pkfox Posted December 15, 2019 Posted December 15, 2019 Hi all, i've installed Postgresql on my Nanopi M4 V2 board which is running Buster Armbian Linux 4.4.192-rk3399 and it appears to have installed ok but it won't start - there's nothing in the logs and running pg_isready returns no response - any ideas guys
GeorgeP Posted December 15, 2019 Posted December 15, 2019 I've no specific postgresql experience but I have found that the way Armbian handles logging to zram can mean that the log files either don't exist or can't be written. Generally the answer to situations like this is to try running the binary from a command prompt with the 'verbose' switch set, if it then runs OK, try to modify the sysctl files to enable logging.
pkfox Posted December 15, 2019 Author Posted December 15, 2019 1 hour ago, GeorgeP said: I've no specific postgresql experience but I have found that the way Armbian handles logging to zram can mean that the log files either don't exist or can't be written. Generally the answer to situations like this is to try running the binary from a command prompt with the 'verbose' switch set, if it then runs OK, try to modify the sysctl files to enable logging. Thanks I'll give it a shot
pkfox Posted December 15, 2019 Author Posted December 15, 2019 4 hours ago, pkfox said: Thanks I'll give it a shot I can't even find the binary - also the install usually creates a /etc/postgresql folder which isn't happening - I've tried removing the install and reinstalling but I receive the message that it's already installed ? WTF ?
Igor Posted December 15, 2019 Posted December 15, 2019 It looks like there is some problem but it installs perfectly on a clean Armbian Buster armhf / Cubietruck http://ix.io/24wp Spoiler apt install postgresql-11 postgresql-client-11 Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: libllvm7 libpq5 libxslt1.1 postgresql-client-common postgresql-common ssl-cert Suggested packages: postgresql-doc-11 libjson-perl openssl-blacklist The following NEW packages will be installed: libllvm7 libpq5 libxslt1.1 postgresql-11 postgresql-client-11 postgresql-client-common postgresql-common ssl-cert 0 upgraded, 8 newly installed, 0 to remove and 0 not upgraded. Need to get 26.8 MB of archives. After this operation, 102 MB of additional disk space will be used. Do you want to continue? [Y/n] Get:1 http://security.debian.org buster/updates/main armhf postgresql-client-common all 200+deb10u3 [84.9 kB] Get:2 http://security.debian.org buster/updates/main armhf postgresql-common all 200+deb10u3 [225 kB] Get:3 http://cdn-fastly.deb.debian.org/debian buster/main armhf libllvm7 armhf 1:7.0.1-8 [11.3 MB] Get:4 http://cdn-fastly.deb.debian.org/debian buster/main armhf libpq5 armhf 11.5-1+deb10u1 [152 kB] Get:5 http://cdn-fastly.deb.debian.org/debian buster/main armhf libxslt1.1 armhf 1.1.32-2.2~deb10u1 [217 kB] Get:6 http://cdn-fastly.deb.debian.org/debian buster/main armhf postgresql-client-11 armhf 11.5-1+deb10u1 [1,328 kB] Get:7 http://cdn-fastly.deb.debian.org/debian buster/main armhf ssl-cert all 1.0.39 [20.8 kB] Get:8 http://cdn-fastly.deb.debian.org/debian buster/main armhf postgresql-11 armhf 11.5-1+deb10u1 [13.5 MB] Fetched 26.8 MB in 5s (5,713 kB/s) Preconfiguring packages ... Selecting previously unselected package libllvm7:armhf. (Reading database ... 