Hello I upgrade my last version Armbian and after shutdown the system the next day armbian won`t start.
I download newest version burnd SC card an after loading is restarting 30 times.
So I change new sd card burn one again armbian and is the same.
I  use converter from HDMI do VGA - and my experience is that converter very stress CPU so i connect directly to TV with HDMI but is the same
Could You advice how to install Armbian on my OPI WIN PLUS.
Regards\
https://docs.armbian.com/User-Guide_Getting-Started/
There is no magic. If build is broken, which is unlikely, but possible, those are options:
- report that image/upgrade doesn't boot in the correct place (which you did)
- install older image from archive and don't update kernel (freeze in armbian-config) until this problem is fixed
- this is amateur based project which has nothing to do with you nor a hardware you use. Support is provided as is. 99.9 % of the costs dealing with hardware and you goes directly from our own pocket. And its Sunday. Keep that in mind.
And one more thing. It looks like this bug is already known:
... but not solved due to lack of time / resources.
I `m beginner user could You advice is this version
should be work`s "
Armbian_5.59_Orangepiwin_Ubuntu_xenial_default_3.10.107_desktop
Not sure how I can check the Kernel version.
I have no Idea how to freeze config to not update kernel.
5 minutes ago, djmcg said:
Those version works.
Yes, but kernel is the important and expensive thing. This one (3.10.107) is very old and long time without any support ... you should really upgrade once this problem is sorted out.
This is strange. I've my OPiWin working fine with 5.4.2, and even yesterday with custom 5.5.0-rc2 !
Maybe problems occurs only with "upgrades" ...
I can recreate this problem. And I did fix it ... somehow (trial and error). After applying this (audio patch is IMO unrelated), my Orangepi Win boots, HDMI audio works, BT works ... I hope yours still work. Test image: https://dl.armbian.com/_old/orangepiwin/archive/Armbian_19.11.4_Orangepiwin_bionic_current_5.3.13_desktop.img.gz
3 minutes ago, djmcg said:
Not work.  5 second I sow boot screen and disappeared .
Huh, I made another image to another SD card and ... no problem.
Can you get a serial console log?
