AM, Werner said: aufs5-standalone.patch fails to apply to the sources If I remember, it was already broken in 5.4 ... 3 hours ago, guidol said: WIREGUARD=no AUFS=no That is what I'm doing since months ...
Igor Posted December 29, 2019 Posted December 29, 2019 1 minute ago, martinayotte said: it was already broken in 5.4 ... Yes, it was only fixed few days ago by the AUFS maintainer.
martinayotte Posted December 29, 2019 Posted December 29, 2019 1 minute ago, Igor said: Yes, it was only fixed few days ago by the AUFS maintainer. So, no more needs to default it to "no" ?
Igor Posted December 29, 2019 Posted December 29, 2019 1 minute ago, martinayotte said: So, no more needs to default it to "no" ? 5.4.y is supported, while for 5.5.y I didn't tried it yet.
Werner Posted December 29, 2019 Posted December 29, 2019 4 hours ago, guidol said: I did compile with ./compile.sh EXPERT=yes WIREGUARD=no AUFS=no BUILD_KSRC=no and it did also work for for my non-64Bit-sunxi SBCs OPi Zero, OPi One and my BPi M2 Berry At this time I have no need for WireGuard. Wireguard seems to work in 5.5.0-rc2. It compiled at least. LD [M] drivers/net/wireguard/wireguard.ko LD [M] net/wireguard/wireguard.ko INSTALL drivers/net/wireguard/wireguard.ko INSTALL net/wireguard/wireguard.ko
Werner Posted December 29, 2019 Posted December 29, 2019 Looking decent. ___ ____ _ ___ / _ \| _ \(_) / _ \ _ __ ___ | | | | |_) | | | | | | '_ \ / _ \ | |_| | __/| | | |_| | | | | __/ \___/|_| |_| \___/|_| |_|\___| Welcome to Armbian Buster with Linux 5.5.0-rc2-sunxi [...] root@honeypot:~# lsmod Module Size Used by wireguard 57344 0 Edit: OPi0+ looking good too. ___ ____ _ _____ ____ _ / _ \| _ \(_) |__ /___ _ __ ___ | _ \| |_ _ ___ | | | | |_) | | / // _ \ '__/ _ \ | |_) | | | | / __| | |_| | __/| | / /| __/ | | (_) | | __/| | |_| \__ \ \___/|_| |_| /____\___|_| \___/ |_| |_|\__,_|___/ Welcome to Armbian buster with Linux 5.5.0-rc2-sunxi64 Though CPU is capped to 1.01GHz while the H5 should work at 1.2GHz. Found this: [ 6.037059] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 6.037083] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000) [ 6.037167] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 6.037174] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000) [ 6.037301] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator [ 6.037309] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000) [ 6.037392] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator [ 6.037400] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000) Maybe something missing in the dts? 1