33631 files and directories currently installed.) Preparing to unpack .../0-libllvm7_1%3a7.0.1-8_armhf.deb ... Unpacking libllvm7:armhf (1:7.0.1-8) ... Selecting previously unselected package libpq5:armhf. Preparing to unpack .../1-libpq5_11.5-1+deb10u1_armhf.deb ... Unpacking libpq5:armhf (11.5-1+deb10u1) ... Selecting previously unselected package libxslt1.1:armhf. Preparing to unpack .../2-libxslt1.1_1.1.32-2.2~deb10u1_armhf.deb ... Unpacking libxslt1.1:armhf (1.1.32-2.2~deb10u1) ... Selecting previously unselected package postgresql-client-common. Preparing to unpack .../3-postgresql-client-common_200+deb10u3_all.deb ... Unpacking postgresql-client-common (200+deb10u3) ... Selecting previously unselected package postgresql-client-11. Preparing to unpack .../4-postgresql-client-11_11.5-1+deb10u1_armhf.deb ... Unpacking postgresql-client-11 (11.5-1+deb10u1) ... Selecting previously unselected package ssl-cert. Preparing to unpack .../5-ssl-cert_1.0.39_all.deb ... Unpacking ssl-cert (1.0.39) ... Selecting previously unselected package postgresql-common. Preparing to unpack .../6-postgresql-common_200+deb10u3_all.deb ... Adding 'diversion of /usr/bin/pg_config to /usr/bin/pg_config.libpq-dev by postgresql-common' Unpacking postgresql-common (200+deb10u3) ... Selecting previously unselected package postgresql-11. Preparing to unpack .../7-postgresql-11_11.5-1+deb10u1_armhf.deb ... Unpacking postgresql-11 (11.5-1+deb10u1) ... Setting up postgresql-client-common (200+deb10u3) ... Setting up libpq5:armhf (11.5-1+deb10u1) ... Setting up ssl-cert (1.0.39) ... Setting up postgresql-client-11 (11.5-1+deb10u1) ... update-alternatives: using /usr/share/postgresql/11/man/man1/psql.1.gz to provide /usr/share/man/man1/psql.1.gz (psql.1.gz) in auto mode Setting up postgresql-common (200+deb10u3) ... Adding user postgres to group ssl-cert Creating config file /etc/postgresql-common/createcluster.conf with new version Building PostgreSQL dictionaries from installed myspell/hunspell packages... Removing obsolete dictionary files: Created symlink /etc/systemd/system/multi-user.target.wants/postgresql.service → /lib/systemd/system/postgresql.service. Setting up libxslt1.1:armhf (1.1.32-2.2~deb10u1) ... Setting up libllvm7:armhf (1:7.0.1-8) ... Setting up postgresql-11 (11.5-1+deb10u1) ... Creating new PostgreSQL cluster 11/main ... /usr/lib/postgresql/11/bin/initdb -D /var/lib/postgresql/11/main --auth-local peer --auth-host md5 The files belonging to this database system will be owned by user "postgres". This user must also own the server process. The database cluster will be initialized with locale "en_US.UTF-8". The default database encoding has accordingly been set to "UTF8". The default text search configuration will be set to "english". Data page checksums are disabled. fixing permissions on existing directory /var/lib/postgresql/11/main ... ok creating subdirectories ... ok selecting default max_connections ... 100 selecting default shared_buffers ... 128MB selecting default timezone ... Etc/UTC selecting dynamic shared memory implementation ... posix creating configuration files ... ok running bootstrap script ... ok performing post-bootstrap initialization ... ok syncing data to disk ... ok Success. You can now start the database server using: pg_ctlcluster 11 main start Ver Cluster Port Status Owner Data directory Log file 11 main 5432 down postgres /var/lib/postgresql/11/main /var/log/postgresql/postgresql-11-main.log update-alternatives: using /usr/share/postgresql/11/man/man1/postmaster.1.gz to provide /usr/share/man/man1/postmaster.1.gz (postmaster.1.gz) in auto mode Processing triggers for systemd (241-7~deb10u2) ... Processing triggers for man-db (2.8.5-2) ... Processing triggers for libc-bin (2.28-10) ... root@cubietruck:~# pg_isready /var/run/postgresql:5432 - accepting connections root@cubietruck:~# systemctl status postgresql ● postgresql.service - PostgreSQL RDBMS Loaded: loaded (/lib/systemd/system/postgresql.service; enabled; vendor preset: enabled) Active: active (exited) since Sun 2019-12-15 17:37:47 UTC; 55s ago Main PID: 8447 (code=exited, status=0/SUCCESS) Tasks: 0 (limit: 4560) Memory: 0B CGroup: /system.slice/postgresql.service Dec 15 17:37:47 cubietruck systemd[1]: Starting PostgreSQL RDBMS... Dec 15 17:37:47 cubietruck systemd[1]: Started PostgreSQL RDBMS. root@cubietruck:~# su - postgres postgres@cubietruck:~$ psql psql (11.5 (Debian 11.5-1+deb10u1)) Type "help" for help. postgres=#
pkfox Posted December 15, 2019 Author Posted December 15, 2019 3 hours ago, Igor said: It looks like there is some problem but it installs perfectly on a clean Armbian Buster armhf / Cubietruck http://ix.io/24wp Reveal hidden contents apt install postgresql-11 postgresql-client-11 Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: libllvm7 libpq5 libxslt1.1 postgresql-client-common postgresql-common ssl-cert Suggested packages: postgresql-doc-11 libjson-perl openssl-blacklist The following NEW packages will be installed: libllvm7 libpq5 libxslt1.1 postgresql-11 postgresql-client-11 postgresql-client-common postgresql-common ssl-cert 0 upgraded, 8 newly installed, 0 to remove and 0 not upgraded. Need to get 26.8 MB of archives. After this operation, 102 MB of additional disk space will be used. Do you want to continue? [Y/n] Get:1 http://security.debian.org buster/updates/main armhf postgresql-client-common all 200+deb10u3 [84.9 kB] Get:2 http://security.debian.org buster/updates/main armhf postgresql-common all 200+deb10u3 [225 kB] Get:3 http://cdn-fastly.deb.debian.org/debian buster/main armhf libllvm7 armhf 1:7.0.1-8 [11.3 MB] Get:4 http://cdn-fastly.deb.debian.org/debian buster/main armhf libpq5 armhf 11.5-1+deb10u1 [152 kB] Get:5 http://cdn-fastly.deb.debian.org/debian buster/main armhf libxslt1.1 armhf 1.1.32-2.2~deb10u1 [217 kB] Get:6 http://cdn-fastly.deb.debian.org/debian buster/main armhf postgresql-client-11 armhf 11.5-1+deb10u1 [1,328 kB] Get:7 http://cdn-fastly.deb.debian.org/debian buster/main armhf ssl-cert all 1.0.39 [20.8 kB] Get:8 http://cdn-fastly.deb.debian.org/debian buster/main armhf postgresql-11 armhf 11.5-1+deb10u1 [13.5 MB] Fetched 26.8 MB in 5s (5,713 kB/s) Preconfiguring packages ... Selecting previously unselected package libllvm7:armhf. (Reading database ... 33631 files and directories currently installed.) Preparing to unpack .../0-libllvm7_1%3a7.0.1-8_armhf.deb ... Unpacking libllvm7:armhf (1:7.0.1-8) ... Selecting previously unselected package libpq5:armhf. Preparing to unpack .../1-libpq5_11.5-1+deb10u1_armhf.deb ... Unpacking libpq5:armhf (11.5-1+deb10u1) ... Selecting previously unselected package libxslt1.1:armhf. Preparing to unpack .../2-libxslt1.1_1.1.32-2.2~deb10u1_armhf.deb ... Unpacking libxslt1.1:armhf (1.1.32-2.2~deb10u1) ... Selecting previously unselected package postgresql-client-common. Preparing to unpack .../3-postgresql-client-common_200+deb10u3_all.deb ... Unpacking postgresql-client-common (200+deb10u3) ... Selecting previously unselected package postgresql-client-11. Preparing to unpack .../4-postgresql-client-11_11.5-1+deb10u1_armhf.deb ... Unpacking postgresql-client-11 (11.5-1+deb10u1) ... Selecting previously unselected package ssl-cert. Preparing to unpack .../5-ssl-cert_1.0.39_all.deb ... Unpacking ssl-cert (1.0.39) ... Selecting previously unselected package postgresql-common. Preparing to unpack .../6-postgresql-common_200+deb10u3_all.deb ... Adding 'diversion of /usr/bin/pg_config to /usr/bin/pg_config.libpq-dev by postgresql-common' Unpacking postgresql-common (200+deb10u3) ... Selecting previously unselected package postgresql-11. Preparing to unpack .../7-postgresql-11_11.5-1+deb10u1_armhf.deb ... Unpacking postgresql-11 (11.5-1+deb10u1) ... Setting up postgresql-client-common (200+deb10u3) ... Setting up libpq5:armhf (11.5-1+deb10u1) ... Setting up ssl-cert (1.0.39) ... Setting up postgresql-client-11 (11.5-1+deb10u1) ... update-alternatives: using /usr/share/postgresql/11/man/man1/psql.1.gz to provide /usr/share/man/man1/psql.1.gz (psql.1.gz) in auto mode Setting up postgresql-common (200+deb10u3) ... Adding user postgres to group ssl-cert Creating config file /etc/postgresql-common/createcluster.conf with new version Building PostgreSQL dictionaries from installed myspell/hunspell packages... Removing obsolete dictionary files: Created symlink /etc/systemd/system/multi-user.target.wants/postgresql.service → /lib/systemd/system/postgresql.service. Setting up libxslt1.1:armhf (1.1.32-2.2~deb10u1) ... Setting up libllvm7:armhf (1:7.0.1-8) ... Setting up postgresql-11 (11.5-1+deb10u1) ... Creating new PostgreSQL cluster 11/main ... /usr/lib/postgresql/11/bin/initdb -D /var/lib/postgresql/11/main --auth-local peer --auth-host md5 The files belonging to this database system will be owned by user "postgres". This user must also own the server process. The database cluster will be initialized with locale "en_US.UTF-8". The default database encoding has accordingly been set to "UTF8". The default text search configuration will be set to "english". Data page checksums are disabled. fixing permissions on existing directory /var/lib/postgresql/11/main ... ok creating subdirectories ... ok selecting default max_connections ... 100 selecting default shared_buffers ... 128MB selecting default timezone ... Etc/UTC selecting dynamic shared memory implementation ... posix creating configuration files ... ok running bootstrap script ... ok performing post-bootstrap initialization ... ok syncing data to disk ... ok Success. You can now start the database server using: pg_ctlcluster 11 main start Ver Cluster Port Status Owner Data directory Log file 11 main 5432 down postgres /var/lib/postgresql/11/main /var/log/postgresql/postgresql-11-main.log update-alternatives: using /usr/share/postgresql/11/man/man1/postmaster.1.gz to provide /usr/share/man/man1/postmaster.1.gz (postmaster.1.gz) in auto mode Processing triggers for systemd (241-7~deb10u2) ... Processing triggers for man-db (2.8.5-2) ... Processing triggers for libc-bin (2.28-10) ... root@cubietruck:~# pg_isready /var/run/postgresql:5432 - accepting connections root@cubietruck:~# systemctl status postgresql ● postgresql.service - PostgreSQL RDBMS Loaded: loaded (/lib/systemd/system/postgresql.service; enabled; vendor preset: enabled) Active: active (exited) since Sun 2019-12-15 17:37:47 UTC; 55s ago Main PID: 8447 (code=exited, status=0/SUCCESS) Tasks: 0 (limit: 4560) Memory: 0B CGroup: /system.slice/postgresql.service Dec 15 17:37:47 cubietruck systemd[1]: Starting PostgreSQL RDBMS... Dec 15 17:37:47 cubietruck systemd[1]: Started PostgreSQL RDBMS. root@cubietruck:~# su - postgres postgres@cubietruck:~$ psql psql (11.5 (Debian 11.5-1+deb10u1)) Type "help" for help. postgres=# OK Igor v weird though ? I have it running perfectly on the M4 V1
Igor Posted December 16, 2019 Posted December 16, 2019 8 hours ago, pkfox said: OK Igor v weird though ? I have it running perfectly on the M4 V1 Need to do more tests to find out where is the source of this trouble. M4 V2 image is still labelled as "testing" - it is expected that you will not use it for real yet - which means this is not a big problem yet. But yes, we have to fix it.
pkfox Posted December 16, 2019 Author Posted December 16, 2019 1 hour ago, Igor said: Need to do more tests to find out where is the source of this trouble. M4 V2 image is still labelled as "testing" - it is expected that you will not use it for real yet - which means this is not a big problem yet. But yes, we have to fix it. Oh I'm not using it for real just trying to do something useful with it as I am with the M4 V1 , I only bought the V2 because they seem to have discontinued the V1 4gb model which is a pity as Armbian is rock solid on those.
Igor Posted December 16, 2019 Posted December 16, 2019 51 minutes ago, pkfox said: I only bought the V2 because they seem to have discontinued the V1 4gb model which is a pity as Armbian is rock solid on those. Understand, but there is little we can do about. We need to adjust software. Perhaps help develop support? Its heavily sponsored from our private time which is currently covered less than 0.5%. We - people that move things forward - are 10 - 50 x too small to fix thing with the speed average user expects You are frustrated since things are not working, we as well since we can't do much about ...
pkfox Posted December 17, 2019 Author Posted December 17, 2019 15 hours ago, Igor said: Understand, but there is little we can do about. We need to adjust software. Perhaps help develop support? Its heavily sponsored from our private time which is currently covered less than 0.5%. We - people that move things forward - are 10 - 50 x too small to fix thing with the speed average user expects You are frustrated since things are not working, we as well since we can't do much about I do appreciate what you people do and if I was more knowledgeable I would contribute but I'm quite limited in my knowledge of Linux
Igor Posted December 17, 2019 Posted December 17, 2019 5 hours ago, pkfox said: but I'm quite limited in my knowledge of Linux That is great. You have a lot of opportunities to learn ... and help. When I started with this project, most of activities were either a blur from the past or something totally new. Persistence is the key. There are lots of tasks, where no Linux know-how is needed, but has to be done. Since most people don't even notice, nobody likes to do them ... I have to do it. 1
pkfox Posted December 17, 2019 Author Posted December 17, 2019 9 hours ago, Igor said: That is great. You have a lot of opportunities to learn ... and help. When I started with this project, most of activities were either a blur from the past or something totally new. Persistence is the key. There are lots of tasks, where no Linux know-how is needed, but has to be done. Since most people don't even notice, nobody likes to do them ... I have to do it. Hi Igor, I though I'd start from scratch, so , I flashed the image supplied by @pask , used the wi-fi drivers specified by @martinayotte, and applied the boot loader patch supplied by @pask. All booted fine with wi-fi working , so I attempted to install postgresql. And it worked perfectly, don't know why but I must have screwed something up before - good news is it works, bad news is I don't know why - thanks for your help.
pask Posted December 17, 2019 Posted December 17, 2019 4 hours ago, pkfox said: Hi Igor, I though I'd start from scratch, so , I flashed the image supplied by @pask , used the wi-fi drivers specified by @martinayotte, and applied the boot loader patch supplied by @pask. All booted fine with wi-fi working , so I attempted to install postgresql. And it worked perfectly, don't know why but I must have screwed something up before - good news is it works, bad news is I don't know why - thanks for your help. @pkfox It's time to use WIP images for this board https://www.armbian.com/nanopi-m4-v2/ No need anymore for patchs or other magics. Anyway, my experience is that the 4.4.y images still don't work for me. While the ones with buster 5.4 kernel work, but I'm still struggling to get anything really useful done as I'm still experiencing some unreliable behavior, like sudden freezes when connecting be means of tigervnc. Perhaps my board is an unlucky sample. Let us know if you experience goes better.
pkfox Posted December 17, 2019 Author Posted December 17, 2019 59 minutes ago, pask said: @pkfox It's time to use WIP images for this board https://www.armbian.com/nanopi-m4-v2/ No need anymore for patchs or other magics. Anyway, my experience is that the 4.4.y images still don't work for me. While the ones with buster 5.4 kernel work, but I'm still struggling to get anything really useful done as I'm still experiencing some unreliable behavior, like sudden freezes when connecting be means of tigervnc. Perhaps my board is an unlucky sample. Let us know if you experience goes better. Hi @pask are you saying I can flash the image you gave a link to and it will boot and wifi will work ? your original images were about 1gb and these are only 300mb ish is this correct ?
pask Posted December 17, 2019 Posted December 17, 2019 20 minutes ago, pkfox said: Hi @pask are you saying I can flash the image you gave a link to and it will boot and wifi will work ? your original images were about 1gb and these are only 300mb ish is this correct ? I you scroll down the page https://www.armbian.com/nanopi-m4-v2/ you'll find the fat desktop images too.
piter75 Posted December 17, 2019 Posted December 17, 2019 1 hour ago, pask said: my experience is that the 4.4.y images still don't work for me Is it still the issue that as soon as you connect UART it stops working? The other thing that does not work in 4.4.x right now is networking I was able to fix wireless with the following addition to the NetworkManager's config file. /etc/NetworkManager/NetworkManager.conf [device] wifi.scan-rand-mac-address=no Wired connection is another beast. As soon as it connects and receives IP address it becomes totally slow, unreliable and starts dropping packets. I tried to make the Frankenstein image your way (M4 image + rockpi's u-boot) and it behaves the same. OTOH FriendlyARM's image has stable wired connection and I cannot find the reason why, yet
pkfox Posted December 17, 2019 Author Posted December 17, 2019 47 minutes ago, pask said: I you scroll down the page https://www.armbian.com/nanopi-m4-v2/ you'll find the fat desktop images too. Hey good work @pask - flashed it straight to eMMC and it booted - no WiFi though :-( - I tried copying the broadcom drivers I've been using with your original image but no joy - using armbian-config my network is shown but won't connect ( fails with no reason given ) tried it from cli nmcli but same error message
piter75 Posted December 17, 2019 Posted December 17, 2019 @pkfox try modifying NetworkManager.conf file according to my example in earlier post. It should make the wifi work - without the need to change firmware files.
pkfox Posted December 17, 2019 Author Posted December 17, 2019 48 minutes ago, piter75 said: Is it still the issue that as soon as you connect UART it stops working? The other thing that does not work in 4.4.x right now is networking I was able to fix wireless with the following addition to the NetworkManager's config file. /etc/NetworkManager/NetworkManager.conf [device] wifi.scan-rand-mac-address=no Wired connection is another beast. As soon as it connects and receives IP address it becomes totally slow, unreliable and starts dropping packets. I tried to make the Frankenstein image your way (M4 image + rockpi's u-boot) and it behaves the same. OTOH FriendlyARM's image has stable wired connection and I cannot find the reason why, yet Good man WiFi now works - thanks very much - maybe @pask can add those lines to his build - did I need to use the drivers from @pask original build ? or will the ones in the new build work ok
pkfox Posted December 17, 2019 Author Posted December 17, 2019 1 hour ago, pask said: I you scroll down the page https://www.armbian.com/nanopi-m4-v2/ you'll find the fat desktop images too. All looking good thanks @pask
pask Posted December 18, 2019 Posted December 18, 2019 9 hours ago, piter75 said: Is it still the issue that as soon as you connect UART it stops working? The other thing that does not work in 4.4.x right now is networking Hello @piter75 Thank you! Now I understand why I'm not able to reach the nanopim4-v2 with a buster/4.4x sd image through the wired network. BTW I've not anymore connected my serial dongle to the m4v2, as I've moved the board from my desktop to an "intended production" position, and I'm using it headless and wired connected. The 5.4.2 buster image works quite well in server mode (wired network, usb, and so on). Still troubles when in desktop mode as I have experienced frequent freezes that make it unusable. Even when connected via a tigervnc client to a tigervnc server there are frequent freezes of the xfce desktop environment. But the board itself doesn't freeze: indeed, if I close the tigervnc client window once frozen, when I reconnect to the tigervnc server, I can continue using the desktop, at least until the next freeze. I suspect It's not a tigervnc specific issue, as I've also tried x2go and experienced a similar behavior. 8 hours ago, pkfox said: Good man WiFi now works - thanks very much - maybe @pask can add those lines to his build - did I need to use the drivers from @pask original build ? or will the ones in the new build work ok Thank you too @pkfox. Actually who deserves our kudos are the great armbian developers, and among them I can cite @piter75, who has made possible to us the use of the great armbian OS on this board.
pkfox Posted December 18, 2019 Author Posted December 18, 2019 2 hours ago, pask said: Hello @piter75 Thank you! Now I understand why I'm not able to reach the nanopim4-v2 with a buster/4.4x sd image through the wired network. BTW I've not anymore connected my serial dongle to the m4v2, as I've moved the board from my desktop to an "intended production" position, and I'm using it headless and wired connected. The 5.4.2 buster image works quite well in server mode (wired network, usb, and so on). Still troubles when in desktop mode as I have experienced frequent freezes that make it unusable. Even when connected via a tigervnc client to a tigervnc server there are frequent freezes of the xfce desktop environment. But the board itself doesn't freeze: indeed, if I close the tigervnc client window once frozen, when I reconnect to the tigervnc server, I can continue using the desktop, at least until the next freeze. I suspect It's not a tigervnc specific issue, as I've also tried x2go and experienced a similar behavior. Thank you too @pkfox. Actually who deserves our kudos are the great armbian developers, and among them I can cite @piter75, who has made possible to us the use of the great armbian OS on this board. I've now redone the whole process from scratch thus ( I did this using a Linux box and a USB TTL serial cable) 1) Download an image from @pask link 2) Start a terminal 3) cd to the folder containing your download 4) Unzip your download to extract the *.img file 5) Connect an sdcard or eMMC to your pc ( I used a transcend adapter ) 6) Run lsblk to identify your device, in my case it returned /dev/sdc 7) Run mount to ensure it is not mounted and unmount it if necessary ( umount /dev/sdc or umount /dev/sdc1 ) 8) Run dd if =NameOfYourImage.img of=/dev/sdc status=progress 9) When completed ( it takes a while ) make a directory to enable you to mount your device ( mkdir /mnt/MyDevice) 10) Run mount /dev/sdc1 /mnt/MyDevice 11) nano /mnt/MyDevice/etc/NetworkManager/NetworkManager.conf 12) Add these two lines and save the file [device] wifi.scan-rand-mac-address=no 13) Unmount the device (umount /mnt/MyDevice) 14) Put the device( sdcard or eMMC ) in the M4 - DO NOT APPLY POWER YET ! 15) Connect a serial cable to the UART pins on the board and attach the other end to a USB port on your PC 16) Issue this command picocom -b 1150000 /dev/ttyUSB0 ( I'm typing this at work but I think this is correct ) this should connect you to the M4 16) Apply power to the M4 and you should see the boot output 15) Login as root with password 1234 ( you'll be prompted to change the password ) 17) Run armbian-config to configure wifi 18) Ensure you have an ip address ( ip a ) and look for wlan0 19) Reboot the M4 having removed the serial cable first. In my case It all worked - your case may be different.
piter75 Posted December 27, 2019 Posted December 27, 2019 On 12/18/2019 at 8:50 AM, pask said: I understand why I'm not able to reach the nanopim4-v2 with a buster/4.4x sd image through the wired network I hopefully managed to fix networking in legacy kernel. At least it works well on my unit now ;-) It is merged into master and downloadable images are also recreated. On 12/18/2019 at 8:50 AM, pask said: troubles when in desktop mode as I have experienced frequent freezes that make it unusable. Even when connected via a tigervnc client to a tigervnc server there are frequent freezes I am wondering whether it may have something to do with Panfrost gpu driver being not really stable yet. Maybe VNC is also using gpu to accelerate desktop drawing...
